[GRASS-SVN] r54662 - grass/trunk/scripts/r.in.wms
svn_grass at osgeo.org
Wed Jan 16 02:13:21 PST 2013
Author: martinl
Date: 2013-01-16 02:13:20 -0800 (Wed, 16 Jan 2013)
New Revision: 54662
grass/trunk/scripts/r.in.wms/wms_cap_parsers.py
grass/trunk/scripts/r.in.wms/wms_drv.py
r.in.wms: fix importing ParseError (patch by Stepan Turek)
Modified: grass/trunk/scripts/r.in.wms/wms_cap_parsers.py
--- grass/trunk/scripts/r.in.wms/wms_cap_parsers.py 2013-01-16 10:03:03 UTC (rev 54661)
+++ grass/trunk/scripts/r.in.wms/wms_cap_parsers.py 2013-01-16 10:13:20 UTC (rev 54662)
@@ -16,6 +16,10 @@
@author Stepan Turek <stepan.turek seznam.cz> (Mentor: Martin Landa)
+try:
+ from xml.etree.ElementTree import ParseError
+except ImportError: # < Python 2.7
+ from xml.parsers.expat import ExpatError as ParseError
import xml.etree.ElementTree as etree
import grass.script as grass
@@ -26,13 +30,13 @@
try:
etree.ElementTree.__init__(self, file = cap_file)
- except etree.ParseError:
- raise etree.ParseError(_("Unable to parse XML file"))
+ except ParseError:
+ raise ParseError(_("Unable to parse XML file"))
except IOError as error:
- raise etree.ParseError(_("Unabble to open XML file '%s'.\n%s\n" % (cap_file, error)))
+ raise ParseError(_("Unable to open XML file '%s'.\n%s\n" % (cap_file, error)))
if self.getroot() is None:
- raise etree.ParseError(_("Root node was not found."))
+ raise ParseError(_("Root node was not found."))
class WMSXMLNsHandler:
def __init__(self, caps):
@@ -45,8 +49,8 @@
elif caps.getroot().find(self.namespace + "Service") is not None:
self.use_ns = True
else:
- raise etree.ParseError(_("Unable to parse capabilities file.\n\
- Tag <%s> was not found.") % "Service")
+ raise ParseError(_("Unable to parse capabilities file.\n\
+ Tag <%s> was not found.") % "Service")
def Ns(self, tag_name):
"""!Add namespace to tag_name according to version
@@ -74,8 +78,8 @@
grass.debug('Checking WMS capabilities tree.', 4)
if not "version" in self.getroot().attrib:
- raise etree.ParseError(_("Missing version attribute root node "
- "in Capabilities XML file"))
+ raise ParseError(_("Missing version attribute root node "
+ "in Capabilities XML file"))
else:
wms_version = self.getroot().attrib["version"]
@@ -86,7 +90,7 @@
if force_version is not None:
if wms_version != force_version:
- raise etree.ParseError(_("WMS server does not support '%s' version.") % wms_version)
+ raise ParseError(_("WMS server does not support '%s' version.") % wms_version)
capability = self._find(self.getroot(), "Capability")
root_layer = self._find(capability, "Layer")
@@ -220,8 +224,8 @@
res = etreeElement.find(self.xml_ns.Ns(tag))
if res is None:
- raise etree.ParseError(_("Unable to parse capabilities file. \n\
- Tag <%s> was not found.") % tag)
+ raise ParseError(_("Unable to parse capabilities file. \n\
+ Tag <%s> was not found.") % tag)
return res
@@ -232,8 +236,8 @@
res = etreeElement.findall(self.xml_ns.Ns(tag))
if not res:
return res
@@ -462,8 +466,8 @@
res = etreeElement.find(ns(tag))
if res is None:
- Tag '%s' was not found.") % tag)
+ Tag '%s' was not found.") % tag)
return res
@@ -477,8 +481,8 @@
res = etreeElement.findall(ns(tag))
if not res:
return res
@@ -531,8 +535,8 @@
res = etreeElement.find(tag)
if res is None:
- raise etree.ParseError(_("Unable to parse tile service file. \n\
+ raise ParseError(_("Unable to parse tile service file. \n\
return res
Modified: grass/trunk/scripts/r.in.wms/wms_drv.py
--- grass/trunk/scripts/r.in.wms/wms_drv.py 2013-01-16 10:03:03 UTC (rev 54661)
+++ grass/trunk/scripts/r.in.wms/wms_drv.py 2013-01-16 10:13:20 UTC (rev 54662)
@@ -30,8 +30,11 @@
from math import pi, floor
from urllib2 import HTTPError
from httplib import HTTPException
-from xml.etree.ElementTree import ParseError
+try:
from wms_base import WMSBase
from wms_cap_parsers import WMTSCapabilitiesTree, OnEarthCapabilitiesTree
