[GRASS-SVN] r54615 - grass-addons/grass7/raster/r.agent/libagent
svn_grass at osgeo.org
Sun Jan 13 09:47:41 PST 2013
Author: mic
Date: 2013-01-13 09:47:40 -0800 (Sun, 13 Jan 2013)
New Revision: 54615
grass-addons/grass7/raster/r.agent/libagent/grassland.py
write documentation first
Modified: grass-addons/grass7/raster/r.agent/libagent/grassland.py
--- grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-13 17:20:11 UTC (rev 54614)
+++ grass-addons/grass7/raster/r.agent/libagent/grassland.py 2013-01-13 17:47:40 UTC (rev 54615)
@@ -21,23 +21,54 @@
raise error.DataError("r.agent::libagent.playground.Playground()",
"Only square raster cells make sense.")
def getregion(self):
- """Return the region information"""
+ Return the region information
+ @return dict region
return self.region
def getbound(self, bound):
- """Return the requested boundary, takes: 'n', 's', 'w', or 'e'"""
+ Return the requested bound, takes: 'n', 's', 'w', or 'e'
+ @param string bound
+ @return float the outermost coordinate
if bound == "n" or bound == "s" or bound == "w" or bound == "e":
return self.region[bound]
def setlayer(self, layername, layer, force=False):
- """Put an existing map from GRASS to the layer collection"""
+ Put an existing map layer to the layer collection
+ @param string name of the layer
+ @param list a map layer
+ @param boolean optional, whether to overwrite values if key exists
pass
- def createlayer(self, layername, grassmap=False):
- """Create a new layer and add it to the layer collection"""
+ def setgrasslayer(self, layername, grassmapname, force=False):
+ Put an existing map from GRASS to the layer collection
+ @param string name of a GRASS map layer
pass
+ def createlayer(self, layername, grassmapname=False):
+ Create a new layer and add it to the layer collection
+ @param string name of a GRASS map layer or False if layer is only local
+ pass
def getlayer(self, layername):
- """Return a layer from the collection by its name"""
+ Return a layer from the collection by its name
+ @return list the requested map layer
return []
def removelayer(self, layername):
- """Remove the layer named from the layer collection"""
+ Remove (forget about) the layer named from the layer collection
pass
# def writelayer(self, layername):
# pass
