[GRASS-SVN] r56982 - in grass/trunk: display/d.font general/g.access general/g.mkfontcap include include/defs include/iostream lib/db/dbmi_base lib/gis lib/init lib/vector/Vlib lib/vector/dglib/examples lib/vector/diglib raster/r.li/r.li.daemon vector/v.mapcalc
svn_grass at osgeo.org
Tue Jul 2 07:37:38 PDT 2013
Author: mmetz
Date: 2013-07-02 07:37:37 -0700 (Tue, 02 Jul 2013)
New Revision: 56982
grass/trunk/display/d.font/main.c
grass/trunk/general/g.access/get_perms.c
grass/trunk/general/g.mkfontcap/freetype_fonts.c
grass/trunk/include/config.h.in
grass/trunk/include/defs/gis.h
grass/trunk/include/iostream/ami_stream.h
grass/trunk/lib/db/dbmi_base/isdir.c
grass/trunk/lib/gis/copy_dir.c
grass/trunk/lib/gis/mapset_msc.c
grass/trunk/lib/gis/mapset_nme.c
grass/trunk/lib/gis/paths.c
grass/trunk/lib/gis/remove.c
grass/trunk/lib/gis/user_config.c
grass/trunk/lib/init/clean_temp.c
grass/trunk/lib/vector/Vlib/open.c
grass/trunk/lib/vector/dglib/examples/parse.c
grass/trunk/lib/vector/diglib/file.c
grass/trunk/raster/r.li/r.li.daemon/daemon.c
grass/trunk/vector/v.mapcalc/map.c
simplify wingrass LFS
Modified: grass/trunk/display/d.font/main.c
--- grass/trunk/display/d.font/main.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/display/d.font/main.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -17,7 +17,6 @@
* for details.
-#include <grass/config.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
@@ -99,7 +98,7 @@
if (opt2->answer) { /* Full path to freetype font */
- STRUCT_STAT info;
+ struct stat info;
/* Check a valid filename has been supplied */
if (stat(opt2->answer, &info) != 0)
Modified: grass/trunk/general/g.access/get_perms.c
--- grass/trunk/general/g.access/get_perms.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/general/g.access/get_perms.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -1,11 +1,11 @@
#include <sys/types.h>
#include <sys/stat.h>
+#include <grass/config.h>
#include "access.h"
int get_perms(char *path, int *perms, int *group, int *other)
- STRUCT_STAT buf;
+ struct stat buf;
if (stat(path, &buf) != 0)
return -1;
Modified: grass/trunk/general/g.mkfontcap/freetype_fonts.c
--- grass/trunk/general/g.mkfontcap/freetype_fonts.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/general/g.mkfontcap/freetype_fonts.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -14,7 +14,6 @@
#include <stdio.h>
#include <string.h>
@@ -84,7 +83,7 @@
char filepath[GPATH_MAX];
DIR *curdir;
struct dirent *cur_entry;
- STRUCT_STAT info;
+ struct stat info;
curdir = opendir(dirpath);
if (curdir == NULL)
Modified: grass/trunk/include/config.h.in
--- grass/trunk/include/config.h.in 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/include/config.h.in 2013-07-02 14:37:37 UTC (rev 56982)
@@ -297,20 +297,12 @@
#define stat _stati64
#define fstat _fstati64
-#define _STRUCT_STAT_
-typedef struct _stati64 STRUCT_STAT;
#endif /* MINGW32 LFS */
#endif /* HAVE_LARGEFILES */
-#ifndef _STRUCT_STAT_
-#include <sys/stat.h>
-typedef struct stat STRUCT_STAT;
-#endif
/* define if langinfo.h exists */
#undef HAVE_LANGINFO_H
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/include/defs/gis.h 2013-07-02 14:37:37 UTC (rev 56982)
@@ -498,8 +498,8 @@
int G_is_absolute_path(const char *);
char *G_convert_dirseps_to_host(char *);
char *G_convert_dirseps_from_host(char *);
-int G_lstat(const char *, STRUCT_STAT *);
-int G_stat(const char *, STRUCT_STAT *);
+int G_lstat(const char *, struct stat *);
+int G_stat(const char *, struct stat *);
int G_owner(const char *);
/* percent.c */
Modified: grass/trunk/include/iostream/ami_stream.h
--- grass/trunk/include/iostream/ami_stream.h 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/include/iostream/ami_stream.h 2013-07-02 14:37:37 UTC (rev 56982)
@@ -412,7 +412,7 @@
return (st_size / sizeof(T));
#else
- STRUCT_STAT buf;
+ struct stat buf;
if (stat(path, &buf) == -1) {
perror("AMI_STREAM::stream_len(): fstat failed ");
DEBUG_ASSERT assert(0);
Modified: grass/trunk/lib/db/dbmi_base/isdir.c
--- grass/trunk/lib/db/dbmi_base/isdir.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/db/dbmi_base/isdir.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -28,7 +28,7 @@
int db_isdir(const char *path)
- STRUCT_STAT x;
+ struct stat x;
if (stat(path, &x) != 0)
return DB_FAILED;
Modified: grass/trunk/lib/gis/copy_dir.c
--- grass/trunk/lib/gis/copy_dir.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/gis/copy_dir.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -63,7 +63,7 @@
int G_recursive_copy(const char *src, const char *dst)
DIR *dirp;
- STRUCT_STAT sb;
+ struct stat sb;
if (G_lstat(src, &sb) < 0)
return 1;
Modified: grass/trunk/lib/gis/mapset_msc.c
--- grass/trunk/lib/gis/mapset_msc.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/gis/mapset_msc.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -88,7 +88,7 @@
return G__make_mapset_element(buf);
-static int check_owner(const STRUCT_STAT *info)
+static int check_owner(const struct stat *info)
#if defined(__MINGW32__) || defined(SKIP_MAPSET_OWN_CHK)
return 1;
@@ -116,7 +116,7 @@
int G__mapset_permissions(const char *mapset)
char path[GPATH_MAX];
- STRUCT_STAT info;
+ struct stat info;
G_file_name(path, "", "", mapset);
@@ -146,7 +146,7 @@
const char *mapset)
- STRUCT_STAT info;
+ struct stat info;
sprintf(path, "%s/%s/%s", gisdbase, location, mapset);
Modified: grass/trunk/lib/gis/mapset_nme.c
--- grass/trunk/lib/gis/mapset_nme.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/gis/mapset_nme.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -159,7 +159,7 @@
while ((ent = readdir(dir))) {
char buf[GPATH_MAX];
- STRUCT_STAT st;
+ struct stat st;
sprintf(buf, "%s/%s/WIND", G_location_path(), ent->d_name);
Modified: grass/trunk/lib/gis/paths.c
--- grass/trunk/lib/gis/paths.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/gis/paths.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -120,12 +120,12 @@
* Returns information about the specified file.
