[GRASS-SVN] r54751 - in grass/trunk: lib/python/temporal temporal temporal/t.info temporal/t.list temporal/t.rast.extract temporal/t.rast.list temporal/t.rast.mapcalc temporal/t.rast3d.list temporal/t.rast3d.mapcalc temporal/t.sample temporal/t.vect.db.select temporal/t.vect.list temporal/t.vect.univar
svn_grass at osgeo.org
Tue Jan 22 05:44:09 PST 2013
Author: huhabla
Date: 2013-01-22 05:44:08 -0800 (Tue, 22 Jan 2013)
New Revision: 54751
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/unit_tests.py
grass/trunk/temporal/t.info/t.info.html
grass/trunk/temporal/t.list/t.list.html
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
grass/trunk/temporal/t.rast.list/t.rast.list.py
grass/trunk/temporal/t.rast.list/test.t.rast.list.sh
grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
grass/trunk/temporal/t.rast3d.list/test.t.rast3d.list.sh
grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
grass/trunk/temporal/t.sample/t.sample.py
grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
grass/trunk/temporal/t.vect.list/t.vect.list.py
grass/trunk/temporal/t.vect.list/test.t.vect.list.layer.sh
grass/trunk/temporal/t.vect.list/test.t.vect.list.sh
grass/trunk/temporal/t.vect.univar/t.vect.univar.py
grass/trunk/temporal/temporalintro.html
Using "separator" instead of "fs". Relative time fixes and doc update.
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/lib/python/temporal/extract.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -241,8 +241,8 @@
start, end, tz = old_map.get_absolute_time()
new_map.set_absolute_time(start, end, tz)
else:
- start, end = old_map.get_relative_time()
- new_map.set_relative_time(start, end)
+ start, end, unit = old_map.get_relative_time()
+ new_map.set_relative_time(start, end, unit)
# Insert map in temporal database
new_map.insert(dbif)
Modified: grass/trunk/lib/python/temporal/unit_tests.py
--- grass/trunk/lib/python/temporal/unit_tests.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/lib/python/temporal/unit_tests.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -613,7 +613,7 @@
end = start + fact
map = RasterDataset(None)
- map.set_relative_time(start, end)
+ map.set_relative_time(start, end, "years")
maps.append(map)
gran = round(compute_relative_time_granularity(maps))
@@ -632,7 +632,7 @@
end = start * fact
if count % 2 == 0:
else:
map.set_relative_time(start, None)
maps.append(map)
@@ -653,7 +653,7 @@
for i in range(10):
point = (i + 1) * fact * start
- map.set_relative_time(point, None)
+ map.set_relative_time(point, None, years)
maps.append(map)
gran = round(compute_relative_time_granularity(maps) * 86400)
Modified: grass/trunk/temporal/t.info/t.info.html
--- grass/trunk/temporal/t.info/t.info.html 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.info/t.info.html 2013-01-22 13:44:08 UTC (rev 54751)
@@ -10,7 +10,7 @@
to report detailed informations about raster, 3D raster and vector maps, since
not all map specific informations and metadata are stored in the temporal database.
<p>
-In addition informations about the chosen temporal database backend can be reported.
+In addition, informations about the chosen temporal database backend can be reported.
<h2>EXAMPLE</h2>
Modified: grass/trunk/temporal/t.list/t.list.html
--- grass/trunk/temporal/t.list/t.list.html 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.list/t.list.html 2013-01-22 13:44:08 UTC (rev 54751)
@@ -1,6 +1,14 @@
<h2>DESCRIPTION</h2>
-TBD.
+<em>t.list</em> lists any dataset that is registered in the temporal database.
+Datasets are raster, 3D raster and vector maps as well as their
+corresponding space time datasets (STRDS, STR3DS and STVDS). The type of the dataset
+can be specified using the <em>type</em> option, default is STRDS. By default all datasets with
+relative and absolute time are listed. However, the user has the ability to specify
+a single temporal type with the <em>temporaltype</em> option.
+The user can define the columns that should
+be printed for each dataset and the order of the datasets. In addition a SQL WHERE statement can
+be specified to select a subset of the requested datasets.
