[GRASS-SVN] r54708 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Sat Jan 19 05:39:27 PST 2013
Author: martinl
Date: 2013-01-19 05:39:26 -0800 (Sat, 19 Jan 2013)
New Revision: 54708
grass/trunk/lib/vector/Vlib/build.c
vlib: improve doxygen docs for Vect_topo_check()
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c 2013-01-19 09:29:05 UTC (rev 54707)
+++ grass/trunk/lib/vector/Vlib/build.c 2013-01-19 13:39:26 UTC (rev 54708)
@@ -574,8 +574,12 @@
\brief Extensive tests for correct topology
+ - lines or boundaries of zero length
+ - intersecting boundaries, ie. overlapping areas
+ - areas without centroids that are not isles
\param Map vector map
- \param[out] Err vector map where errors will be written
+ \param[out] Err vector map where errors will be written or NULL
\return 1 on success
\return 0 on error
@@ -587,6 +591,7 @@
struct line_pnts *Points;
struct line_cats *Cats;
+ /* rebuild topology if needed */
if (Vect_get_built(Map) != GV_BUILD_ALL) {
Vect_build_partial(Map, GV_BUILD_NONE);
Vect_build(Map);
@@ -597,12 +602,12 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
- /* boundaries of zero length */
+ /* lines or boundaries of zero length */
n_zero_lines = n_zero_boundaries = 0;
nlines = Vect_get_num_lines(Map);
for (line = 1; line <= nlines; line++) {
int type;
if (!Vect_line_alive(Map, line))
continue;
@@ -625,6 +630,7 @@
if (n_zero_lines)
G_warning(_("Number of lines of length zero: %d"), n_zero_lines);
if (n_zero_boundaries)
@@ -639,7 +645,7 @@
if (nerrors)
G_warning(_("Number of boundary intersections: %d"), nerrors);
- /* areas without centroids that are not holes
+ /* areas without centroids that are not isles
* only makes sense if all boundaries are correct */
nerrors = 0;
