[GRASS-SVN] r54775 - in grass-addons/grass6/vector: . r.broscoe v.strahler2
svn_grass at osgeo.org
Sat Jan 26 09:22:08 PST 2013
Author: neteler
Date: 2013-01-26 09:22:08 -0800 (Sat, 26 Jan 2013)
New Revision: 54775
Added:
grass-addons/grass6/vector/r.broscoe/
grass-addons/grass6/vector/r.broscoe/r.broscoe_flowchart.dia
grass-addons/grass6/vector/r.broscoe/r.broscoe_flowchart.jpeg
grass-addons/grass6/vector/r.strahler/
grass-addons/grass6/vector/v.mainchannel/
grass-addons/grass6/vector/v.strahler2/
grass-addons/grass6/vector/v.strahler2/Qgisout_vstrahler.jpg
grass-addons/grass6/vector/v.strahler2/at_rbroscoe.jpg
grass-addons/grass6/vector/v.strahler2/description.html
grass-addons/grass6/vector/v.strahler2/helper.c
grass-addons/grass6/vector/v.strahler2/input_vstrahler.jpg
grass-addons/grass6/vector/v.strahler2/lr_rbroscoe.jpg
grass-addons/grass6/vector/v.strahler2/main.c
grass-addons/grass6/vector/v.strahler2/menotre.jpg
grass-addons/grass6/vector/v.strahler2/output_vstrahler.jpg
grass-addons/grass6/vector/v.strahler2/thrVScell.jpg
grass-addons/grass6/vector/v.strahler2/v.strahler_flowchart.dia
grass-addons/grass6/vector/v.strahler2/v.strahler_flowchart.jpeg
grass-addons/grass6/vector/v.strahler2/wt_rbroscoe.jpg
Removed:
avoid hierarchical code structure for g.extension
Copied: grass-addons/grass6/vector/r.broscoe/r.broscoe_flowchart.dia (from rev 54774, grass-addons/grass6/vector/v.strahler/r.broscoe/r.broscoe_flowchart.dia)
(Binary files differ)
Copied: grass-addons/grass6/vector/r.broscoe/r.broscoe_flowchart.jpeg (from rev 54774, grass-addons/grass6/vector/v.strahler/r.broscoe/r.broscoe_flowchart.jpeg)
Copied: grass-addons/grass6/vector/v.strahler2/Qgisout_vstrahler.jpg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/Qgisout_vstrahler.jpg)
Copied: grass-addons/grass6/vector/v.strahler2/at_rbroscoe.jpg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/at_rbroscoe.jpg)
Deleted: grass-addons/grass6/vector/v.strahler2/description.html
--- grass-addons/grass6/vector/v.strahler/v.strahler/description.html 2013-01-26 13:13:23 UTC (rev 54771)
+++ grass-addons/grass6/vector/v.strahler2/description.html 2013-01-26 17:22:08 UTC (rev 54775)
@@ -1,119 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.strahler</em> calculates the Strahler Order for all lines of a given
-dendritic network. The input vector map must be free of cycles. For the
-elaboration a new imported network or a network extracted from DEM by
-using <em><a href="r.watershed.html">r.watershed</a></em> can be used
-(in this case the topology has to be cleaned manually). More than one
-tree in the input data is allowed. No given flow direction is needed.
-To find the outlet of each tree, a DEM must be given.
-There are two additional scripts distributed with v.strahler:<br />
-- <em>r.strahler.sh</em> extracts streams from a DEM and call v.strahler
- on the result. <br />
-- <em>r.broscoe.sh</em> computes further statistical values for a given
- basin. <br />
-<h2>NOTES</h2>
-<h3>Problems</h3>
-This program is in beta status. It has the following shortcomings: <br />
-- The input data has to be topologically clean. Use <em>sloppy</em>=0.0 <br />
-- Source code comments are not doxydized. <br />
-<h3>How the algorithm works</h3>
-In a first step, <em>v.strahler</em> identifies all separate networks in
-the input dataset. That means, all connected lines are assigned a common
-<em>Basin ID</em>.<br />
-Consequently, the lowest leaf of each tree is identified as outlet.
-An auxiliary DEM is needed at this point. <br />
-Strahler ordering begins at each leaf of the tree with order N=1
-(excluding the outlet). At a confluence, the order N(r) of the resulting
-stream is equal to the highest order N(max) of the joining streams or is
-raised by one if there are two or more joining streams of order N(max).<br />
-The algorithm returns an ASCII text file with columns: <em>Category</em>
-(from input map), <em>Line</em> (topology), <em>Basin</em>, <em>Order</em>;
-and the output map has the Strahler Order value instead of "category"
-for each line, and no connection with the database.
-See the also the diagrams in the documentation/ directory.