<h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.list/t.list.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -66,9 +66,9 @@
#%end
#%option
-#% key: fs
+#% key: separator
#% type: string
-#% description: The field separator character between the columns, default is tabular "\t"
+#% description: Separator character between the columns, default is tabular "\t"
#% guisection: Formatting
#% required: no
#%end
@@ -93,7 +93,7 @@
columns = options["columns"]
order = options["order"]
where = options["where"]
- separator = options["fs"]
+ separator = options["separator"]
colhead = flags['c']
# Make sure the temporal database exists
Modified: grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
--- grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh 2013-01-22 13:44:08 UTC (rev 54751)
@@ -23,7 +23,7 @@
t.info type=strds input=precip_abs2
t.rast.extract --o --v -n input=precip_abs1 output=precip_abs3 where="start_time > '2001-06-01'" \
- expression=" if(precip_abs1 at PERMANENT > 400, precip_abs1 at PERMANENT, null())" base=new_prec nprocs=4
+ expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=4
t.info type=strds input=precip_abs3
t.rast.extract --o --v input=precip_abs1 output=precip_abs4 where="start_time > '2001-06-01'"
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.py
--- grass/trunk/temporal/t.rast.list/t.rast.list.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -59,9 +59,9 @@
#%end
#%option
-#% key: fs
+#% key: separator
#% type: string
-#% description: Field separator character between the columns, default is tabular "\t"
#% required: no
#%end
@@ -83,7 +83,7 @@
method = options["method"]
header = flags["h"]
Modified: grass/trunk/temporal/t.rast.list/test.t.rast.list.sh
--- grass/trunk/temporal/t.rast.list/test.t.rast.list.sh 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.rast.list/test.t.rast.list.sh 2013-01-22 13:44:08 UTC (rev 54751)
@@ -69,49 +69,49 @@
# The @test
t.register type=rast --o -i input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
-t.rast.list fs=" | " method=comma input=precip_abs0
+t.rast.list separator=" | " method=comma input=precip_abs0
t.rast.list -h input=precip_abs0
-t.rast.list -h fs=" | " method=cols input=precip_abs0
-t.rast.list -h fs=" | " method=delta input=precip_abs0
-t.rast.list -h fs=" | " method=deltagaps input=precip_abs0
-t.rast.list -h fs=" | " method=gran input=precip_abs0
+t.rast.list -h separator=" | " method=cols input=precip_abs0
+t.rast.list -h separator=" | " method=delta input=precip_abs0
+t.rast.list -h separator=" | " method=deltagaps input=precip_abs0
+t.rast.list -h separator=" | " method=gran input=precip_abs0
t.register type=rast --o input=precip_abs0 file="${n1}" start="2001-01-01" increment="1 months"
# ERROR: no interval time
t.register type=rast --o -i input=precip_abs0 file="${n2}"
t.register type=rast --o -i input=precip_abs0 file="${n3}"
t.register type=rast --o -i input=precip_abs0 file="${n4}"
t.register type=rast --o -i input=precip_abs0 file="${n5}"
t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.remove type=strds input=precip_abs0
Modified: grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
--- grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh 2013-01-22 13:44:08 UTC (rev 54751)
@@ -17,7 +17,7 @@
t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-t.register type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.register --o type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.info precip_abs1
t.info precip_abs2
@@ -29,17 +29,17 @@
t.rast.mapcalc --o --v -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
- expression=" (precip_abs1 + precip_abs2) / precip_abs3 at PERMANENT " base=new_prec \
+ expression=" (precip_abs1 + precip_abs2) / precip_abs2" base=new_prec \
method=equal nprocs=5
t.info type=strds input=precip_abs4
t.rast.mapcalc --o --v -s inputs=precip_abs1,precip_abs2 output=precip_abs4 \
