[GRASS-SVN] r54610 - grass/trunk/gui/wxpython/web_services
Sun Jan 13 06:54:13 PST 2013
Author: martinl
Date: 2013-01-13 06:54:13 -0800 (Sun, 13 Jan 2013)
New Revision: 54610
   grass/trunk/gui/wxpython/web_services/dialogs.py
   grass/trunk/gui/wxpython/web_services/widgets.py
wxGUI: wms dialog layout cosmetics
Modified: grass/trunk/gui/wxpython/web_services/dialogs.py
--- grass/trunk/gui/wxpython/web_services/dialogs.py	2013-01-12 16:55:42 UTC (rev 54609)
+++ grass/trunk/gui/wxpython/web_services/dialogs.py	2013-01-13 14:54:13 UTC (rev 54610)
@@ -115,6 +115,10 @@
         self.reqDataPanel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.layerNameBox = wx.StaticBox(parent = self.reqDataPanel,
+                                         id = wx.ID_ANY,
+                                         label = _(" Layer Manager Settings "))
         self.layerNameText = wx.StaticText(parent = self.reqDataPanel, id = wx.ID_ANY,
                                            label = _("Output layer name:"))
         self.layerName = wx.TextCtrl(parent = self.reqDataPanel, id = wx.ID_ANY)
@@ -178,10 +182,10 @@
         reqDataSizer = wx.BoxSizer(wx.VERTICAL)
-        layerNameSizer = wx.BoxSizer(wx.HORIZONTAL)
+        layerNameSizer = wx.StaticBoxSizer(self.layerNameBox, wx.HORIZONTAL)
         layerNameSizer.Add(item = self.layerNameText,
-                           flag = wx.ALIGN_CENTER_VERTICAL | wx.RIGHT, border = 5)
+                           flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = 5)
         layerNameSizer.Add(item = self.layerName,
                            flag = wx.EXPAND, proportion = 1)
@@ -405,7 +409,7 @@
             self.Bind(wx.EVT_RADIOBOX, self.OnChooseWs, self.choose_ws_rb)
             self.ch_ws_sizer.Add(item = self.choose_ws_rb,
-                                 flag = wx.TOP | wx.LEFT | wx.RIGHT, border = 5)
+                                 flag = wx.TOP | wx.LEFT | wx.RIGHT | wx.EXPAND, border = 5)
             self._showWsPanel(self.web_service_sel[self.choose_ws_rb.GetSelection()])
             self.statusbar.SetStatusText(_("Connected to <%s>" % self.server.GetValue().strip()))
             for btn in self.run_btns:
@@ -466,7 +470,7 @@
         WSDialogBase._createWidgets(self)
         self.btn_add = wx.Button(parent = self, id = wx.ID_ANY, label = _("&Add layer"))
-        self.btn_add.SetToolTipString(_("Import selected layers"))
+        self.btn_add.SetToolTipString(_("Add selected web service layers as map layer into layer tree"))
         self.btn_add.Enable(False)
         self.run_btns.append(self.btn_add)
@@ -896,7 +900,7 @@
             msg = _('Output map <%s> already exists' % self.output)
         if msg:
-            GWarning(parent = self,
+            GMessage(parent = self,
                      message = msg)
             return
Modified: grass/trunk/gui/wxpython/web_services/widgets.py
--- grass/trunk/gui/wxpython/web_services/widgets.py	2013-01-12 16:55:42 UTC (rev 54609)
+++ grass/trunk/gui/wxpython/web_services/widgets.py	2013-01-13 14:54:13 UTC (rev 54610)
@@ -7,7 +7,7 @@
  - widgets::WSPanel
  - widgets::LayersList
-(C) 2012 by the GRASS Development Team
+(C) 2012-2013 by the GRASS Development Team
 This program is free software under the GNU General Public License
 (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -32,19 +32,16 @@
 from core              import globalvar
 from core.debug        import Debug
-from core.gcmd         import GWarning
+from core.gcmd         import GWarning, GMessage
 from core.gconsole     import CmdThread, EVT_CMD_DONE
-from web_services.cap_interface import WMSCapabilities, \
-                                       WMTSCapabilities, \
-                                       OnEarthCapabilities
+from web_services.cap_interface import WMSCapabilities, WMTSCapabilities, OnEarthCapabilities
 from gui_core.widgets  import GNotebook
 import grass.script as grass
-WMSLibPath = os.path.join(os.getenv("GISBASE"), "etc", "r.in.wms")
-sys.path.append(WMSLibPath)
+sys.path.append(os.path.join(os.getenv("GISBASE"), "etc", "r.in.wms"))
 from wms_base import WMSDriversInfo
@@ -158,11 +155,10 @@
         self.params['srs'] = None
         if 'srs' not in  self.drv_props['ignored_params']:
             projText = wx.StaticText(parent = self.req_page_panel, id = wx.ID_ANY, label = _("Source projection:"))
-            self.params['srs'] =  wx.Choice(parent = self.req_page_panel, id = wx.ID_ANY, pos = wx.DefaultPosition,
-                                            choices = [], style = wx.RA_SPECIFY_COLS)
+            self.params['srs'] =  wx.Choice(parent = self.req_page_panel, id = wx.ID_ANY, style = wx.RA_SPECIFY_COLS)
         self.list.Bind(wx.EVT_TREE_SEL_CHANGED, self.OnListSelChanged)
         # layout
         self.req_page_sizer = wx.BoxSizer(wx.VERTICAL)
@@ -170,24 +166,24 @@
         layersSizer.Add(item = self.list, proportion = 1,
                         flag = wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border = 5)
         self.req_page_sizer.Add(item = layersSizer, proportion = 1,
+        self.source_sizer = wx.BoxSizer(wx.HORIZONTAL)
         if self.params['format'] is not None:
-            self.req_page_sizer.Add(item = self.params['format'],
-                                flag = wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
+            self.source_sizer.Add(item = self.params['format'],
+                                  flag = wx.LEFT | wx.RIGHT | wx.BOTTOM, border = 5)
-        projSizer = wx.BoxSizer(wx.HORIZONTAL)
         if self.params['srs'] is not None:
-            projSizer.Add(item = projText, flag = wx.ALIGN_CENTER_VERTICAL)
-            projSizer.Add(item = self.params['srs'])
-        self.req_page_sizer.Add(item = projSizer,
+            self.source_sizer.Add(item = projText, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = 5)
+            self.source_sizer.Add(item = self.params['srs'],
+                                  flag = wx.ALIGN_CENTER_VERTICAL | wx.RIGHT | wx.TOP | wx.BOTTOM, border = 5)
+        self.req_page_sizer.Add(item = self.source_sizer,
         self.req_page_panel.SetSizer(self.req_page_sizer)
     def enableButtons(self, enable = True):
@@ -751,9 +747,9 @@
                                                  label = _("Source image format"), pos = wx.DefaultPosition,
                                                  choices = formats_list,  majorDimension = 4,
-            self.req_page_sizer.Insert(item = self.params['format'], before = 2,
+            self.source_sizer.Insert(item = self.params['format'], before = 2,
     def _getFormats(self, layer = None):
         """!Get formats
@@ -795,11 +791,11 @@
             show_war = True
         if not self.o_layer_name:
-            warning_str += _("Insert output layer name.\n")
+            warning_str += _("Choose output layer name.\n")
             show_war = True
         if show_war:
-            GWarning(parent = self.parent,
+            GMessage(parent = self.parent,
                      message = warning_str)
             return False
