[GRASS-SVN] r54801 - in grass-addons/grass7/raster/r.agent: libagent tests
svn_grass at osgeo.org
Sun Jan 27 16:40:21 PST 2013
Author: mic
Date: 2013-01-27 16:40:20 -0800 (Sun, 27 Jan 2013)
New Revision: 54801
grass-addons/grass7/raster/r.agent/libagent/playground.py
grass-addons/grass7/raster/r.agent/libagent/world.py
grass-addons/grass7/raster/r.agent/tests/test_aco.py
grass-addons/grass7/raster/r.agent/tests/test_world.py
get some agents into the world
Modified: grass-addons/grass7/raster/r.agent/libagent/playground.py
--- grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-27 23:33:09 UTC (rev 54800)
+++ grass-addons/grass7/raster/r.agent/libagent/playground.py 2013-01-28 00:40:20 UTC (rev 54801)
@@ -106,3 +106,15 @@
ns = random.randrange(0,self.region["rows"])
nw = random.randrange(0,self.region["cols"])
return [ns,nw]
+ def isvalidposition(self, position):
+ Test if a position realy is on the playground
+ @return boolean True if on, False if off the playground
+ if self.region["s"] <= position[0] < self.region["n"] and \
+ self.region["w"] <= position[1] < self.region["e"]:
+ return True
+ else:
+ return False
Modified: grass-addons/grass7/raster/r.agent/libagent/world.py
--- grass-addons/grass7/raster/r.agent/libagent/world.py 2013-01-27 23:33:09 UTC (rev 54800)
+++ grass-addons/grass7/raster/r.agent/libagent/world.py 2013-01-28 00:40:20 UTC (rev 54801)
@@ -56,6 +56,22 @@
return self.playground.getlayer(layername)
+ def findposition(self, position=None):
+ Find a given position on the playground, i.e. test if the
+ given position is valid or invent a new one by creating a
+ random one
+ @param list optional coordinates on the playground or None for random
+ @return list position or False if the given one was invalid
+ if position:
+ if self.playground.isvalidposition(position):
+ return position
+ else:
+ return False
+ else:
+ return self.playground.getrandomposition()
def bear(self, timetolive, position=None, agenttype=None):
Set a new agent into the world
@@ -63,19 +79,23 @@
@param list coordinates to put the agent or none for a random position
@return agent the newly created agent
+ position = self.findposition(position)
if not position:
- position = self.playground.getrandomposition()
+ raise error.DataError("world.bear", "invalid position")
agent = self.agenttype(timetolive, self, position)
self.agents.append(agent)
return agent
- def move(self, agent, position):
+ def move(self, agent, position=None):
Set agent to a new position
@param agent to be moved
- @param list coordinates of the new position
+ @param list coordinates of the new position or none for a random one
- pass
+ if not position:
+ agent.setposition(position)
def getposition(self, agent):
Modified: grass-addons/grass7/raster/r.agent/tests/test_aco.py
--- grass-addons/grass7/raster/r.agent/tests/test_aco.py 2013-01-27 23:33:09 UTC (rev 54800)
+++ grass-addons/grass7/raster/r.agent/tests/test_aco.py 2013-01-28 00:40:20 UTC (rev 54801)
@@ -17,6 +17,9 @@
def test_getlayer(self):
pass
+ def findposition(self):
+ pass
def test_bear(self):
pass
Modified: grass-addons/grass7/raster/r.agent/tests/test_world.py
--- grass-addons/grass7/raster/r.agent/tests/test_world.py 2013-01-27 23:33:09 UTC (rev 54800)
+++ grass-addons/grass7/raster/r.agent/tests/test_world.py 2013-01-28 00:40:20 UTC (rev 54801)
@@ -2,7 +2,7 @@
import unittest2 as unittest
#import unittest
-from libagent import world
+from libagent import world, error
class TestWorld(unittest.TestCase):
def setUp(self):
@@ -23,13 +23,25 @@
self.assertIs(self.world.getlayer("foo"),
self.world.playground.layers["foo"])
+ self.assertFalse(self.world.findposition([-1,-1]))
+ self.assertNotNone(self.world.findposition([0,0]))
+ self.assertEqual(0,*self.world.findposition())
- agent = self.world.bear(1, [1,1])
+ self.assertRaises(error.DataError, self.world.bear, *(1, [-1,-1]))
+ agent = self.world.bear(1, [0,0])
self.assertIsInstance(agent, self.world.agenttype)
self.assertIs(agent, self.world.agents.pop())
+ agent = self.world.bear(1)
+ self.assertIs(agent, self.world.agents.pop())
def test_move(self):
- pass
+ self.assertRaises(error.DataError, self.world.move, *(agent, [-1,-1]))
+ position = [0,0]
+ self.world.move(agent, position)
+ self.assertEqual(agent.position, position)
def test_getposition(self):
pass
