[GRASS-SVN] r54571 - grass/trunk/vector/v.external
svn_grass at osgeo.org
Tue Jan 8 02:17:41 PST 2013
Author: martinl
Date: 2013-01-08 02:17:38 -0800 (Tue, 08 Jan 2013)
New Revision: 54571
grass/trunk/vector/v.external/args.c
grass/trunk/vector/v.external/list.c
v.external: -t -> print name,type,projection_check
Modified: grass/trunk/vector/v.external/args.c
--- grass/trunk/vector/v.external/args.c 2013-01-08 09:48:06 UTC (rev 54570)
+++ grass/trunk/vector/v.external/args.c 2013-01-08 10:17:38 UTC (rev 54571)
@@ -49,8 +49,9 @@
flags->tlist = G_define_flag();
flags->tlist->key = 't';
- flags->tlist->description = _("List available layers including feature type "
- "in data source and exit");
+ flags->tlist->label = _("List available layers including feature type "
+ "in data source and exit");
+ flags->tlist->description = _("Format: layer name,type,projection check");
flags->tlist->guisection = _("Print");
flags->tlist->suppress_required = YES;
Modified: grass/trunk/vector/v.external/list.c
--- grass/trunk/vector/v.external/list.c 2013-01-08 09:48:06 UTC (rev 54570)
+++ grass/trunk/vector/v.external/list.c 2013-01-08 10:17:38 UTC (rev 54571)
@@ -3,6 +3,7 @@
#include <grass/gis.h>
#include <grass/vector.h>
#include <grass/dbmi.h>
+#include <grass/gprojects.h>
#include <grass/glocale.h>
#ifdef HAVE_OGR
@@ -197,11 +198,11 @@
if (fd) {
if (print_types) {
if (print_schema && G_strcasecmp(value_schema, "public") != 0)
- fprintf(fd, "%s.%s (%s)\n",
+ fprintf(fd, "%s.%s,%s,0\n",
value_schema, value_table,
feature_type(PQgetvalue(res, row, 2)));
else
- fprintf(fd, "%s (%s)\n", value_table,
+ fprintf(fd, "%s,%s,0\n", value_table,
else {
@@ -237,13 +238,19 @@
int nlayers;
char *layer_name;
+ struct Key_Value *loc_proj_info, *loc_proj_units;
+ struct Key_Value *proj_info, *proj_units;
+ struct Cell_head loc_wind;
OGRDataSourceH Ogr_ds;
OGRLayerH Ogr_layer;
OGRFeatureDefnH Ogr_featuredefn;
OGRwkbGeometryType Ogr_geom_type;
ret = -1;
+ loc_proj_info = loc_proj_units = NULL;
+ proj_info = proj_units = NULL;
/* open OGR DSN */
Ogr_ds = OGROpen(dsn, FALSE, NULL);
if (!Ogr_ds) {
@@ -258,6 +265,12 @@
dsn, OGR_Dr_GetName(OGR_DS_GetDriver(Ogr_ds)), nlayers);
+ G_get_default_window(&loc_wind);
+ if (print_types && loc_wind.proj != PROJECTION_XY) {
+ loc_proj_info = G_get_projinfo();
+ loc_proj_units = G_get_projunits();
for (i = 0; i < nlayers; i++) {
Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
@@ -265,11 +278,34 @@
layer_name = (char *) OGR_FD_GetName(Ogr_featuredefn);
if (fd) {
- if (print_types)
- fprintf(fd, "%s (%s)\n", layer_name,
- feature_type(OGRGeometryTypeToName(Ogr_geom_type)));
- else
+ if (print_types) {
+ int proj_same;
+ OGRSpatialReferenceH Ogr_projection;
+ /* projection check */
+ Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer);
+ proj_same = 0;
+ if (GPJ_osr_to_grass(&loc_wind, &proj_info,
+ &proj_units, Ogr_projection, 0) < 0) {
+ G_warning(_("Unable to convert input map projection to GRASS "
+ "format. Projection check cannot be provided for "
+ "OGR layer <%s>"), layer_name);
+ else {
+ if (TRUE == G_compare_projections(loc_proj_info, loc_proj_units,
+ proj_info, proj_units))
+ proj_same = 1;
+ else
+ proj_same = 0;
+ fprintf(fd, "%s,%s,%d\n", layer_name,
+ feature_type(OGRGeometryTypeToName(Ogr_geom_type)),
+ proj_same);
+ else {
fprintf(fd, "%s\n", layer_name);
if (layer)
if (strcmp(layer_name, layer) == 0) {
