[GRASS-SVN] r57179 - in sandbox: . turek turek/turntable turek/turntable/include turek/turntable/include/defs turek/turntable/lib turek/turntable/lib/vector turek/turntable/lib/vector/Vlib
svn_grass at osgeo.org
Tue Jul 16 07:45:05 PDT 2013
Author: turek
Date: 2013-07-16 07:45:05 -0700 (Tue, 16 Jul 2013)
New Revision: 57179
Added:
sandbox/turek/
sandbox/turek/scatter_plot/
sandbox/turek/turntable/
sandbox/turek/turntable/include/
sandbox/turek/turntable/include/defs/
sandbox/turek/turntable/include/defs/vector.h
sandbox/turek/turntable/lib/
sandbox/turek/turntable/lib/vector/
sandbox/turek/turntable/lib/vector/Vlib/
sandbox/turek/turntable/lib/vector/Vlib/net.c
changes for turns support added
Added: sandbox/turek/turntable/include/defs/vector.h
--- sandbox/turek/turntable/include/defs/vector.h (rev 0)
+++ sandbox/turek/turntable/include/defs/vector.h 2013-07-16 14:45:05 UTC (rev 57179)
@@ -0,0 +1,613 @@
+#ifndef GRASS_VECTORDEFS_H
+#define GRASS_VECTORDEFS_H
+ * "Public" functions, for use in modules
+/* Points (line) */
+struct line_pnts *Vect_new_line_struct(void);
+int Vect_append_point(struct line_pnts *, double, double, double);
+int Vect_append_points(struct line_pnts *, const struct line_pnts *, int);
+int Vect_line_insert_point(struct line_pnts *, int, double, double, double);
+int Vect_line_delete_point(struct line_pnts *, int);
+int Vect_line_get_point(const struct line_pnts *, int ,
+ double *, double *, double *);
+int Vect_get_num_line_points(const struct line_pnts *);
+int Vect_line_prune(struct line_pnts *);
+int Vect_line_prune_thresh(struct line_pnts *, double);
+void Vect_line_reverse(struct line_pnts *);
+int Vect_copy_xyz_to_pnts(struct line_pnts *, const double *, const double *, const double *,
+ int);
+int Vect_copy_pnts_to_xyz(const struct line_pnts *, double *, double *, double *,
+ int *);
+void Vect_reset_line(struct line_pnts *);
+void Vect_destroy_line_struct(struct line_pnts *);
+int Vect_point_on_line(const struct line_pnts *, double, double *, double *,
+int Vect_line_segment(const struct line_pnts *, double, double, struct line_pnts *);
+double Vect_line_length(const struct line_pnts *);
+double Vect_line_geodesic_length(const struct line_pnts *);
+int Vect_line_distance(const struct line_pnts *, double, double, double, int,
+ double *, double *, double *, double *, double *,
+ double *);
+int Vect_line_geodesic_distance(const struct line_pnts *, double, double, double, int,
+ double *);
+void Vect_line_box(const struct line_pnts *, struct bound_box *);
+void Vect_line_parallel(struct line_pnts *, double, double, int,
+ struct line_pnts *);
+void Vect_line_parallel2(struct line_pnts *, double, double,
+ double, int, int, double,
+void Vect_line_buffer(const struct line_pnts *, double, double, struct line_pnts *);
+void Vect_line_buffer2(const struct line_pnts *, double, double,
+ struct line_pnts **,
+ struct line_pnts ***, int *);
+void Vect_area_buffer2(const struct Map_info *, int, double, double,
+void Vect_point_buffer2(double, double, double, double,
+ double, int, double,
+ struct line_pnts **);
+/* Categories */
+struct line_cats *Vect_new_cats_struct(void);
+int Vect_cat_set(struct line_cats *, int, int);
+int Vect_cat_get(const struct line_cats *, int, int *);
+int Vect_cat_del(struct line_cats *, int);
+int Vect_field_cat_del(struct line_cats *, int, int);
+int Vect_field_cat_get(const struct line_cats *, int, struct ilist *);
+int Vect_cat_in_array(int, const int *, int);
+int Vect_reset_cats(struct line_cats *);
+void Vect_destroy_cats_struct(struct line_cats *);
+int Vect_get_area_cats(const struct Map_info *, int, struct line_cats *);
+int Vect_get_area_cat(const struct Map_info *, int, int);
+int Vect_get_line_cat(const struct Map_info *, int, int);
+struct cat_list *Vect_cats_set_constraint(struct Map_info *, int, char *, char *);
+int Vect_cats_in_constraint(struct line_cats *, int, struct cat_list *);
+/* List of categories */
