[GRASS-SVN] r54723 - in grass-addons/grass6/vector: . v.flip
svn_grass at osgeo.org
Sun Jan 20 11:49:43 PST 2013
Author: msieczka
Date: 2013-01-20 11:49:43 -0800 (Sun, 20 Jan 2013)
New Revision: 54723
Added:
grass-addons/grass6/vector/v.flip/
grass-addons/grass6/vector/v.flip/Makefile
grass-addons/grass6/vector/v.flip/description.html
grass-addons/grass6/vector/v.flip/v.flip
Submitting v.flip addon shell script.
Added: grass-addons/grass6/vector/v.flip/Makefile
--- grass-addons/grass6/vector/v.flip/Makefile (rev 0)
+++ grass-addons/grass6/vector/v.flip/Makefile 2013-01-20 19:49:43 UTC (rev 54723)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.flip
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass6/vector/v.flip/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass-addons/grass6/vector/v.flip/description.html
--- grass-addons/grass6/vector/v.flip/description.html (rev 0)
+++ grass-addons/grass6/vector/v.flip/description.html 2013-01-20 19:49:43 UTC (rev 54723)
@@ -0,0 +1,31 @@
+<h2>DESCRIPTION</h2>
+<em>v.flip</em> is a Bourne Shell and Awk script. The <b>output</b> vector map contains all lines that have a category in the given <b>layer</b> of the <b>input</b> vector map. Lines specified in <b>cat</b> have their direction flipped.
+<p>
+The input layer number and category numbers are preserved in the output. If a datatable is attatched to the input vector map's layer, it will be copied under the output vector map's name and connected to the output vector map, in the same database where the input layer's table is stored.
+<h2>NOTES</h2>
+<ul>
+ 1. Requires GRASS 6.x.<br>
+ 2. Only lines with categories will be flipped. Use <b>v.category</b> to adjust category assignment first, if needed.
+</ul>
+<em>v.flip</em> was tested only in <em>metric</em> Locations. I can't guarantee it will work properly
+in <em>latlong</em> or <em>unprojected xy</em> Locations, as <B>v.clean</B> is used internally
+with a fixed snapping distance of <B><em>0.0001</em></B> for connecting flipped and non-flipped lines.
+<h2>SEE ALSO</h2>
+<em>
+ <a href="v.category.html">v.category</a>,
+ <a href="v.clean.html">v.clean</a>
+</em>
+<h2>AUTHOR</h2>
+Maciej Sieczka
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass-addons/grass6/vector/v.flip/description.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass-addons/grass6/vector/v.flip/v.flip
--- grass-addons/grass6/vector/v.flip/v.flip (rev 0)
+++ grass-addons/grass6/vector/v.flip/v.flip 2013-01-20 19:49:43 UTC (rev 54723)
@@ -0,0 +1,207 @@
+#!/bin/sh
+# MODULE: v.flip
+# AUTHOR(S): Maciej Sieczka
+# PURPOSE: Flip direction of selected vector lines.
+# VERSION: 1.7, developed over Grass 6.1 CVS 2006.05.19
+# COPYRIGHT: (c) 2006 Maciej Sieczka
+# NOTES: This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# CHANGELOG:
+# 1.6, 2006.05.19:
+# - first public release
+# 1.7, 2007.01.30:
+# - cosmetics
+#%Module
+#% description: Flip direction of selected vector lines.
+#%END
+#%option
+#% key: input
+#% type: string
+#% gisprompt: old,vector,vector
+#% description: Input vector name
+#% required : yes
+#%END
+#%option
+#% key: layer
+#% type: string
+#% description: Input's layer containing lines to be flipped
+#% required : yes
+#%END
+#%option
+#% key: cat
+#% type: string
+#% description: Category ranges of lines to be flipped (e.g. 1,3-8,13)
+#% required : yes
+#%END
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new,dig,vector
+#% description: Output vector name
+#% required : yes
+#%END
+# called from Grass?
+if [ -z "$GISBASE" ]; then
+ echo "ERROR: You must be in GRASS GIS to run this program." >&2
+ exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ]; then
+ exec g.parser "$0" "$@"
+fi
+PROG=`basename $0`
+# check if we have awk
+if [ ! -x "`which awk`" ] ; then
+ g.message -e '"awk" executable required but not found' 2>&1
+ exit 1
+fi
+# set environment so that awk works properly in all languages
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+# set up temporary files
+TMP="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+ g.message -e 'Unable to create temporary files' 1>&2
+ exit 1
+fi
+cleanup() {
+ rm -f $TMP $TMP.${PROG} $TMP.${PROG}.flip $TMP.${PROG}.meta $TMP.${PROG}.data $TMP.${PROG}.head $TMP.${PROG}.cat_toflip $TMP.${PROG}.cat_all $TMP.${PROG}.cat_asis $TMP.${PROG}.cat_asis_short $TMP.${PROG}.start_stop
+# what to do in case of user break:
+exitprocedure() {
+ g.message -w 'User break!'
