[GRASS-SVN] r57064 - grass/trunk/raster/r.neighbors
svn_grass at osgeo.org
Thu Jul 11 04:30:42 PDT 2013
Author: glynn
Date: 2013-07-11 04:30:42 -0700 (Thu, 11 Jul 2013)
New Revision: 57064
grass/trunk/raster/r.neighbors/main.c
Don't add 0.5 to floating-point output maps
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c 2013-07-10 14:14:16 UTC (rev 57063)
+++ grass/trunk/raster/r.neighbors/main.c 2013-07-11 11:30:42 UTC (rev 57064)
@@ -36,7 +36,7 @@
stat_func_w *method_w; /* routine to compute new value (weighted) */
ifunc cat_names; /* routine to make category names */
int copycolr; /* flag if color table can be copied */
- int half; /* whether to add 0.5 to result */
+ int half; /* whether to add 0.5 to result (redundant) */
char *name; /* method name */
char *text; /* menu display - full description */
@@ -77,7 +77,6 @@
stat_func *method_fn;
stat_func_w *method_fn_w;
int copycolr;
- int half;
ifunc cat_names;
int map_type;
double quantile;
@@ -314,7 +313,6 @@
out->method_fn = menu[method].method;
out->method_fn_w = NULL;
- out->half = menu[method].half;
out->copycolr = menu[method].copycolr;
out->cat_names = menu[method].cat_names;
if (out->copycolr)
@@ -411,9 +409,6 @@
memcpy(values_tmp, values, n * sizeof(DCELL));
(*out->method_fn)(rp, values_tmp, n, &out->quantile);
- if (out->half && !Rast_is_d_null_value(rp))
- *rp += 0.5;