-<h2>EXAMPLE</h2>
-The input map (vector on DEM): <br />
-<br />
-<img src="images/input_vstrahler.jpg"> <br />
-<br />
-<br />
-An example of the sintax in GRASS shell: <br />
-<br />
-<div class="code"><pre>
-GRASS> v.strahler input=esp_1 at mapset output=esp_1 dem=dem_20 at mapset \
- txout=/home/mapset/esp_1 sloppy=0 layer=1
-</pre></div>
-<br />
-<br />
-An extract from the resultant text file: <br />
-<br />
-== Result of Strahler Order ==
- Category: Line: Basin: Order:
- 22 1 1 4
- 73 2 1 1
- 25 3 1 4
- 27 4 1 4
- 39 5 1 1
- 48 6 1 1
- 56 7 1 4
- 55 8 1 2
- 88 9 1 4
- 59 10 1 1
- 60 11 1 1
- 61 12 1 2
- 83 13 1 2
- 82 14 1 1
- 91 15 1 1
- 87 16 1 4
- 95 17 1 2
- 96 18 1 1
- 106 19 1 1
- 102 20 1 1
- 104 21 1 4
- 111 22 1 1
- 112 23 1 3
- 121 24 1 3
- 126 25 1 1
- 128 26 1 3
- 137 27 1 3
-</pre></div>
-<br />
-<br />
-The output map (vector on DEM) form a snapshot of GRASS display: <br />
-<br />
-<img src="images/output_vstrahler.jpg"> <br />
-<br />
-<br />
-The output map (vector only) from Qgis (different colors for different orders): <br />
-<br />
-<img src="images/Qgisout_vstrahler.jpg"> <br />
-<br />
-<br />
-<h2>SEE ALSO</h2>
-<em><a href="r.watershed.html">r.watershed</a></em><br>
-<h2>AUTHOR</h2>
-Florian Kindl, Univ. Innsbruck.<br />
-<br />
-Modified by: Ivan Marchesini and Annalisa Minelli, Univ. Perugia.<br />
-<p>
-<i>Last changed: $Date$</i>
Copied: grass-addons/grass6/vector/v.strahler2/description.html (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/description.html)
--- grass-addons/grass6/vector/v.strahler2/description.html (rev 0)
@@ -0,0 +1,125 @@
+<h2>DESCRIPTION</h2>
+<em>v.strahler</em> calculates the Strahler Order for all lines of a given
+dendritic network. The input vector map must be free of cycles. For the
+elaboration a new imported network or a network extracted from DEM by
+using <em><a href="r.watershed.html">r.watershed</a></em> can be used
+(in this case the topology has to be cleaned manually). More than one
+tree in the input data is allowed. No given flow direction is needed.
+To find the outlet of each tree, a DEM must be given.
+There are two additional scripts distributed with v.strahler:<br>
+- <em>r.strahler.sh</em> extracts streams from a DEM and call v.strahler
+ on the result. <br>
+- <em>r.broscoe.sh</em> computes further statistical values for a given
+ basin.
+<h2>NOTES</h2>
+<h3>Problems</h3>
+This program is in beta status. It has the following shortcomings: <br />
+- The input data has to be topologically clean. Use <em>sloppy</em>=0.0 <br />
+- Source code comments are not doxygenized (not a real problem). <br />
+<h3>How the algorithm works</h3>
+In a first step, <em>v.strahler</em> identifies all separate networks in
+the input dataset. That means, all connected lines are assigned a common
+<em>Basin ID</em>.
+<p>
+Consequently, the lowest leaf of each tree is identified as outlet.
+An auxiliary DEM is needed at this point.
+<p>
+Strahler ordering begins at each leaf of the tree with order N=1
+(excluding the outlet). At a confluence, the order N(r) of the resulting
+stream is equal to the highest order N(max) of the joining streams or is
+raised by one if there are two or more joining streams of order N(max).
+<p>
+The algorithm returns an ASCII text file with columns: <em>Category</em>
+(from input map), <em>Line</em> (topology), <em>Basin</em>, <em>Order</em>;
+and the output map has the Strahler Order value instead of "category"
+for each line, and no connection with the database.
+See the also the diagrams in the documentation/ directory.
