[GRASS-SVN] r54524 - grass/trunk/vector/v.build.polylines
    svn_grass at osgeo.org
    Fri Jan  4 05:29:48 PST 2013
Author: martinl
Date: 2013-01-04 05:29:48 -0800 (Fri, 04 Jan 2013)
New Revision: 54524
   grass/trunk/vector/v.build.polylines/main.c
v.build.polylines: fix bug in type
		   be less verbose
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c	2013-01-04 13:02:48 UTC (rev 54523)
+++ grass/trunk/vector/v.build.polylines/main.c	2013-01-04 13:29:48 UTC (rev 54524)
@@ -176,7 +176,7 @@
 	write_cats = MULTI_CATS;
     if (type_opt->answer)
-	Vect_option_to_types(type_opt);
+	type = Vect_option_to_types(type_opt);
     else
 	type = GV_LINES;
@@ -223,10 +223,10 @@
 	polyline++;
-    G_message(_("%d lines or boundaries found in vector map <%s@%s>"),
-	      nlines, Vect_get_name(&map), Vect_get_mapset(&map));
-    G_message(_("%d polylines stored in vector map <%s@%s>"),
-	      polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
+    G_verbose_message(_("%d lines or boundaries found in input vector map"),
+		      nlines, Vect_get_name(&map), Vect_get_mapset(&map));
+    G_verbose_message(_("%d polylines stored in output vector map"),
+		      polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
     /* Copy (all linked) tables if needed */
     if (copy_tables) {
