[GRASS-SVN] r54550 - grass/trunk/raster/r.flow
Sun Jan 6 07:18:22 PST 2013
Author: martinl
Date: 2013-01-06 07:18:22 -0800 (Sun, 06 Jan 2013)
New Revision: 54550
   grass/trunk/raster/r.flow/io.c
   grass/trunk/raster/r.flow/main.c
   grass/trunk/raster/r.flow/precomp.c
r.flow: progress info cosmetics
Modified: grass/trunk/raster/r.flow/io.c
--- grass/trunk/raster/r.flow/io.c	2013-01-06 13:53:11 UTC (rev 54549)
+++ grass/trunk/raster/r.flow/io.c	2013-01-06 15:18:22 UTC (rev 54550)
@@ -82,33 +82,36 @@
     int fd, row, col;
     struct Cell_head hd;
-    G_message(_("Reading input files: elevation"));
     fd = open_existing_cell_file(parm.elevin, &hd);
     if (!compare_regions(&region, &hd))
-	G_fatal_error(_("Elevation file's resolution differs from current region resolution"));
+	G_fatal_error(_("Elevation raster map resolution differs from current region resolution"));
+    G_important_message(_("Reading input raster map <%s>..."), parm.elevin);
     for (row = 0; row < region.rows; row++) {
+        G_percent(row, region.rows, 5);
 	Rast_get_d_row(fd, el.buf[row], row);
 	if (parm.seg)
 	    put_row_seg(el, row);
+    G_percent(1, 1, 1);
     if (parm.seg)
 	segment_flush(el.seg);
     Rast_close(fd);
     if (parm.aspin) {
-	G_message(_("Reading input files: aspect"));
 	fd = open_existing_cell_file(parm.aspin, &hd);
 	    G_fatal_error(_("Resolution of aspect file differs from "
 			    "current region resolution"));
+        G_important_message(_("Reading input raster map <%s>..."), parm.aspin);
 	    Rast_get_d_row(fd, as.buf[row], row);
 	    if (parm.seg)
 		put_row_seg(as, row);
 	if (parm.seg)
 	    segment_flush(as.seg);
 	Rast_close(fd);
@@ -201,15 +204,17 @@
     Rast_set_output_window(&region);
-    G_message(_("Writing density file"));
+    G_message(_("Writing output raster map <%s>..."), parm.dsout);
     dsfd = Rast_open_new(parm.dsout, DCELL_TYPE);
 	Rast_put_row(dsfd, get_row(ds, row), DCELL_TYPE);
 	for (col = 0; col < region.cols; col++)
 	    if (ds.buf[row][col] > dsmax)
 		dsmax = ds.buf[row][col];
     Rast_close(dsfd);
     Rast_init_colors(&colors);
@@ -234,7 +239,7 @@
     Rast_add_c_color_rule(&val1, 0, 0, 255, &val2, 0, 0, 0, &colors);
     if ((mapset = G_find_file("cell", parm.dsout, "")) == NULL)
-	G_fatal_error(_("Unable to find file %s"), parm.dsout);
+	G_fatal_error(_("Raster map <%s> not found"), parm.dsout);
     Rast_write_colors(parm.dsout, mapset, &colors);
     Rast_free_colors(&colors);
Modified: grass/trunk/raster/r.flow/main.c
--- grass/trunk/raster/r.flow/main.c	2013-01-06 13:53:11 UTC (rev 54549)
+++ grass/trunk/raster/r.flow/main.c	2013-01-06 15:18:22 UTC (rev 54550)
@@ -313,7 +313,7 @@
     struct line_cats *cats = Vect_new_cats_struct();
     int loopstep = (!parm.dsout && !parm.lgout && parm.flout) ? parm.skip : 1;
-    G_message(_("Calculating maps ..."));
+    G_important_message(_("Calculating..."));
     fls.px = (double *)G_calloc(parm.bound, sizeof(double));
     fls.py = (double *)G_calloc(parm.bound, sizeof(double));
@@ -387,7 +387,8 @@
 	if (parm.lgout)
 	    Rast_put_f_row(lgfd, lg);
+    G_percent (1, 1, 1);
     G_free(fls.px);
     G_free(fls.py);
     /*    G_free (fls); *//* commented 19/10/99 MN */
Modified: grass/trunk/raster/r.flow/precomp.c
--- grass/trunk/raster/r.flow/precomp.c	2013-01-06 13:53:11 UTC (rev 54549)
+++ grass/trunk/raster/r.flow/precomp.c	2013-01-06 15:18:22 UTC (rev 54550)
@@ -45,26 +45,26 @@
 void precompute(void)
-    G_message(_("Precomputing: e/w distances"));
+    G_verbose_message(_("Precomputing e/w distances..."));
     precompute_ew_dists();
-    G_message(_("Precomputing: quantization tolerances"));
+    G_verbose_message(_("Precomputing quantization tolerances..."));
     precompute_epsilons();
     if (parm.up) {
-	G_message(_("Precomputing: inverted elevations"));
+	G_verbose_message(_("Precomputing inverted elevations..."));
 	upslope_correction();
     if (!parm.aspin) {
-	G_message(_("Precomputing: interpolated border elevations"));
+	G_verbose_message(_("Precomputing interpolated border elevations..."));
 	interpolate_border();
     if (!parm.mem) {
 	if (parm.aspin) {
-	    G_message(_("Precomputing: re-oriented aspects"));
+	    G_verbose_message(_("Precomputing re-oriented aspects..."));
 	    reflect_and_sentinel();
 	else {
-	    G_message(_("Precomputing: aspects"));
+	    G_verbose_message(_("Precomputing aspects..."));
 	    precompute_aspects();