+<h2>EXAMPLE</h2>
+The input map (vector on DEM):
+<p>
+<center>
+<img src="input_vstrahler.jpg">
+</center>
+<p>
+An example of the syntax in GRASS command line:
+<p>
+<div class="code"><pre>
+v.strahler input=esp_1 at mapset output=esp_1 dem=dem_20 at mapset \
+ txout=/home/mapset/esp_1 sloppy=0 layer=1
+</pre></div>
+<p>
+An extract from the resultant text file:
+<p>
+== Result of Strahler Order ==
+ Category: Line: Basin: Order:
+ 22 1 1 4
+ 73 2 1 1
+ 25 3 1 4
+ 27 4 1 4
+ 39 5 1 1
+ 48 6 1 1
+ 56 7 1 4
+ 55 8 1 2
+ 88 9 1 4
+ 59 10 1 1
+ 60 11 1 1
+ 61 12 1 2
+ 83 13 1 2
+ 82 14 1 1
+ 91 15 1 1
+ 87 16 1 4
+ 95 17 1 2
+ 96 18 1 1
+ 106 19 1 1
+ 102 20 1 1
+ 104 21 1 4
+ 111 22 1 1
+ 112 23 1 3
+ 121 24 1 3
+ 126 25 1 1
+ 128 26 1 3
+ 137 27 1 3
+</pre></div>
+<p>
+The output map (vector on DEM) form a snapshot of GRASS display:
+<p>
+<center>
+<img src="output_vstrahler.jpg">
+</center>
+The output map (vector only) from Qgis (different colors for different orders):
+<p>
+<center>
+<img src="Qgisout_vstrahler.jpg">
+</center>
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.watershed.html">r.watershed</a>
+</em>
+<h2>AUTHOR</h2>
+Florian Kindl, Univ. Innsbruck.<br />
+<br />
+Modified by: Ivan Marchesini and Annalisa Minelli, Univ. Perugia.<br />
+<p>
+<i>Last changed: $Date$</i>
Deleted: grass-addons/grass6/vector/v.strahler2/helper.c
--- grass-addons/grass6/vector/v.strahler/v.strahler/helper.c 2013-01-26 13:13:23 UTC (rev 54771)
+++ grass-addons/grass6/vector/v.strahler2/helper.c 2013-01-26 17:22:08 UTC (rev 54775)
@@ -1,80 +0,0 @@
-#include "strahler.h"
-/* Replacement for Vect_get_node_n_lines in sloppy mode
- Gets adjacent lines by coordinate */
-int StrahGetDegr(struct Map_info *In, int node)
- extern double sloppy;
- int degr, onode, j;
- double x, y;
- BOUND_BOX *Box;
- struct ilist *list;
- if (sloppy != 0.0) {
- Vect_get_node_coor(In, node, &x, &y, NULL);
- Box->N = y + sloppy;
- Box->S = y - sloppy;
- Box->W = x + sloppy;
- Box->E = x - sloppy;
- list = Vect_new_list();
- printf( "N %f\n", Box->N );
- printf( "S %f\n", Box->S );
- printf( "W %f\n", Box->W );
- printf( "E %f\n", Box->E );
- Vect_select_nodes_by_box(In, Box, list);
- G_debug(3, " %d nodes selected", list->n_values);
- /* is always 0 -why? */
- for (j = 0; j < list->n_values; j++) {
- onode = abs(list->value[j]);
- G_debug(3, "List %d: %d\n", j, onode);
- Vect_list_append ( StArcs, line );
- Vect_get_line_nodes ( &Map, line, &node1, &node2);
- Vect_list_append ( StNodes, node1 );
- Vect_list_append ( StNodes, node2 );
- else {
- degr = Vect_get_node_n_lines(In, node);
- G_debug(4, "node %d degr %d sloppy %f\n", node, degr, sloppy);
- return degr;
-int StrahGetNodeLine(struct Map_info *In, int node, int d)
- int aline;
- G_debug(4, "StrahGetNodeLine at node %d", node);
- get all nodes within sloppy from node -> from table StrahGetDegr has written
- get all lines for each found node -> Vect_get_node_line(In, foundnode, df)
- for ( fn=0; fn<foundnodes.length; fn++ ) {
- degrf = Vect_get_node_n_lines( In, fn );
- for (df = 0; df < degrf; df++) {
- foundline = abs( Vect_get_node_line( In, fn, df ) );
- addtolist(foundline);
- return line d in list of foundlines;
- else {
- /* method if junction is only 1 node */
- aline = abs(Vect_get_node_line(In, node, d));
- return aline;
Copied: grass-addons/grass6/vector/v.strahler2/helper.c (from rev 54773, grass-addons/grass6/vector/v.strahler/v.strahler/helper.c)
--- grass-addons/grass6/vector/v.strahler2/helper.c (rev 0)
@@ -0,0 +1,81 @@
+#include "strahler.h"
+/* Replacement for Vect_get_node_n_lines in sloppy mode
+ Gets adjacent lines by coordinate */
+int StrahGetDegr(struct Map_info *In, int node)
+ extern double sloppy;
+ int degr, onode, j;
+ double x, y;
+ BOUND_BOX *Box;
+ struct ilist *list;
+ if (sloppy != 0.0) {
+ Vect_get_node_coor(In, node, &x, &y, NULL);
+ Vect_get_map_box(In, Box);
+ Box->N = y + sloppy;
+ Box->S = y - sloppy;
+ Box->W = x + sloppy;
+ Box->E = x - sloppy;
+ list = Vect_new_list();
+ printf( "N %f\n", Box->N );
+ printf( "S %f\n", Box->S );
+ printf( "W %f\n", Box->W );
+ printf( "E %f\n", Box->E );
+ Vect_select_nodes_by_box(In, Box, list);
+ G_debug(3, " %d nodes selected", list->n_values);
+ /* is always 0 -why? */
+ for (j = 0; j < list->n_values; j++) {
+ onode = abs(list->value[j]);
+ G_debug(3, "List %d: %d\n", j, onode);