+struct cat_list *Vect_new_cat_list(void);
+int Vect_str_to_cat_list(const char *, struct cat_list *);
+int Vect_array_to_cat_list(const int *, int, struct cat_list *);
+int Vect_cat_list_to_array(const struct cat_list *, int **, int *);
+int Vect_cat_in_cat_list(int, const struct cat_list *);
+void Vect_destroy_cat_list(struct cat_list *);
+/* Vector array */
+struct varray *Vect_new_varray(int);
+int Vect_set_varray_from_cat_string(const struct Map_info *, int, const char *, int,
+ int, struct varray *);
+int Vect_set_varray_from_cat_list(const struct Map_info *, int, struct cat_list *,
+ int, int, struct varray *);
+int Vect_set_varray_from_db(const struct Map_info *, int, const char *, int, int,
+ struct varray *);
+/* DB connection - field info */
+struct dblinks *Vect_new_dblinks_struct(void);
+void Vect_reset_dblinks(struct dblinks *);
+int Vect_add_dblink(struct dblinks *, int, const char *,
+ const char *, const char *, const char *, const char *);
+int Vect_check_dblink(const struct dblinks *, int, const char *);
+int Vect_map_add_dblink(struct Map_info *, int, const char *,
+ const char *);
+int Vect_map_del_dblink(struct Map_info *, int);
+void Vect_copy_map_dblinks(const struct Map_info *, struct Map_info *, int);
+int Vect_map_check_dblink(const struct Map_info *, int, const char *);
+int Vect_read_dblinks(struct Map_info *);
+int Vect_write_dblinks(struct Map_info *);
+struct field_info *Vect_default_field_info(struct Map_info *, int,
+ const char *, int);
+struct field_info *Vect_get_dblink(const struct Map_info *, int);
+struct field_info *Vect_get_field(const struct Map_info *, int);
+struct field_info *Vect_get_field_by_name(const struct Map_info *, const char *);
+struct field_info *Vect_get_field2(const struct Map_info *, const char *);
+int Vect_get_field_number(const struct Map_info *, const char *);
+void Vect_set_db_updated(struct Map_info *);
+const char *Vect_get_column_names(const struct Map_info *, int);
+const char *Vect_get_column_types(const struct Map_info *, int);
+const char *Vect_get_column_names_types(const struct Map_info *, int);
+/* List of FID (feature ID) (integers) */
+struct ilist *Vect_new_list(void);
+int Vect_list_append(struct ilist *, int);
+int Vect_list_append_list(struct ilist *, const struct ilist *);
+int Vect_list_delete(struct ilist *, int);
+int Vect_list_delete_list(struct ilist *, const struct ilist *);
+int Vect_val_in_list(const struct ilist *, int);
+int Vect_reset_list(struct ilist *);
+void Vect_destroy_list(struct ilist *);
+/* List of bounding boxes with ids */
+struct boxlist *Vect_new_boxlist(int);
+int Vect_boxlist_append(struct boxlist *, int, const struct bound_box *);
+int Vect_boxlist_append_boxlist(struct boxlist *, const struct boxlist *);
+int Vect_boxlist_delete(struct boxlist *, int);
+int Vect_boxlist_delete_boxlist(struct boxlist *, const struct boxlist *);
+int Vect_val_in_boxlist(const struct boxlist *, int);
+int Vect_reset_boxlist(struct boxlist *);
+void Vect_destroy_boxlist(struct boxlist *);
+/* Bounding box (MBR) */
+int Vect_point_in_box(double, double, double, const struct bound_box *);
+int Vect_box_overlap(const struct bound_box *, const struct bound_box *);
+int Vect_box_copy(struct bound_box *, const struct bound_box *);
+int Vect_box_extend(struct bound_box *, const struct bound_box *);
+int Vect_box_clip(double *, double *, double *, double *, const struct bound_box *);
+int Vect_region_box(const struct Cell_head *, struct bound_box *);
+/* Category index */
+int Vect_cidx_get_num_fields(const struct Map_info *);
+int Vect_cidx_get_field_number(const struct Map_info *, int);
+int Vect_cidx_get_field_index(const struct Map_info *, int);
+int Vect_cidx_get_num_unique_cats_by_index(const struct Map_info *, int);
+int Vect_cidx_get_num_cats_by_index(const struct Map_info *, int);
+int Vect_cidx_get_num_types_by_index(const struct Map_info *, int);
