[GRASS-SVN] r54581 - in grass-addons/grass7/raster/r.modis: libmodis r.modis.import
Tue Jan 8 08:03:07 PST 2013
Author: lucadelu
Date: 2013-01-08 08:03:07 -0800 (Tue, 08 Jan 2013)
New Revision: 54581
   grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py
   grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
fix and cleanup r.modis.import
Modified: grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py
--- grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py	2013-01-08 15:57:56 UTC (rev 54580)
+++ grass-addons/grass7/raster/r.modis/libmodis/rmodislib.py	2013-01-08 16:03:07 UTC (rev 54581)
@@ -64,8 +64,8 @@
         # color for lst product
         lst_color = ['celsius']
         ### values of vi product:
-        vi_spec = '( 1 1 0 0 0 0 0 0 0 0 0 )'
-        vi_specqa = '( 1 1 1 0 0 0 0 0 0 0 0 )'
+        vi_spec = '( 1 1 0 0 0 0 0 0 0 0 0 0 )'
+        vi_specqa = '( 1 1 1 0 0 0 0 0 0 0 0 1 )'
         vi_patt = {3: [2, 3], 63: [13, 14, 15], 128: [3], 1024: [1],
                    8192: [0, 6, 7], 16384: [1], 32768: [1]}
         vi_color = ['ndvi', 'evi']
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2013-01-08 15:57:56 UTC (rev 54580)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py	2013-01-08 16:03:07 UTC (rev 54581)
@@ -5,8 +5,8 @@
 # MODULE:        r.modis.import
 # AUTHOR(S):     Luca Delucchi
-# PURPOSE:       r.modis.import is an interface to pyModis for import into GRASS
-#                GIS level 3 MODIS produts
+# PURPOSE:       r.modis.import is an interface to pyModis for import into
+#                GRASS GIS level 3 MODIS produts
 # COPYRIGHT:        (C) 2011 by Luca Delucchi
@@ -17,7 +17,7 @@
 # REQUIREMENTS:
-#      -  MRT tools, https://lpdaac.usgs.gov/lpdaac/tools/modis_reprojection_tool
+#   -  MRT tools, https://lpdaac.usgs.gov/lpdaac/tools/modis_reprojection_tool
@@ -62,7 +62,7 @@
 #% key: files
 #% type: string
 #% key_desc: file
-#% description: Full path to file with list of HDF files
+#% description: Full path to file with list of HDF files
 #% gisprompt: old,file,input
 #% required: no
 #%end
@@ -83,11 +83,15 @@
 #% key: spectral
 #% type: string
 #% key_desc: spectral subset
-#% description: String to choose subset of layers in HDF file for import
+#% description: String to choose subset of layers in HDF file for import
 #% required: no
 #%end
-import os, sys, string, glob, shutil
+import os
+import sys
+import string
+import glob
+import shutil
 import grass.script as grass
 from datetime import date
@@ -95,17 +99,18 @@
 if os.path.isdir(os.path.join(os.getenv('GISBASE'), 'etc', 'r.modis')):
     libmodis = os.path.join(os.getenv('GISBASE'), 'etc', 'r.modis')
 elif os.getenv('GRASS_ADDON_BASE') and \
-        os.path.isdir(os.path.join(os.getenv('GRASS_ADDON_BASE'), 'etc', 'r.modis')):
+        os.path.isdir(os.path.join(os.getenv('GRASS_ADDON_BASE'), 'etc',
+                                   'r.modis')):
     libmodis = os.path.join(os.getenv('GRASS_ADDON_BASE'), 'etc', 'r.modis')
 elif os.path.isdir(os.path.join('..', 'libmodis')):
-    libmodis = os.path.join('..', 'libmodis')
+    libmodis = os.path.join('..', 'libmodis')
 if not libmodis:
     sys.exit("ERROR: modis library not found")
 sys.path.append(libmodis)
 # try to import pymodis (modis) and some classes for r.modis.download
 try:
-    from rmodislib import resampling, product, get_proj, projection
+    from rmodislib import resampling, product, projection
 except ImportError, e:
     grass.fatal(e)
 try:
@@ -117,13 +122,15 @@
     grass.fatal(e)
-def list_files(opt, mosaik = False):
-    """If used in function single(): Return a list of HDF files from the file list
-    If used in function mosaic(): Return a dictionary with a list of HDF files for each day
+def list_files(opt, mosaik=False):
+    """If used in function single(): Return a list of HDF files from the file
+    list. If used in function mosaic(): Return a dictionary with a list of HDF
+    files for each day
     # read the file with the list of HDF
