[GRASS-SVN] r57049 - grass/trunk/lib/vector/Vlib
Tue Jul 9 14:27:37 PDT 2013
Author: mmetz
Date: 2013-07-09 14:27:37 -0700 (Tue, 09 Jul 2013)
New Revision: 57049
   grass/trunk/lib/vector/Vlib/remove_areas.c
Vlib: enhance Vect_remove_small_areas()
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c	2013-07-09 19:56:08 UTC (rev 57048)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c	2013-07-09 21:27:37 UTC (rev 57049)
@@ -17,6 +17,14 @@
 #include <grass/vector.h>
 #include <grass/glocale.h>
+/* #define DEGUG_RMAREA */
+int Vect_remove_small_areas_nat(struct Map_info *, double,
+                                struct Map_info *, double *);
+int Vect_remove_small_areas_ext(struct Map_info *, double,
    \brief Remove small areas from the map map.
@@ -30,10 +38,22 @@
    \return number of removed areas
 int
 Vect_remove_small_areas(struct Map_info *Map, double thresh,
 			struct Map_info *Err, double *removed_area)
+    if (Map->format == GV_FORMAT_NATIVE)
+	return Vect_remove_small_areas_nat(Map, thresh, Err, removed_area);
+    else
+	return Vect_remove_small_areas_ext(Map, thresh, Err, removed_area);
+int
+Vect_remove_small_areas_ext(struct Map_info *Map, double thresh,
+			struct Map_info *Err, double *removed_area)
     int area, nareas;
     int nremoved = 0;
     struct ilist *List;
@@ -101,7 +121,7 @@
 	G_debug(3, "num neighbours = %d", AList->n_values);
-	/* Go through the list of neghours and find that with the longest boundary */
+	/* Go through the list of neighours and find that with the longest boundary */
 	dissolve_neighbour = 0;
 	length = -1.0;
 	for (i = 0; i < AList->n_values; i++) {
@@ -178,3 +198,414 @@
     return (nremoved);
+/* much faster version */
+int
+Vect_remove_small_areas_nat(struct Map_info *Map, double thresh,
+    int area, nareas;
+    int nremoved = 0;
+    struct ilist *List;
+    struct ilist *AList;
+    struct ilist *BList;
+#ifdef DEGUG_RMAREA
+    struct ilist *NList;
+#endif
+    struct ilist *IList;
+    struct line_pnts *Points;
+    struct line_cats *Cats;
+    double size_removed = 0.0;
+    int dissolve_neighbour;
+    int line, left, right, neighbour;
+    int nisles, nnisles;
+    List = Vect_new_list();
+    AList = Vect_new_list();
+    BList = Vect_new_list();
+    NList = Vect_new_list();
+#endif
+    IList = Vect_new_list();
+    Points = Vect_new_line_struct();
+    Cats = Vect_new_cats_struct();
+    nareas = Vect_get_num_areas(Map);
+    for (area = 1; area <= nareas; area++) {
+	int i, j, centroid, ncentroid;
+	double length, l, size;
+	int outer_area = -1;
+	int narea, same_atype = 0;
+	G_percent(area, nareas, 1);
+	G_debug(3, "area = %d", area);
+	if (!Vect_area_alive(Map, area))
+	    continue;
+	size = Vect_get_area_area(Map, area);
+	if (size > thresh)
+	    continue;
+	size_removed += size;
+	/* The area is smaller than the limit -> remove */
+	/* Remove centroid */
+	centroid = Vect_get_area_centroid(Map, area);
+	if (centroid > 0) {
+	    if (Err) {
+		Vect_read_line(Map, Points, Cats, centroid);
+		Vect_write_line(Err, GV_CENTROID, Points, Cats);
+	    Vect_delete_line(Map, centroid);
+	/* Find the adjacent area with which the longest boundary is shared */
+	Vect_get_area_boundaries(Map, area, List);
