[GRASS-SVN] r57008 - grass/trunk/imagery/i.segment
svn_grass at osgeo.org
Thu Jul 4 02:13:47 PDT 2013
Author: mmetz
Date: 2013-07-04 02:13:47 -0700 (Thu, 04 Jul 2013)
New Revision: 57008
grass/trunk/imagery/i.segment/create_isegs.c
grass/trunk/imagery/i.segment/iseg.h
grass/trunk/imagery/i.segment/open_files.c
i.segment: fix NULL handling, bounds input, min size
Modified: grass/trunk/imagery/i.segment/create_isegs.c
--- grass/trunk/imagery/i.segment/create_isegs.c 2013-07-04 07:55:17 UTC (rev 57007)
+++ grass/trunk/imagery/i.segment/create_isegs.c 2013-07-04 09:13:47 UTC (rev 57008)
@@ -16,8 +16,14 @@
#define EPSILON 1.0e-8
-#define MAX(a,b) ( ((a)>(b)) ? (a) : (b) )
-#define MIN(a,b) ( ((a)<(b)) ? (a) : (b) )
+#ifdef MAX
+#undef MAX
+#endif
+#define MAX(a,b) ( ((a) > (b)) ? (a) : (b) )
+#ifdef MIN
+#undef MIN
+#endif
+#define MIN(a,b) ( ((a) < (b)) ? (a) : (b) )
/* internal functions */
@@ -111,7 +117,7 @@
int row, col;
int successflag = 1;
- int have_bound;
+ int have_bound, rid;
CELL current_bound, bounds_val;
G_debug(1, "segmentation method: %d", globals->method);
@@ -136,25 +142,29 @@
globals->col_max = 0;
for (row = 0; row < globals->nrows; row++) {
for (col = 0; col < globals->ncols; col++) {
+ FLAG_SET(globals->null_flag, row, col);
segment_get(&globals->bounds_seg, &bounds_val,
row, col);
- if (bounds_val == current_bound) {
- have_bound = 1;
+ if (!Rast_is_c_null_value(&bounds_val)
+ && bounds_val == current_bound) {
- FLAG_UNSET(globals->null_flag, row, col);
+ segment_get(&globals->rid_seg, &rid, row, col);
+ if (!Rast_is_c_null_value(&rid)) {
+ have_bound = 1;
- if (globals->row_min > row)
- globals->row_min = row;
- if (globals->row_max < row)
- globals->row_max = row;
- if (globals->col_min > col)
- globals->col_min = col;
- if (globals->col_max < col)
- globals->col_max = col;
+ FLAG_UNSET(globals->null_flag, row, col);
+ if (globals->row_min > row)
+ globals->row_min = row;
+ if (globals->row_max < row)
+ globals->row_max = row;
+ if (globals->col_min > col)
+ globals->col_min = col;
+ if (globals->col_max < col)
+ globals->col_max = col;
- else
- FLAG_SET(globals->null_flag, row, col);
globals->row_max++;
@@ -163,6 +173,17 @@
if (have_bound)
successflag = region_growing(globals);
} /* end outer loop for processing polygons */
+ /* restore NULL flag */
+ flag_clear_all(globals->null_flag);
+ for (row = 0; row < globals->nrows; row++) {
+ for (col = 0; col < globals->ncols; col++) {
+ if (Rast_is_c_null_value(&rid))
return successflag;
@@ -237,12 +258,14 @@
- G_debug(4, "Starting to process %d candidate cells",
+ G_debug(4, "Starting to process %ld candidate cells",
globals->candidate_count);
/*process candidate cells */
+ G_percent_reset();
for (row = globals->row_min; row < globals->row_max; row++) {
- G_percent(row, globals->row_max, 4);
+ G_percent(row - globals->row_min,
+ globals->row_max - globals->row_min, 4);
for (col = globals->col_min; col < globals->col_max; col++) {
if (!(FLAG_GET(globals->candidate_flag, row, col)))
continue;
@@ -301,6 +324,7 @@
if (Ri.count < Rk.count)
smaller = Ri.count;
+ /* TODO: better */
adjthresh = pow(alpha2, 1. + (double) smaller / divisor);
if (compare_double(Ri_similarity, adjthresh) == -1) {
@@ -322,6 +346,9 @@
(globals->nn >= 8 && Rk.count <= globals->nn))
candidates_only = FALSE;
+ if (Rk.id == 0)
+ pathflag = FALSE;
while (pathflag) {
pathflag = FALSE;
@@ -364,6 +391,9 @@
if (Ri_nn == 1 && Rk_nn > 1)
do_merge = 1;
+ if (Rk.id == 0)
+ do_merge = 0;
