[GRASS-SVN] r57101 - in grass/trunk/gui/wxpython: gui_core mapdisp
svn_grass at osgeo.org
Sun Jul 14 02:33:10 PDT 2013
Author: wenzeslaus
Date: 2013-07-14 02:33:10 -0700 (Sun, 14 Jul 2013)
New Revision: 57101
grass/trunk/gui/wxpython/gui_core/mapdisp.py
grass/trunk/gui/wxpython/gui_core/toolbars.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/mapwindow.py
wxGUI/mapwindow: removing direct StatusbarUpdate calls from mapwindow, replaced by zoomChanged signal (statusbar text partialy broken, temporarily)
Modified: grass/trunk/gui/wxpython/gui_core/mapdisp.py
--- grass/trunk/gui/wxpython/gui_core/mapdisp.py 2013-07-14 09:22:09 UTC (rev 57100)
+++ grass/trunk/gui/wxpython/gui_core/mapdisp.py 2013-07-14 09:33:10 UTC (rev 57101)
@@ -242,6 +242,7 @@
def StatusbarUpdate(self):
"""!Update statusbar content"""
+ Debug.msg(5, "MapFrameBase.StatusbarUpdate()")
self.statusbarManager.Update()
def IsAutoRendered(self):
Modified: grass/trunk/gui/wxpython/gui_core/toolbars.py
--- grass/trunk/gui/wxpython/gui_core/toolbars.py 2013-07-14 09:22:09 UTC (rev 57100)
+++ grass/trunk/gui/wxpython/gui_core/toolbars.py 2013-07-14 09:33:10 UTC (rev 57101)
@@ -205,6 +205,7 @@
try:
id = getattr(self, tool)
except AttributeError:
+ # this should raise an error
return
self.EnableTool(id, enable)
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2013-07-14 09:22:09 UTC (rev 57100)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2013-07-14 09:33:10 UTC (rev 57101)
@@ -165,6 +165,7 @@
self.MapWindow2D.mouseHandlerUnregistered.connect(self.ResetPointer)
self.MapWindow2D.InitZoomHistory()
+ self.MapWindow2D.zoomChanged.connect(self.StatusbarUpdate)
self._giface.updateMap.connect(self.MapWindow2D.UpdateMap)
# default is 2D display mode
@@ -1352,4 +1353,6 @@
bar = self.statusbarManager.GetProgressBar()
bar.SetRange(range)
bar.SetValue(value)
- self.SetStatusText(text)
+ # minimalize the damage in the status bar text
+ if text:
+ self.SetStatusText(text)
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-07-14 09:22:09 UTC (rev 57100)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py 2013-07-14 09:33:10 UTC (rev 57101)
@@ -1072,10 +1072,7 @@
# redraw map
self.UpdateMap()
- # update statusbar
- self.frame.StatusbarUpdate()
self.Refresh()
self.processMouse = True
@@ -1186,10 +1183,7 @@
# redraw map
self.UpdateMap(render = True)
elif self.mouse["use"] == "query":
self.mapQueried.emit(x=self.mouse['end'][0], y=self.mouse['end'][1])
@@ -1324,10 +1318,7 @@
# redraw map
def OnMouseEnter(self, event):
"""!Mouse entered window and no mouse buttons were pressed
@@ -1527,9 +1518,6 @@
update = True)
# update map
self.UpdateMap()
self.zoomChanged.emit()
@@ -1540,6 +1528,10 @@
Emits zoomHistoryAvailable signal when stack is not empty.
Emits zoomHistoryUnavailable signal when stack is empty.
+ All methods which are changing zoom should call this method
+ to make a record in the history. The signal zoomChanged will be
+ then emitted automatically.
@param n,s,e,w north, south, east, west
@return removed history item if exists (or None)
@@ -1637,9 +1629,7 @@
if render:
self.UpdateMap()
def ZoomToWind(self):
"""!Set display geometry to match computational region
settings (set with g.region)
@@ -1650,8 +1640,6 @@
self.Map.region['e'], self.Map.region['w'])
self.UpdateMap()
def ZoomToDefault(self):
"""!Set display geometry to match default region settings
@@ -1663,10 +1651,7 @@
self.UpdateMap()
def GoTo(self, e, n):
region = self.Map.GetCurrentRegion()
