[GRASS-SVN] r54552 - grass/trunk/vector/v.kernel
svn_grass at osgeo.org
Sun Jan 6 09:03:17 PST 2013
Author: martinl
Date: 2013-01-06 09:03:16 -0800 (Sun, 06 Jan 2013)
New Revision: 54552
grass/trunk/vector/v.kernel/main.c
grass/trunk/vector/v.kernel/v.kernel.html
v.kernel: clarify module's description
message cosmetics
update manual
Modified: grass/trunk/vector/v.kernel/main.c
--- grass/trunk/vector/v.kernel/main.c 2013-01-06 15:32:45 UTC (rev 54551)
+++ grass/trunk/vector/v.kernel/main.c 2013-01-06 17:03:16 UTC (rev 54552)
@@ -81,6 +81,7 @@
char *desc;
struct Map_info In, Net, Out;
+ int overwrite;
int fdout = -1, maskfd = -1;
int node_method, kernel_function;
int row, col;
@@ -106,24 +107,29 @@
module = G_define_module();
G_add_keyword(_("vector"));
G_add_keyword(_("kernel density"));
- module->description =
- _("Generates a raster density map from vector point data using a moving kernel or "
- "optionally generates a vector density map on a vector network.");
+ module->label =
+ _("Generates a raster density map from vector points map.");
+ module->description = _("Density is computed using a moving kernel. "
+ "Optionally generates a vector density map on a vector network.");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
- in_opt->description = _("Input vector with training points");
+ in_opt->label = _("Name of input vector map with training points");
+ in_opt->description = NULL;
net_opt = G_define_standard_option(G_OPT_V_INPUT);
net_opt->key = "net";
- net_opt->description = _("Input network vector map");
+ net_opt->label = _("Name of input network vector map");
+ net_opt->description = NULL;
net_opt->required = NO;
+ net_opt->guisection = _("Network");
out_opt = G_define_option();
out_opt->key = "output";
out_opt->type = TYPE_STRING;
out_opt->key_desc = "name";
out_opt->required = YES;
- out_opt->description = _("Output raster/vector map");
+ out_opt->label = _("Name for output raster/vector map");
+ out_opt->description = _("Outputs vector map if network map is given, otherwise raster map");
radius_opt = G_define_option();
radius_opt->key = "radius";
@@ -144,6 +150,7 @@
segmax_opt->required = NO;
segmax_opt->description = _("Maximum length of segment on network");
segmax_opt->answer = "100.";
+ segmax_opt->guisection = _("Network");
netmax_opt = G_define_option();
netmax_opt->key = "distmax";
@@ -151,6 +158,7 @@
netmax_opt->required = NO;
netmax_opt->description = _("Maximum distance from point to network");
netmax_opt->answer = "100.";
+ netmax_opt->guisection = _("Network");
multip_opt = G_define_option();
multip_opt->key = "mult";
@@ -172,6 +180,7 @@
_("No method applied at nodes with more than 2 arcs"),
_("Equal split (Okabe 2009) applied at nodes"));
node_opt->descriptions = desc;
+ node_opt->guisection = _("Network");
kernel_opt = G_define_option();
kernel_opt->key = "kernel";
@@ -196,15 +205,37 @@
flag_normalize->key = 'n';
flag_normalize->description =
_("In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult");
+ flag_normalize->guisection = _("Network");
flag_multiply = G_define_flag();
flag_multiply->key = 'm';
flag_multiply->description =
- _("In network mode, multiply the result by number of input points.");
+ _("In network mode, multiply the result by number of input points");
+ flag_multiply->guisection = _("Network");
+ overwrite = G_check_overwrite(argc, argv);
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if (net_opt->answer) {
+ if (G_find_vector2(out_opt->answer, G_mapset()))
+ if (overwrite)
+ G_warning(_("Vector map <%s> already exists and will be overwritten"),
+ out_opt->answer);
+ else
+ G_fatal_error(_("Vector map <%s> already exists"),
+ out_opt->answer);
+ else {
+ if (G_find_raster(out_opt->answer, G_mapset()))
+ if (overwrite)
+ G_warning(_("Raster map <%s> already exists and will be overwritten"),
+ out_opt->answer);
+ else
+ G_fatal_error(_("Raster map <%s> already exists"),
+ out_opt->answer);
/*read options */
dmax = atof(radius_opt->answer);
sigma = dmax;
@@ -263,14 +294,14 @@
G_get_window(&window);
- G_message("STDDEV: %f\nRES: %f\tROWS: %d\tCOLS: %d",
- sigma, window.ew_res, window.rows, window.cols);
+ G_verbose_message(_("Standard deviation: %f"), sigma);
+ G_verbose_message(_("Output raster map: res: %f\trows: %d\tcols: %d"),
+ window.ew_res, window.rows, window.cols);
/* Open input vector */
Vect_set_open_level(2);
Vect_open_old(&In, in_opt->answer, "");
int nlines, line;
struct line_pnts *Points;
@@ -391,10 +422,10 @@
struct line_cats *SCats;
double total = 0.0;
- G_message(_("Writing output vector map using smooth parameter=%f."),
- sigma);
- G_message(_("Normalising factor=%f."),
- 1. / gaussianFunction(sigma / 4., sigma, dimension));
