[GRASS-SVN] r57152 - grass-addons/grass7/raster/r.stream.extract
svn_grass at osgeo.org
Mon Jul 15 08:41:00 PDT 2013
Author: mmetz
Date: 2013-07-15 08:41:00 -0700 (Mon, 15 Jul 2013)
New Revision: 57152
grass-addons/grass7/raster/r.stream.extract/do_astar.c
grass-addons/grass7/raster/r.stream.extract/dseg.c
grass-addons/grass7/raster/r.stream.extract/streams.c
r.stream.extract: code clean-up, sync to r.watershed
Modified: grass-addons/grass7/raster/r.stream.extract/do_astar.c
--- grass-addons/grass7/raster/r.stream.extract/do_astar.c 2013-07-15 15:38:18 UTC (rev 57151)
+++ grass-addons/grass7/raster/r.stream.extract/do_astar.c 2013-07-15 15:41:00 UTC (rev 57152)
@@ -31,7 +31,7 @@
double dx, dy, dist_to_nbr[8], ew_res, ns_res;
double slope[8];
struct Cell_head window;
- int skip_me;
+ int skip_diag;
count = 0;
@@ -79,7 +79,7 @@
r_nbr = r + nextdr[ct_dir];
c_nbr = c + nextdc[ct_dir];
slope[ct_dir] = ele_nbr[ct_dir] = 0;
- skip_me = 0;
+ skip_diag = 0;
/* check that neighbour is within region */
if (r_nbr < 0 || r_nbr >= nrows || c_nbr < 0 || c_nbr >= ncols)
@@ -102,19 +102,19 @@
if (slope[ct_dir] <
get_slope(ele_nbr[nbr_ew[ct_dir]],
ele_nbr[ct_dir], ew_res))
- skip_me = 1;
+ skip_diag = 1;
- if (!skip_me && slope[nbr_ns[ct_dir]] > 0) {
+ if (!skip_diag && slope[nbr_ns[ct_dir]] > 0) {
/* slope to ns nbr > slope to center */
if (slope[ct_dir] <
get_slope(ele_nbr[nbr_ns[ct_dir]],
ele_nbr[ct_dir], ns_res))
- skip_me = 1;
+ skip_diag = 1;
- if (!skip_me) {
+ if (!skip_diag) {
if (is_in_list == 0) {
ele_up = ele_nbr[ct_dir];
af.asp = drain[r_nbr - r + 1][c_nbr - c + 1];
Modified: grass-addons/grass7/raster/r.stream.extract/dseg.c
--- grass-addons/grass7/raster/r.stream.extract/dseg.c 2013-07-15 15:38:18 UTC (rev 57151)
+++ grass-addons/grass7/raster/r.stream.extract/dseg.c 2013-07-15 15:41:00 UTC (rev 57152)
@@ -102,7 +102,7 @@
int dseg_read_raster(DSEG *dseg, char *map_name, char *mapset)
- int row, nrows, ncols;
+ int row, nrows;
int map_fd;
DCELL *dbuffer;
@@ -111,7 +111,6 @@
map_fd = Rast_open_old(map_name, mapset);
nrows = Rast_window_rows();
- ncols = Rast_window_cols();
dbuffer = Rast_allocate_d_buf();
for (row = 0; row < nrows; row++) {
Rast_get_d_row(map_fd, dbuffer, row);
@@ -136,12 +135,11 @@
int dseg_write_cellfile(DSEG *dseg, char *map_name)
int map_fd;
+ int row, nrows;
DCELL *dbuffer;
map_fd = Rast_open_new(map_name, DCELL_TYPE);
segment_flush(&(dseg->seg));
Modified: grass-addons/grass7/raster/r.stream.extract/streams.c
--- grass-addons/grass7/raster/r.stream.extract/streams.c 2013-07-15 15:38:18 UTC (rev 57151)
+++ grass-addons/grass7/raster/r.stream.extract/streams.c 2013-07-15 15:41:00 UTC (rev 57152)
@@ -143,15 +143,15 @@
int mfd_cells, astar_not_set;
double *dist_to_nbr, *weight, sum_weight, max_weight;
double dx, dy;
- int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side;
+ int r_nbr, c_nbr, ct_dir, np_side;
int is_worked;
- double max_acc, prop;
+ double prop;
int edge;
int asp_r[9] = { 0, -1, -1, -1, 0, 1, 1, 1, 0 };
int asp_c[9] = { 0, 1, 0, -1, -1, -1, 0, 1, 1 };
int nextdr[8] = { 1, -1, 0, 0, -1, 1, 1, -1 };
int nextdc[8] = { 0, 0, -1, 1, 1, -1, 1, -1 };
- GW_LARGE_INT workedon, killer, count;
+ GW_LARGE_INT workedon, killer;
char *flag_nbr;
POINT astarpoint;
WAT_ALT wa;
@@ -182,7 +182,6 @@
/* distribute and accumulate */
- count = 0;
for (killer = 0; killer < n_points; killer++) {
G_percent(killer, n_points, 1);
@@ -205,9 +204,6 @@
dc = c + asp_c[abs((int)af.asp)];
- r_max = dr;
- c_max = dc;
seg_get(&watalt, (char *)&wa, r, c);
value = wa.wat;
@@ -309,8 +305,6 @@
if (fabs(value) > d8cut)
mfd_cells = 0;
- max_acc = -1;
if (mfd_cells > 1) {
prop = 0.0;
for (ct_dir = 0; ct_dir < sides; ct_dir++) {
@@ -370,7 +364,7 @@
CELL is_swale, ele_val, *ele_nbr;
DCELL value, valued, *wat_nbr;
- int mfd_cells, stream_cells, swale_cells, astar_not_set;
+ int mfd_cells, stream_cells, swale_cells;
double *dist_to_nbr;
double dx, dy;
int r_nbr, c_nbr, r_max, c_max, ct_dir, np_side, max_side;
@@ -387,7 +381,7 @@
* | 2 | | 3 |
* | 5 | 0 | 6 |
int stream_no = 0, stream_node_step = 1000;
double slope, diag;
char *flag_nbr;
@@ -435,7 +429,6 @@
workedon = 0;
/* extract streams */
- count = 0;
@@ -505,7 +498,6 @@
mfd_cells = 0;
stream_cells = 0;
swale_cells = 0;
- astar_not_set = 1;
ele_val = wa.ele;
edge = 0;
flat = 1;
@@ -562,10 +554,6 @@
c_max = c_nbr;
max_side = ct_dir;
- if (dr == r_nbr && dc == c_nbr) {
- astar_not_set = 0;
else if (ct_dir == np_side && !edge) {