+int Vect_cidx_get_type_count_by_index(const struct Map_info *, int, int, int *,
+ int *);
+int Vect_cidx_get_type_count(const struct Map_info *, int, int);
+int Vect_cidx_get_cat_by_index(const struct Map_info *, int, int, int *, int *,
+ int *);
+int Vect_cidx_find_next(const struct Map_info *, int, int, int, int, int *, int *);
+void Vect_cidx_find_all(const struct Map_info *, int, int, int, struct ilist *);
+int Vect_cidx_dump(const struct Map_info *, FILE *);
+int Vect_cidx_save(struct Map_info *);
+int Vect_cidx_open(struct Map_info *, int);
+/* Set/get map header info */
+int Vect_read_header(struct Map_info *);
+int Vect_write_header(const struct Map_info *);
+const char *Vect_get_name(const struct Map_info *);
+const char *Vect_get_mapset(const struct Map_info *);
+const char *Vect_get_full_name(const struct Map_info *);
+const char *Vect_get_finfo_dsn_name(const struct Map_info *);
+char *Vect_get_finfo_layer_name(const struct Map_info *);
+const char *Vect_get_finfo_format_info(const struct Map_info *);
+const char *Vect_get_finfo_geometry_type(const struct Map_info *);
+const struct Format_info *Vect_get_finfo(const struct Map_info *);
+int Vect_is_3d(const struct Map_info *);
+int Vect_set_organization(struct Map_info *, const char *);
+const char *Vect_get_organization(const struct Map_info *);
+int Vect_set_date(struct Map_info *, const char *);
+const char *Vect_get_date(const struct Map_info *);
+int Vect_set_person(struct Map_info *, const char *);
+const char *Vect_get_person(const struct Map_info *);
+int Vect_set_map_name(struct Map_info *, const char *);
+const char *Vect_get_map_name(const struct Map_info *);
+int Vect_set_map_date(struct Map_info *, const char *);
+const char *Vect_get_map_date(const struct Map_info *);
+int Vect_set_comment(struct Map_info *, const char *);
+const char *Vect_get_comment(const struct Map_info *);
+int Vect_set_scale(struct Map_info *, int);
+int Vect_get_scale(const struct Map_info *);
+int Vect_set_zone(struct Map_info *, int);
+int Vect_get_zone(const struct Map_info *);
+int Vect_get_proj(const struct Map_info *);
+int Vect_set_proj(struct Map_info *, int);
+const char *Vect_get_proj_name(const struct Map_info *);
+int Vect_set_thresh(struct Map_info *, double);
+double Vect_get_thresh(const struct Map_info *);
+int Vect_get_constraint_box(const struct Map_info *, struct bound_box *);
+/* Get map level 2 information */
+int Vect_level(const struct Map_info *);
+int Vect_get_line_type(const struct Map_info *, int);
+plus_t Vect_get_num_nodes(const struct Map_info *);
+plus_t Vect_get_num_primitives(const struct Map_info *, int);
+plus_t Vect_get_num_lines(const struct Map_info *);
+plus_t Vect_get_num_areas(const struct Map_info *);
+plus_t Vect_get_num_faces(const struct Map_info *);
+plus_t Vect_get_num_kernels(const struct Map_info *);
+plus_t Vect_get_num_volumes(const struct Map_info *);
+plus_t Vect_get_num_islands(const struct Map_info *);
+plus_t Vect_get_num_holes(const struct Map_info *);
+int Vect_get_line_box(const struct Map_info *, int, struct bound_box *);
+int Vect_get_area_box(const struct Map_info *, int, struct bound_box *);
+int Vect_get_isle_box(const struct Map_info *, int, struct bound_box *);
+int Vect_get_map_box(const struct Map_info *, struct bound_box *);
+int V__map_overlap(struct Map_info *, double, double, double, double);
+void Vect_set_release_support(struct Map_info *);
+void Vect_set_category_index_update(struct Map_info *);
+/* Open/close/rewind/set_constraints for map */
+int Vect_check_input_output_name(const char *, const char *, int);
+int Vect_legal_filename(const char *);
+int Vect_set_open_level(int);
+int Vect_open_old(struct Map_info *, const char *, const char *);
+int Vect_open_old2(struct Map_info *, const char *, const char *, const char *);
+int Vect_open_old_head(struct Map_info *, const char *, const char *);
+int Vect_open_old_head2(struct Map_info *, const char *, const char *, const char *);
