[GRASS-SVN] r54528 - in grass/trunk: raster/r.buffer scripts/r.buffer.lowmem
Fri Jan 4 07:21:52 PST 2013
Author: martinl
Date: 2013-01-04 07:21:51 -0800 (Fri, 04 Jan 2013)
New Revision: 54528
   grass/trunk/raster/r.buffer/main.c
   grass/trunk/raster/r.buffer/r.buffer.html
   grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.html
   grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py
r.buffer/r.buffer.lowmem: manual page clean up
Modified: grass/trunk/raster/r.buffer/main.c
--- grass/trunk/raster/r.buffer/main.c	2013-01-04 14:18:39 UTC (rev 54527)
+++ grass/trunk/raster/r.buffer/main.c	2013-01-04 15:21:51 UTC (rev 54528)
@@ -66,7 +66,7 @@
     G_add_keyword(_("raster"));
     G_add_keyword(_("buffer"));
     module->description =
-	_("Creates a raster map layer showing buffer zones "
+	_("Creates a raster map showing buffer zones "
 	  "surrounding cells that contain non-NULL category values.");
     opt1 = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/raster/r.buffer/r.buffer.html
--- grass/trunk/raster/r.buffer/r.buffer.html	2013-01-04 14:18:39 UTC (rev 54527)
+++ grass/trunk/raster/r.buffer/r.buffer.html	2013-01-04 15:21:51 UTC (rev 54528)
@@ -1,14 +1,14 @@
 <h2>DESCRIPTION</h2>
-<em>r.buffer</em> creates a new raster map layer showing
+<em>r.buffer</em> creates a new raster map showing
 buffer (a.k.a. "distance" or "proximity") zones around all
 cells that contain non-NULL category values in an existing
-raster map layer.  The distances of buffer zones from cells
+raster map. The distances of buffer zones from cells
 with non-zero category values are user-chosen.  Suppose,
 for example, that you want to place buffer zones around
-roads.  This program could create the raster map layer
+roads.  This program could create the raster map
 shown below on the right based on road information
-contained in the raster map layer shown on the left.
+contained in the raster map shown on the left.
 <div class="code"><pre>
       000000000000000000000000 222233333333333333444444
@@ -27,20 +27,17 @@
       Category 3: Buffer Zone 2 around roads
       Category 4: Buffer Zone 3 around roads
 </pre></div>
-<br>
 <h2>NOTES</h2>
 The user has the option of identifying up to 250 continuous zones.
-The zones are identified by specifying the upper limit of each desired zone
-(<em>r.buffer</em> assumes that <tt>0</tt> is the starting point).
-("Continuous" is used in the sense that each category
-zone's lower value is the previous zone's upper value. The
-first buffer zone always has distance <tt>0</tt> as its lower
-bound.) Buffer distances can be specified using one of five units with the <em>
-units</em> parameter: <em>meters, kilometers, feet, miles</em>, and <em>nautmiles</em>
-(nautical miles).
+The zones are identified by specifying the upper limit of each desired
+zone (<em>r.buffer</em> assumes that <tt>0</tt> is the starting
+point).  "Continuous" is used in the sense that each category zone's
+lower value is the previous zone's upper value. The first buffer zone
+always has distance <tt>0</tt> as its lower bound. Buffer distances
+can be specified using one of five units with the <b>units</b> parameter.
 <p>
 <!-- ??? is this the real method used or some ancient option ??? -->
 Distances from cells containing the user-specified category values
@@ -57,10 +54,10 @@
 planimetric locations (like UTM) and using ellipsoidal
 geodesic distance measure for latitude/longitude locations.
 <p>
-<em>r.buffer</em> calculates distance zones from all cells having non-NULL
-category values in the <em>input</em> map. If the user wishes to calculate
-distances from only selected <em>input</em> map layer
-category values, the user should run (for example)
+<em>r.buffer</em> calculates distance zones from all cells having
+non-NULL category values in the <b>input</b> map. If the user wishes
+to calculate distances from only selected <b>input</b> map category
+values, the user should run (for example)
 <em><a href="r.reclass.html">r.reclass</a></em> prior to
 <em>r.buffer</em>, to reclass all categories from which distance zones
 are not desired to be calculated into category NULL.
@@ -68,12 +65,13 @@
 The <b>-z</b> flag can be used to ignore raster values of zero instead of NULL
 values in the input raster map.
 <p>
-When working with massive raster regions consider the <em>r.buffer.lowmem</em>
-module if RAM use becomes a problem. The lowmem version can be > 40x slower,
-but will work with minimal memory requirements. The classic <em>r.buffer</em>
-should be able to deal with raster maps of 32000x32000 size on a system with
-1 GB RAM, and rasters of 90000x90000 on a system with 8 GB RAM without going
-into swap.
+When working with massive raster regions consider
+the <em><a href="r.buffer.lowmem.html">r.buffer.lowmem</a></em> module
+if RAM use becomes a problem. The lowmem version can be > 40x
+slower, but will work with minimal memory requirements. The
+classic <em>r.buffer</em> should be able to deal with raster maps of
+32000x32000 size on a system with 1 GB RAM, and rasters of 90000x90000
+on a system with 8 GB RAM without going into swap.
 <h2>EXAMPLE</h2>
@@ -82,13 +80,13 @@
 of meters):  0-100, 101-200, 201-300, 301-400 and 401-500.