+	/* Create a list of neighbour areas */
+	Vect_reset_list(AList);
+	for (i = 0; i < List->n_values; i++) {
+	    line = List->value[i];
+	    if (!Vect_line_alive(Map, abs(line)))	/* Should not happen */
+		G_fatal_error(_("Area is composed of dead boundary"));
+	    Vect_get_line_areas(Map, abs(line), &left, &right);
+	    if (line > 0)
+		neighbour = left;
+	    else
+		neighbour = right;
+	    G_debug(4, "  line = %d left = %d right = %d neighbour = %d",
+		    line, left, right, neighbour);
+	    ncentroid = 0;
+	    if (neighbour > 0) {
+		ncentroid = Vect_get_area_centroid(Map, neighbour);
+	    if (neighbour < 0) {
+		narea = Vect_get_isle_area(Map, -neighbour);
+		if (narea > 0)
+		    ncentroid = Vect_get_area_centroid(Map, narea);
+	    if ((centroid != 0) + (ncentroid != 0) != 1)
+		same_atype = 1;
+	    Vect_list_append(AList, neighbour);	/* this checks for duplicity */
+	G_debug(3, "num neighbours = %d", AList->n_values);
+	if (AList->n_values == 1)
+	    same_atype = 0;
+	/* Go through the list of neighbours and find the one with the longest boundary */
+	dissolve_neighbour = 0;
+	length = -1.0;
+	for (i = 0; i < AList->n_values; i++) {
+	    int neighbour1;
+	    l = 0.0;
+	    neighbour1 = AList->value[i];
+	    G_debug(4, "   neighbour1 = %d", neighbour1);
+	    if (same_atype) {
+		ncentroid = 0;
+		if (neighbour1 > 0) {
+		    ncentroid = Vect_get_area_centroid(Map, neighbour1);
+		if (neighbour1 < 0) {
+		    narea = Vect_get_isle_area(Map, -neighbour1);
+		    if (narea > 0)
+		if ((centroid != 0) + (ncentroid != 0) == 1)
+		    continue;
+	    for (j = 0; j < List->n_values; j++) {
+		int neighbour2;
+		line = List->value[j];
+		if (line > 0)
+		    neighbour2 = left;
+		else
+		    neighbour2 = right;
+		if (neighbour2 == neighbour1) {
+		    Vect_read_line(Map, Points, NULL, abs(line));
+		    l += Vect_line_length(Points);
+	    if (l > length) {
+		length = l;
+		dissolve_neighbour = neighbour1;
+	G_debug(3, "dissolve_neighbour = %d", dissolve_neighbour);
+	if (dissolve_neighbour == 0) {
+	    G_fatal_error("could not find neighbour to dissolve");
+	/* Make list of boundaries to be removed */
+	Vect_reset_list(BList);
+	    if (line > 0)
+		neighbour = left;
+	    else
+	    G_debug(3, "   neighbour = %d", neighbour);
+	    if (neighbour == dissolve_neighbour) {
+		Vect_list_append(AList, abs(line));
+	    else
+		Vect_list_append(BList, line);
+	G_debug(3, "remove %d of %d boundaries", AList->n_values, List->n_values);
+	/* Get isles inside area */
+	Vect_reset_list(IList);
+	if ((nisles = Vect_get_area_num_isles(Map, area)) > 0) {
+	    for (i = 0; i < nisles; i++) {
+		Vect_list_append(IList, Vect_get_area_isle(Map, area, i));
+	/* Remove boundaries */
+	    int ret;
+	    line = AList->value[i];
+	    if (Err) {
+		Vect_read_line(Map, Points, Cats, line);
+		Vect_write_line(Err, GV_BOUNDARY, Points, Cats);
+	    /* Vect_delete_line(Map, line); */
+	    /* delete the line from coor */
+	    ret = V1_delete_line_nat(Map, Map->plus.Line[line]->offset);
+	    if (ret == -1) {
+		G_fatal_error(_("Could not delete line from coor"));
+	/* update topo */
+	if (dissolve_neighbour > 0) {
+	    G_debug(3, "dissolve with neighbour area");
+	    /* get neighbour centroid */
