[GRASS-SVN] r54627 - grass/trunk/mswindows
svn_grass at osgeo.org
Mon Jan 14 04:20:24 PST 2013
Author: martinl
Date: 2013-01-14 04:20:24 -0800 (Mon, 14 Jan 2013)
New Revision: 54627
grass/trunk/mswindows/FileAssociation.nsh
fix svn prop (eol)
Modified: grass/trunk/mswindows/FileAssociation.nsh
--- grass/trunk/mswindows/FileAssociation.nsh 2013-01-14 12:12:24 UTC (rev 54626)
+++ grass/trunk/mswindows/FileAssociation.nsh 2013-01-14 12:20:24 UTC (rev 54627)
@@ -1,190 +1,190 @@
-_____________________________________________________________________________
- File Association
- Based on code taken from http://nsis.sourceforge.net/File_Association
- Usage in script:
- 1. !include "FileAssociation.nsh"
- 2. [Section|Function]
- ${FileAssociationFunction} "Param1" "Param2" "..." $var
- [SectionEnd|FunctionEnd]
- FileAssociationFunction=[RegisterExtension|UnRegisterExtension]
- ${RegisterExtension} "[executable]" "[extension]" "[description]"
-"[executable]" ; executable which opens the file format
-"[extension]" ; extension, which represents the file format to open
-"[description]" ; description for the extension. This will be display in Windows Explorer.
- ${UnRegisterExtension} "[extension]" "[description]"
- Macros
- Change log window verbosity (default: 3=no script)
- Example:
- !include "FileAssociation.nsh"
- !insertmacro RegisterExtension
- ${FileAssociation_VERBOSE} 4 # all verbosity
- !insertmacro UnRegisterExtension
- ${FileAssociation_VERBOSE} 3 # no script
-!ifndef FileAssociation_INCLUDED
-!define FileAssociation_INCLUDED
-!include Util.nsh
-!verbose push
-!verbose 3
-!ifndef _FileAssociation_VERBOSE
- !define _FileAssociation_VERBOSE 3
-!endif
-!verbose ${_FileAssociation_VERBOSE}
-!define FileAssociation_VERBOSE `!insertmacro FileAssociation_VERBOSE`
-!verbose pop
-!macro FileAssociation_VERBOSE _VERBOSE
- !verbose push
- !verbose 3
- !undef _FileAssociation_VERBOSE
- !define _FileAssociation_VERBOSE ${_VERBOSE}
- !verbose pop
-!macroend
-!macro RegisterExtensionCall _EXECUTABLE _EXTENSION _DESCRIPTION
- !verbose push
- !verbose ${_FileAssociation_VERBOSE}
- Push `${_DESCRIPTION}`
- Push `${_EXTENSION}`
- Push `${_EXECUTABLE}`
- ${CallArtificialFunction} RegisterExtension_
- !verbose pop
-!macroend
-!macro UnRegisterExtensionCall _EXTENSION _DESCRIPTION
- !verbose push
- ${CallArtificialFunction} UnRegisterExtension_
- !verbose pop
-!macroend
-!define RegisterExtension `!insertmacro RegisterExtensionCall`
-!define un.RegisterExtension `!insertmacro RegisterExtensionCall`
-!macroend
-!macro un.RegisterExtension
-!macroend
-!macro RegisterExtension_
- !verbose push
- Exch $R2 ;exe
- Exch
- Exch $R1 ;ext
- Exch
- Exch 2
- Exch $R0 ;desc
- Exch 2
- Push $0
- Push $1
- ReadRegStr $1 HKCR $R1 "" ; read current file association
- StrCmp "$1" "" NoBackup ; is it empty
- StrCmp "$1" "$R0" NoBackup ; is it our own
- WriteRegStr HKCR $R1 "backup_val" "$1" ; backup current value
-NoBackup:
- WriteRegStr HKCR $R1 "" "$R0" ; set our file association
- ReadRegStr $0 HKCR $R0 ""
- StrCmp $0 "" 0 Skip
- WriteRegStr HKCR "$R0" "" "$R0"
- WriteRegStr HKCR "$R0\shell" "" "open"
- WriteRegStr HKCR "$R0\DefaultIcon" "" "$R2,0"
-Skip:
- WriteRegStr HKCR "$R0\shell\open\command" "" '"$R2" "%1"'
- WriteRegStr HKCR "$R0\shell\edit" "" "Edit $R0"
- WriteRegStr HKCR "$R0\shell\edit\command" "" '"$R2" "%1"'
- Pop $1
- Pop $0
- Pop $R2
- Pop $R1
- Pop $R0
- !verbose pop
-!macroend
-!define UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
-!define un.UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
-!macroend
-!macro un.UnRegisterExtension
-!macroend
-!macro UnRegisterExtension_
- !verbose push
- Exch $R1 ;desc
- Exch
- Exch $R0 ;ext
- Exch
- Push $0
- Push $1
- ReadRegStr $1 HKCR $R0 ""
- StrCmp $1 $R1 0 NoOwn ; only do this if we own it
- ReadRegStr $1 HKCR $R0 "backup_val"
- StrCmp $1 "" 0 Restore ; if backup="" then delete the whole key
- DeleteRegKey HKCR $R0
- Goto NoOwn
-Restore:
- WriteRegStr HKCR $R0 "" $1
- DeleteRegValue HKCR $R0 "backup_val"
- DeleteRegKey HKCR $R1 ;Delete key with association name settings
-NoOwn:
- Pop $1
- Pop $0
- Pop $R1
- Pop $R0
- !verbose pop
-!macroend
-!endif # !FileAssociation_INCLUDED
+_____________________________________________________________________________
+ File Association
+ Based on code taken from http://nsis.sourceforge.net/File_Association
+ Usage in script:
+ 1. !include "FileAssociation.nsh"
+ 2. [Section|Function]
+ ${FileAssociationFunction} "Param1" "Param2" "..." $var
+ [SectionEnd|FunctionEnd]
+ FileAssociationFunction=[RegisterExtension|UnRegisterExtension]
+ ${RegisterExtension} "[executable]" "[extension]" "[description]"
+"[executable]" ; executable which opens the file format
+"[extension]" ; extension, which represents the file format to open
+"[description]" ; description for the extension. This will be display in Windows Explorer.
