[GRASS-SVN] r54591 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Fri Jan 11 08:38:02 PST 2013
Author: zarch
Date: 2013-01-11 08:38:02 -0800 (Fri, 11 Jan 2013)
New Revision: 54591
grass/trunk/lib/python/pygrass/vector/geometry.py
Fix reading attribute table for areas
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2013-01-11 16:37:52 UTC (rev 54590)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2013-01-11 16:38:02 UTC (rev 54591)
@@ -112,10 +112,10 @@
class Attrs(object):
- def __init__(self, v_id, table, writable=False):
- self.id = v_id
+ def __init__(self, line, table, writable=False):
+ self.line = line
self.table = table
- self.cond = "%s=%d" % (self.table.key, self.id)
+ self.cond = "%s=%d" % (self.table.key, self.line)
self.writable = writable
def __getitem__(self, key):
@@ -185,6 +185,7 @@
def __init__(self, v_id=None, c_mapinfo=None, c_points=None, c_cats=None,
table=None, writable=False):
self.id = v_id # vector id
+ self.line = self.id
self.c_mapinfo = c_mapinfo
# set c_points
@@ -200,8 +201,8 @@
self.c_cats = c_cats
# set the attributes
- if table and self.id:
- self.attrs = Attrs(self.id, table, writable)
+ if table and self.line:
+ self.attrs = Attrs(self.line, table, writable)
def is_with_topology(self):
if self.c_mapinfo is not None:
@@ -1092,6 +1093,9 @@
self.boundary = self.points()
self.centroid = self.centroid()
self.isles = self.get_isles()
+ libvect.Vect_read_line(self.c_mapinfo, None, self.c_cats,
+ self.centroid.id)
+ self.line = self.c_cats.contents.cat.contents.value
elif boundary and centroid:
self.boundary = boundary
self.centroid = centroid
@@ -1100,6 +1104,11 @@
str_err = "To instantiate an Area you need at least: Boundary and Centroid"
raise GrassError(str_err)
+ # set the attributes
+ if self.attrs.table and self.line:
+ self.attrs.table, self.attrs.writable)
# geometry type
self.gtype = libvect.GV_AREA