- expression=" (precip_abs1 + precip_abs2) * null() " base=new_prec \
+ expression=" (precip_abs1 + precip_abs2) * null()" base=new_prec \
t.rast.mapcalc --o --v -sn inputs=precip_abs1,precip_abs2 output=precip_abs4 \
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -59,9 +59,9 @@
#%end
#%option
-#% key: fs
+#% key: separator
#% type: string
-#% description: Field separator character between the output columns, default is tabular "\t"
+#% description: Separator character between the output columns, default is tabular "\t"
#% required: no
#%end
@@ -83,7 +83,7 @@
header = flags["h"]
Modified: grass/trunk/temporal/t.rast3d.list/test.t.rast3d.list.sh
--- grass/trunk/temporal/t.rast3d.list/test.t.rast3d.list.sh 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.rast3d.list/test.t.rast3d.list.sh 2013-01-22 13:44:08 UTC (rev 54751)
@@ -72,35 +72,35 @@
# The first @test
t.register type=rast3d input=volume_abs1 file="${n1}" start="2001-01-01" increment="1 months"
-t.rast3d.list fs=" | " method=comma input=volume_abs1
+t.rast3d.list separator=" | " method=comma input=volume_abs1
t.rast3d.list -h input=volume_abs1
-t.rast3d.list -h fs=" | " method=cols input=volume_abs1
-t.rast3d.list -h fs=" | " method=delta input=volume_abs1
-t.rast3d.list -h fs=" | " method=deltagaps input=volume_abs1
+t.rast3d.list -h separator=" | " method=cols input=volume_abs1
+t.rast3d.list -h separator=" | " method=delta input=volume_abs1
+t.rast3d.list -h separator=" | " method=deltagaps input=volume_abs1
t.register -i type=rast3d input=volume_abs2 file="${n2}"
-t.rast3d.list fs=" | " method=comma input=volume_abs2
+t.rast3d.list separator=" | " method=comma input=volume_abs2
t.rast3d.list -h input=volume_abs2
-t.rast3d.list -h fs=" | " method=cols input=volume_abs2
-t.rast3d.list -h fs=" | " method=delta input=volume_abs2
-t.rast3d.list -h fs=" | " method=deltagaps input=volume_abs2
+t.rast3d.list -h separator=" | " method=cols input=volume_abs2
+t.rast3d.list -h separator=" | " method=delta input=volume_abs2
+t.rast3d.list -h separator=" | " method=deltagaps input=volume_abs2
t.register -i type=rast3d input=volume_abs3 file="${n3}"
-t.rast3d.list fs=" | " method=comma input=volume_abs3
-t.rast3d.list -h fs=" | " method=delta input=volume_abs3
-t.rast3d.list -h fs=" | " method=deltagaps input=volume_abs3
+t.rast3d.list separator=" | " method=comma input=volume_abs3
+t.rast3d.list -h separator=" | " method=delta input=volume_abs3
+t.rast3d.list -h separator=" | " method=deltagaps input=volume_abs3
t.register -i type=rast3d input=volume_abs4 file="${n4}"
-t.rast3d.list fs=" | " method=comma input=volume_abs4
-t.rast3d.list -h fs=" | " method=delta input=volume_abs4
-t.rast3d.list -h fs=" | " method=deltagaps input=volume_abs4
+t.rast3d.list separator=" | " method=comma input=volume_abs4
+t.rast3d.list -h separator=" | " method=delta input=volume_abs4
+t.rast3d.list -h separator=" | " method=deltagaps input=volume_abs4
t.register -i type=rast3d input=volume_abs5 file="${n5}"
-t.rast3d.list fs=" | " method=comma input=volume_abs5
+t.rast3d.list separator=" | " method=comma input=volume_abs5
t.rast3d.list -h input=volume_abs5
-t.rast3d.list -h fs=" | " method=cols input=volume_abs5
-t.rast3d.list -h fs=" | " method=delta input=volume_abs5
-t.rast3d.list -h fs=" | " method=deltagaps input=volume_abs5
+t.rast3d.list -h separator=" | " method=cols input=volume_abs5
+t.rast3d.list -h separator=" | " method=delta input=volume_abs5
+t.rast3d.list -h separator=" | " method=deltagaps input=volume_abs5
t.unregister type=rast3d maps=vol_1,vol_2,vol_3,vol_4,vol_5,vol_6
t.remove type=str3ds input=volume_abs1,volume_abs2,volume_abs3,volume_abs4,volume_abs5
Modified: grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh
--- grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.rast3d.mapcalc/test.t.rast3d.mapcalc.sh 2013-01-22 13:44:08 UTC (rev 54751)