 <br>
-<b>r.buffer input=</b>roads <b>output=</b>roads.buf <b>distances=</b>100,200,300,400,500
+r.buffer input=roads output=roads.buf distances=100,200,300,400,500
 </pre></div>
 Result:
-<b>r.category input=</b>roads.buf
+r.category input=roads.buf
       1       distances calculated from these locations
       2       0-100 meters
@@ -98,19 +96,17 @@
       6       400-500 meters
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
-<a href="g.region.html">g.region</a><br>
-<a href="r.buffer.lowmem.html">r.buffer.lowmem</a><br>
-<a href="r.cost.html">r.cost</a><br>
-<a href="r.mapcalc.html">r.mapcalc</a><br>
-<a href="r.reclass.html">r.reclass</a><br>
+<a href="g.region.html">g.region</a>,
+<a href="r.buffer.lowmem.html">r.buffer.lowmem</a>,
+<a href="r.cost.html">r.cost</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.reclass.html">r.reclass</a>,
 <a href="v.buffer.html">v.buffer</a>
 </em>
 <h2>AUTHORS</h2>
 Michael Shapiro, U.S. Army Construction Engineering
@@ -119,4 +115,5 @@
 James Westervelt, U.S. Army Construction Engineering
 Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.html
--- grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.html	2013-01-04 14:18:39 UTC (rev 54527)
+++ grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.html	2013-01-04 15:21:51 UTC (rev 54528)
@@ -1,96 +1,35 @@
-<em>r.buffer.lowmem</em> creates a new raster map layer showing
-buffer (a.k.a. "distance" or "proximity") zones around all
-cells that contain non-NULL category values in an existing
-with non-zero category values are user-chosen.
+<em>r.buffer.lowmem</em> creates a new raster map showing buffer
+(a.k.a. "distance" or "proximity") zones around all cells that contain
+non-NULL category values in an existing raster map. The distances of
+buffer zones from cells with non-zero category values are user-chosen.
 <p>
-This is the low-memory alternative to the classic <em>r.buffer</em>
-module. It is much slower than the classic version, but will
-run on massive raster maps without using a lot of RAM. If your
-raster map is larger than 32000x32000 cells on a system with
-1 GB of RAM, or larger than 90000x90000 cells on a system with
-8 GB of RAM, consider using this module.
+This is the low-memory alternative to the
+classic <em><a href="r.buffer.html">r.buffer</a></em> module. It is
+much slower than the classic version, but will run on massive raster
+maps without using a lot of RAM. If your raster map is larger than
+32000x32000 cells on a system with 1 GB of RAM, or larger than
+90000x90000 cells on a system with 8 GB of RAM, consider using this
+module.
 <p>
-Suppose,
-for example, that you want to place buffer zones around
-shown below on the right based on road information
+For more info see manual of <em><a href="r.buffer.html">r.buffer</a></em>.
-<div class="code"><pre>
-      000000000000000000000000 222233333333333333444444
-      111000000000000000000000 111222222222223333333333
-      000111111111100000000000 222111111111122223333333
-      000000001000011100000000 332222221222211122222222
-      000000001000000011111111 333333321233222211111111
-      000000001000000000000000 433333321233333222222222
-      000000001000000000000000 444443321233333333333333
-      000000001000000000000000 444443321233443333333333
-      000000001000000000000000 444443321233444444444444
-      Category 0: No roads
-      Category 1: Road location
-      Category 2: Buffer Zone 1 around roads
-      Category 3: Buffer Zone 2 around roads
-      Category 4: Buffer Zone 3 around roads
-</pre></div>
-<br>
-<h2>NOTES</h2>
-The user has the option of identifying up to 250 continuous zones.
-(nautical miles).
-<p>
-<!-- ??? is this the real method used or some ancient option ??? -->
-Distances from cells containing the user-specified category values
-are calculated using the "fromcell" method. This method locates each
-cell that contains a category value from which distances are to be
-calculated, and draws the requested distance rings around
-them. This method works very fast when there are few cells
-containing the category values of interest, but works
-slowly when there are numerous cells containing the
-category values of interest spread throughout the area.
-<p>
-<em>r.buffer</em> measures distances from center of cell to
-center of cell using Euclidean distance measure for
-planimetric locations (like UTM) and using ellipsoidal
-geodesic distance measure for latitude/longitude locations.
-<p>
-<em><a href="r.reclass.html">r.reclass</a></em> prior to
-<em>r.buffer</em>, to reclass all categories from which distance zones
-are not desired to be calculated into category NULL.
-<p>
-The <b>-z</b> flag can be used to ignore raster values of zero instead of NULL
-values in the input raster map.
-<p>
 <h2>EXAMPLE</h2>
 In the following example, the buffer zones would be (in the default units
-of meters):  0-100, 101-200, 201-300, 301-400 and 401-500.
-<br>
+of meters): 0-100, 101-200, 201-300, 301-400 and 401-500.
+r.buffer.lowmem input=roads output=roads.buf distances=100,200,300,400,500
 </pre></div>
 Result:
       2       0-100 meters
@@ -103,16 +42,15 @@
 <h2>SEE ALSO</h2>
 <em>
-<a href="r.buffer.html">r.buffer</a><br>
-<a href="r.grow.distance.html">r.grow.distance</a><br>
+<a href="r.buffer.html">r.buffer</a>,
+<a href="r.grow.distance.html">r.grow.distance</a>,
 </em>
 <h2>AUTHORS</h2>
Modified: grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py
--- grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py	2013-01-04 14:18:39 UTC (rev 54527)
+++ grass/trunk/scripts/r.buffer.lowmem/r.buffer.lowmem.py	2013-01-04 15:21:51 UTC (rev 54528)
@@ -15,7 +15,8 @@
 #%module
-#% description: Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values.
+#% label: Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values.
+#% description: This is the low-memory alternative to the classic r.buffer module.
 #% keywords: raster
 #% keywords: buffer
 #%end