     if opt['files'] != '':
-        listoffile = open(opt['files'],'r')
+        listoffile = open(opt['files'], 'r')
         basedir = os.path.split(listoffile.name)[0]
         # if mosaic create a dictionary
         if mosaik:
@@ -133,10 +140,10 @@
             filelist = []
         # append hdf files
         for line in listoffile:
-            if string.find(line,'xml') == -1 and mosaik == False:
+            if string.find(line, 'xml') == -1 and mosaik == False:
                 filelist.append(line.strip())
             # for mosaic create a list of hdf files for each day
-            elif string.find(line,'xml') == -1 and mosaik == True:
+            elif string.find(line, 'xml') == -1 and mosaik == True:
                 day = line.split('/')[-1].split('.')[1]
                 if filelist.has_key(day):
                     filelist[day].append(line)
@@ -148,7 +155,8 @@
         basedir = os.path.split(filelist[0])[0]
     return filelist, basedir
-def spectral(opts, prod, q, m = False):
+def spectral(opts, prod, q, m=False):
     """Return spectral string"""
     # return the spectral set selected by the user
     if opts['spectral'] != '':
@@ -158,7 +166,7 @@
         if q:
             if prod['spec_qa']:
                 spectr = prod['spec_qa']
-            else:
+            else:
                 spectr = prod['spec']
         else:
@@ -166,9 +174,10 @@
             spectr = spectr.replace(' 0', '')
     return spectr
 def confile(pm, opts, q, mosaik=False):
     """Create the configuration file for MRT software"""
-    # return projection and datum
+    # return projection and datum
     projObj = projection()
     proj = projObj.returned()
     dat = projObj.datum()
@@ -179,7 +188,7 @@
     cod = os.path.split(pm.hdfname)[1].split('.')[0]
     prod = product().fromcode(cod)
     if mosaik:
-        # if mosaic it remove all the 0 from the subset string to convert all
+        # if mosaic it remove all the 0 from the subset string to convert all
         # the right layer
         spectr = spectral(opts, prod, q, True)
     else:
@@ -198,26 +207,30 @@
     else:
         res = None
     try:
-        conf = pm.confResample(spectr, res, pref, dat, resampl,
+        conf = pm.confResample(spectr, res, pref, dat, resampl,
                                 proj, zone, projpar)
         return conf
     except IOError, e:
         grass.fatal(e)
-def prefix(options, name = False):
+def prefix(options, name=False):
     """Return the prefix of output file if not set return None to use default
        value
     if options['output']:
-        return options['output']
+        return '%s.tif' % options['output']
     else:
-        return None
+        return None
 def import_tif(out, basedir, rem, write, target=None):
     """Import TIF files"""
     # list of tif files
-    tifiles = glob.glob1(basedir, out + "*.tif")
+    tifiles = glob.glob1(basedir, "*.tif")
     if not tifiles:
+        tifiles = glob.glob1(os.getcwd(), "*.tif")
+    if not tifiles:
         grass.fatal(_('Error during the conversion'))
     # check if user is in latlong location to set flag l
     if projection().val == 'll':
@@ -228,25 +241,32 @@
     # for each file import it
     for t in tifiles:
         basename = os.path.splitext(t)[0]
-        name = os.path.join(basedir,t)
+        name = os.path.join(basedir, t)
+        if not os.path.exists(name):
+            name = os.path.join(os.getcwd(), t)
+            grass.warning(_("File %s doesn't find" % basename))
+            continue
         filesize = int(os.path.getsize(name))
         if filesize < 1000:
             grass.warning(_('Probably some error occur during the conversion' \
             + 'for file <%s>. Escape import' % name))
             continue
         try:
-            grass.run_command('r.in.gdal', input = name, output = basename,
-                              flags = f, overwrite = write, quiet = True)
+            grass.run_command('r.in.gdal', input=name, output=basename,