+ Vect_list_append ( StArcs, line );
+ Vect_get_line_nodes ( &Map, line, &node1, &node2);
+ Vect_list_append ( StNodes, node1 );
+ Vect_list_append ( StNodes, node2 );
+ else {
+ degr = Vect_get_node_n_lines(In, node);
+ G_debug(4, "node %d degr %d sloppy %f\n", node, degr, sloppy);
+ return degr;
+int StrahGetNodeLine(struct Map_info *In, int node, int d)
+ int aline;
+ G_debug(4, "StrahGetNodeLine at node %d", node);
+ get all nodes within sloppy from node -> from table StrahGetDegr has written
+ get all lines for each found node -> Vect_get_node_line(In, foundnode, df)
+ for ( fn=0; fn<foundnodes.length; fn++ ) {
+ degrf = Vect_get_node_n_lines( In, fn );
+ for (df = 0; df < degrf; df++) {
+ foundline = abs( Vect_get_node_line( In, fn, df ) );
+ addtolist(foundline);
+ return line d in list of foundlines;
+ else {
+ /* method if junction is only 1 node */
+ aline = abs(Vect_get_node_line(In, node, d));
+ return aline;
Copied: grass-addons/grass6/vector/v.strahler2/input_vstrahler.jpg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/input_vstrahler.jpg)
Copied: grass-addons/grass6/vector/v.strahler2/lr_rbroscoe.jpg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/lr_rbroscoe.jpg)
Deleted: grass-addons/grass6/vector/v.strahler2/main.c
--- grass-addons/grass6/vector/v.strahler/v.strahler/main.c 2013-01-26 13:13:23 UTC (rev 54771)
+++ grass-addons/grass6/vector/v.strahler2/main.c 2013-01-26 17:22:08 UTC (rev 54775)
@@ -1,384 +0,0 @@
- * MODULE: v.strahler
- * AUTHOR(S): Florian Kindl, Norbert Pfeifer, The GRASS development team
- * Modified by: Ivan Marchesini <marchesini unipg.it> and
- Annalisa Minelli <annapatri tiscali.it>
- * PURPOSE: Assign Strahler order to dendritic network
- * COPYRIGHT: (C) 2006 by the Authors
- * This program is free software under the
- * GNU General Public License (v2).
- * Read the file COPYING that comes with GRASS
- * for details.
-/*! \file main.c
- \brief Assign Strahler order to dendritic network
- \author Florian Kindl
- \todo Deal with poor topology
- \li implemement sloppy mode or
- \li force clean topology
- \todo ...
-#include <stdio.h>
-#include <stdlib.h>
-#include <string.h>
-#include <search.h>
-#include <time.h>
-#include <grass/gis.h>
-#include <grass/Vect.h>
-#include <grass/dgl.h>
-#include <grass/dbmi.h>
-#include <grass/glocale.h>
-#define COPYBLAH 1
-#define DDFIELDBLAH 1
-#define BADDCOLUMNBLAH 1
-#define RITEDBLAH 1
-#define EBUG 1
-#define REATEDBLAH 1
-int ret, type; /* return and type related to Vect_read_line and Vect_write_line */
-int fdrast; /* file descriptor for raster file is int */
-int ntrees; /* number of trees in dataset, returned by StrahForestToTrees */
-double sloppy;
-int main(int argc, char **argv)
- int line, node;
- char buf[1024];
- int nnodes, nlines, tlines;
- DBBUF *dbbuf;
- NODEV *nodev;
- struct Option *input, *output, *dem_opt, *txout_opt, *sloppy_opt,
- *field_opt;
- struct GModule *module;
- char *inputset, *demset;
- struct Map_info In, Out;
- struct Map_info Trees;
- FILE *txout;
- struct Cell_head window; /* for cell sampling */
- extern int ntrees; /* number of trees calculated by StrahForestToTrees */
- extern int fdrast;
- /* Attribute table (from v.net.path/path.c) */
- struct line_cats *Cats; /* introduced and initialized the structures line_cats and line_pnts */
- static struct line_pnts *Points;
- Points = Vect_new_line_struct();
- Cats = Vect_new_cats_struct();
- dbString sql;
- dbDriver *driver;
- dbColumn *column;
- struct field_info *Fi;
- int field;
- /* Initialize the GIS calls */
- G_gisinit(argv[0]);
- input = G_define_standard_option(G_OPT_V_INPUT);
- output = G_define_standard_option(G_OPT_V_OUTPUT);
- module = G_define_module();
- module->description = _("Strahler order");
- dem_opt = G_define_standard_option(G_OPT_R_INPUT);
- dem_opt->key = "dem";
- dem_opt->description = _("Underlying DEM");
- txout_opt = G_define_option();
- txout_opt->key = "txout";
- txout_opt->type = TYPE_STRING;
- txout_opt->required = NO;
- txout_opt->multiple = NO;
- txout_opt->gisprompt = "new_file,file,output";
- txout_opt->description =
- _("Path to ASCII file where results will be written");
- /* option sloppy for bad topology */
- sloppy_opt = G_define_option();
- sloppy_opt->key = "sloppy";
- sloppy_opt->type = TYPE_DOUBLE;
- sloppy_opt->required = NO;
- sloppy_opt->answer = "0.0";