+int Vect_open_new(struct Map_info *, const char *, int);
+int Vect_open_tmp_new(struct Map_info *, const char *, int);
+int Vect_open_update(struct Map_info *, const char *, const char *);
+int Vect_open_update2(struct Map_info *, const char *, const char *, const char *);
+int Vect_open_update_head(struct Map_info *, const char *, const char *);
+int Vect_copy_head_data(const struct Map_info *, struct Map_info *);
+int Vect_build(struct Map_info *);
+int Vect_topo_check(struct Map_info *, struct Map_info *);
+int Vect_get_built(const struct Map_info *);
+int Vect_build_partial(struct Map_info *, int);
+int Vect_set_constraint_region(struct Map_info *, double, double, double,
+ double, double, double);
+int Vect_set_constraint_type(struct Map_info *, int);
+int Vect_set_constraint_field(struct Map_info *, int);
+void Vect_remove_constraints(struct Map_info *);
+int Vect_rewind(struct Map_info *);
+int Vect_close(struct Map_info *);
+void Vect_set_error_handler_io(struct Map_info *, struct Map_info *);
+/* Read/write lines, nodes, areas */
+/* Level 1 and 2 */
+int Vect_get_next_line_id(const struct Map_info *);
+int Vect_read_next_line(const struct Map_info *, struct line_pnts *,
+ struct line_cats *);
+off_t Vect_write_line(struct Map_info *, int, const struct line_pnts *,
+ const struct line_cats *);
+int Vect_get_num_dblinks(const struct Map_info *);
+/* Level 2 only */
+int Vect_read_line(const struct Map_info *, struct line_pnts *, struct line_cats *,
+ int);
+off_t Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
+int Vect_delete_line(struct Map_info *, int);
+int Vect_restore_line(struct Map_info *, int, off_t);
+int Vect_line_alive(const struct Map_info *, int);
+int Vect_node_alive(const struct Map_info *, int);
+int Vect_area_alive(const struct Map_info *, int);
+int Vect_isle_alive(const struct Map_info *, int);
+int Vect_get_line_nodes(const struct Map_info *, int, int *, int *);
+int Vect_get_line_areas(const struct Map_info *, int, int *, int *);
+off_t Vect_get_line_offset(const struct Map_info *, int);
+int Vect_get_node_coor(const struct Map_info *, int, double *, double *, double *);
+int Vect_get_node_n_lines(const struct Map_info *, int);
+int Vect_get_node_line(const struct Map_info *, int, int);
+float Vect_get_node_line_angle(const struct Map_info *, int, int);
+double Vect_area_perimeter(const struct line_pnts *);
+int Vect_get_area_points(const struct Map_info *, int, struct line_pnts *);
+int Vect_get_area_centroid(const struct Map_info *, int);
+int Vect_get_area_num_isles(const struct Map_info *, int);
+int Vect_get_area_isle(const struct Map_info *, int, int);
+double Vect_get_area_area(const struct Map_info *, int);
+int Vect_get_area_boundaries(const struct Map_info *, int, struct ilist *);
+int Vect_get_isle_points(const struct Map_info *, int, struct line_pnts *);
+int Vect_get_isle_area(const struct Map_info *, int);
+int Vect_get_isle_boundaries(const struct Map_info *, int, struct ilist *);
+int Vect_get_centroid_area(const struct Map_info *, int);
+/* Level 2 update only */
+int Vect_get_num_updated_lines(const struct Map_info *);
+int Vect_get_updated_line(const struct Map_info *, int);
+off_t Vect_get_updated_line_offset(const struct Map_info *, int);
+int Vect_get_num_updated_nodes(const struct Map_info *);
+int Vect_get_updated_node(const struct Map_info *, int);
+void Vect_set_updated(struct Map_info *, int);
+void Vect_reset_updated(struct Map_info *);
+/* History */
+int Vect_hist_command(struct Map_info *);
+int Vect_hist_write(struct Map_info *, const char *);
+int Vect_hist_copy(const struct Map_info *, struct Map_info *);
+void Vect_hist_rewind(struct Map_info *);
+char *Vect_hist_read(char *, int, const struct Map_info *);
+/* Selecting features */
+int Vect_select_lines_by_box(struct Map_info *, const struct bound_box *,
+ int, struct boxlist *);
+int Vect_select_areas_by_box(struct Map_info *, const struct bound_box *,
