[GRASS-SVN] r54784 - grass-addons/grass6/raster/r.maxent.lambdas
Sun Jan 27 04:47:43 PST 2013
Author: pvanbosgeo
Date: 2013-01-27 04:47:42 -0800 (Sun, 27 Jan 2013)
New Revision: 54784
Added:
   grass-addons/grass6/raster/r.maxent.lambdas/r.maxent.lambdas_v2
Running the script  gave a different output layer then when produced with Maxent, which is because the raw features are not extracted, as described here: https://groups.google.com/forum/?fromgroups=#!searchin/maxent/pvb/maxent/Z1PgTnHmlLQ/tnmhLxfSMsIJ. This file contains a proposed change to make this work.
Added: grass-addons/grass6/raster/r.maxent.lambdas/r.maxent.lambdas_v2
--- grass-addons/grass6/raster/r.maxent.lambdas/r.maxent.lambdas_v2	                        (rev 0)
+++ grass-addons/grass6/raster/r.maxent.lambdas/r.maxent.lambdas_v2	2013-01-27 12:47:42 UTC (rev 54784)
@@ -0,0 +1,276 @@
+#!/bin/sh
+# MODULE:       r.maxent.lambdas
+# AUTHOR(S):    Stefan Blumentrath <stefan dot blumentrath at nina dot no >
+#               Proposed small change in how raw features are extracted
+#               from the lambdas file as this didn't work in original
+#               code (Paulo van Breugel)
+# PURPOSE:      Compute raw and/or logistic prediction maps from a lambdas
+#               file produced with MaxEnt 3.3.3e.
+#               !!!This script works only if the input data to MaxEnt
+#               are accessible from the current region.!!!
+#               This script will parse the specified lambdas-file from
+#               MaxEnt 3.3.3e (see http://www.cs.princeton.edu/~schapire/maxent/)
+#               and translate it into an r.mapcalc-expression which is then stored
+#               in a temporary file and finally piped to r.mapcalc.
+#               If alias names had been used in MaxEnt, these alias names can
+#               automatically be replaced according to a  CSV-like file provided
+#               by the user. This file should contain alias names in the first
+#               column and map names in the second column, seperated by comma,
+#               without header. It should look e.g. like this:
+#               alias_1,map_1
+#               alias_2,map_2
+#               If such a CSV-file with alias names used in MaxEnt is provided,
+#               the alias names from MaxEnt are replaced by map names.
+#               A raw output map is always computed from the MaxEnt model
+#               as a first step. If logistic output is requested, the raw output
+#               map can be deleted by the script ( using the l-flag). The
+#               production of logistic output can be omitted. The logistic map
+#               can be produced as an integer map. To do so the user has to specify
+#               the number of digits after comma, that should be preserved in
+#               integer output.
+#               Optionally the map calculator expressions can be saved in a text
+#               file, as especially the one for the raw output is likely to exceed
+#               the space in the map history.
+#               Due to conversion from double to floating-point in exp()-function, a
+#               loss of precision from the 7th digit onwards is possible in the
+#               logistic output.
+# COPYRIGHT:    (C) 2011 by the Norwegian Institute for Nature Research (NINA)
+#               http://www.nina.no
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+# REQUIREMENTS:
+# awk
+#%Module
+#% description: Computes raw and/or logistic prediction maps from MaxEnt lambdas files
+#%End
+#%flag
+#%  key: r
+#%  description: Produce only raw output (both are computed by default).
+#%end
+#%flag
+#%  key: l
+#%  description: Produce only logistic output (both are computed by default).
+#%end
+#%option
+#% key: lambdas_file
+#% type: string
+#% description: MaxEnt lambdas-file to compute distribution-model from
+#% required : yes
+#% gisprompt: old_file,file,input
+#%end
+#%option
+#% key: output_prefix
+#% type: string
+#% description: Prefix for output raster maps
+#% required : yes
+#% gisprompt: new,cell,raster
+#%end
+#%option
+#% key: alias_file
+#% type: string
+#% description: CSV-file to replace alias names from MaxEnt by GRASS map names
+#% required : no
+#%end
+#%option
+#% key: integer_output
+#% type: integer
+#% description: Produce logistic integer output with this number of digits preserved
+#% required : no
+#% answer : 0
+#%end
+#%option
+#% key: output_mapcalc
+#% type: string
+#% description: Save r.mapcalc expression to file
+#% required : no
+#% gisprompt: new_file,file,output
+#%end
+FLAG_ONLY_RAW=${GIS_FLAG_R}
+FLAG_ONLY_LOGISTIC=${GIS_FLAG_L}
+LAMBDAS_FILE="${GIS_OPT_LAMBDAS_FILE}"
+INTEGER_OUTPUT=${GIS_OPT_INTEGER_OUTPUT}
+ALIAS_FILE="${GIS_OPT_ALIAS_FILE}"
+OUTPUT_PREFIX="${GIS_OPT_OUTPUT_PREFIX}"
+OUTPUT_MAPCALC="${GIS_OPT_OUTPUT_MAPCALC}"
+#Check if script is started from within GRASS
+if [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." 1>&2
+    exit 1
+fi
+#Check if awk is installed
+	if [ ! -x "`which awk`" ] ; then
+	    g.message -e "awk is required, please install awk or gawk first"
+	    exit 1
+	fi
+#Set environment so that awk works properly in all languages
+	unset LC_ALL
+	LC_NUMERIC=C
+	export LC_NUMERIC
+#Pass evtl. command line arguments to gui and start it
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    exec g.parser "$0" "$@"
+fi
+#Check if input file exists
+if [ ! -r "$LAMBDAS_FILE" ] ; then
+	g.message -e "MaxEnt lambdas-file could not be found or is not readable."