- sloppy_opt->multiple = NO;
- sloppy_opt->description =
- _("Threshold for distance within different nodes are considered the same node - may not work");
- field_opt = G_define_standard_option(G_OPT_V_FIELD);
- field = atoi(field_opt->answer);
- if (G_parser(argc, argv))
- exit(EXIT_FAILURE);
- Vect_check_input_output_name(input->answer, output->answer,
- GV_FATAL_EXIT);
- inputset = G_find_vector2(input->answer, NULL);
- if (inputset == NULL) {
- G_fatal_error(_("Could not find input input <%s>"), input->answer);
- /* open datasets at topology level 2 */
- Vect_set_open_level(2);
- Vect_open_old(&In, input->answer, inputset);
- G_debug(1, "Input vector opened");
- /* Open new vector, make 3D if input is 3D */
- if (1 > Vect_open_new(&Out, output->answer, Vect_is_3d(&In))) {
- Vect_close(&In);
- G_fatal_error("Failed opening output vector file %s", output->answer);
- /* Open DEM */
- demset = G_find_cell2(dem_opt->answer, NULL);
- if (demset == NULL) {
- G_fatal_error("DEM file %s not found", dem_opt->answer);
- if (1 > (fdrast = G_open_cell_old(dem_opt->answer, demset))) {
- G_fatal_error("Failed opening DEM file %s", dem_opt->answer);
- /* Open text file for results if given */
- if (txout_opt->answer) {
- txout = fopen(txout_opt->answer, "w");
- if (txout == NULL)
- G_fatal_error(_("Cannot open file %s"), txout_opt->answer);
- sloppy = atof(sloppy_opt->answer);
- /* printf("blah %f", sloppy*2.4 ); */
- /* write history */
- /*Vect_copy_head_data( &In, &Out );
- Vect_hist_copy( &In, &Out );
- Vect_hist_command( &Out ); */
-#ifdef COPYBLAH
- /* this works, we want to continue here and ADD two columns to the &Out */
- /* Copy input to output (from v.clean/main.c) */
- /*G_debug( 1, "Copying vector lines to Output" );
- /* This works for both level 1 and 2 */
- /*Vect_copy_map_lines ( &In, &Out ); */
- /* 0: copy all fields, else field number */
-#endif
-#ifdef ADDFIELDBLAH /* Create table (from v.net.path/path.c) */
- /* or: add fields to existing table? */
- /* *Map, field, field_name, type */
- Fi = Vect_default_field_info(&Out, field, NULL, GV_1TABLE);
- Vect_map_add_dblink(&Out, field, NULL, Fi->table, "cat", Fi->database,
- Fi->driver);
- driver = db_start_driver_open_database(Fi->driver, Fi->database);
- driver =
- db_start_driver_open_database(Fi->driver,
- Vect_subst_var(Fi->database, &Out));
- /* from v.reclass/main.c :
- if (driver == NULL) {
- G_fatal_error("Cannot open database %s by driver %s", Fi->database,
- Fi->driver);
- /* store the statement to create a table with category, basin ID and strahler order of the arc */
- sprintf(buf,
- "CREATE TABLE %s ( cat integer, bsnid integer, sorder integer )",
- Fi->table);
- /* from v.reclass/main.c : */
- dbString stmt;
- db_init_string(&stmt);
- db_set_string(&stmt, buf);
- if (db_execute_immediate(driver, &stmt) != DB_OK) {
- Vect_close(&Out);
- db_close_database_shutdown_driver(driver);
- G_fatal_error("Cannot create table: %s", db_get_string(&stmt));
- sprintf ( buf, "ALTER TABLE %s ADD COLUMN cat integer", Fi->table );
- sprintf ( buf, "ALTER TABLE %s ADD COLUMN bsnid integer", Fi->table );
- sprintf ( buf, "ALTER TABLE %s ADD COLUMN sorder integer", Fi->table );
-#endif
-#ifdef DBADDCOLUMNBLAH
- sprintf(buf, "bsnid");
- db_set_string(&sql, buf);
- column->columnName = sql;
- column->sqlDataType = 1;
- sprintf(buf, "%s", Fi->table);
- /*db_set_string ( &sql, buf ); */
- /* why such complicated arguments for db_add_column???
- dbDriver, dbString, dbColumn */
- if (db_add_column(driver, &sql, column) != DB_OK) {
- G_fatal_error("Cannot add column column in table %s", Fi->table);
-#endif
- /* execute statement */
-#ifdef CREATEDBLAH
- sprintf(buf,
- Fi->table);
- G_debug(2, db_get_string(&sql));
- if (db_execute_immediate(driver, &sql) != DB_OK) {
- G_fatal_error("Cannot create table: %s", db_get_string(&sql));
- else
- printf("table created\n");
- if (db_create_index2(driver, Fi->table, "cat") != DB_OK) {
- G_warning("Cannot create index");
- else
- printf("index created\n");
- if (db_grant_on_table
- (driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK) {
- G_fatal_error("Cannot grant privileges on table %s", Fi->table);
- else
- printf("privileges granted\n");
-#endif
- nnodes = Vect_get_num_nodes(&In);
- nlines = Vect_get_num_lines(&In);
- G_debug(1, "Number of lines: %d", nlines);
