[GRASS-SVN] r54618 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Sun Jan 13 10:02:40 PST 2013
Author: martinl
Date: 2013-01-13 10:02:39 -0800 (Sun, 13 Jan 2013)
New Revision: 54618
grass/trunk/gui/wxpython/gui_core/dialogs.py
wxGUI: remove 'command dialog' btn from import/link dialogs
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py 2013-01-13 18:02:05 UTC (rev 54617)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py 2013-01-13 18:02:39 UTC (rev 54618)
@@ -1670,10 +1670,6 @@
self.btn_run.SetDefault()
self.btn_run.Enable(False)
self.btn_run.Bind(wx.EVT_BUTTON, self.OnRun)
- # run command dialog
- self.btn_cmd = wx.Button(parent = self.panel, id = wx.ID_ANY,
- label = _("Command dialog"))
- self.btn_cmd.Bind(wx.EVT_BUTTON, self.OnCmdDialog)
def doLayout(self):
"""!Do layout"""
@@ -1715,10 +1711,6 @@
btnsizer = wx.BoxSizer(orient = wx.HORIZONTAL)
- btnsizer.Add(item = self.btn_cmd, proportion = 0,
- flag = wx.RIGHT | wx.ALIGN_CENTER,
- border = 10)
btnsizer.Add(item = self.btn_close, proportion = 0,
flag = wx.LEFT | wx.RIGHT | wx.ALIGN_CENTER,
border = 10)
@@ -1756,10 +1748,6 @@
"""!Import/Link data (each layes as separate vector map)"""
pass
- def OnCmdDialog(self, event):
- """!Show command dialog"""
- pass
def AddLayers(self, returncode, cmd = None):
"""!Add imported/linked layers into layer tree"""
if not self.add.IsChecked() or returncode != 0:
@@ -1841,17 +1829,9 @@
if link:
self.btn_run.SetLabel(_("&Link"))
self.btn_run.SetToolTipString(_("Link selected layers"))
- if ogr:
- self.btn_cmd.SetToolTipString(_('Open %s dialog') % 'v.external')
- else:
- self.btn_cmd.SetToolTipString(_('Open %s dialog') % 'r.external')
else:
self.btn_run.SetLabel(_("&Import"))
self.btn_run.SetToolTipString(_("Import selected layers"))
- if ogr:
- self.btn_cmd.SetToolTipString(_('Open %s dialog') % 'v.in.ogr')
- else:
- self.btn_cmd.SetToolTipString(_('Open %s dialog') % 'r.in.gdal')
self.doLayout()
@@ -1939,11 +1919,6 @@
return 'r.in.gdal'
return ''
- name = self._getCommand()
- GUI(parent = self, modal = False).ParseCommand(cmd = [name])
class GdalOutputDialog(wx.Dialog):
def __init__(self, parent, id = wx.ID_ANY, ogr = False,
@@ -1969,9 +1944,6 @@
self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
# buttons
- self.btnCmd = wx.Button(parent = self.panel, id = wx.ID_ANY,
- self.btnCmd.Bind(wx.EVT_BUTTON, self.OnCmdDialog)
self.btnCancel = wx.Button(parent = self.panel, id = wx.ID_CANCEL)
self.btnCancel.SetToolTipString(_("Close dialog"))
self.btnOk = wx.Button(parent = self.panel, id = wx.ID_OK)
@@ -1995,9 +1967,6 @@
flag = wx.EXPAND)
btnSizer = wx.BoxSizer(orient = wx.HORIZONTAL)
- btnSizer.Add(item = self.btnCmd, proportion = 0,
- border = 10)
btnSizer.Add(item = self.btnCancel, proportion = 0,
border = 10)
@@ -2018,9 +1987,6 @@
self.SetSize((size.width, size.height))
self.Layout()
- GUI(parent = self, modal = True).ParseCommand(cmd = ['v.external.out'])
def OnCancel(self, event):
self.Destroy()
@@ -2121,11 +2087,7 @@
self.btn_run.Enable(True)
else:
- GUI(parent = self, modal = True).ParseCommand(cmd = ['v.in.dxf'])
class LayersList(GListCtrl, listmix.TextEditMixin):
"""!List of layers to be imported (dxf, shp...)"""
def __init__(self, parent, columns, log = None):
