[GRASS-SVN] r57076 - grass-addons/grass7/raster/r.wf
svn_grass at osgeo.org
Sat Jul 13 07:00:04 PDT 2013
Author: neteler
Date: 2013-07-13 07:00:03 -0700 (Sat, 13 Jul 2013)
New Revision: 57076
grass-addons/grass7/raster/r.wf/r.wf.html
r.wf: fix HTML
Modified: grass-addons/grass7/raster/r.wf/r.wf.html
--- grass-addons/grass7/raster/r.wf/r.wf.html 2013-07-13 13:54:41 UTC (rev 57075)
+++ grass-addons/grass7/raster/r.wf/r.wf.html 2013-07-13 14:00:03 UTC (rev 57076)
@@ -1,16 +1,25 @@
<h2>DESCRIPTION</h2>
-<em>r.wf</em> produces the Width Function of a basin. The Width Function W(x) gives the number of the cells in a basin at a flow distance x from the outlet (it is also referred as distance-area function). It is important to underline the fact that the distance is not the euclidean one, but it is measured along the flowpath towards the outlet.
+<em>r.wf</em> produces the Width Function of a basin. The Width
+Function W(x) gives the number of the cells in a basin at a flow
+distance x from the outlet (it is also referred as distance-area
+function). It is important to underline the fact that the distance
+is not the euclidean one, but it is measured along the flowpath
+towards the outlet.
<h3>Input</h3>
-<dt><em>Distance to outlet map: </em>Input map, required. It is obtained by r.stream.distance (with
- the option: distance to outlet, flag -o) </dt>
-<dt><em>Output plot: </em> Path and name of the plot</dt>
+<em>Distance to outlet map: </em>Input map, required. It is obtained
+by r.stream.distance (with the option: distance to outlet, flag -o).
+<p>
+<em>Output plot: </em> Path and name of the plot.
<h3>Output</h3>
-<p>It provides the quantiles of the area - distance distribution and the plot of the Width Function. In x axis is reported the distance and in y axis is the area.
+It provides the quantiles of the area - distance distribution and
+the plot of the Width Function. In x axis is reported the distance
+and in y axis is the area.
<h3>Dependencies</h3>
<ul>
<li>Matplotlib</li>
@@ -24,12 +33,21 @@
</em>
<h2>REFERENCES</h2>
-<p><em>Rodriguez-Iturbe I., Rinaldo A. — Fractal River Basins, Chance and Self-Organization. Cambridge Press (2001)</em>
-<p><em>In Italian: Di Leo M., Di Stefano M., Claps P., Sole A. — Caratterizzazione morfometrica del bacino idrografico in GRASS GIS
-(Morphometric characterization of the catchment in GRASS GIS environment), <a href="http://geomatica.como.polimi.it/workbooks/">Geomatics Workbooks</a>, n. 9 (2010)</em></a>
+<ul>
+<li><em>Rodriguez-Iturbe I., Rinaldo A. — Fractal River
+Basins, Chance and Self-Organization. Cambridge Press (2001)</em>
+<li><em>In Italian: Di Leo M., Di Stefano M., Claps P., Sole A.
+— Caratterizzazione morfometrica del bacino idrografico in
+GRASS GIS (Morphometric characterization of the catchment in GRASS
+GIS environment),
+<a href="http://geomatica.como.polimi.it/workbooks/">Geomatics Workbooks</a>,
+n. 9 (2010)</em>
+</ul>
<h2>AUTHORS</h2>
-<p>Margherita Di Leo (dileomargherita AT gmail DOT com), Massimo Di Stefano, Francesco Di Stefano
+Margherita Di Leo (dileomargherita AT gmail DOT com), Massimo Di
+Stefano, Francesco Di Stefano
<p>
<i>Last changed: $Date$</i>
