[GRASS-SVN] r54720 - grass/trunk/lib/gis
Sun Jan 20 10:06:57 PST 2013
Author: wenzeslaus
Date: 2013-01-20 10:06:56 -0800 (Sun, 20 Jan 2013)
New Revision: 54720
   grass/trunk/lib/gis/area.c
libgis: noting necessary call in documentation
Modified: grass/trunk/lib/gis/area.c
--- grass/trunk/lib/gis/area.c	2013-01-20 17:19:29 UTC (rev 54719)
+++ grass/trunk/lib/gis/area.c	2013-01-20 18:06:56 UTC (rev 54720)
@@ -148,7 +148,10 @@
  * planimetric grids.  If the units for <i>x,y</i> are meters, then
  * the area is in square meters.  If the units are feet, then the area
  * is in square feet, and so on.
+ * You should call G_begin_polygon_area_calculations() function before
+ * calling this function.
  * <b>Note:</b> If the database is planimetric with the non-meter grid,
  * this routine performs the required unit conversion to produce square
  * meters.
