[GRASS-SVN] r57144 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Mon Jul 15 05:20:06 PDT 2013
Author: annakrat
Date: 2013-07-15 05:20:05 -0700 (Mon, 15 Jul 2013)
New Revision: 57144
grass/trunk/gui/wxpython/core/toolboxes.py
wxGUI/toolboxes: add <addons> tag to list addons in menu
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py 2013-07-15 11:22:27 UTC (rev 57143)
+++ grass/trunk/gui/wxpython/core/toolboxes.py 2013-07-15 12:20:05 UTC (rev 57144)
@@ -38,7 +38,7 @@
from core.globalvar import ETCWXDIR
from core.utils import GetSettingsPath
-from core.gcmd import GError
+from core.gcmd import GError, RunCommand
import grass.script.task as gtask
import grass.script.core as gcore
@@ -181,6 +181,8 @@
if not userHasToolboxes:
_removeUserToolboxesItem(root)
+ _expandAddonsItem(root)
toolboxes = etree.parse(toolboxesFile)
_expandToolboxes(root, toolboxes)
@@ -339,6 +341,46 @@
items.remove(n)
+def _expandAddonsItem(node):
+ """!Expands tag addons (in main_menu.xml) with currently installed addons.append
+ Note: there is no mechanism yet to tell the gui to rebuild the menudata.xml
+ file when new addons are added/removed.
+ # no addonsTag -> do nothing
+ addonsTags = node.findall('./items/addons')
+ if not addonsTags:
+ return
+ # fetch addons
+ addons = sorted(RunCommand('g.extension', quiet=True, read=True,
+ flags = 'a').splitlines())
+ # no addons -> remove addons tag
+ if not addons:
+ for n in addonsTags:
+ items = node.find('./items')
+ idx = items.getchildren().index(n)
+ items.remove(n)
+ return
+ # create addons toolbox
+ # keywords and desc are handled later automatically
+ el = etree.Element('toolbox', attrib={'name': 'AddonsToolboxesList'})
+ items.insert(idx, el)
+ label = etree.SubElement(el, tag='label')
+ label.text = _("Addons")
+ it = etree.SubElement(el, tag='items')
+ for addon in addons:
+ addonItem = etree.SubElement(it, tag='module-item')
+ addonItem.attrib = {'name': addon}
+ addonLabel = etree.SubElement(addonItem, tag='label')
+ addonLabel.text = addon
+ items.remove(n)
def _expandItems(node, items, itemTag):
"""!Expand items from file
