[GRASS-SVN] r54773 - grass-addons/grass6/vector/v.strahler/v.strahler
Sat Jan 26 08:21:33 PST 2013
Author: neteler
Date: 2013-01-26 08:21:32 -0800 (Sat, 26 Jan 2013)
New Revision: 54773
   grass-addons/grass6/vector/v.strahler/v.strahler/helper.c
   grass-addons/grass6/vector/v.strahler/v.strahler/main.c
fix missing Box initialization; fix comment in comment
Modified: grass-addons/grass6/vector/v.strahler/v.strahler/helper.c
--- grass-addons/grass6/vector/v.strahler/v.strahler/helper.c	2013-01-26 15:22:36 UTC (rev 54772)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/helper.c	2013-01-26 16:21:32 UTC (rev 54773)
@@ -14,6 +14,7 @@
     if (sloppy != 0.0) {
 	Vect_get_node_coor(In, node, &x, &y, NULL);
+	Vect_get_map_box(In, Box);
 	Box->N = y + sloppy;
 	Box->S = y - sloppy;
 	Box->W = x + sloppy;
Modified: grass-addons/grass6/vector/v.strahler/v.strahler/main.c
--- grass-addons/grass6/vector/v.strahler/v.strahler/main.c	2013-01-26 15:22:36 UTC (rev 54772)
+++ grass-addons/grass6/vector/v.strahler/v.strahler/main.c	2013-01-26 16:21:32 UTC (rev 54773)
@@ -178,7 +178,7 @@
 #ifdef COPYBLAH
     /* this works, we want to continue here and ADD two columns to the &Out */
     /* Copy input to output (from v.clean/main.c) */
-    /*G_debug( 1, "Copying vector lines to Output" );
+    /*G_debug( 1, "Copying vector lines to Output" ); */
        /* This works for both level 1 and 2 */
     /*Vect_copy_map_lines ( &In, &Out );        */