+	exit 1
+fi
+#Check if raw output files exists
+eval `g.findfile element=cell file=${OUTPUT_PREFIX}_raw`
+if [ -n "$name" ] ; then
+	g.message -e  "Raw output file already exists."
+	exit 1
+fi
+#Check if logistic output files exists when requestd
+if [ "${FLAG_ONLY_RAW}" -ne 1 ] ; then
+	eval `g.findfile element=cell file=${OUTPUT_PREFIX}_logistic`
+	if [ -n "$name" ] ; then
+		g.message -e  "Logistic output file already exists."
+		exit 1
+	fi
+fi
+#Check if output flags are set properly
+if [ "${FLAG_ONLY_RAW}" -eq 1 -a "${FLAG_ONLY_LOGISTIC}" -eq 1 ] ; then
+	g.message -e  "The r and l flags are exclusive. Do not tick both!"
+	rm "$temp1"
+	exit 1
+fi
+###Save r.mapcalc expression to file if requested, else to tmp-file
+if [ -z "$OUTPUT_MAPCALC" ] ; then
+	#Create tempfile
+	temp1=`g.tempfile pid=$$`
+	if [ $? -ne 0 ] || [ -z "$temp1" ] ; then
+			g.message -e "ERROR: unable to create temporary files"
+			exit 1
+	fi
+else
+	temp1="$OUTPUT_MAPCALC"
+fi
+###Parse lambdas-file and translate it to a mapcalculator expression (safed in temporary file)
+###Get variables linearPredictorNormalizer, densityNormalizer and entropy from lambdas-file
+linearPredictorNormalizer=$(cat ${LAMBDAS_FILE} | grep linearPredictorNormalizer | sed 's/ //g' | tr -d '\r' | cut -f2 -d",")
+densityNormalizer=$(cat ${LAMBDAS_FILE} | grep densityNormalizer | sed 's/ //g' | tr -d '\r' | cut -f2 -d",")
+entropy=$(cat ${LAMBDAS_FILE} | grep entropy | sed 's/ //g' | tr -d '\r' | cut -f2 -d",")
+###Create file with initial part of mapcalc-expression
+echo "${OUTPUT_PREFIX}_raw=exp(((\\" > "$temp1"
+###Extract raw features
+cat -v "${LAMBDAS_FILE}" | awk '$0 !~ /\^|\(|\*/' | grep -vP "\`" | grep -vP "\'" | sed 's/\^M//g' | sed 's/,//g' | awk 'NF==4{print "if(isnull(" $1 "),0,(" $2 "*(" $1 "-" $3 ")/(" $4 "-" $3 ")))" "+" "\\"}' | sed 's/--/+/g' | sed 's/+-/-/g' >> $temp1
+###Extract quadratic features
+cat -v "${LAMBDAS_FILE}" | grep '\^2' | sed 's/\^M//g' | sed 's/,//g' | sed 's/\^2//g' | awk '{print "if(isnull(" $1 "),0,((" $2 "*(" $1 "*" $1 "-" $3 "))/" "(" $4 "-" $3 ")))" "+" "\\"}' | sed 's/--/+/g' | sed 's/+-/-/g' >> $temp1
+###Extract product features
+cat -v "${LAMBDAS_FILE}" | grep '*' | sed 's/\^M//g' | sed 's/,//g' | tr '*' ' ' | awk '{print "if((isnull(" $1 ")||isnull(" $2 ")),0,(" $3 "*(" $1 "*" $2 "-" $4 ")/(" $5 "-" $4 ")))+\\"}' | sed 's/--/+/g' | sed 's/+-/-/g' >> $temp1
+###Extract forward hinge features
+cat -v "${LAMBDAS_FILE}" | grep -P "\'" | sed 's/\^M//g' | sed 's/,//g' | cut -b 2- | tr '<' ' ' | awk '{print "if(isnull(" $1 "),0,if(" $1 ">=" $3 ",(" $2 "*(" $1 "-" $3 ")/(" $4 "-" $3 ")),0.0))+\\"}' | sed 's/--/+/g' | sed 's/+-/-/g' >> $temp1
+###Extract reverse hinge features
+cat -v "${LAMBDAS_FILE}" | grep -P "\`" | sed 's/\^M//g' | sed 's/,//g' | cut -b 2- | tr '<' ' ' | awk '{print "if(isnull(" $1 "),0,if(" $1 "<" $4 ",(" $2 "*(" $4 "-" $1 ")/(" $4 "-" $3 ")),0.0))+\\"}' | sed 's/--/+/g' | sed 's/+-/-/g' >> $temp1
+###Extract threshold features
+cat -v "${LAMBDAS_FILE}" | grep '(' | grep -v '=' | sed 's/\^M//g' | sed 's/,//g' | sed 's/(//g' | sed 's/)//g' | tr '<' ' ' | awk '{print "if(isnull(" $2 "),0,if(" $2 ">=" $1 "," $3 "))" "+\\"}' | sed 's/--/+/g' | sed 's/+-/-/g' >> $temp1
