[GRASS-SVN] r54601 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Fri Jan 11 08:39:39 PST 2013
Author: zarch
Date: 2013-01-11 08:39:38 -0800 (Fri, 11 Jan 2013)
New Revision: 54601
grass/trunk/lib/python/pygrass/vector/__init__.py
Rewrite the write method of the Vector class
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2013-01-11 16:39:26 UTC (rev 54600)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2013-01-11 16:39:38 UTC (rev 54601)
@@ -13,7 +13,6 @@
# import pygrass modules
from pygrass.errors import GrassError, must_be_open
-from pygrass.functions import getenv
import geometry
from abstract import Info
@@ -135,33 +134,68 @@
raise GrassError("Vect_rewind raise an error.")
@must_be_open
- def write(self, geo_obj):
+ def write(self, geo_obj, attrs=None, line=0, layer=None):
+ """Write geometry features and attributes
- >>> mun = Vector('boundary_municp_sqlite') #doctest: +SKIP
- >>> mun.open(mode='rw') #doctest: +SKIP
- >>> feature1 = mun.read(1) #doctest: +SKIP
- >>> feature1 #doctest: +SKIP
- Boundary(v_id=1)
- >>> feature1[:3] #doctest: +SKIP +NORMALIZE_WHITESPACE
- [Point(463718.874987, 310970.844494),
- Point(463707.405987, 310989.499494),
- Point(463714.593986, 311084.281494)]
- >>> from geometry import Point #doctest: +SKIP
- >>> feature1.insert(1, Point(463713.000000, 310980.000000))
- ... #doctest: +SKIP
- >>> feature1[:4] #doctest: +SKIP +NORMALIZE_WHITESPACE
- Point(463713.000000, 310980.000000),
- >>> mun.write(feature1) #doctest: +SKIP
- Boundary(v_id=8708)
- >>> mun.close() #doctest: +SKIP
+ Open a new vector map ::
+ >>> new = VectorTopo('newvect')
+ >>> new.exist()
+ False
+ define the new columns of the attribute table ::
+ >>> cols = [(u'cat', 'INTEGER PRIMARY KEY'),
+ ... (u'name', 'TEXT')]
+ open the vector map in write mode
+ >>> new.open('w', tab_name='newvect', tab_cols=cols)
+ import a geometry feature ::
+ >>> from pygrass.vector.geometry import Point
+ create two points ::
+ >>> point0 = Point(636981.336043, 256517.602235)
+ >>> point1 = Point(637209.083058, 257970.129540)
+ then write the two points on the map, with ::
+ >>> new.write2(point0, ('pub', ))
+ >>> new.write2(point1, ('resturnat', ))
+ close the vector map ::
+ >>> new.close()
+ >>> new.exist()
+ True
+ then play with the map ::
+ >>> new.open()
+ >>> new.read(1)
+ Point(636981.336043, 256517.602235)
+ >>> new.read(2)
+ Point(637209.083058, 257970.129540)
+ >>> new.read(1).attrs['name']
+ u'pub'
+ >>> new.read(2).attrs['cat', 'name']
+ (2, u'resturnat')
+ >>> new.close()
+ >>> new.remove()
+ if layer:
+ table = self.dblinks.by_layer(layer).table()
+ else:
+ table = self.table
+ layer = self.layer
+ line = line if line else table.num_rows() + 1
+ attr = [line, ]
+ attr.extend(attrs)
+ libvect.Vect_cat_set(geo_obj.c_cats, layer, line)
result = libvect.Vect_write_line(self.c_mapinfo, geo_obj.gtype,
geo_obj.c_points, geo_obj.c_cats)
if result == -1:
@@ -173,7 +207,12 @@
# return offset into file where the feature starts (on level 1)
geo_obj.offset = result
+ cur = table.conn.cursor()
+ cur.execute(table.columns.insert_str, attr)
+ table.conn.commit()
+ cur.close()
# VECTOR WITH TOPOLOGY
@@ -204,7 +243,7 @@
return [self.read(indx + 1)
for indx in xrange(*key.indices(len(self)))]
elif isinstance(key, int):
- self.read(key)
+ return self.read(key)
else:
raise ValueError("Invalid argument type: %r." % key)
