[GRASS-SVN] r57127 - in grass/trunk/scripts: . g.isis3mt
svn_grass at osgeo.org
Sun Jul 14 09:56:43 PDT 2013
Author: ychemin
Date: 2013-07-14 09:56:43 -0700 (Sun, 14 Jul 2013)
New Revision: 57127
Added:
grass/trunk/scripts/g.isis3mt/
grass/trunk/scripts/g.isis3mt/Makefile
grass/trunk/scripts/g.isis3mt/g.isis3mt.html
grass/trunk/scripts/g.isis3mt/g.isis3mt.py
grass/trunk/scripts/Makefile
Generate an ISIS3 map template from actual location
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile 2013-07-14 16:45:55 UTC (rev 57126)
+++ grass/trunk/scripts/Makefile 2013-07-14 16:56:43 UTC (rev 57127)
@@ -15,6 +15,7 @@
db.test \
g.extension \
g.extension.rebuild.all \
+ g.isis3mt \
g.manual \
i.image.mosaic \
i.in.spotvgt \
Added: grass/trunk/scripts/g.isis3mt/Makefile
--- grass/trunk/scripts/g.isis3mt/Makefile (rev 0)
+++ grass/trunk/scripts/g.isis3mt/Makefile 2013-07-14 16:56:43 UTC (rev 57127)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM=g.isis3mt
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass/trunk/scripts/g.isis3mt/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass/trunk/scripts/g.isis3mt/g.isis3mt.html
--- grass/trunk/scripts/g.isis3mt/g.isis3mt.html (rev 0)
+++ grass/trunk/scripts/g.isis3mt/g.isis3mt.html 2013-07-14 16:56:43 UTC (rev 57127)
@@ -0,0 +1,15 @@
+<h2>DESCRIPTION</h2>
+<em>g.isis3mt</em> Generates an ISIS3 map template file according to the
+ current GRASS projection parameters
+<h2>NOTE</h2>
+The ISIS3 user should use matchmap=yes in cam2map
+<h2>AUTHOR</h2>
+Alessandro Frigeri, INA, Ispra, Italy
+Added to GRASS 7 by Yann Chemin
+<p><i>Last changed: $Date$</i>
Property changes on: grass/trunk/scripts/g.isis3mt/g.isis3mt.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass/trunk/scripts/g.isis3mt/g.isis3mt.py
--- grass/trunk/scripts/g.isis3mt/g.isis3mt.py (rev 0)
+++ grass/trunk/scripts/g.isis3mt/g.isis3mt.py 2013-07-14 16:56:43 UTC (rev 57127)
@@ -0,0 +1,158 @@
+#!/usr/bin/env python
+# MODULE: g.isis3mt
+# AUTHOR(S): Alessandro Frigeri;
+# PURPOSE: Generates an ISIS3 map template file according to the current
+# GRASS projection parameters
+# COPYRIGHT: (C) 2009,2010 by Alessandro Frigeri for the GRASS Development Team
+# This program is free software under the GNU General Public
+# License (>=v2). Read the file COPYING that comes with GRASS
+# for details.
+# HISTORY: Apr 15th, 2010: Time for the first public release
+# Sep 15th, 2010: added LatLon Range and mpp/ppd resolution
+# options
+# TODO
+# Add a note to the user to use matchmap=yes in cam2map
+#%module
+#% description: Generates an ISIS3 map template file according to the current GRASS coordinate reference system
+#% keywords: generic, projection
+#%end
+#%option
+#% key: body
+#% type: string
+#% description: Target planetary body
+#% options: MOON,MERCURY,VENUS,MARS,Phobos,Deimos,JUPITER,Amalthea,Io,Europa,Ganymede,Callisto,SATURN,Janus,Epimetheus,Mimas,Enceladus,Tethys,Dione,Rhea,Titan,Hyperion,Iapetus,URANUS,Miranda,Ariel,Umbriel,Titania,Oberon,NEPTUNE
+#% required : yes
+#%end
+#%option
+#% key: out
+#% type: string
+#% gisprompt: new_file,file,output
+#% description: Filename for the ISIS3 maptemplate to be generated
+#% required : yes
+#%end
+#%option
+#% key: outres
+#% type: double
+#% description: Resolution of the ISIS3 projected data (default is: camera resolution)
+#% required : no
+#%end
+#%Option
+#% key: restype
+#% type: string
+#% required: no
+#% multiple: no
+#% options: mpp,ppd
+#% description: Resolution type: meters per pixel (mpp) or pixels per degree (ppd)
+#% answer: mpp
+#%End
+#%flag
+#% key: a
+#% description: Align ISIS3 data to the extents of the current GRASS region
+#%end
+import subprocess,sys,os,platform
+import grass.script as grass
+from grass.lib import gis as grasslib
+from grass.lib import proj as grassproj
+from UserDict import *
+import re,string
+if "GISBASE" not in os.environ:
+ print "You must be in GRASS GIS to run this program."