- G_debug(1, "Number of nodes: %d", nnodes);
- /* Create table to store ordering */
- dbbuf = (DBBUF *) G_malloc((nlines + 1) * ((int)sizeof(DBBUF)));
- nodev = (NODEV *) G_malloc((nnodes + 1) * ((int)sizeof(NODEV)));
- /* initialize properly */
- for (line = 1; line <= nlines; line++) {
- dbbuf[line].category = dbbuf[line].line = dbbuf[line].bsnid =
- dbbuf[line].sorder = 0;
- for (node = 1; node <= nnodes; node++) {
- nodev[node].node = nodev[node].degree = nodev[node].visited = 0;
- ntrees = (int)StrahForestToTrees(&In, &Out, dbbuf);
- G_debug(1, "Number of trees: %d", ntrees);
- StrahFindLeaves(&In, dbbuf, nodev, ntrees, fdrast);
- G_debug(2, "dbbuf after FindLeaves:\nline\tbsnid\tsorder");
- sprintf(buf, "%d\t%d\t%d\n", dbbuf[line].line, dbbuf[line].bsnid,
- dbbuf[line].sorder);
- G_debug(2, "%s", buf);
- G_debug(2, "nodev after FindLeaves:\nnode\tdegree\tvisited");
- sprintf(buf, "%d\t%d\t%d\n", (int)nodev[node].node,
- nodev[node].degree, nodev[node].visited);
- StrahOrder(&In, dbbuf, nodev);
- G_debug(2, "dbbuf after StrahOrder:\nline\tbsnid\tsorder\n");
- G_debug(2, "nodev after StrahOrder:\nnode\tdegree\tvisited\n");
-#ifdef WRITEDBLAH
- /* and write DB records */
- db_begin_transaction(driver);
- sprintf(buf, "insert into %s values ( %d, %d, %d )", Fi->table, line,
- dbbuf[line].bsnid, dbbuf[line].sorder);
- /* G_debug ( 3, db_get_string ( &sql ) ); */
- G_fatal_error("Insert new row: %s", db_get_string(&sql));
- db_commit_transaction(driver);
-#endif
- /* writing StrahOrder instead of category in the output */
- type = Vect_read_line(&In, Points, Cats, line);
- ret = Vect_cat_del(Cats, field);
- G_debug(4, "deleted categories, ret=%d", ret);
- Vect_cat_set(Cats, field, dbbuf[line].sorder);
- Vect_write_line(&Out, type, Points, Cats);
- G_debug(4, "category written for line %d", line);
- /* assign category values */
- dbbuf[line].category = Vect_get_line_cat(&In, line, field);
- G_debug(4, "added category %d for line %d", dbbuf[line].category,
- dbbuf[line].line);
- /* Write text file for results if given */
- StrahWriteToFile(dbbuf, nlines, txout);
- Vect_close(&In);
- G_close_cell(fdrast);
- Vect_build(&Out);
- Vect_close(&Out);
- fclose(txout);
- return (EXIT_SUCCESS);
Copied: grass-addons/grass6/vector/v.strahler2/main.c (from rev 54773, grass-addons/grass6/vector/v.strahler/v.strahler/main.c)
--- grass-addons/grass6/vector/v.strahler2/main.c (rev 0)
@@ -0,0 +1,384 @@
+ * MODULE: v.strahler
+ * AUTHOR(S): Florian Kindl, Norbert Pfeifer, The GRASS development team
+ * Modified by: Ivan Marchesini <marchesini unipg.it> and
+ Annalisa Minelli <annapatri tiscali.it>
+ * PURPOSE: Assign Strahler order to dendritic network
+ * COPYRIGHT: (C) 2006 by the Authors
+ * This program is free software under the
+ * GNU General Public License (v2).
+ * Read the file COPYING that comes with GRASS
+ * for details.
+/*! \file main.c
+ \brief Assign Strahler order to dendritic network
+ \author Florian Kindl
+ \todo Deal with poor topology
+ \li implemement sloppy mode or
+ \li force clean topology
+ \todo ...
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <search.h>
+#include <time.h>
+#include <grass/gis.h>
+#include <grass/Vect.h>
+#include <grass/dgl.h>
+#include <grass/dbmi.h>
+#include <grass/glocale.h>
+#define COPYBLAH 1
+#define DDFIELDBLAH 1
+#define BADDCOLUMNBLAH 1
+#define RITEDBLAH 1
+#define EBUG 1
+#define REATEDBLAH 1
+int ret, type; /* return and type related to Vect_read_line and Vect_write_line */
+int fdrast; /* file descriptor for raster file is int */
+int ntrees; /* number of trees in dataset, returned by StrahForestToTrees */
+double sloppy;
+int main(int argc, char **argv)
+ int line, node;
+ char buf[1024];
+ int nnodes, nlines, tlines;
+ DBBUF *dbbuf;
+ NODEV *nodev;
+ struct Option *input, *output, *dem_opt, *txout_opt, *sloppy_opt,
+ *field_opt;
+ struct GModule *module;
+ char *inputset, *demset;
+ struct Map_info In, Out;
+ struct Map_info Trees;
+ FILE *txout;
+ struct Cell_head window; /* for cell sampling */
+ extern int ntrees; /* number of trees calculated by StrahForestToTrees */
+ extern int fdrast;
+ /* Attribute table (from v.net.path/path.c) */
+ struct line_cats *Cats; /* introduced and initialized the structures line_cats and line_pnts */
+ static struct line_pnts *Points;
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ dbString sql;
