[GRASS-SVN] r54596 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Fri Jan 11 08:38:48 PST 2013
Author: zarch
Date: 2013-01-11 08:38:48 -0800 (Fri, 11 Jan 2013)
New Revision: 54596
grass/trunk/lib/python/pygrass/vector/sql.py
Add SQL insert string
Modified: grass/trunk/lib/python/pygrass/vector/sql.py
--- grass/trunk/lib/python/pygrass/vector/sql.py 2013-01-11 16:38:40 UTC (rev 54595)
+++ grass/trunk/lib/python/pygrass/vector/sql.py 2013-01-11 16:38:48 UTC (rev 54596)
@@ -34,6 +34,7 @@
RENAME_COL = "ALTER TABLE {tname} RENAME COLUMN {old_name} TO {new_name};"
CAST_COL = "ALTER TABLE {tname} ALTER COLUMN {col} SET DATA TYPE {ctype};"
RENAME_TAB = "ALTER TABLE {old_name} RENAME TO {new_name};"
+INSERT = "INSERT INTO {tname} VALUES ({values})"
#SELECT
SELECT = "SELECT {cols} FROM {tname};"