+ sys.exit(1)
+# initialize
+grasslib.G_gisinit('')
+projdict = {'sinu':'Sinusoidal',
+ 'merc':'Mercator',
+ 'tmerc':'TransverseMercator',
+ 'ortho':'Orthographic',
+ 'stere':'PolarStereographic',
+ 'cc':'SimpleCylindrical',
+ 'eqc':'Equirectangular',
+ 'lcc':'LambertConformal'
+paradict = {'proj' :'ProjectionName', # Name of the projection
+ 'lon_0':'CenterLongitude', # Center Longitude
+ 'lat_0':'CenterLatitude', # Center Latitude
+ 'k':'ScaleFactor', # Scale Factor
+ 'lat_1':'FirstStandardParallel', # First standard parallel
+ 'lat_2':'SecondStandardParallel', # Second standard parallel
+ 'a':'EquatorialRadius', # semi major axis
+ 'b':'PolarRadius', # semi minor axis
+ 'to_meter':None, # no map on isis3
+ 'y_0':None, # false northing
+ 'x_0':None, # false easting
+class IsisMapTemplate(IterableUserDict):
+ def __init__(self,isisdict):
+ UserDict.__init__(self)
+ if isisdict is not None:
+ UserDict.__init__(self,isisdict)
+ self['LatitudeType'] = 'Planetographic'
+ self['LongitudeDirection'] = 'PositiveEast'
+ self['LongitudeDomain'] = '180'
+ def dump(self,out):
+ out.write("Group = Mapping\n")
+ keys = self.keys()
+ for k in self.keys():
+ if k != None:
+ myk = string.rjust(k, 30)
+ myv = string.ljust(self[k], 20)
+ out.write("%s = %s\n"%(myk,myv))
+ out.write("End_Group\nEnd")
+def main():
+ isis3 = {}
+ outfile = options['out']
+ body = options['body']
+ pj = grasslib.G_get_projinfo()
+ if options['outres'] and options['restype']=='mpp' : isis3['PixelResolution'] = "%f <meters>"%float(options['outres'])
+ if options['outres'] and options['restype']=='ppd' : isis3['Scale'] = "%f <pixel/degree>"%float(options['outres'])
+ isis3['TargetName'] = body
+ if flags['a']:
+ ret = grass.start_command("g.region", flags="gl", stdout = subprocess.PIPE)
+ exec(ret.communicate()[0])
+ isis3['MinimumLatitude'] = "%f"%min(se_lat,sw_lat)
+ isis3['MaximumLatitude'] = "%f"%max(ne_lat,nw_lat)
+ isis3['MinimumLongitude'] = "%f"%min(sw_long,nw_long)
+ isis3['MaximumLongitude'] = "%f"%max(se_long,ne_long)
+ for p in paradict.keys():
+ if grasslib.G_find_key_value(p, pj):
+ k = paradict[p]
+ v = grasslib.G_find_key_value(p, pj)
+ if p == 'a' or p == 'b': v = v + ' <meters>'
+ if p == 'proj' and v == 'll': sys.exit("This GRASS location is in LatLong, no cartographic projection is set.\nExiting...")
+ if p == 'proj': k,v = 'ProjectionName', projdict[v]
+ isis3[k] = v
+ isis3mt = IsisMapTemplate(isis3)
+ of = open(outfile,'w')
+ isis3mt.dump(of)
+ sys.stderr.write("Done writing %s ISIS3 MapTemplate file\n"%outfile)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ main()
Property changes on: grass/trunk/scripts/g.isis3mt/g.isis3mt.py
Added: svn:executable
+ text/x-python
+ native