+ struct boxlist *);
+int Vect_select_isles_by_box(struct Map_info *, const struct bound_box *,
+int Vect_select_nodes_by_box(struct Map_info *, const struct bound_box *,
+ struct ilist *);
+int Vect_find_node(struct Map_info *, double, double, double, double, int);
+int Vect_find_line(struct Map_info *, double, double, double, int, double,
+ int, int);
+int Vect_find_line_list(struct Map_info *, double, double, double, int,
+ double, int, const struct ilist *, struct ilist *);
+int Vect_find_area(struct Map_info *, double, double);
+int Vect_find_island(struct Map_info *, double, double);
+int Vect_select_lines_by_polygon(struct Map_info *, struct line_pnts *, int,
+ struct line_pnts **, int, struct ilist *);
+int Vect_select_areas_by_polygon(struct Map_info *, struct line_pnts *, int,
+ struct line_pnts **, struct ilist *);
+/* Analysis */
+int Vect_tin_get_z(struct Map_info *, double, double, double *, double *,
+ double *);
+/* int Vect_point_in_islands (struct Map_info *, int, double, double); */
+int Vect_find_poly_centroid(const struct line_pnts *, double *, double *);
+int Vect__intersect_line_with_poly(const struct line_pnts *, double,
+int Vect_get_point_in_area(const struct Map_info *, int, double *, double *);
+int Vect_get_point_in_poly(const struct line_pnts *, double *, double *);
+int Vect_get_point_in_poly_isl(const struct line_pnts *, const struct line_pnts **, int,
+ double *, double *);
+int Vect_point_in_area(double, double, const struct Map_info *, int, struct bound_box *);
+int Vect_point_in_area_outer_ring(double, double, const struct Map_info *, int, struct bound_box *);
+int Vect_point_in_island(double, double, const struct Map_info *, int, struct bound_box *);
+int Vect_point_in_poly(double, double, const struct line_pnts *);
+/* Cleaning */
+void Vect_break_lines(struct Map_info *, int, struct Map_info *);
+int Vect_break_lines_list(struct Map_info *, struct ilist *, struct ilist *,
+ int, struct Map_info *);
+int Vect_check_line_breaks(struct Map_info *, int, struct Map_info *);
+int Vect_check_line_breaks_list(struct Map_info *, struct ilist *, struct ilist *,
+int Vect_merge_lines(struct Map_info *, int, int *, struct Map_info *);
+void Vect_break_polygons(struct Map_info *, int, struct Map_info *);
+void Vect_remove_duplicates(struct Map_info *, int, struct Map_info *);
+int Vect_line_check_duplicate(const struct line_pnts *,
+ const struct line_pnts *, int);
+void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *);
+void Vect_snap_lines_list(struct Map_info *, const struct ilist *, double,
+ struct Map_info *);
+int Vect_snap_line(struct Map_info *, struct ilist *, struct line_pnts *,
+ double, int, int *, int *);
+void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *);
+void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *);
+void Vect_select_dangles(struct Map_info *, int, double, struct ilist *);
+void Vect_remove_bridges(struct Map_info *, struct Map_info *, int *, int *);
+void Vect_chtype_bridges(struct Map_info *, struct Map_info *, int *, int *);
+int Vect_remove_small_areas(struct Map_info *, double, struct Map_info *,
+ double *);
+int Vect_clean_small_angles_at_nodes(struct Map_info *, int,
+/* Overlay */
+int Vect_overlay_str_to_operator(const char *);
+int Vect_overlay(struct Map_info *, int, struct ilist *, struct ilist *,
+ struct Map_info *, int, struct ilist *, struct ilist *,
+int Vect_overlay_and(struct Map_info *, int, struct ilist *,
+ struct ilist *, struct Map_info *, int,
+ struct ilist *, struct ilist *, struct Map_info *);
+/* Graph */
+void Vect_graph_init(dglGraph_s *, int);
+void Vect_graph_build(dglGraph_s *);
+void Vect_graph_add_edge(dglGraph_s *, int, int, double, int);
+void Vect_graph_set_node_costs(dglGraph_s *, int, double);
+int Vect_graph_shortest_path(dglGraph_s *, int, int, struct ilist *, double *);
+/* Network (graph) */
+int Vect_net_build_graph(struct Map_info *, int, int, int, const char *,