/* adjust threshold */
if (do_merge) {
int smaller = Rk.count;
@@ -371,6 +401,7 @@
smaller = Ri.count;
do_merge = 0;
@@ -507,6 +538,7 @@
flag_clear_all(globals->candidate_flag);
n_merges = 0;
+ globals->candidate_count = 0;
/* Set candidate flag to true/1 for all non-NULL cells */
@@ -519,20 +551,19 @@
/* process candidate cells */
- G_percent(row, globals->row_max, 9);
int do_merge = 1;
continue;
- nbtree_clear(Ri_ngbrs);
- nbtree_clear(Rk_ngbrs);
Ri.row = row;
Ri.col = col;
@@ -551,8 +582,12 @@
memcpy(Ri.mean, Ri_rs.mean, globals->datasize);
Ri.count = Ri_rs.count;
+ if (Ri.count >= globals->min_segment_size) {
+ set_candidate_flag(&Ri, FALSE, globals);
+ do_merge = 0;
while (do_merge) {
do_merge = 0;
/* merge all smaller than min size */
@@ -561,6 +596,8 @@
Ri_nn = 0;
Ri_similarity = 2;
+ Rk.id = 0;
if (do_merge) {
@@ -571,10 +608,7 @@
globals);
- if (Ri_nn > 0) {
+ if (Ri_nn > 0 && Rk.id != 0) {
/* merge Ri with Rk */
/* do not clear candidate flag for Rk */
merge_regions(&Ri, &Ri_rs, &Rk, &Rk_rs, 0, globals);
@@ -631,6 +665,13 @@
G_debug(4, "find_best_neighbor()");
+ if (Ri->id != Ri_rs->id)
+ G_fatal_error("Ri = %d but Ri_rs = %d", Ri->id, Ri_rs->id);
+ if (Ri->id <= 0)
+ G_fatal_error("Ri is %d", Ri->id);
+ if (Ri_rs->id <= 0)
+ G_fatal_error("Ri_rs is %d", Ri_rs->id);
/* dynamics of the region growing algorithm
* some regions are growing fast, often surrounded by many small regions
* not all regions are equally growing, some will only grow at a later stage ? */
@@ -642,17 +683,11 @@
ngbr_rc.col = Ri->col;
rbtree_insert(no_check_tree, &ngbr_rc);
+ nbtree_clear(Ri_ngbrs);
n_ngbrs = 0;
/* TODO: add size of largest region to reg_tree, use this as min */
Rk->count = globals->ncells;
Rk->id = Rk_rs->id = 0;
- if (Ri->id != Ri_rs->id)
- G_fatal_error("Ri = %d but Ri_rs = %d", Ri->id, Ri_rs->id);
- if (Ri->id <= 0)
- G_fatal_error("Ri is %d", Ri->id);
- if (Ri_rs->id <= 0)
- G_fatal_error("Ri_rs is %d", Ri_rs->id);
/* go through segment, spreading outwards from head */
rclist_init(&rilist);
@@ -1031,12 +1066,9 @@
int update_band_vals(int row, int col, struct reg_stats *rs,
struct globals *globals) {
- struct RB_TREE *rc_check_tree; /* cells already checked */
- struct rclist rlist;
struct rc next, ngbr_rc;
int neighbors[8][2];
int rid, count, n;
- int no_check;
/* update band values with sum */
/* rs->id must be set */
@@ -1053,70 +1085,116 @@
G_fatal_error(_("Region ids are different"));
- /* TODO: add fast version for globals->min_reg_size == 3 */
+ if (rs->count == 1) {
+ G_warning(_("Region consists of only one cell, nothing to update"));
+ return rs->count;
- /* go through region, spreading outwards from head */
- rclist_init(&rlist);
- rc_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
- ngbr_rc.row = row;
- ngbr_rc.col = col;
- rbtree_insert(rc_check_tree, &ngbr_rc);
+ /* update region stats */
+ segment_put(&globals->bands_seg, (void *)rs->sum, row, col);
count = 1;
- /* update region stats */
- segment_put(&globals->bands_seg, (void *)rs->sum,
- ngbr_rc.row, ngbr_rc.col);
+ /* fast version for rs->count == 2 */
+ if (rs->count == 2) {
+ globals->find_neighbors(row, col, neighbors);
- next.row = row;
- next.col = col;
- do {
- G_debug(5, "find_pixel_neighbors for row: %d , col %d",
- next.row, next.col);
- globals->find_neighbors(next.row, next.col, neighbors);
n = globals->nn - 1;
do {
ngbr_rc.row = neighbors[n][0];
ngbr_rc.col = neighbors[n][1];
- no_check = (ngbr_rc.row < 0 || ngbr_rc.row >= globals->nrows ||
