[GRASS-SVN] r57018 - grass/branches/releasebranch_6_4/vector/v.in.ogr
svn_grass at osgeo.org
Fri Jul 5 03:49:57 PDT 2013
Author: mmetz
Date: 2013-07-05 03:49:57 -0700 (Fri, 05 Jul 2013)
New Revision: 57018
grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c
v.in.ogr: fix OGR field evaluation
Modified: grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c
--- grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c 2013-07-05 10:49:46 UTC (rev 57017)
+++ grass/branches/releasebranch_6_4/vector/v.in.ogr/main.c 2013-07-05 10:49:57 UTC (rev 57018)
@@ -878,9 +878,9 @@
if (Ogr_ftype == OFTInteger || Ogr_ftype == OFTReal) {
sprintf(buf, ", %s",
OGR_F_GetFieldAsString(Ogr_feature, i));
#if GDAL_VERSION_NUM >= 1320
/* should we use OGR_F_GetFieldAsDateTime() here ? */
else if (Ogr_ftype == OFTDate || Ogr_ftype == OFTTime
|| Ogr_ftype == OFTDateTime) {
char *newbuf;
@@ -892,8 +892,8 @@
sprintf(buf, ", '%s'", db_get_string(&strval));
newbuf = G_str_replace(buf, "/", "-"); /* fix 2001/10/21 to 2001-10-21 */
sprintf(buf, "%s", newbuf);
#endif
else if (Ogr_ftype == OFTString ||
Ogr_ftype == OFTIntegerList) {
db_set_string(&strval, (char *)
@@ -902,24 +902,31 @@
db_double_quote_string(&strval);
+ else {
+ /* column type not supported */
+ buf[0] = 0;
else {
/* G_warning (_("Column value not set" )); */
sprintf(buf, ", NULL");
+ else if (Ogr_ftype == OFTDate ||
+ Ogr_ftype == OFTTime ||
+ Ogr_ftype == OFTDateTime) {
+ sprintf(buf, ", ''");
+#endif
- Ogr_ftype == OFTIntegerList ||
- Ogr_ftype == OFTDate) {
-#else
- else if (Ogr_ftype == OFTString ||
-#endif
+ else {
+ buf[0] = 0;
db_append_string(&sql, buf);