+ dbDriver *driver;
+ dbColumn *column;
+ struct field_info *Fi;
+ int field;
+ /* Initialize the GIS calls */
+ G_gisinit(argv[0]);
+ input = G_define_standard_option(G_OPT_V_INPUT);
+ output = G_define_standard_option(G_OPT_V_OUTPUT);
+ module = G_define_module();
+ module->description = _("Strahler order");
+ dem_opt = G_define_standard_option(G_OPT_R_INPUT);
+ dem_opt->key = "dem";
+ dem_opt->description = _("Underlying DEM");
+ txout_opt = G_define_option();
+ txout_opt->key = "txout";
+ txout_opt->type = TYPE_STRING;
+ txout_opt->required = NO;
+ txout_opt->multiple = NO;
+ txout_opt->gisprompt = "new_file,file,output";
+ txout_opt->description =
+ _("Path to ASCII file where results will be written");
+ /* option sloppy for bad topology */
+ sloppy_opt = G_define_option();
+ sloppy_opt->key = "sloppy";
+ sloppy_opt->type = TYPE_DOUBLE;
+ sloppy_opt->required = NO;
+ sloppy_opt->answer = "0.0";
+ sloppy_opt->multiple = NO;
+ sloppy_opt->description =
+ _("Threshold for distance within different nodes are considered the same node - may not work");
+ field_opt = G_define_standard_option(G_OPT_V_FIELD);
+ field = atoi(field_opt->answer);
+ if (G_parser(argc, argv))
+ exit(EXIT_FAILURE);
+ Vect_check_input_output_name(input->answer, output->answer,
+ GV_FATAL_EXIT);
+ inputset = G_find_vector2(input->answer, NULL);
+ if (inputset == NULL) {
+ G_fatal_error(_("Could not find input input <%s>"), input->answer);
+ /* open datasets at topology level 2 */
+ Vect_set_open_level(2);
+ Vect_open_old(&In, input->answer, inputset);
+ G_debug(1, "Input vector opened");
+ /* Open new vector, make 3D if input is 3D */
+ if (1 > Vect_open_new(&Out, output->answer, Vect_is_3d(&In))) {
+ Vect_close(&In);
+ G_fatal_error("Failed opening output vector file %s", output->answer);
+ /* Open DEM */
+ demset = G_find_cell2(dem_opt->answer, NULL);
+ if (demset == NULL) {
+ G_fatal_error("DEM file %s not found", dem_opt->answer);
+ if (1 > (fdrast = G_open_cell_old(dem_opt->answer, demset))) {
+ G_fatal_error("Failed opening DEM file %s", dem_opt->answer);
+ /* Open text file for results if given */
+ if (txout_opt->answer) {
+ txout = fopen(txout_opt->answer, "w");
+ if (txout == NULL)
+ G_fatal_error(_("Cannot open file %s"), txout_opt->answer);
+ sloppy = atof(sloppy_opt->answer);
+ /* printf("blah %f", sloppy*2.4 ); */
+ /* write history */
+ /*Vect_copy_head_data( &In, &Out );
+ Vect_hist_copy( &In, &Out );
+ Vect_hist_command( &Out ); */
+#ifdef COPYBLAH
+ /* this works, we want to continue here and ADD two columns to the &Out */
+ /* Copy input to output (from v.clean/main.c) */
+ /*G_debug( 1, "Copying vector lines to Output" ); */
+ /* This works for both level 1 and 2 */
+ /*Vect_copy_map_lines ( &In, &Out ); */
+ /* 0: copy all fields, else field number */
+#endif
+#ifdef ADDFIELDBLAH /* Create table (from v.net.path/path.c) */
+ /* or: add fields to existing table? */
+ /* *Map, field, field_name, type */
+ Fi = Vect_default_field_info(&Out, field, NULL, GV_1TABLE);
+ Vect_map_add_dblink(&Out, field, NULL, Fi->table, "cat", Fi->database,
+ Fi->driver);
+ driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ driver =
+ db_start_driver_open_database(Fi->driver,
+ Vect_subst_var(Fi->database, &Out));
+ /* from v.reclass/main.c :
+ if (driver == NULL) {
+ G_fatal_error("Cannot open database %s by driver %s", Fi->database,
+ Fi->driver);
+ /* store the statement to create a table with category, basin ID and strahler order of the arc */
+ sprintf(buf,
+ "CREATE TABLE %s ( cat integer, bsnid integer, sorder integer )",
+ Fi->table);
+ /* from v.reclass/main.c : */
+ dbString stmt;
+ db_init_string(&stmt);
+ db_set_string(&stmt, buf);
+ if (db_execute_immediate(driver, &stmt) != DB_OK) {
+ Vect_close(&Out);
+ db_close_database_shutdown_driver(driver);
+ G_fatal_error("Cannot create table: %s", db_get_string(&stmt));
+ sprintf ( buf, "ALTER TABLE %s ADD COLUMN cat integer", Fi->table );
+ sprintf ( buf, "ALTER TABLE %s ADD COLUMN bsnid integer", Fi->table );
+ sprintf ( buf, "ALTER TABLE %s ADD COLUMN sorder integer", Fi->table );
+#endif
+#ifdef DBADDCOLUMNBLAH
+ sprintf(buf, "bsnid");
+ db_set_string(&sql, buf);
+ column->columnName = sql;
+ column->sqlDataType = 1;
+ sprintf(buf, "%s", Fi->table);
+ /*db_set_string ( &sql, buf ); */
+ /* why such complicated arguments for db_add_column???