+ cleanup
+# shell check for user break (signal list: trap -l)
+trap "exitprocedure" 2 3 15
+INPUT="$GIS_OPT_INPUT"
+OUTPUT="$GIS_OPT_OUTPUT"
+CAT="$GIS_OPT_CAT"
+LAYER="$GIS_OPT_LAYER"
+for i in toflip leaveasis flipped patched; do
+ g.findfile elem=vector file=${OUTPUT}_$i > /dev/null
+ if [ $? -eq 0 ] ; then
+ g.message -e "Intermediate vector <${OUTPUT}_$i> already exists" 1>&2
+ exit 1
+ fi
+done
+### DO IT ###
+# is a table connected to the given layer?
+v.db.connect -p layer=$LAYER map=$INPUT >/dev/null 2>&1
+CNCTSTAT=$?
+if [ "$CNCTSTAT" -eq "0" ]; then
+ # extract the database connection settings of the input vector
+ cnct=`v.db.connect -g layer=$LAYER map=$INPUT`
+ tbl=`echo $cnct | cut -d " " -f2`
+ key=`echo $cnct | cut -d " " -f3`
+ dbs=`echo $cnct | cut -d " " -f4`
+ drv=`echo $cnct | cut -d " " -f5`
+fi
+# extract lines to be reverted into separate vector
+v.extract -t layer=$LAYER input=$INPUT list=$CAT output="${OUTPUT}_toflip" > /dev/null
+#transform it to ascii for reverting lines
+v.out.ascii input="${OUTPUT}_toflip" format=standard > $TMP.${PROG}.flip
+# get categories of lines NOT to be reverted
+v.category layer=$LAYER input="${OUTPUT}_toflip" option=print > $TMP.${PROG}.cat_toflip
+v.category layer=$LAYER input=$INPUT option=print > $TMP.${PROG}.cat_all
+cat $TMP.${PROG}.cat_toflip $TMP.${PROG}.cat_all | sort -n | uniq -u > $TMP.${PROG}.cat_asis
+# translate long category list like "1,2,3,...,100" to "1-100"
+# (to avoid hitting the 4096 chars Bash variable limit)
+awk '
+{if (NR==1) {prev=$1; print}
+ else {if ($1==prev+1) {foll="-"$1}
+ else {print foll; print ","$1; foll=""}
+prev=$1}
+END {print foll}
+' $TMP.${PROG}.cat_asis | grep . > $TMP.${PROG}.cat_asis_short
+asis=`cat $TMP.${PROG}.cat_asis_short`
+asis=`echo $asis | sed 's/ //g'`
+# extract lines NOT to be reverted into a separate vector
+v.extract -t layer=$LAYER input=$INPUT list=$asis output="${OUTPUT}_leaveasis" > /dev/null
+# extract header from to-be-reverted vector (for later patching)
+awk '(NR<11)' $TMP.${PROG}.flip > $TMP.${PROG}.head
+# extract vector type, number of lines and categories (for later patching)
+awk '
+{if ((NR>10) && ($1=="L") || ($1=='$LAYER')) {print} else if (NR>10) {print""}}
+' $TMP.${PROG}.flip > $TMP.${PROG}.meta
+# get starting and ending lines of each line feature
+awk '
+($1 == "L") {print FNR+1","$2+FNR}
+' $TMP.${PROG}.flip > $TMP.${PROG}.start_stop
+# pipe vertices into a file...
+for a in `cat $TMP.${PROG}.start_stop`; do
+ echo >> $TMP.${PROG}.data
+ # ...reverting lines at the same time (tac)
+ cat $TMP.${PROG}.flip | sed -n "$a p" | tac >> $TMP.${PROG}.data
+ # empty echoes are to make empty lines where needed
+done
+# merge header, data and meta into final, reverted ascii vector
+paste -d '' $TMP.${PROG}.data $TMP.${PROG}.meta >> $TMP.${PROG}.head
+echo
+v.in.ascii input=$TMP.${PROG}.head output="${OUTPUT}_flipped" format=standard > /dev/null
+# patch reverted and left-as-is, clean to snap nodes
+v.patch input="${OUTPUT}_leaveasis","${OUTPUT}_flipped" output="${OUTPUT}_patched" > /dev/null
+echo
+v.clean input="${OUTPUT}_patched" output=$OUTPUT type=line tool=snap thresh=0.0001 > /dev/null
+echo
+### ALL DONE ###
+cleanup
+g.remove vect="${OUTPUT}_toflip","${OUTPUT}_leaveasis","${OUTPUT}_flipped","${OUTPUT}_patched" > /dev/null
+ # copy the original table using the OUTPUT vector name, and connect to the OUTPUT
+ db.copy from_driver=$drv from_database=$dbs from_table=$tbl to_driver=$drv to_database=$dbs to_table=$OUTPUT > /dev/null
+ v.db.connect map=$OUTPUT layer=$LAYER driver=$drv database=$dbs table=$OUTPUT key=$key > /dev/null
+fi
+echo
Property changes on: grass-addons/grass6/vector/v.flip/v.flip
Added: svn:executable
+ text/x-sh
+ native