+	    centroid = Vect_get_area_centroid(Map, dissolve_neighbour);
+	    /* get neighbour isles */
+	    if ((nnisles = Vect_get_area_num_isles(Map, dissolve_neighbour)) > 0) {
+		for (i = 0; i < nnisles; i++) {
+		    Vect_list_append(IList, Vect_get_area_isle(Map, dissolve_neighbour, i));
+	    /* get neighbour boundaries */
+	    Vect_get_area_boundaries(Map, dissolve_neighbour, NList);
+#endif
+	    /* delete area from topo */
+	    dig_del_area(&(Map->plus), area);
+	    /* delete neighbour area from topo */
+	    dig_del_area(&(Map->plus), dissolve_neighbour);
+	    /* delete boundaries from topo */
+		struct P_topo_b *topo;
+		struct P_node *Node;
+		topo = (struct P_topo_b *)Map->plus.Line[line]->topo;
+		Node = Map->plus.Node[topo->N1];
+		dig_del_line(&(Map->plus), line, Node->x, Node->y, Node->z);
+	    /* rebuild neighbour area from leftover boundaries */
+	    for (i = 0; i < BList->n_values; i++) {
+		line = BList->value[i];
+		topo = Map->plus.Line[abs(line)]->topo;
+		if (topo->left == 0 || topo->right == 0) {
+		    int new_isle;
+		    new_isle = Vect_build_line_area(Map, abs(line), (line > 0 ? GV_RIGHT : GV_LEFT));
+		    if (new_isle > 0) {
+			outer_area = new_isle;
+			/* reattach centroid */
+			Map->plus.Area[outer_area]->centroid = centroid;
+			    struct P_topo_c *ctopo = Map->plus.Line[centroid]->topo;
+			    ctopo->area = outer_area;
+		    else {
+			/* should not happen */
+			G_warning(_("Failed to build new area"));
+		/* check */
+		    G_warning(_("Dissolve with neighbour area: corrupt topology"));
+	    for (i = 0; i < NList->n_values; i++) {
+		line = NList->value[i];
+		    continue;
+		    int new_isle;
+		    G_warning(_("Neighbor boundaries should be complete"));
+		    else {
+#endif
+	/* dissolve with outer isle */
+	else if (dissolve_neighbour < 0) {
+	    G_debug(3, "dissolve with outer isle");
+	    outer_area = Vect_get_isle_area(Map, -dissolve_neighbour);
+	    /* get isle boundaries */
+	    Vect_get_isle_boundaries(Map, -dissolve_neighbour, NList);
+#endif
+	    /* delete isle from topo */
+	    dig_del_isle(&(Map->plus), -dissolve_neighbour);
+	    /* rebuild isles from leftover boundaries */
+		    int new_isle;
+		    if (new_isle < 0) {
+			Vect_list_append(IList, -new_isle);
+		    else {
+			G_warning(_("Failed to build new isle"));
+		/* check */
+		    G_warning(_("Dissolve with outer isle: corrupt topology"));
+		    continue;
+		    int new_isle;
+		    else {
+		/* check */
+#endif
+	if (dissolve_neighbour > 0 && outer_area <= 0) {
+	    G_fatal_error(_("Area merging failed"));
+	/* attach all isles to outer or new area */
+	if (outer_area >= 0) {
+	    for (i = 0; i < IList->n_values; i++) {
+		Map->plus.Isle[IList->value[i]]->area = outer_area;
+		if (outer_area > 0)
+		    dig_area_add_isle(&(Map->plus), outer_area, IList->value[i]);
+	nremoved++;
+    if (removed_area)
+	*removed_area = size_removed;
+    G_message(_("%d areas of total size %g removed"), nremoved,
+              size_removed);
+    Vect_destroy_list(List);
+    Vect_destroy_list(AList);
+    Vect_destroy_list(BList);
+    Vect_destroy_list(NList);
+#endif
+    Vect_destroy_list(IList);
+    Vect_destroy_line_struct(Points);
+    Vect_destroy_cats_struct(Cats);
+    return (nremoved);
