[GRASS-SVN] r57001 - grass/trunk/gui/wxpython
svn_grass at osgeo.org
Wed Jul 3 08:29:38 PDT 2013
Author: wenzeslaus
Date: 2013-07-03 08:29:37 -0700 (Wed, 03 Jul 2013)
New Revision: 57001
grass/trunk/gui/wxpython/wxguitoolboxes.dox
wxGUI/toolboxes: reflecting the change in r57000 and noting the need for valid XML file
Modified: grass/trunk/gui/wxpython/wxguitoolboxes.dox
--- grass/trunk/gui/wxpython/wxguitoolboxes.dox 2013-07-03 15:23:20 UTC (rev 57000)
+++ grass/trunk/gui/wxpython/wxguitoolboxes.dox 2013-07-03 15:29:37 UTC (rev 57001)
@@ -121,9 +121,9 @@
When \c toolboxes.xml or \c main_menu.xml file is not in user home directory
but \c menudata.xml is, the file is re-generated (each time the GUI starts).
So, if you just have your own \c main_menu.xml, it is better to create also
-a \c toolboxes.xml file with no toolboxes (you may want to remove
-\c "<user-toolboxes-list>" tag from your \c main_menu.xml file because it will
-be no longer ignored). Similarly, if you have only the \c toolboxes.xml file it
+a \c toolboxes.xml file with no toolboxes (note that you still need to create
+a valid XML toolbox file).
+Similarly, if you have only the \c toolboxes.xml file it
is better to copy the \c main_menu.xml file from distribution into your home
directory.