@@ -16,7 +16,7 @@
t.create --o type=str3ds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
t.create --o type=str3ds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
t.register -i type=rast3d input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-t.register type=rast3d input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.register --o type=rast3d input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
t.info type=str3ds input=precip_abs1
t.info type=str3ds input=precip_abs2
@@ -28,7 +28,7 @@
t.info type=str3ds input=precip_abs3
t.rast3d.mapcalc --o --v -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
method=equal nprocs=6
t.info type=str3ds input=precip_abs4
Modified: grass/trunk/temporal/t.sample/t.sample.py
--- grass/trunk/temporal/t.sample/t.sample.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.sample/t.sample.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -45,9 +45,9 @@
#%end
#%option
-#% key: fs
+#% key: separator
#% type: string
-#% description: Field separator character between the output columns, default is tabular " | ". Do not use "," as this char is reserved to list several map ids in a sample granule
+#% description: Separator character between the output columns, default is tabular " | ". Do not use "," as this char is reserved to list several map ids in a sample granule
#% required: no
#%end
@@ -75,7 +75,7 @@
sampler = options["sample"]
samtype = options["samtype"]
intype = options["intype"]
header = flags["c"]
spatial = flags["s"]
Modified: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py
--- grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.vect.db.select/t.vect.db.select.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -30,9 +30,9 @@
#%end
#%option
-#% key: fs
+#% key: separator
#% type: string
#% required: no
#% answer: |
#%end
@@ -62,7 +62,7 @@
tempwhere = options["t_where"]
layer = options["layer"]
- fs = options["fs"]
+ fs = options["separator"]
if where == "" or where == " " or where == "\n":
where = None
Modified: grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh
--- grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.vect.db.select/test.t.vect.db.select.sh 2013-01-22 13:44:08 UTC (rev 54751)
@@ -22,8 +22,8 @@
t.vect.observe.strds input=prec strds=precip_abs1 output=prec_observer vector=prec_observer column=observation
t.vect.list input=prec_observer
t.vect.db.select input=prec_observer
-t.vect.db.select input=prec_observer where="cat = 1" fs=" | "
-t.vect.db.select input=prec_observer where="cat = 1" fs=" | " columns=observation
+t.vect.db.select input=prec_observer where="cat = 1" separator=" | "
+t.vect.db.select input=prec_observer where="cat = 1" separator=" | " columns=observation
# Time instances
t.register --o input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2004-01-01 00:00:00" increment="3 months"
@@ -31,7 +31,7 @@
t.vect.observe.strds --o input=prec strds=precip_abs1 output=prec_observer vector=prec_observer
# @postprocess
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.py
--- grass/trunk/temporal/t.vect.list/t.vect.list.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -58,9 +58,9 @@
#%end
#%option
-#% key: fs
+#% key: separator
#% type: string
#% required: no
#%end
@@ -82,7 +82,7 @@
header = flags["h"]
Modified: grass/trunk/temporal/t.vect.list/test.t.vect.list.layer.sh
--- grass/trunk/temporal/t.vect.list/test.t.vect.list.layer.sh 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.vect.list/test.t.vect.list.layer.sh 2013-01-22 13:44:08 UTC (rev 54751)
@@ -86,35 +86,35 @@
# The first @test
t.register type=vect --o input=soils_abs1 file="${n1}" start="2001-01-01" increment="1 months"
-t.vect.list fs=" | " method=comma input=soils_abs1
+t.vect.list separator=" | " method=comma input=soils_abs1
t.vect.list -h input=soils_abs1
-t.vect.list -h fs=" | " method=cols input=soils_abs1
