[GRASS-SVN] r54560 - in grass/trunk/gui/wxpython: gmodeler gui_core
svn_grass at osgeo.org
Mon Jan 7 09:21:25 PST 2013
Author: martinl
Date: 2013-01-07 09:21:24 -0800 (Mon, 07 Jan 2013)
New Revision: 54560
grass/trunk/gui/wxpython/gmodeler/model.py
grass/trunk/gui/wxpython/gui_core/forms.py
grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI: list extra map items for Graphical Modeler
Modified: grass/trunk/gui/wxpython/gmodeler/model.py
--- grass/trunk/gui/wxpython/gmodeler/model.py 2013-01-07 16:23:15 UTC (rev 54559)
+++ grass/trunk/gui/wxpython/gmodeler/model.py 2013-01-07 17:21:24 UTC (rev 54560)
@@ -183,6 +183,16 @@
return None
+ def GetMaps(self, prompt):
+ """!Get list of maps of selected type
+ @param promt to filter maps"""
+ maps = list()
+ for data in self.GetData():
+ if prompt == data.GetPrompt():
+ maps.append(data.GetValue())
+ return maps
def GetData(self):
"""!Get list of data items"""
result = list()
Modified: grass/trunk/gui/wxpython/gui_core/forms.py
--- grass/trunk/gui/wxpython/gui_core/forms.py 2013-01-07 16:23:15 UTC (rev 54559)
+++ grass/trunk/gui/wxpython/gui_core/forms.py 2013-01-07 17:21:24 UTC (rev 54560)
@@ -1176,12 +1176,16 @@
element_dict = {'rast': 'strds', 'vect': 'stvds', 'rast3d': 'str3ds'}
elem = element_dict[type_param.get('default')]
+ if self.parent.modeler:
+ extraItems = {_('Graphical Modeler') : self.parent.modeler.GetModel().GetMaps(p.get('prompt'))}
+ else:
+ extraItems = None
selection = gselect.Select(parent = which_panel, id = wx.ID_ANY,
size = globalvar.DIALOG_GSELECT_SIZE,
- type = elem,
- multiple = multiple, nmaps = len(p.get('key_desc', [])),
- mapsets = mapsets, fullyQualified = p.get('age', 'old') == 'old')
+ type = elem, multiple = multiple, nmaps = len(p.get('key_desc', [])),
+ mapsets = mapsets, fullyQualified = p.get('age', 'old') == 'old',
+ extraItems = extraItems)
value = self._getValue(p)
if value:
selection.SetValue(value)
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py 2013-01-07 16:23:15 UTC (rev 54559)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py 2013-01-07 17:21:24 UTC (rev 54560)
@@ -66,7 +66,7 @@
def __init__(self, parent, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
type = None, multiple = False, nmaps = 1,
mapsets = None, updateOnPopup = True, onPopup = None,
- fullyQualified = True):
+ fullyQualified = True, extraItems = {}):
"""!Custom control to create a ComboBox with a tree control to
display and select GIS elements within acessible mapsets.
Elements can be selected with mouse. Can allow multiple
@@ -80,6 +80,7 @@
@param updateOnPopup True for updating list of elements on popup
@param onPopup function to be called on Popup
@param fullyQualified True to provide fully qualified names (map at mapset)
+ @param extraItems extra items to add (given as dictionary) - see gmodeler for usage
wx.combo.ComboCtrl.__init__(self, parent=parent, id=id, size=size)
self.GetChildren()[0].SetName("Select")
@@ -92,7 +93,7 @@
self.tcp.SetData(type = type, mapsets = mapsets,
multiple = multiple, nmaps = nmaps,
updateOnPopup = updateOnPopup, onPopup = onPopup,
- fullyQualified = fullyQualified)
+ fullyQualified = fullyQualified, extraItems = extraItems)
self.GetChildren()[0].Bind(wx.EVT_KEY_UP, self.OnKeyUp)
def OnKeyUp(self, event):
@@ -165,6 +166,7 @@
self.updateOnPopup = True
self.onPopup = None
self.fullyQualified = True
+ self.extraItems = dict()
self.SetFilter(None)
@@ -342,12 +344,21 @@
check_search_path = False)
else:
filesdict = grass.list_grouped(elementdict[element],
- check_search_path = False)
+ check_search_path = False)
+ # add extra items first
+ if self.extraItems:
+ for group, items in self.extraItems.iteritems():
+ node = self.AddItem(group, node = True)
+ self.seltree.SetItemTextColour(node, wx.Colour(50, 50, 200))
+ for item in items:
+ self.AddItem(item, node = False, parent = node)
+ self.seltree.ExpandAllChildren(node)
# list of mapsets in current location
if mapsets is None:
mapsets = grass.mapsets(search_path = True)
# current mapset first
if curr_mapset in mapsets and mapsets[0] != curr_mapset:
mapsets.remove(curr_mapset)
@@ -511,7 +522,7 @@
self.value = []
else:
fullName = self.seltree.GetItemText(item)
- if self.fullyQualified:
+ if self.fullyQualified and self.seltree.GetPyData(item)['mapset']:
fullName += '@' + self.seltree.GetPyData(item)['mapset']
if self.multiple:
@@ -548,7 +559,7 @@
return
if self.multiple:
@@ -584,6 +595,8 @@
self.onPopup = kargs['onPopup']
if 'fullyQualified' in kargs:
self.fullyQualified = kargs['fullyQualified']
+ if 'extraItems' in kargs:
+ self.extraItems = kargs['extraItems']
def GetType(self):
"""!Get element type
