[GRASS-SVN] r54815 - grass/trunk/db/db.select
svn_grass at osgeo.org
Wed Jan 30 05:27:49 PST 2013
Author: lucadelu
Date: 2013-01-30 05:27:49 -0800 (Wed, 30 Jan 2013)
New Revision: 54815
grass/trunk/db/db.select/main.c
fix separator in db.select
Modified: grass/trunk/db/db.select/main.c
--- grass/trunk/db/db.select/main.c 2013-01-30 11:24:13 UTC (rev 54814)
+++ grass/trunk/db/db.select/main.c 2013-01-30 13:27:49 UTC (rev 54815)
@@ -27,7 +27,7 @@
#include "local_proto.h"
struct {
- char *driver, *database, *table, *sql, *fs, *vs, *nv, *input, *output;
+ char *driver, *database, *table, *sql, fs, vs, *nv, *input, *output;
int c, d, h, test_only;
} parms;
@@ -141,7 +141,7 @@
for (col = 0; col < ncols; col++) {
column = db_get_table_column(table, col);
if (col)
- fprintf(stdout, "%s", parms.fs);
+ fprintf(stdout, "%s", &parms.fs);
fprintf(stdout, "%s", db_get_column_name(column));
fprintf(stdout, "\n");
@@ -159,9 +159,9 @@
value = db_get_column_value(column);
db_convert_column_value_to_string(column, &value_string);
if (parms.c && !parms.h)
- fprintf(stdout, "%s%s", db_get_column_name(column), parms.fs);
+ fprintf(stdout, "%s%s", db_get_column_name(column), &parms.fs);
if (col && parms.h)
if (parms.nv && db_test_value_isnull(value))
fprintf(stdout, "%s", parms.nv);
else
@@ -172,7 +172,7 @@
if (parms.h)
else if (parms.vs)
- fprintf(stdout, "%s\n", parms.vs);
+ fprintf(stdout, "%s\n", &parms.vs);
return OK;
@@ -270,8 +270,11 @@
parms.database = database->answer;
parms.table = table->answer;
parms.sql = sql->answer;
- parms.fs = fs->answer;
- parms.vs = vs->answer;
+ parms.fs = G_option_to_separator(fs);
+ if (vs->answer)
+ parms.vs = G_option_to_separator(vs);
+ else
+ parms.vs = vs->answer;
parms.nv = nv->answer;
parms.input = input->answer;
parms.output = output->answer;
@@ -287,9 +290,6 @@
parms.h = FALSE;
parms.test_only = flag_test->answer;
- if (!parms.fs)
- parms.fs = "";
if (parms.input && *parms.input == 0) {
G_usage();
