[GRASS-SVN] r56998 - grass/trunk/gui/wxpython/vnet
svn_grass at osgeo.org
Wed Jul 3 05:38:12 PDT 2013
Author: turek
Date: 2013-07-03 05:38:12 -0700 (Wed, 03 Jul 2013)
New Revision: 56998
grass/trunk/gui/wxpython/vnet/dialogs.py
grass/trunk/gui/wxpython/vnet/vnet_core.py
grass/trunk/gui/wxpython/vnet/vnet_data.py
wx.vnet: cleanup fix
Modified: grass/trunk/gui/wxpython/vnet/dialogs.py
--- grass/trunk/gui/wxpython/vnet/dialogs.py 2013-07-03 11:06:40 UTC (rev 56997)
+++ grass/trunk/gui/wxpython/vnet/dialogs.py 2013-07-03 12:38:12 UTC (rev 56998)
@@ -158,10 +158,6 @@
self.toolbars['mainToolbar'].UpdateUndoRedo(0, 0)
- def __del__(self):
- """!Removes temp layers, unregisters handlers and graphics"""
- #TODO onclose
- pass
def _addPanes(self):
"""!Adds toolbar pane and pane with tabs"""
@@ -759,6 +755,7 @@
def OnCloseDialog(self, event):
"""!Cancel dialog"""
+ self.vnet_mgr.CleanUp()
self.parent.dialogs['vnet'] = None
self.Destroy()
@@ -1633,7 +1630,7 @@
self.btnAdd.Bind(wx.EVT_BUTTON, self.OnAddButtonClick)
self.btnRemove.Bind(wx.EVT_BUTTON, self.OnRemoveButtonClick)
- self.btnClose.Bind(wx.EVT_BUTTON, self.OnCloseDialog)
+ self.Bind(wx.EVT_CLOSE, self.OnCloseDialog)
self.useUTurns.Bind(wx.EVT_CHECKBOX, self.OnCheckedUTurns)
self.btnClose.SetDefault()
Modified: grass/trunk/gui/wxpython/vnet/vnet_core.py
--- grass/trunk/gui/wxpython/vnet/vnet_core.py 2013-07-03 11:06:40 UTC (rev 56997)
+++ grass/trunk/gui/wxpython/vnet/vnet_core.py 2013-07-03 12:38:12 UTC (rev 56998)
@@ -60,9 +60,6 @@
self.history = VNETHistory(self.guiparent, self.vnet_data, self.tmp_maps)
self.analyses = VNETAnalyses(self.vnet_data, self.RunAnDone, self.goutput, self.tmp_maps)
- # information, whether mouse event handler is registered in map window
- self.handlerRegistered = False
self.snap_nodes = SnappingNodes(self.vnet_data, self.tmp_maps, self.mapWin)
self.ttbCreated = Signal('VNETManager.ttbCreated')
@@ -75,9 +72,15 @@
def __del__(self):
+ self.CleanUp()
+ def CleanUp(self):
update = self.tmp_maps.DeleteAllTmpMaps()
+ self.vnet_data.CleanUp()
if update:
up_map_evt = gUpdateMap(render = True, renderVector = True)
wx.PostEvent(self.mapWin, up_map_evt)
Modified: grass/trunk/gui/wxpython/vnet/vnet_data.py
--- grass/trunk/gui/wxpython/vnet/vnet_data.py 2013-07-03 11:06:40 UTC (rev 56997)
+++ grass/trunk/gui/wxpython/vnet/vnet_data.py 2013-07-03 12:38:12 UTC (rev 56998)
@@ -60,6 +60,9 @@
self.pointsChanged = self.an_points.pointsChanged
self.parametersChanged = self.an_params.parametersChanged
+ self.an_points.CleanUp()
def GetAnalyses(self):
return self.an_props.used_an
@@ -220,6 +223,7 @@
self.an_data = an_data
self.an_params = an_params
+ # information, whether mouse event handler is registered in map window
self.pointsChanged = Signal('VNETPointsData.pointsChanged')
@@ -250,7 +254,9 @@
self.selected = 0
def __del__(self):
+ self.CleanUp()
self.mapWin.UnregisterGraphicsToDraw(self.pointsToDraw)
if self.handlerRegistered:
