[GRASS-SVN] r57033 - in grass/trunk: gui/wxpython/core scripts/m.proj scripts/r.in.wms
svn_grass at osgeo.org
Sat Jul 6 21:18:00 PDT 2013
Author: hamish
Date: 2013-07-06 21:18:00 -0700 (Sat, 06 Jul 2013)
New Revision: 57033
grass/trunk/gui/wxpython/core/utils.py
grass/trunk/scripts/m.proj/m.proj.py
grass/trunk/scripts/r.in.wms/wms_base.py
back to orig option name; refers to direction of travel, not entity being passed
Modified: grass/trunk/gui/wxpython/core/utils.py
--- grass/trunk/gui/wxpython/core/utils.py 2013-07-07 04:13:36 UTC (rev 57032)
+++ grass/trunk/gui/wxpython/core/utils.py 2013-07-07 04:18:00 UTC (rev 57033)
@@ -577,8 +577,8 @@
coors = RunCommand('m.proj',
flags = flags,
input = '-',
- proj_input = projIn,
- proj_output = projOut,
+ proj_in = projIn,
+ proj_out = projOut,
sep = ';',
stdin = '%f;%f' % (coord[0], coord[1]),
read = True)
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py 2013-07-07 04:13:36 UTC (rev 57032)
+++ grass/trunk/scripts/m.proj/m.proj.py 2013-07-07 04:18:00 UTC (rev 57033)
@@ -46,14 +46,14 @@
#% guisection: Files & format
#%end
#%option
-#% key: proj_input
+#% key: proj_in
#% type: string
#% description: Input projection parameters (PROJ.4 style)
#% required : no
#% guisection: Projections
#%end
#%option
-#% key: proj_output
+#% key: proj_out
#% type: string
#% description: Output projection parameters (PROJ.4 style)
#% required : no
@@ -113,8 +113,8 @@
input = options['input']
output = options['output']
fs = options['separator']
- proj_in = options['proj_input']
- proj_out = options['proj_output']
+ proj_in = options['proj_in']
+ proj_out = options['proj_out']
ll_in = flags['i']
ll_out = flags['o']
decimal = flags['d']
Modified: grass/trunk/scripts/r.in.wms/wms_base.py
--- grass/trunk/scripts/r.in.wms/wms_base.py 2013-07-07 04:13:36 UTC (rev 57032)
+++ grass/trunk/scripts/r.in.wms/wms_base.py 2013-07-07 04:18:00 UTC (rev 57033)
@@ -301,8 +301,8 @@
temp_region_opened.close()
points = grass.read_command('m.proj', flags = 'd',
- proj_output = self.proj_srs,
- proj_input = self.proj_location,
+ proj_out = self.proj_srs,
+ proj_in = self.proj_location,
input = temp_region,
quiet = True) # TODO: stdin
grass.try_remove(temp_region)
