[GRASS-SVN] r54710 - grass-addons/grass7/raster/r.hants
svn_grass at osgeo.org
Sat Jan 19 07:14:31 PST 2013
Author: mmetz
Date: 2013-01-19 07:14:30 -0800 (Sat, 19 Jan 2013)
New Revision: 54710
grass-addons/grass7/raster/r.hants/main.c
grass-addons/grass7/raster/r.hants/r.hants.html
r.hants update manual, prepare for amplitude and phase
Modified: grass-addons/grass7/raster/r.hants/main.c
--- grass-addons/grass7/raster/r.hants/main.c 2013-01-19 13:40:03 UTC (rev 54709)
+++ grass-addons/grass7/raster/r.hants/main.c 2013-01-19 15:14:30 UTC (rev 54710)
@@ -135,14 +135,15 @@
struct output *outputs = NULL;
char *suffix;
struct History history;
- DCELL *values = NULL, *rc = NULL;
+ DCELL *values = NULL, *rc = NULL, *amp = NULL, *phase = NULL;
int nrows, ncols;
int row, col;
double lo, hi, fet, *cs, *sn, *ts, delta;
int bl;
double **mat, **mat_t, **A, *za, *zr, maxerrlo, maxerrhi;
int dod, nf, nr, nout, noutmax;
- int rejlo, rejhi, *useval, dumped;
+ int rejlo, rejhi, *useval;
+ int do_amp_phase, dumped;
G_gisinit(argv[0]);
@@ -375,6 +376,12 @@
rc = G_malloc(num_inputs * sizeof(DCELL));
useval = G_malloc(num_inputs * sizeof(int));
+ do_amp_phase = 0;
+ if (do_amp_phase) {
+ amp = G_malloc((nf + 1) * sizeof(DCELL));
+ phase = G_malloc((nf + 1) * sizeof(DCELL));
if (parm.ts->answer) {
for (i = 0; parm.ts->answers[i]; i++);
if (i != num_inputs)
@@ -394,8 +401,17 @@
nr = num_inputs;
noutmax = num_inputs - nr - dod;
+ if (noutmax < 0)
+ G_fatal_error(_("For %d input maps and %d frequencies, "
+ "the degree of overdetermination can not be larger than %d"),
+ num_inputs, nf, dod + noutmax);
- /* are the dimensions correct ? */
+ if (noutmax == 0)
+ G_warning(_("Missing values can not be reconstructed, "
+ "please reduce either '%s' or '%s'"),
+ parm.nf->key, parm.dod->key);
mat = G_alloc_matrix(nr, num_inputs);
mat_t = G_alloc_matrix(num_inputs, nr);
A = G_alloc_matrix(nr, nr);
@@ -579,7 +595,7 @@
* dump original and approximated values for one cell to stdout */
if (non_null >= 20 && done == 1 && !dumped &&
row > nrows / 3 && col > ncols / 2 ) {
-#if 0
+#if 1
for (i = 0; i < num_inputs; i++) {
fprintf(stdout, "%g;%g\n", values[i], rc[i]);
@@ -587,20 +603,20 @@
dumped = 1;
-#if 0
- /* amplitude and phase */
- amp[0] = zr[0];
- phase[0] = 0;
- for (i = 1; i < nr; i += 2) {
- int ifr = (i + 1) / 2;
- double angle = atan2(zr[i + 1], zr[i]) * 180 / M_PI;
+ /* amplitude and phase */
+ amp[0] = zr[0];
+ phase[0] = 0;
+ for (i = 1; i < nr; i += 2) {
+ int ifr = (i + 1) / 2;
+ double angle = atan2(zr[i + 1], zr[i]) * 180 / M_PI;
- if (angle < 0)
- angle += 360;
- phase[ifr] = angle;
- amp[ifr] = sqrt(zr[i] * zr[i] + zr[i + 1] * zr[i + 1]);
+ if (angle < 0)
+ angle += 360;
+ phase[ifr] = angle;
+ amp[ifr] = sqrt(zr[i] * zr[i] + zr[i + 1] * zr[i + 1]);
-#endif
else {
for (i = 0; i < num_outputs; i++) {
Modified: grass-addons/grass7/raster/r.hants/r.hants.html
--- grass-addons/grass7/raster/r.hants/r.hants.html 2013-01-19 13:40:03 UTC (rev 54709)
+++ grass-addons/grass7/raster/r.hants/r.hants.html 2013-01-19 15:14:30 UTC (rev 54710)
@@ -2,8 +2,9 @@
<em>r.hants</em> performs a harmonic analysis of time series in order to
estimate missing values and identify outliers. For each input map, an
-output map with the suffix <em>_hants</em> is created.
+output map with the suffix <em>suffix</em> (default: _hants) is created.
+<p>
The option <b>nf</b>, number of frequencies, should be carefully chosen.
Different numbers of frequencies should be tested first on a small test
region before running the module on the full region. As a rule of thumb,
@@ -13,7 +14,13 @@
analysing one year. If two peaks are assumed per year, the number of
frequencies should be at least 5 when analysing one year.
+<p>The number of frequencies should also not be too large. With a large
+number of frequencies, outliers can not longer be identified because the
+fit is "too good", outliers can be represented by the estimate.
+The number of frequencies should also be smaller than <em>n input maps / 2</em>
+if missing values should be reconstructed.
<h2>NOTES</h2>
<p>
