[GRASS-SVN] r54771 - in grass/trunk/demolocation/PERMANENT: . vector/mysites vector/point
svn_grass at osgeo.org
Sat Jan 26 05:13:23 PST 2013
Author: mmetz
Date: 2013-01-26 05:13:23 -0800 (Sat, 26 Jan 2013)
New Revision: 54771
Added:
grass/trunk/demolocation/PERMANENT/vector/mysites/sidx
grass/trunk/demolocation/PERMANENT/vector/point/sidx
grass/trunk/demolocation/PERMANENT/VAR
grass/trunk/demolocation/PERMANENT/vector/mysites/topo
grass/trunk/demolocation/PERMANENT/vector/point/topo
update demolocation for trunk
Modified: grass/trunk/demolocation/PERMANENT/VAR
--- grass/trunk/demolocation/PERMANENT/VAR 2013-01-26 11:49:49 UTC (rev 54770)
+++ grass/trunk/demolocation/PERMANENT/VAR 2013-01-26 13:13:23 UTC (rev 54771)
@@ -1,2 +1,2 @@
-DB_DRIVER: dbf
-DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
+DB_DRIVER: sqlite
+DB_DATABASE: $GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db
Added: grass/trunk/demolocation/PERMANENT/vector/mysites/sidx
(Binary files differ)
Property changes on: grass/trunk/demolocation/PERMANENT/vector/mysites/sidx
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: grass/trunk/demolocation/PERMANENT/vector/mysites/topo
Added: grass/trunk/demolocation/PERMANENT/vector/point/sidx
Property changes on: grass/trunk/demolocation/PERMANENT/vector/point/sidx
Modified: grass/trunk/demolocation/PERMANENT/vector/point/topo