-t.vect.list -h fs=" | " method=delta input=soils_abs1
-t.vect.list -h fs=" | " method=deltagaps input=soils_abs1
+t.vect.list -h separator=" | " method=cols input=soils_abs1
+t.vect.list -h separator=" | " method=delta input=soils_abs1
+t.vect.list -h separator=" | " method=deltagaps input=soils_abs1
t.register type=vect --o -i input=soils_abs2 file="${n2}"
-t.vect.list fs=" | " method=comma input=soils_abs2
+t.vect.list separator=" | " method=comma input=soils_abs2
t.vect.list -h input=soils_abs2
-t.vect.list -h fs=" | " method=cols input=soils_abs2
-t.vect.list -h fs=" | " method=delta input=soils_abs2
-t.vect.list -h fs=" | " method=deltagaps input=soils_abs2
+t.vect.list -h separator=" | " method=cols input=soils_abs2
+t.vect.list -h separator=" | " method=delta input=soils_abs2
+t.vect.list -h separator=" | " method=deltagaps input=soils_abs2
t.register type=vect --o -i input=soils_abs3 file="${n3}"
-t.vect.list fs=" | " method=comma input=soils_abs3
-t.vect.list -h fs=" | " method=delta input=soils_abs3
-t.vect.list -h fs=" | " method=deltagaps input=soils_abs3
+t.vect.list separator=" | " method=comma input=soils_abs3
+t.vect.list -h separator=" | " method=delta input=soils_abs3
+t.vect.list -h separator=" | " method=deltagaps input=soils_abs3
t.register type=vect --o -i input=soils_abs4 file="${n4}"
-t.vect.list fs=" | " method=comma input=soils_abs4
-t.vect.list -h fs=" | " method=delta input=soils_abs4
-t.vect.list -h fs=" | " method=deltagaps input=soils_abs4
+t.vect.list separator=" | " method=comma input=soils_abs4
+t.vect.list -h separator=" | " method=delta input=soils_abs4
+t.vect.list -h separator=" | " method=deltagaps input=soils_abs4
t.register type=vect --o -i input=soils_abs5 file="${n5}"
-t.vect.list fs=" | " method=comma input=soils_abs5
+t.vect.list separator=" | " method=comma input=soils_abs5
t.vect.list -h input=soils_abs5
-t.vect.list -h fs=" | " method=cols input=soils_abs5
-t.vect.list -h fs=" | " method=delta input=soils_abs5
-t.vect.list -h fs=" | " method=deltagaps input=soils_abs5
+t.vect.list -h separator=" | " method=cols input=soils_abs5
+t.vect.list -h separator=" | " method=delta input=soils_abs5
+t.vect.list -h separator=" | " method=deltagaps input=soils_abs5
t.unregister type=vect maps=soils:1,soils:2,soils:3,soils:4,soils:5,soils:6
t.remove type=stvds input=soils_abs1,soils_abs2,soils_abs3,soils_abs4,soils_abs5
Modified: grass/trunk/temporal/t.vect.list/test.t.vect.list.sh
--- grass/trunk/temporal/t.vect.list/test.t.vect.list.sh 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.vect.list/test.t.vect.list.sh 2013-01-22 13:44:08 UTC (rev 54751)
@@ -72,35 +72,35 @@
# The first @test
t.register --o type=vect input=lidar_abs1 file="${n1}" start="2001-01-01" increment="1 months"
-t.vect.list fs=" | " method=comma input=lidar_abs1
+t.vect.list separator=" | " method=comma input=lidar_abs1
t.vect.list -h input=lidar_abs1
-t.vect.list -h fs=" | " method=cols input=lidar_abs1
-t.vect.list -h fs=" | " method=delta input=lidar_abs1
-t.vect.list -h fs=" | " method=deltagaps input=lidar_abs1
+t.vect.list -h separator=" | " method=cols input=lidar_abs1
+t.vect.list -h separator=" | " method=delta input=lidar_abs1
+t.vect.list -h separator=" | " method=deltagaps input=lidar_abs1
t.register --o type=vect -i input=lidar_abs2 file="${n2}"
-t.vect.list fs=" | " method=comma input=lidar_abs2
+t.vect.list separator=" | " method=comma input=lidar_abs2
t.vect.list -h input=lidar_abs2
-t.vect.list -h fs=" | " method=cols input=lidar_abs2
-t.vect.list -h fs=" | " method=delta input=lidar_abs2
-t.vect.list -h fs=" | " method=deltagaps input=lidar_abs2
+t.vect.list -h separator=" | " method=cols input=lidar_abs2
+t.vect.list -h separator=" | " method=delta input=lidar_abs2
+t.vect.list -h separator=" | " method=deltagaps input=lidar_abs2