+ dbDriver, dbString, dbColumn */
+ if (db_add_column(driver, &sql, column) != DB_OK) {
+ G_fatal_error("Cannot add column column in table %s", Fi->table);
+#endif
+ /* execute statement */
+#ifdef CREATEDBLAH
+ sprintf(buf,
+ Fi->table);
+ G_debug(2, db_get_string(&sql));
+ if (db_execute_immediate(driver, &sql) != DB_OK) {
+ G_fatal_error("Cannot create table: %s", db_get_string(&sql));
+ else
+ printf("table created\n");
+ if (db_create_index2(driver, Fi->table, "cat") != DB_OK) {
+ G_warning("Cannot create index");
+ else
+ printf("index created\n");
+ if (db_grant_on_table
+ (driver, Fi->table, DB_PRIV_SELECT, DB_GROUP | DB_PUBLIC) != DB_OK) {
+ G_fatal_error("Cannot grant privileges on table %s", Fi->table);
+ else
+ printf("privileges granted\n");
+#endif
+ nnodes = Vect_get_num_nodes(&In);
+ nlines = Vect_get_num_lines(&In);
+ G_debug(1, "Number of lines: %d", nlines);
+ G_debug(1, "Number of nodes: %d", nnodes);
+ /* Create table to store ordering */
+ dbbuf = (DBBUF *) G_malloc((nlines + 1) * ((int)sizeof(DBBUF)));
+ nodev = (NODEV *) G_malloc((nnodes + 1) * ((int)sizeof(NODEV)));
+ /* initialize properly */
+ for (line = 1; line <= nlines; line++) {
+ dbbuf[line].category = dbbuf[line].line = dbbuf[line].bsnid =
+ dbbuf[line].sorder = 0;
+ for (node = 1; node <= nnodes; node++) {
+ nodev[node].node = nodev[node].degree = nodev[node].visited = 0;
+ ntrees = (int)StrahForestToTrees(&In, &Out, dbbuf);
+ G_debug(1, "Number of trees: %d", ntrees);
+ StrahFindLeaves(&In, dbbuf, nodev, ntrees, fdrast);
+ G_debug(2, "dbbuf after FindLeaves:\nline\tbsnid\tsorder");
+ sprintf(buf, "%d\t%d\t%d\n", dbbuf[line].line, dbbuf[line].bsnid,
+ dbbuf[line].sorder);
+ G_debug(2, "%s", buf);
+ G_debug(2, "nodev after FindLeaves:\nnode\tdegree\tvisited");
+ sprintf(buf, "%d\t%d\t%d\n", (int)nodev[node].node,
+ nodev[node].degree, nodev[node].visited);
+ StrahOrder(&In, dbbuf, nodev);
+ G_debug(2, "dbbuf after StrahOrder:\nline\tbsnid\tsorder\n");
+ G_debug(2, "nodev after StrahOrder:\nnode\tdegree\tvisited\n");
+#ifdef WRITEDBLAH
+ /* and write DB records */
+ db_begin_transaction(driver);
+ sprintf(buf, "insert into %s values ( %d, %d, %d )", Fi->table, line,
+ dbbuf[line].bsnid, dbbuf[line].sorder);
+ /* G_debug ( 3, db_get_string ( &sql ) ); */
+ G_fatal_error("Insert new row: %s", db_get_string(&sql));
+ db_commit_transaction(driver);
+#endif
+ /* writing StrahOrder instead of category in the output */
+ type = Vect_read_line(&In, Points, Cats, line);
+ ret = Vect_cat_del(Cats, field);
+ G_debug(4, "deleted categories, ret=%d", ret);
+ Vect_cat_set(Cats, field, dbbuf[line].sorder);
+ Vect_write_line(&Out, type, Points, Cats);
+ G_debug(4, "category written for line %d", line);
+ /* assign category values */
+ dbbuf[line].category = Vect_get_line_cat(&In, line, field);
+ G_debug(4, "added category %d for line %d", dbbuf[line].category,
+ dbbuf[line].line);
+ /* Write text file for results if given */
+ StrahWriteToFile(dbbuf, nlines, txout);
+ Vect_close(&In);
+ G_close_cell(fdrast);
+ Vect_build(&Out);
+ Vect_close(&Out);
+ fclose(txout);
+ return (EXIT_SUCCESS);
Copied: grass-addons/grass6/vector/v.strahler2/menotre.jpg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/menotre.jpg)
Copied: grass-addons/grass6/vector/v.strahler2/output_vstrahler.jpg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/output_vstrahler.jpg)
Copied: grass-addons/grass6/vector/v.strahler2/thrVScell.jpg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/thrVScell.jpg)
Copied: grass-addons/grass6/vector/v.strahler2/v.strahler_flowchart.dia (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/v.strahler_flowchart.dia)
Copied: grass-addons/grass6/vector/v.strahler2/v.strahler_flowchart.jpeg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/v.strahler_flowchart.jpeg)
Copied: grass-addons/grass6/vector/v.strahler2/wt_rbroscoe.jpg (from rev 54774, grass-addons/grass6/vector/v.strahler/v.strahler/wt_rbroscoe.jpg)
