[GRASS-SVN] r54760 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Wed Jan 23 05:51:31 PST 2013
Author: mmetz
Date: 2013-01-23 05:51:30 -0800 (Wed, 23 Jan 2013)
New Revision: 54760
grass/trunk/lib/vector/Vlib/ascii.c
Vlib: fix buffer overflow and column handling for ascii export
Modified: grass/trunk/lib/vector/Vlib/ascii.c
--- grass/trunk/lib/vector/Vlib/ascii.c 2013-01-23 06:18:02 UTC (rev 54759)
+++ grass/trunk/lib/vector/Vlib/ascii.c 2013-01-23 13:51:30 UTC (rev 54760)
@@ -26,7 +26,7 @@
static int srch(const void *, const void *);
static int check_cat(const struct line_cats *, const struct cat_list *,
const int *, int);
-static void free_col_arrays(int *, char *, char**);
+static void free_col_arrays(int *, char *, char **);
\brief Read data in GRASS ASCII vector format
@@ -329,7 +329,8 @@
dbString dbstring;
dbColumn *Column;
dbValue *Value;
- char buf[2000];
+ char *buf;
+ size_t bufsize;
dbCursor cursor;
/* columns */
char **columns;
@@ -345,14 +346,14 @@
G_zero(&value, sizeof(dbValue));
db_init_string(&dbstring);
- /* TODO: free memory allocated by G_asprintf(),
- * this is a bad memory leak */
xstring = NULL;
ystring = NULL;
zstring = NULL;
xsize = 0;
ysize = 0;
zsize = 0;
+ buf = NULL;
+ bufsize = 0;
/* get the region */
G_get_window(&window);
@@ -404,21 +405,35 @@
ncols = db_get_table_number_of_columns(Table);
/* key column skipped */
columns = (char **) G_malloc(ncols * sizeof(char *));
- icol = i = 0;
+ icol = 0;
for (i = 0; i < ncols; i++) {
col_name = db_get_column_name(db_get_table_column(Table, i));
- if (strcmp(Fi->key, col_name) == 0)
- continue;
- columns[icol++] = G_store(col_name);
+ if (strcmp(Fi->key, col_name) != 0)
+ columns[icol++] = G_store(col_name);
- columns[ncols-1] = NULL;
+ columns[ncols - 1] = NULL;
db_zero_string(&dbstring);
db_free_table(Table);
Table = NULL;
else {
- columns = (char **)column_names;
+ int icol, ncols;
+ const char *col_name;
+ ncols = 0;
+ while (column_names[ncols])
+ ncols++;
+ columns = (char **) G_malloc((ncols + 1) * sizeof(char *));
+ icol = 0;
+ for (i = 0; i < ncols; i++) {
+ col_name = column_names[i];
+ /* key column skipped */
+ columns[icol] = NULL;
/* selected columns only */
@@ -450,7 +465,7 @@
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
ACats = Vect_new_cats_struct();
@@ -631,7 +646,7 @@
/* print attributes */
if (columns) {
- sprintf(buf, "SELECT %s FROM %s WHERE %s = %d",
+ G_rasprintf(&buf, &bufsize, "SELECT %s FROM %s WHERE %s = %d",
all_columns, Fi->table, Fi->key, fcats->value[0]);
G_debug(2, "SQL: %s", buf);
db_set_string(&dbstring, buf);
@@ -769,6 +784,7 @@
if (format == GV_ASCII_FORMAT_WKT) {
/* process areas - topology required */
int i, area, nareas, isle, nisles;
if (Vect_level(Map) < 2) {
G_warning(_("Topology not available, unable to process areas"));
nareas = 0;
@@ -872,14 +888,14 @@
/* free column arrays, see Vect_write_ascii() */
-void free_col_arrays(int *coltypes, char *all_columns, char**columns)
+void free_col_arrays(int *coltypes, char *all_columns, char **columns)
G_free(coltypes);
G_free(all_columns);
if (columns) {
- int i;
- i = 0;
- while(columns[i])
+ int i = 0;
+ while (columns[i])
G_free(columns[i++]);
G_free(columns);