- ngbr_rc.col < 0 || ngbr_rc.col >= globals->ncols);
+ if (ngbr_rc.row < globals->row_min || ngbr_rc.row >= globals->row_max ||
+ ngbr_rc.col < globals->col_min || ngbr_rc.col >= globals->col_max) {
+ continue;
- if (!no_check) {
- if ((FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col)) == 0) {
+ if ((FLAG_GET(globals->null_flag, ngbr_rc.row, ngbr_rc.col)) == 0) {
+ segment_get(&globals->rid_seg, (void *) &rid,
+ ngbr_rc.row, ngbr_rc.col);
- /* already checked ? */
- if (!rbtree_find(rc_check_tree, &ngbr_rc)) {
+ if (rid == rs->id) {
- /* not yet checked, don't check it again */
+ (void *)rs->sum,
- segment_get(&globals->rid_seg, (void *) &rid,
- if (rid == rs->id) {
+ count++;
- /* want to check this neighbor's neighbors */
- rclist_add(&rlist, ngbr_rc.row, ngbr_rc.col);
+ /* only one other neighbor can have the same ID
+ * deactivate for debugging */
+ break;
+ } while (n--);
+ if (count > 2)
+ G_fatal_error(_("Region size is larger than 2: %d"), count);
+ else if (rs->count > 2) {
+ struct RB_TREE *rc_check_tree; /* cells already checked */
+ struct rclist rlist;
+ int no_check;
- (void *)rs->sum,
+ /* go through region, spreading outwards from head */
+ rclist_init(&rlist);
+ rc_check_tree = rbtree_create(compare_rc, sizeof(struct rc));
+ ngbr_rc.row = row;
+ ngbr_rc.col = col;
+ rbtree_insert(rc_check_tree, &ngbr_rc);
+ next.row = row;
+ next.col = col;
+ do {
+ G_debug(5, "find_pixel_neighbors for row: %d , col %d",
+ next.row, next.col);
+ globals->find_neighbors(next.row, next.col, neighbors);
+ n = globals->nn - 1;
+ do {
+ ngbr_rc.row = neighbors[n][0];
+ ngbr_rc.col = neighbors[n][1];
+ no_check = (ngbr_rc.row < 0 || ngbr_rc.row >= globals->nrows ||
+ ngbr_rc.col < 0 || ngbr_rc.col >= globals->ncols);
+ if (!no_check) {
+ /* already checked ? */
+ if (!rbtree_find(rc_check_tree, &ngbr_rc)) {
+ /* not yet checked, don't check it again */
- count++;
+ /* want to check this neighbor's neighbors */
+ rclist_add(&rlist, ngbr_rc.row, ngbr_rc.col);
+ (void *)rs->sum,
+ count++;
- } while (n--);
- } while (rclist_drop(&rlist, &next));
+ } while (n--);
+ } while (rclist_drop(&rlist, &next));
- /* clean up */
- rbtree_destroy(rc_check_tree);
- rclist_destroy(&rlist);
+ /* clean up */
+ rbtree_destroy(rc_check_tree);
+ rclist_destroy(&rlist);
if (count != rs->count) {
G_fatal_error(_("Region size is %d, should be %d"),
@@ -1470,8 +1548,9 @@
rs->count++;
- /* only one other neighbor can have the same ID */
- /* break; */
+ break;
} while (n--);
Modified: grass/trunk/imagery/i.segment/iseg.h
--- grass/trunk/imagery/i.segment/iseg.h 2013-07-04 07:55:17 UTC (rev 57007)
+++ grass/trunk/imagery/i.segment/iseg.h 2013-07-04 09:13:47 UTC (rev 57008)
@@ -55,7 +55,7 @@
/* region info */
int nrows, ncols;
int row_min, row_max, col_min, col_max; /* region constraints */
- int ncells;
+ long ncells, notnullcells;
char *out_name; /* name of output raster map */
char *seeds, *bounds_map; /* optional segment seeds and polygon constraints/boundaries */
@@ -84,7 +84,7 @@
FLAG *candidate_flag, *null_flag; /*TODO, need some way to remember MASK/NULL values. Was using -1, 0, 1 in int array. Better to use 2 FLAG structures, better readibility? */
/* number of remaining cells to check */
- int candidate_count;
+ long candidate_count;
/* functions */
Modified: grass/trunk/imagery/i.segment/open_files.c
--- grass/trunk/imagery/i.segment/open_files.c 2013-07-04 07:55:17 UTC (rev 57007)