+###Extract categoric features
+cat -v "${LAMBDAS_FILE}" | grep '(' | grep '=' | sed 's/\^M//g' | sed 's/,//g' | sed 's/(//g' | sed 's/)//g' | tr '=' ' ' | awk '{print "if(isnull(" $1 "),0,if(" $1 "==" $2 "," $3 "))" "+\\"}' | sed 's/--/+/g' | sed 's/+-/-/g' >> $temp1
+###Replace last '\' by tail part of mapcalc-expression
+sed -i '$s/..$/\\/' "$temp1"
+echo ")-${linearPredictorNormalizer}))/${densityNormalizer}" >> "$temp1"
+###Replace possible repetitions of mathmatical signs
+sed -i 's/--/+/g' "$temp1"
+sed -i 's/+-/-/g' "$temp1"
+#Check if alias file is provided and readable
+if [ -n "$ALIAS_FILE" ] ; then
+	if [ ! -r "$ALIAS_FILE" ] ; then
+		g.message -e "Alias file could not be found or is not readable."
+		exit 1
+	else
+		#Parse alias-file to replace MaxEnt alias names by GRASS map names (including mapset specification)
+		alias_names=$(cat $ALIAS_FILE | cut -f1 -d",")
+		for a in $alias_names
+		do
+		m=$(cat $ALIAS_FILE | grep -w "${a}" | cut -f2 -d",")
+		g.message -v "Map name for alias $a is $m"
+		sed -i "s/(${a}-/(${m}-/" "$temp1"
+		sed -i "s/(${a}+/(${m}+/" "$temp1"
+		sed -i "s/(${a}>/(${m}>/" "$temp1"
+		sed -i "s/(${a}</(${m}</" "$temp1"
+		sed -i "s/(${a}=/(${m}=/" "$temp1"
+		sed -i "s/(${a}\*/(${m}\*/" "$temp1"
+		sed -i "s/-${a})/-${m})/" "$temp1"
+		sed -i "s/+${a})/+${m})/" "$temp1"
+		sed -i "s/>${a})/>${m})/" "$temp1"
+		sed -i "s/<${a})/<${m})/" "$temp1"
+		sed -i "s/=${a})/=${m})/" "$temp1"
+		sed -i "s/\*${a}-/\*${m}-/" "$temp1"
+		sed -i "s/\*${a}+/\*${m}+/" "$temp1"
+		done
+	fi
+fi
+###Compute raw output map by sending expression saved in file temporary file to r.mapcalc
+cat "$temp1" | r.mapcalc
+###Compute logistic output map if not suppressed
+if [ "${FLAG_ONLY_RAW}" -eq 0 ] ; then
+	if  [ "${INTEGER_OUTPUT}" -le 0 ] ; then
+		echo "${OUTPUT_PREFIX}_logistic = (${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy})))" >> "$temp1"
+		r.mapcalc "${OUTPUT_PREFIX}_logistic = (${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy})))"
+	else
+		if  [ "${INTEGER_OUTPUT}" -lt 5 ] ; then
+			echo "${OUTPUT_PREFIX}_logistic = round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*(10^${INTEGER_OUTPUT}))" >> "$temp1"
+			r.mapcalc "${OUTPUT_PREFIX}_logistic = round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*(10^${INTEGER_OUTPUT}))"
+		else
+			echo "${OUTPUT_PREFIX}_logistic = round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*100000.0)" >> "$temp1"
+			r.mapcalc "${OUTPUT_PREFIX}_logistic = round(((${OUTPUT_PREFIX}_raw*exp(${entropy}))/(1.0+(${OUTPUT_PREFIX}_raw*exp(${entropy}))))*100000.0)"
+		fi
+	fi
+fi
+###Remove raw output map if requested
+if [ "${FLAG_ONLY_LOGISTIC}" -eq 1 ] ; then
+	g.remove -f rast="${OUTPUT_PREFIX}"_raw
+fi
+###Remove tmp-file containing r.mapcalc expressions (if save to file not requested)
+	rm -f "$temp1"
+fi
+g.message "Done"
Property changes on: grass-addons/grass6/raster/r.maxent.lambdas/r.maxent.lambdas_v2
___________________________________________________________________
Added: svn:executable