+                              flags=f, overwrite=write, quiet=True)
             outfile.append(basename)
         except:
-            grass.fatal(_('Error during import'))
+            grass.warning(_('Error during import of %s' % basename))
+            continue
         if rem:
             os.remove(name)
-        if target:
+        if target:
             if target != basedir:
-                shutil.move(name,target)
+                shutil.move(name, target)
     return outfile
 def findfile(pref, suff):
     """ Check if a file exists on mapset """
     if grass.find_file(pref + suff)['file']:
@@ -254,32 +274,38 @@
     else:
         grass.warning(_("Raster map <%s> not found") % (pref + suff))
 def metadata(pars, mapp, coll):
     """ Set metadata to the imported files """
     # metadata
     meta = pars.metastring()
-    grass.run_command('r.support', quiet = True, map=mapp, hist=meta)
+    grass.run_command('r.support', quiet=True, map=mapp, hist=meta)
     # timestamp
     rangetime = pars.retRangeTime()
     data = rangetime['RangeBeginningDate'].split('-')
-    dataobj = date(int(data[0]),int(data[1]),int(data[2]))
-    grass.run_command('r.timestamp', map=mapp, date=dataobj.strftime("%d %b %Y"),
-                      quiet = True)
+    dataobj = date(int(data[0]), int(data[1]), int(data[2]))
+    grass.run_command('r.timestamp', map=mapp, quiet=True,
+                      date=dataobj.strftime("%d %b %Y"))
     # color
     if string.find(mapp, 'QC') != -1 or string.find(mapp, 'Quality') != -1 or \
     string.find(mapp, 'QA') != -1:
-        grass.run_command('r.colors', quiet = True, map=mapp, color = coll)
+        grass.run_command('r.colors', quiet=True, map=mapp, color=coll)
     elif string.find(mapp, 'NDVI') != -1:
-        grass.run_command('r.colors', quiet = True, map=mapp, color = coll[0])
+        grass.run_command('r.colors', quiet=True, map=mapp, color=coll[0])
     elif string.find(mapp, 'EVI') != -1:
-        grass.run_command('r.colors', quiet = True, map=mapp, color = coll[1])
+        grass.run_command('r.colors', quiet=True, map=mapp, color=coll[1])
     elif string.find(mapp, 'LST') != -1:
     elif string.find(mapp, 'Snow') != -1:
 def analyze(pref, an, cod, parse, write):
     """ Analyze the MODIS data using QA if present """
+    if pref.find('.tif') != -1:
+        pref = pref.rstrip('.tif')
+    import pdb
+    pdb.set_trace()
     if not prod['spec_qa']:
         grass.warning(_("There is no QA layer, analysis and filtering will be skipped"))
@@ -289,113 +315,124 @@
     col = prod['color']
     val = []
     qa = []
-    for v,q in suf.iteritems():
-        val.append(findfile(pref,v))
+    for v, q in suf.iteritems():
+        val.append(findfile(pref, v))
         if q:
-            qa.append(findfile(pref,q))
+            qa.append(findfile(pref, q))
+    pdb.set_trace()
     for n in range(len(val)):
         if val[n] == None:
             grass.warning(_("Some error occur"))
             continue
         valname = val[n]['name']
         valfull = val[n]['fullname']
-        grass.run_command('g.region', rast = valfull)
-        grass.run_command('r.null', map = valfull, setnull = 0)
-        if string.find(cod,'13Q1') >= 0 or string.find(cod,'13A2') >= 0:
+        grass.run_command('g.region', rast=valfull)
+        grass.run_command('r.null', map=valfull, setnull=0)
+        if string.find(cod, '13Q1') >= 0 or string.find(cod, '13A2') >= 0:
             mapc = "%s.2 = %s / 10000." % (valname, valfull)
-        elif string.find(cod,'11A1') >= 0 or string.find(cod,'11A2') >= 0 or string.find(cod,'11B1') >= 0:
+        elif string.find(cod, '11A1') >= 0 or string.find(cod, '11A2') >= 0 \
+        or string.find(cod, '11B1') >= 0:
             mapc = "%s.2 = (%s * 0.0200) - 273.15" % (valname, valfull)
+        pdb.set_trace()
         grass.mapcalc(mapc)
         if an == 'noqa':
-            #grass.run_command('g.remove', quiet = True, rast = valfull)