+ ${UnRegisterExtension} "[extension]" "[description]"
+ Macros
+ Change log window verbosity (default: 3=no script)
+ Example:
+ !include "FileAssociation.nsh"
+ !insertmacro RegisterExtension
+ ${FileAssociation_VERBOSE} 4 # all verbosity
+ !insertmacro UnRegisterExtension
+ ${FileAssociation_VERBOSE} 3 # no script
+!ifndef FileAssociation_INCLUDED
+!define FileAssociation_INCLUDED
+!include Util.nsh
+!verbose push
+!verbose 3
+!ifndef _FileAssociation_VERBOSE
+ !define _FileAssociation_VERBOSE 3
+!endif
+!verbose ${_FileAssociation_VERBOSE}
+!define FileAssociation_VERBOSE `!insertmacro FileAssociation_VERBOSE`
+!verbose pop
+!macro FileAssociation_VERBOSE _VERBOSE
+ !verbose push
+ !verbose 3
+ !undef _FileAssociation_VERBOSE
+ !define _FileAssociation_VERBOSE ${_VERBOSE}
+ !verbose pop
+!macroend
+!macro RegisterExtensionCall _EXECUTABLE _EXTENSION _DESCRIPTION
+ !verbose push
+ !verbose ${_FileAssociation_VERBOSE}
+ Push `${_DESCRIPTION}`
+ Push `${_EXTENSION}`
+ Push `${_EXECUTABLE}`
+ ${CallArtificialFunction} RegisterExtension_
+ !verbose pop
+!macroend
+!macro UnRegisterExtensionCall _EXTENSION _DESCRIPTION
+ !verbose push
+ ${CallArtificialFunction} UnRegisterExtension_
+ !verbose pop
+!macroend
+!define RegisterExtension `!insertmacro RegisterExtensionCall`
+!define un.RegisterExtension `!insertmacro RegisterExtensionCall`
+!macroend
+!macro un.RegisterExtension
+!macroend
+!macro RegisterExtension_
+ !verbose push
+ Exch $R2 ;exe
+ Exch
+ Exch $R1 ;ext
+ Exch
+ Exch 2
+ Exch $R0 ;desc
+ Exch 2
+ Push $0
+ Push $1
+ ReadRegStr $1 HKCR $R1 "" ; read current file association
+ StrCmp "$1" "" NoBackup ; is it empty
+ StrCmp "$1" "$R0" NoBackup ; is it our own
+ WriteRegStr HKCR $R1 "backup_val" "$1" ; backup current value
+NoBackup:
+ WriteRegStr HKCR $R1 "" "$R0" ; set our file association
+ ReadRegStr $0 HKCR $R0 ""
+ StrCmp $0 "" 0 Skip
+ WriteRegStr HKCR "$R0" "" "$R0"
+ WriteRegStr HKCR "$R0\shell" "" "open"
+ WriteRegStr HKCR "$R0\DefaultIcon" "" "$R2,0"
+Skip:
+ WriteRegStr HKCR "$R0\shell\open\command" "" '"$R2" "%1"'
+ WriteRegStr HKCR "$R0\shell\edit" "" "Edit $R0"
+ WriteRegStr HKCR "$R0\shell\edit\command" "" '"$R2" "%1"'
+ Pop $1
+ Pop $0
+ Pop $R2
+ Pop $R1
+ Pop $R0
+ !verbose pop
+!macroend
+!define UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
+!define un.UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
+!macroend
+!macro un.UnRegisterExtension
+!macroend
+!macro UnRegisterExtension_
+ !verbose push
+ Exch $R1 ;desc
+ Exch
+ Exch $R0 ;ext
+ Exch
+ Push $0
+ Push $1
+ ReadRegStr $1 HKCR $R0 ""
+ StrCmp $1 $R1 0 NoOwn ; only do this if we own it
+ ReadRegStr $1 HKCR $R0 "backup_val"
+ StrCmp $1 "" 0 Restore ; if backup="" then delete the whole key
+ DeleteRegKey HKCR $R0
+ Goto NoOwn
+Restore:
+ WriteRegStr HKCR $R0 "" $1
+ DeleteRegValue HKCR $R0 "backup_val"
+ DeleteRegKey HKCR $R1 ;Delete key with association name settings
+NoOwn:
+ Pop $1
+ Pop $0
+ Pop $R1
+ Pop $R0
+ !verbose pop
+!macroend
+!endif # !FileAssociation_INCLUDED
Property changes on: grass/trunk/mswindows/FileAssociation.nsh
Added: svn:eol-style
+ native