* \param file_name file name
- * \param stat
+ * \param stat pointer to structure filled with file information
* \return Return value from system lstat function
-int G_stat(const char *file_name, STRUCT_STAT *buf)
+int G_stat(const char *file_name, struct stat *buf)
return stat(file_name, buf);
@@ -135,14 +135,14 @@
- * \param file_name file name
- * \param stat in the case of a symbolic link, the link itself is
- * stat-ed, not the file that it refers to
+ * \param file_name file name, in the case of a symbolic link, the
+ * link itself is stat-ed, not the file that it refers to
-int G_lstat(const char *file_name, STRUCT_STAT *buf)
+int G_lstat(const char *file_name, struct stat *buf)
#ifdef __MINGW32__
@@ -165,7 +165,7 @@
#ifndef __MINGW32__
- STRUCT_STAT info;
+ struct stat info;
G_stat(path, &info);
Modified: grass/trunk/lib/gis/remove.c
--- grass/trunk/lib/gis/remove.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/gis/remove.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -106,7 +106,7 @@
DIR *dirp;
struct dirent *dp;
- STRUCT_STAT sb;
+ struct stat sb;
char path2[GPATH_MAX];
if (G_lstat(path, &sb))
Modified: grass/trunk/lib/gis/user_config.c
--- grass/trunk/lib/gis/user_config.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/gis/user_config.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -59,7 +59,7 @@
uid_t me;
struct passwd *my_passwd;
#endif
- STRUCT_STAT buf;
+ struct stat buf;
char *path;
errno = 0;
@@ -194,7 +194,7 @@
int i, status;
char *cp, *path, *top, *ptr;
- STRUCT_STAT buf;
+ struct stat buf;
/* Get top level path */
if (NULL == (top = _make_toplevel()))
Modified: grass/trunk/lib/init/clean_temp.c
--- grass/trunk/lib/init/clean_temp.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/init/clean_temp.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -42,7 +42,7 @@
char buf[BUF_MAX];
DIR *curdir;
- STRUCT_STAT info;
+ struct stat info;
int n, pathlen;
curdir = opendir(pathname);
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/vector/Vlib/open.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -894,7 +894,7 @@
int Vect_coor_info(const struct Map_info *Map, struct Coor_info *Info)
char *path, file_path[GPATH_MAX];
- STRUCT_STAT stat_buf;
+ struct stat stat_buf;
switch (Map->format) {
case GV_FORMAT_NATIVE:
Modified: grass/trunk/lib/vector/dglib/examples/parse.c
--- grass/trunk/lib/vector/dglib/examples/parse.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/vector/dglib/examples/parse.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -117,7 +117,7 @@
unsigned char *pbNodeAttr, *pbEdgeAttr, *pbToNodeAttr;
- STRUCT_STAT statdata;
+ struct stat statdata;
dglGraph_s graphOut;
Modified: grass/trunk/lib/vector/diglib/file.c
--- grass/trunk/lib/vector/diglib/file.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/lib/vector/diglib/file.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -189,7 +189,7 @@
int ret, mode, load;
const char *cmode;
size_t size;
- STRUCT_STAT sbuf;
+ struct stat sbuf;
G_debug(2, "dig_file_load ()");
Modified: grass/trunk/raster/r.li/r.li.daemon/daemon.c
--- grass/trunk/raster/r.li/r.li.daemon/daemon.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/raster/r.li/r.li.daemon/daemon.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -181,7 +181,7 @@
int parseSetup(char *path, struct list *l, struct g_area *g, char *raster)
- STRUCT_STAT s;
+ struct stat s;
struct Cell_head cellhd;
char *buf;
const char *token;
Modified: grass/trunk/vector/v.mapcalc/map.c
--- grass/trunk/vector/v.mapcalc/map.c 2013-07-02 13:57:15 UTC (rev 56981)
+++ grass/trunk/vector/v.mapcalc/map.c 2013-07-02 14:37:37 UTC (rev 56982)
@@ -129,7 +129,7 @@
return;
while ((ent = readdir(dir)) != NULL) {
- STRUCT_STAT buf;
+ struct stat buf;
if (!strcmp(ent->d_name, ".") || !strcmp(ent->d_name, ".."))
continue;