t.register --o type=vect -i input=lidar_abs3 file="${n3}"
-t.vect.list fs=" | " method=comma input=lidar_abs3
-t.vect.list -h fs=" | " method=delta input=lidar_abs3
-t.vect.list -h fs=" | " method=deltagaps input=lidar_abs3
+t.vect.list separator=" | " method=comma input=lidar_abs3
+t.vect.list -h separator=" | " method=delta input=lidar_abs3
+t.vect.list -h separator=" | " method=deltagaps input=lidar_abs3
t.register --o type=vect -i input=lidar_abs4 file="${n4}"
-t.vect.list fs=" | " method=comma input=lidar_abs4
-t.vect.list -h fs=" | " method=delta input=lidar_abs4
-t.vect.list -h fs=" | " method=deltagaps input=lidar_abs4
+t.vect.list separator=" | " method=comma input=lidar_abs4
+t.vect.list -h separator=" | " method=delta input=lidar_abs4
+t.vect.list -h separator=" | " method=deltagaps input=lidar_abs4
t.register --o type=vect -i input=lidar_abs5 file="${n5}"
-t.vect.list fs=" | " method=comma input=lidar_abs5
+t.vect.list separator=" | " method=comma input=lidar_abs5
t.vect.list -h input=lidar_abs5
-t.vect.list -h fs=" | " method=cols input=lidar_abs5
-t.vect.list -h fs=" | " method=delta input=lidar_abs5
-t.vect.list -h fs=" | " method=deltagaps input=lidar_abs5
+t.vect.list -h separator=" | " method=cols input=lidar_abs5
+t.vect.list -h separator=" | " method=delta input=lidar_abs5
+t.vect.list -h separator=" | " method=deltagaps input=lidar_abs5
t.unregister type=vect maps=lidar_1,lidar_2,lidar_3,lidar_4,lidar_5,lidar_6
t.remove type=stvds input=lidar_abs1,lidar_abs2,lidar_abs3,lidar_abs4,lidar_abs5
Modified: grass/trunk/temporal/t.vect.univar/t.vect.univar.py
--- grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2013-01-22 13:44:08 UTC (rev 54751)
@@ -45,9 +45,9 @@
#%end
#%option
-#% key: fs
+#% key: separator
#% type: string
#% required: no
#% answer: |
#%end
Modified: grass/trunk/temporal/temporalintro.html
--- grass/trunk/temporal/temporalintro.html 2013-01-22 13:26:19 UTC (rev 54750)
+++ grass/trunk/temporal/temporalintro.html 2013-01-22 13:44:08 UTC (rev 54751)
@@ -21,6 +21,7 @@
<ul>
<li><a href="t.connect.html">t.connect</a></li>
<li><a href="t.create.html">t.create</a></li>
+ <li><a href="t.rename.html">t.rename</a></li>
<li><a href="t.remove.html">t.remove</a></li>
<li><a href="t.register.html">t.register</a></li>
<li><a href="t.unregister.html">t.unregister</a></li>
@@ -36,7 +37,7 @@
Space time datasets are stored in a temporal database. SQLite3 or
PostgreSQL are supported as SQL database back end.
Connection settings are performed with <a href="t.connect.html">t.connect</a>.
-<!-- todo: really always PERMANENT? -->
+<!-- todo: really always PERMANENT? -> Yes thats the default that can be modified -->
As default a sqlite3 database will be created in the PERMANENT mapset that
stores all space time datasets and registered time series maps from all
mapsets in the location.
@@ -50,11 +51,15 @@
from the temporal database. Use <a href="t.support.html">t.support</a>
to modify the metadata of space time datasets or to update the metadata
that is derived from registered maps. This module also checks for removed
-and modified maps and updates the space time datasets accordingly.
+and modified maps and updates the space time datasets accordingly.
+You can rename a space time dataset with <a href="t.rename.html">t.rename</a>.
<p>
The module <a href="t.register.html">t.register</a> was designed to
register raster, 3D raster and vector maps in the temporal database and
-optionally in a space time dataset.
+optionally in a space time dataset. It supports different input options. Maps
+to register can be provided as a comma separated string on the command line, or
+in an input file. The module supports the definition of time stamps
+(time instances or intervals) for each map in the input file.
With <a href="t.unregister.html">t.unregister</a> maps can be unregistered
from space time datasets or the temporal database.
<p>