+            #grass.run_command('g.remove', quiet=True, rast = valfull)
             try:
-                grass.run_command('g.rename', quiet = True, overwrite = write,
-                                rast=(valname,valname + '.orig'))
-                                rast= (valname + '.2', valname))
+                grass.run_command('g.rename', quiet=True, overwrite=write,
+                                  rast=(valname, valname + '.orig'))
+                                  rast=(valname + '.2', valname))
             except:
                 pass
             metadata(parse, valname, col)
-            metadata(parse, qafull, 'byr')
+            metadata(parse, valname, 'byr')
         if an == 'all':
             if len(qa) != len(val):
-                grass.fatal(_("The number of QA and value maps is different, something is wrong"))
+                grass.fatal(_("The number of QA and value maps is different,"\
+                              " something is wrong"))
             qaname = qa[n]['name']
             qafull = qa[n]['fullname']
             finalmap = "%s.3=if(" % valname
             first_map = 1
-            for key,value in prod['pattern'].iteritems():
+            for key, value in prod['pattern'].iteritems():
                 for v in value:
                     outpat = "%s.%i.%i" % (qaname, key, v)
-                    grass.run_command('r.bitpattern', quiet = True, input = qafull,
-                                    output = outpat, pattern = key, patval= v)
+                    grass.run_command('r.bitpattern', quiet=True, input=valname,
+                                      output=outpat, pattern=key, patval=v)
                     if first_map:
                         first_map = 0
                         finalmap += "%s == 0 " % outpat
                     else:
                         finalmap += "&& %s == 0 " % outpat
                     finalmap += "&& %s.2 <= 1.000" % valname
             finalmap += ",%s.2, null() )" % valname
             # grass.message("mapc finalmap: %s" % finalmap)
+            pdb.set_trace()
             grass.mapcalc(finalmap)
-            #grass.run_command('g.remove', quiet = True, rast=(valname, valname + '.2'))
-            grass.run_command('g.remove', quiet = True, rast=(valname + '.2'))
-            grass.run_command('g.mremove', flags="f", quiet = True,
-			      rast = ("%s.*" % qaname))
+            grass.run_command('g.remove', quiet=True, rast=(valname + '.2'))
+            grass.run_command('g.mremove', flags="f", quiet=True,
+                              rast=("%s.*" % qaname))
                               rast=(valname + '.3', valname))
-def single(options,remove,an,ow):
+def single(options, remove, an, ow):
     """Convert the HDF file to TIF and import it
     listfile, basedir = list_files(options)
     pid = str(os.getpid())
     # for each file
     for i in listfile:
-        # the full path to hdf file
-        hdf = os.path.join(basedir,i)
+        if os.path.exists(i):
+            hdf = i
+        else:
+            # the full path to hdf file
+            hdf = os.path.join(basedir, i)
+            if not os.path.exists(hdf):
+                grass.warning(_("%s not found" % i))
+                continue
         # create conf file fro mrt tools
         pm = parseModis(hdf)
-        confname = confile(pm,options,an)
-        print confname
+        confname = confile(pm, options, an)
         # create convertModis class and convert it in tif file
-        execmodis = convertModis(hdf,confname,options['mrtpath'])
+        execmodis = convertModis(hdf, confname, options['mrtpath'])
         execmodis.run()
         output = prefix(options)
         if not output:
             output = os.path.split(hdf)[1].rstrip('.hdf')
         # import tif files
-        maps_import = import_tif(output,basedir,remove,ow)
+        maps_import = import_tif(output, basedir, remove, ow)
         if an and len(maps_import) != 0:
-            grass.run_command('g.region', save = 'oldregion.%s' % pid)
