[GRASS-SVN] r57105 - grass/trunk/gui/wxpython/vnet
svn_grass at osgeo.org
Sun Jul 14 02:51:18 PDT 2013
Author: turek
Date: 2013-07-14 02:51:17 -0700 (Sun, 14 Jul 2013)
New Revision: 57105
grass/trunk/gui/wxpython/vnet/vnet_data.py
wx.vnet points list bug fixing
Modified: grass/trunk/gui/wxpython/vnet/vnet_data.py
--- grass/trunk/gui/wxpython/vnet/vnet_data.py 2013-07-14 09:50:25 UTC (rev 57104)
+++ grass/trunk/gui/wxpython/vnet/vnet_data.py 2013-07-14 09:51:17 UTC (rev 57105)
@@ -277,8 +277,10 @@
self.pointsChanged.emit(method = "AddPoint", kwargs = {})
def DeletePoint(self, pt_id):
- self.pointsToDraw.DeleteItem(pt_id)
- self.data.pop(pt_id)
+ item = self.pointsToDraw.GetItem(pt_id)
+ if item:
+ self.pointsToDraw.DeleteItem(item)
+ self.data.pop(pt_id)
self.pointsChanged.emit(method = "DeletePoint", kwargs = {"pt_id" : pt_id})
@@ -307,7 +309,7 @@
if self._usePoint(pt_id, data["use"]) == -1:
data["use"] = False
idx = self.cols["name"].index("use")
- self.data[pt_id][idx] = v
+ self.data[pt_id][idx] = data["use"]
self.pointsChanged.emit(method = "SetPointData", kwargs = {"pt_id" : pt_id, "data" : data})
@@ -402,7 +404,6 @@
"""!Item is checked/unchecked"""
analysis, valid = self.an_params.GetParam("analysis")
cats = self.an_data[analysis]["cmdParams"]["cats"]
##TODO move
#if self.updateMap:
# up_map_evt = gUpdateMap(render = False, renderVector = False)
@@ -500,18 +501,18 @@
else:
msg = _("new point")
- if self.selected == len(self.data) - 1:
- self.SetSelected(0)
- else:
- self.SetSelected(self.GetSelected() + 1)
self.SetPointData(self.selected,
{'topology' : msg,
'e' : e,
'n' : n})
self.pointsToDraw.GetItem(self.selected).SetCoords([e, n])
+ if self.selected == len(self.data) - 1:
+ self.SetSelected(0)
+ else:
+ self.SetSelected(self.GetSelected() + 1)
def GetColumns(self, only_relevant = True):
cols_data = deepcopy(self.cols)