+++ grass/trunk/imagery/i.segment/open_files.c 2013-07-04 09:13:47 UTC (rev 57008)
@@ -17,7 +17,7 @@
int *in_fd, bounds_fd, is_null;
int n, row, col, srows, scols, inlen, outlen, nseg;
DCELL **inbuf; /* buffers to store lines from each of the imagery group rasters */
- CELL *boundsbuf, bounds_null, bounds_val;
+ CELL *boundsbuf, bounds_val;
int have_bounds = 0;
CELL s, id;
struct Range range; /* min/max values of bounds map */
@@ -29,6 +29,9 @@
globals->null_flag = flag_create(globals->nrows, globals->ncols);
globals->candidate_flag = flag_create(globals->nrows, globals->ncols);
+ flag_clear_all(globals->candidate_flag);
G_debug(1, "Checking image group...");
/* ****** open the input rasters ******* */
@@ -92,6 +95,29 @@
G_debug(1, "data element size, in: %d , out: %d ", inlen, outlen);
globals->datasize = sizeof(double) * globals->nbands;
+ /* count non-null cells */
+ globals->notnullcells = (long)globals->nrows * globals->ncols;
+ for (n = 0; n < Ref.nfiles; n++) {
+ Rast_get_d_row(in_fd[n], inbuf[n], row);
+ is_null = 0; /*Assume there is data */
+ if (Rast_is_d_null_value(&inbuf[n][col])) {
+ is_null = 1;
+ if (is_null) {
+ globals->notnullcells--;
+ if (globals->notnullcells < 2)
+ G_fatal_error(_("Insufficient number of non-NULL cells in current region"));
/* segment lib segment size */
srows = 64;
scols = 64;
@@ -110,7 +136,10 @@
G_fatal_error("Unable to create input temporary files");
/* load input bands to segment structure */
- G_debug(1, "Reading input rasters into segmentation data files...");
+ if (Ref.nfiles > 1)
+ G_message(_("Loading input bands..."));
+ else
+ G_message(_("Loading input band..."));
globals->bands_val = (double *)G_malloc(inlen);
globals->second_val = (double *)G_malloc(inlen);
@@ -122,6 +151,7 @@
globals->col_min = globals->ncols;
+ G_percent(row, globals->nrows, 4);
@@ -129,24 +159,21 @@
+ globals->bands_val[n] = inbuf[n][col];
is_null = 1;
- globals->bands_val[n] = inbuf[n][col];
else {
- if (globals->weighted == TRUE)
- else
+ if (globals->weighted == FALSE)
/* scaled version */
globals->bands_val[n] = (inbuf[n][col] - min[n]) / (max[n] - min[n]);
- segment_put(&globals->bands_seg, (void *)globals->bands_val, row, col);
+ if (segment_put(&globals->bands_seg,
+ (void *)globals->bands_val, row, col) != 1)
+ G_fatal_error(_("Unable to write to temporary file"));
if (!is_null) {
if (!globals->seeds) {
/* sequentially number all cells with a unique segment ID */
id = s;
@@ -154,7 +181,6 @@
/* get min/max row/col to narrow the processing window */
@@ -167,19 +193,24 @@
else {
/* all input bands NULL */
Rast_set_c_null_value(&id, 1);
- /*Rast_set_c_null_value(&(globals->rid[row][col]), 1);*/
- if (!globals->seeds)
- segment_put(&globals->rid_seg, (void *)&id, row, col);
+ if (!globals->seeds || is_null) {
+ if (segment_put(&globals->rid_seg,
+ (void *)&id, row, col) != 1)
- G_debug(1, "nrows: %d, min row: %d, max row %d", globals->nrows, globals->row_min, globals->row_max);
- G_debug(1, "ncols: %d, min col: %d, max col %d", globals->ncols, globals->col_min, globals->col_max);
+ G_debug(1, "nrows: %d, min row: %d, max row %d",
+ globals->nrows, globals->row_min, globals->row_max);
+ G_debug(1, "ncols: %d, min col: %d, max col %d",
+ globals->ncols, globals->col_min, globals->col_max);
globals->row_max++;
globals->col_max++;
- globals->ncells = (globals->row_max - globals->row_min) * (globals->col_max - globals->col_min);
+ globals->ncells = (long)(globals->row_max - globals->row_min) *
