[GRASS-SVN] r57037 - grass/branches/develbranch_6/scripts/m.proj
svn_grass at osgeo.org
Sun Jul 7 07:12:47 PDT 2013
Author: hamish
Date: 2013-07-07 07:12:47 -0700 (Sun, 07 Jul 2013)
New Revision: 57037
grass/branches/develbranch_6/scripts/m.proj/m.proj
another attempt at trying to make cs2cs, msys, bash, and Windows to play nicely together
Modified: grass/branches/develbranch_6/scripts/m.proj/m.proj
--- grass/branches/develbranch_6/scripts/m.proj/m.proj 2013-07-07 13:15:46 UTC (rev 57036)
+++ grass/branches/develbranch_6/scripts/m.proj/m.proj 2013-07-07 14:12:47 UTC (rev 57037)
@@ -113,6 +113,25 @@
LC_NUMERIC=C
export LC_NUMERIC
+# Get the system name
+SYSTEM=`uname -s`
+case $SYSTEM in
+MINGW* | MSYS*)
+ MINGW=1
+CYGWIN*)
+ CYGWIN=1
+Darwin*)
+ MACOSX=1
+esac
+dos2unix_path()
+ echo "$1" | sed -e 's|\("[A-Za-z]\):[\\/]|/\1/|' -e 's|\\|/|g'
# turn verbose mode on if requested either way
if [ "$GIS_FLAG_V" -eq 1 ] ; then
g.message -w "The verbosity option is superseded. Use --verbose instead"
@@ -173,10 +192,14 @@
if [ $(echo "$line" | grep -c '+nadgrids=') -gt 0 ] ; then
line=$(echo "$line" | sed -e 's/=/="/' -e 's/$/"/')
fi
- IN_PROJ="$IN_PROJ '$line'"
+ IN_PROJ="$IN_PROJ $line"
done
echo "$IN_PROJ"
+ # cs2cs gives an error for "C:/" not "C:\", but "/c/" seems ok
+ if [ "$MINGW" ] ; then
+ IN_PROJ=`dos2unix_path "$IN_PROJ"`
+ fi
fi
if [ -n "$GIS_OPT_PROJ_IN" ] ; then
IN_PROJ="$GIS_OPT_PROJ_IN"
@@ -198,10 +221,14 @@
fi
- OUT_PROJ="$OUT_PROJ '$line'"
+ OUT_PROJ="$OUT_PROJ $line"
done
echo "$OUT_PROJ"
+ OUT_PROJ=`dos2unix_path "$OUT_PROJ"`
+ fi
fi
if [ -n "$GIS_OPT_PROJ_OUT" ] ; then
OUT_PROJ="$GIS_OPT_PROJ_OUT"
@@ -280,12 +307,12 @@
if [ "$GIS_FLAG_G" -eq 1 ] ; then
if [ -z "$outfile" ] ; then
cat "$infile" | tr "$fs" ' ' | \
- eval cs2cs $COPYINP $OUTFMT `echo $IN_PROJ` +to `echo $OUT_PROJ` | \
+ eval cs2cs $COPYINP $OUTFMT $IN_PROJ +to $OUT_PROJ | \
tr -s "\t" "$GIS_OPT_FS" | tr -s " " "$GIS_OPT_FS"
EXITCODE=$?
else
tr -s "\t" "$GIS_OPT_FS" | tr -s " " "$GIS_OPT_FS" \
> "$outfile"
EXITCODE=$?
@@ -299,11 +326,11 @@
# write cs2cs output as is
EXITCODE=$?
else
- eval cs2cs $COPYINP $OUTFMT `echo $IN_PROJ` +to `echo $OUT_PROJ` \
+ eval cs2cs $COPYINP $OUTFMT $IN_PROJ +to $OUT_PROJ \
> "$outfile"
EXITCODE=$?
