[GRASS-SVN] r57148 - in grass/trunk/gui/wxpython: core modules
Mon Jul 15 07:03:40 PDT 2013
Author: annakrat
Date: 2013-07-15 07:03:40 -0700 (Mon, 15 Jul 2013)
New Revision: 57148
   grass/trunk/gui/wxpython/core/toolboxes.py
   grass/trunk/gui/wxpython/modules/extensions.py
update toolboxes after change in addons
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py	2013-07-15 13:35:35 UTC (rev 57147)
+++ grass/trunk/gui/wxpython/core/toolboxes.py	2013-07-15 14:03:40 UTC (rev 57148)
@@ -59,6 +59,14 @@
     userMainMenuFile = None
+def toolboxesOutdated():
+    """!Removes auto-generated menudata.xml
+    to let gui regenerate it next time it starts."""
+    path = os.path.join(GetSettingsPath(), 'toolboxes', 'menudata.xml')
+    if os.path.exists(path):
+        gcore.try_remove(path)
 def getMenuFile():
     """!Returns path to XML file for building menu.
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py	2013-07-15 13:35:35 UTC (rev 57147)
+++ grass/trunk/gui/wxpython/modules/extensions.py	2013-07-15 14:03:40 UTC (rev 57148)
@@ -31,6 +31,7 @@
 from core.menutree    import TreeModel, ModuleNode
 from gui_core.widgets import GListCtrl, SearchModuleWidget
 from gui_core.treeview import CTreeView
+from core.toolboxes   import toolboxesOutdated
 class InstallExtensionWindow(wx.Frame):
@@ -205,6 +206,8 @@
                 SetAddOnPath(key = 'BASE')
             globalvar.UpdateGRASSAddOnCommands()
+            toolboxesOutdated()
     def OnItemSelected(self, node):
         """!Item selected"""
@@ -386,6 +389,7 @@
         # update prompt
         globalvar.UpdateGRASSAddOnCommands(eList)
 class CheckListExtension(GListCtrl):