+ (globals->col_max - globals->col_min);
/* bounds/constraints */
@@ -205,27 +236,27 @@
globals->bounds_map);
- bounds_null = globals->upper_bound = globals->lower_bound + 1;
bounds_fd = Rast_open_old(globals->bounds_map, globals->bounds_mapset);
boundsbuf = Rast_allocate_c_buf();
Rast_get_c_row(bounds_fd, boundsbuf, row);
+ bounds_val = boundsbuf[col];
if (FLAG_GET(globals->null_flag, row, col)) {
Rast_set_c_null_value(&bounds_val, 1);
else {
- if (Rast_is_c_null_value(&boundsbuf[col]))
- boundsbuf[col] = bounds_null;
- else {
+ if (!Rast_is_c_null_value(&bounds_val)) {
have_bounds = 1;
- if (globals->lower_bound > boundsbuf[col])
- globals->lower_bound = boundsbuf[col];
+ if (globals->lower_bound > bounds_val)
+ globals->lower_bound = bounds_val;
+ if (globals->upper_bound < bounds_val)
+ globals->upper_bound = bounds_val;
- segment_put(&globals->bounds_seg, &bounds_val, row, col);
+ if (segment_put(&globals->bounds_seg, &bounds_val, row, col) != 1)
Rast_close(bounds_fd);
@@ -269,7 +300,6 @@
G_free(fp_range);
G_free(min);
G_free(max);
- /* Need to clean up anything else? */
return TRUE;
@@ -307,10 +337,11 @@
else {
seeds_val = seeds_buf[col];
- if (!Rast_is_c_null_value(&seeds_buf[col]))
+ if (!Rast_is_c_null_value(&seeds_val))
have_seeds = 1;
- segment_put(&seeds_seg, &seeds_val, row, col);
+ if (segment_put(&seeds_seg, &seeds_val, row, col) != 1)
@@ -331,12 +362,12 @@
Rast_get_c_row(seeds_fd, seeds_buf, row);
- if (FLAG_GET(globals->null_flag, row, col)) {
- segment_put(&globals->rid_seg, &seeds_val, row, col);
- else if (!(FLAG_GET(globals->candidate_flag, row, col))) {
- if (Rast_is_c_null_value(&(seeds_buf[col])) || seeds_buf[col] < 1) {
- segment_put(&globals->rid_seg, &sneg, row, col);
+ if (!(FLAG_GET(globals->null_flag, row, col)) &&
+ !(FLAG_GET(globals->candidate_flag, row, col))) {
+ if (Rast_is_c_null_value(&(seeds_buf[col]))) {
+ if (segment_put(&globals->rid_seg, &sneg, row, col) != 1)
sneg--;
else {
@@ -374,7 +405,8 @@
segment_get(seeds_seg, &Ri_id, Ri->row, Ri->col);
/* set new segment id */
- segment_put(&globals->rid_seg, &new_id, Ri->row, Ri->col);
+ if (segment_put(&globals->rid_seg, &new_id, Ri->row, Ri->col) != 1)
/* set candidate flag */
FLAG_SET(globals->candidate_flag, Ri->row, Ri->col);
@@ -428,7 +460,9 @@
/* set segment id */
- segment_put(&globals->rid_seg, &new_id, ngbr_rc.row, ngbr_rc.col);
+ &new_id, ngbr_rc.row, ngbr_rc.col) != 1)
FLAG_SET(globals->candidate_flag, ngbr_rc.row, ngbr_rc.col);
@@ -486,16 +520,16 @@
/* calculate number of region stats that can be kept in memory */
reg_size_count = (globals->mb - segs_mb) / reg_size_mb;
globals->min_reg_size = 3;
- if (reg_size_count < (double) globals->nrows * globals->ncols / globals->min_reg_size) {
- globals->min_reg_size = (double) globals->nrows * globals->ncols / reg_size_count;
+ if (reg_size_count < (double) globals->notnullcells / globals->min_reg_size) {
+ globals->min_reg_size = (double) globals->notnullcells / reg_size_count;
else {
- reg_size_count = (double) globals->nrows * globals->ncols / globals->min_reg_size;
+ reg_size_count = (double) globals->notnullcells / globals->min_reg_size;
/* recalculate segs_mb */
segs_mb = globals->mb - reg_size_count * reg_size_mb;
- G_verbose_message(_("Stats for regions with at least %d cells are stored in memory"),
+ G_verbose_message(_("Regions with at least %d cells are stored in memory"),
globals->min_reg_size);
/* calculate number of segments in memory */