+            grass.run_command('g.region', save='oldregion.%s' % pid)
             try:
-                analyze(outname, an, cod, pm, ow)
+                analyze(output, an, cod, pm, ow)
             except:
-                grass.run_command('g.region', region = 'oldregion.%s' % pid)
-                grass.run_command('g.remove',quiet = True,
-                    region = 'oldregion.%s' % pid)
-            cod = os.path.split(pm.hdfname)[1].split('.')[0]
-            analyze(output, an, cod, pm, ow)
+                grass.run_command('g.region', region='oldregion.%s' % pid)
+                                  region='oldregion.%s' % pid)
+#            cod = os.path.split(pm.hdfname)[1].split('.')[0]
+#            analyze(output, an, cod, pm, ow)
         #os.remove(confname)
-def mosaic(options,remove,an,ow):
+def mosaic(options, remove, an, ow):
     """Create a daily mosaic of HDF files convert to TIF and import it
-    dictfile, targetdir = list_files(options,True)
+    dictfile, targetdir = list_files(options, True)
     # for each day
     for dat, listfiles in dictfile.iteritems():
         # create the file with the list of name
-        tempfile = open(os.path.join(targetdir,pid),'w')
+        tempfile = open(os.path.join(targetdir, pid), 'w')
         tempfile.writelines(listfiles)
         tempfile.close()
         # basedir of tempfile, where hdf files are write
@@ -404,7 +441,7 @@
                                     listfiles[0].split('/')[-1].split('.')[1])
         # return the spectral subset in according mrtmosaic tool format
         prod = product().fromcode(listfiles[0].split('/')[-1].split('.')[0])
-        spectr = spectral(options,prod,an)
+        spectr = spectral(options, prod, an)
         spectr = spectr.lstrip('( ').rstrip(' )')
         # create mosaic
         cm = createMosaic(tempfile.name, outname, options['mrtpath'], spectr)
@@ -413,26 +450,26 @@
         hdfiles = glob.glob1(basedir, outname + "*.hdf")
         for i in hdfiles:
-            confname = confile(pm,options,an, True)
+            confname = confile(pm, options, an, True)
             execmodis.run()
-            # remove hdf
-            if remove:
+            # remove hdf
+            if remove:
                 # import tif files
                 maps_import = import_tif(outname, basedir, remove, ow)
                 if an:
                     try:
                     except:
                 os.remove(hdf)
                 os.remove(hdf + '.xml')
             # or move the hdf and hdf.xml to the dir where are the original files
@@ -440,23 +477,24 @@
                 # import tif files
                 import_tif(outname, basedir, remove, ow, targetdir)
                     try:
                     except:
-                        grass.run_command('g.remove', region = 'oldregion.%s' % pid)
-                try:
-                    shutil.move(hdf,targetdir)
-                    shutil.move(hdf + '.xml',targetdir)
+                        grass.run_command('g.remove', region='oldregion.%s' % pid)
+                try:
+                    shutil.move(hdf, targetdir)
+                    shutil.move(hdf + '.xml', targetdir)
                 except:
                     pass
             # remove the conf file
             os.remove(confname)
         grass.try_remove(tempfile.name)
-        grass.try_remove(os.path.join(targetdir,'mosaic',pid))
+        grass.try_remove(os.path.join(targetdir, 'mosaic', pid))
 def main():
     # check if you are in GRASS
     gisbase = os.getenv('GISBASE')
@@ -501,9 +539,9 @@
         grass.fatal(_('It is not possible to create a mosaic with a single HDF file'))
         return 0
     elif flags['m']:
-        mosaic(options,remove,analyze,over)
+        mosaic(options, remove, analyze, over)
     else:
-        single(options,remove,analyze,over)
+        single(options, remove, analyze, over)
 if __name__ == "__main__":
     options, flags = grass.parser()