+ G_verbose_message(_("Writing output vector map using smooth parameter %f"),
+ sigma);
+ G_verbose_message(_("Normalising factor %f"),
+ 1. / gaussianFunction(sigma / 4., sigma, dimension));
/* Divide lines to segments and calculate gaussian for center of each segment */
Points = Vect_new_line_struct();
@@ -408,6 +439,7 @@
int seg, nseg, ltype;
double llength, length, x, y;
+ G_percent(line, nlines, 5);
ltype = Vect_read_line(&Net, Points, NULL, line);
if (!(ltype & GV_LINES))
continue;
@@ -457,7 +489,6 @@
total += length * gaussian;
- G_percent(line, nlines, 1);
if (flag_normalize->answer || flag_multiply->answer) {
@@ -501,10 +532,10 @@
struct bound_box box;
struct boxlist *NList = Vect_new_boxlist(1);
- G_message(_("\nWriting output raster map using smooth parameter=%f."),
- sigma);
- G_message(_("\nNormalising factor=%f."),
+ G_verbose_message(_("Writing output raster map using smooth parameter %f"),
+ sigma);
for (row = 0; row < window.rows; row++) {
G_percent(row, window.rows, 2);
@@ -548,11 +579,12 @@
Rast_put_row(fdout, output_cell, DCELL_TYPE);
+ G_percent(1, 1, 1);
Rast_close(fdout);
- G_message(_("Maximum value in output: %e."), multip * gausmax);
+ G_done_msg(_("Maximum value in output: %e."), multip * gausmax);
Vect_close(&In);
Modified: grass/trunk/vector/v.kernel/v.kernel.html
--- grass/trunk/vector/v.kernel/v.kernel.html 2013-01-06 15:32:45 UTC (rev 54551)
+++ grass/trunk/vector/v.kernel/v.kernel.html 2013-01-06 17:03:16 UTC (rev 54552)
@@ -1,50 +1,55 @@
<h2>DESCRIPTION</h2>
-<em>v.kernel</em> generates a raster density map from vector points data using
-a moving kernel. Available <a href="http://en.wikipedia.org/wiki/Kernel_(statistics)#Kernel_functions_in_common_use">kernel density functions</a> are <em>uniform,
-triangular, epanechnikov, quartic, triweight, gaussian, cosine</em>,
-default is <em>gaussian</em>.
+<em>v.kernel</em> generates a raster density map from vector points
+data using a moving
+kernel. Available <a href="http://en.wikipedia.org/wiki/Kernel_(statistics)#Kernel_functions_in_common_use">kernel
+density functions</a> are <em>uniform, triangular, epanechnikov,
+quartic, triweight, gaussian, cosine</em>, default
+is <em>gaussian</em>.
<p>The module can also generate a vector density map on a vector network.
Conventional kernel functions produce biased estimates by overestimating
the densities around network nodes, whereas the equal split method of
Okabe et al. (2009) produces unbiased density estimates. The equal split
-method uses the kernel function selected with the <em>kernel</em> option
-and can be enabled with <em>node=split</em>.
+method uses the kernel function selected with the <b>kernel</b> option
+and can be enabled with <b>node=split</b>.
<h2>NOTES</h2>
-The <em>mult</em> option is needed to overcome the limitation that
+The <b>mult</b> option is needed to overcome the limitation that
the resulting density in case of a vector map output is stored as category
-(Integer). The density result stored as category may be multiplied by this number.
+(integer). The density result stored as category may be multiplied by this number.
<p>
For the <em>gaussian</em> kernel, standard deviation for the
<a href="http://en.wikipedia.org/wiki/Kernel_(statistics)#Kernel_functions_in_common_use">gaussian function</a>
is set to 1/4 of the radius.
<p>
-With the <em>-o</em> flag (experimental) the command tries to calculate an
+With the <b>-o</b> flag (experimental) the command tries to calculate an
optimal standard deviation. The value of <em>stddeviation</em> is taken
as maximum value. Standard deviation is calculated using ALL points,
not just those in the current region.
<h2>LIMITATIONS</h2>
The module only considers the presence of points, but not
(yet) any attribute values.
-<h2>SEE ALSO</h2>
-<a href="v.surf.rst.html">v.surf.rst</a>
+<h2>REFERENCES</h2>
-<h2>REFERENCES</h2>
-Okabe, A., Satoh, T., Sugihara, K. (2009). <i>A kernel density estimation
+<ul>
+<li>Okabe, A., Satoh, T., Sugihara, K. (2009). <i>A kernel density estimation
method for networks, its computational method and a GIS-based tool</i>.
<b>International Journal of Geographical Information Science</b>, Vol 23(1),
pp. 7-32.<br>
DOI: <a href="http://dx.doi.org/10.1080/13658810802475491">10.1080/13658810802475491</a>
+</ul>
+<h2>SEE ALSO</h2>
+<em><a href="v.surf.rst.html">v.surf.rst</a></em>
<h2>AUTHORS</h2>
-Stefano Menegon, <a href="http://mpa.itc.it/">ITC-irst</a>, Trento, Italy
-<br>
+Stefano Menegon, <a href="http://mpa.itc.it/">ITC-irst</a>, Trento, Italy<br>
Radim Blazek (additional kernel density functions and network part)
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