+ const char *, const char *, int, int);
+int Vect_net_ttb_build_graph(struct Map_info *, int, int, int, int, int ,
+ const char *, const char *, const char *, int, int);
+int Vect_net_shortest_path(struct Map_info *, int, int, struct ilist *,
+ double *);
+int Vect_net_ttb_shortest_path(struct Map_info *, int, int, int, int, int, int,
+ struct ilist *, double *);
+dglGraph_s *Vect_net_get_graph(struct Map_info *);
+int Vect_net_get_line_cost(const struct Map_info *, int, int, double *);
+int Vect_net_get_node_cost(const struct Map_info *, int, double *);
+int Vect_net_nearest_nodes(struct Map_info *, double, double, double, int,
+ double, int *, int *, int *, double *, double *,
+ struct line_pnts *, struct line_pnts *, double *);
+int Vect_net_shortest_path_coor(struct Map_info *, double, double, double,
+ double, double, double, double, double,
+ double *, struct line_pnts *, struct ilist *,
+int Vect_net_shortest_path_coor2(struct Map_info *, double, double, double,
+ double *, struct line_pnts *, struct ilist *, struct ilist *,
+int Vect_net_ttb_shortest_path_coor(struct Map_info *, double, double, double,
+ double, double, double, double, double, int, int,
+int Vect_net_ttb_shortest_path_coor2(struct Map_info *, double, double, double,
+/* Miscellaneous */
+int Vect_topo_dump(const struct Map_info *, FILE *);
+double Vect_points_distance(double, double, double, double, double, double,
+ int);
+int Vect_option_to_types(const struct Option *);
+int Vect_copy_map_lines(struct Map_info *, struct Map_info *);
+int Vect_copy_map_lines_field(struct Map_info *, int, struct Map_info *);
+int Vect_copy(const char *, const char *, const char *);
+int Vect_rename(const char *, const char *);
+int Vect_copy_table(const struct Map_info *, struct Map_info *, int, int,
+int Vect_copy_table_by_cat_list(const struct Map_info *, struct Map_info *, int, int,
+ const char *, int, const struct cat_list *);
+int Vect_copy_table_by_cats(const struct Map_info *, struct Map_info *, int, int,
+ const char *, int, int *, int);
+int Vect_copy_tables(const struct Map_info *, struct Map_info *, int);
+int Vect_delete(const char *);
+int Vect_segment_intersection(double, double, double, double, double, double,
+ double, double, double, double, double, double,
+ double *, double *, int);
+int Vect_line_intersection(struct line_pnts *, struct line_pnts *,
+ struct bound_box *, struct bound_box *,
+ struct line_pnts ***, struct line_pnts ***, int *,
+ int *, int);
+int Vect_line_check_intersection(struct line_pnts *, struct line_pnts *, int);
+int Vect_line_get_intersections(struct line_pnts *, struct line_pnts *,
+ struct line_pnts *, int);
+char *Vect_subst_var(const char *, const struct Map_info *);
+/* Custom spatial index */
+void Vect_spatial_index_init(struct spatial_index *, int);
+void Vect_spatial_index_destroy(struct spatial_index *);
+void Vect_spatial_index_add_item(struct spatial_index *, int, const struct bound_box *);
+void Vect_spatial_index_del_item(struct spatial_index *, int, const struct bound_box *);
+int Vect_spatial_index_select(const struct spatial_index *, const struct bound_box *, struct ilist *);
+/* GRASS ASCII vector format */
+int Vect_read_ascii(FILE *, struct Map_info *);
+int Vect_read_ascii_head(FILE *, struct Map_info *);
+int Vect_write_ascii(FILE *, FILE *, struct Map_info *, int,
+ int, int, char *, int, int,
+ int, const struct cat_list *, const char*,
+ const char **, int);
+void Vect_write_ascii_head(FILE *, struct Map_info *);
+/* Simple Features */
+SF_FeatureType Vect_sfa_get_line_type(const struct line_pnts *, int, int);
+int Vect_sfa_get_type(SF_FeatureType);
+int Vect_sfa_check_line_type(const struct line_pnts *, int, SF_FeatureType, int);
+int Vect_sfa_line_dimension(int);
+char *Vect_sfa_line_geometry_type(const struct line_pnts *, int);
+int Vect_sfa_line_astext(const struct line_pnts *, int, int, int, FILE *);
+int Vect_sfa_is_line_simple(const struct line_pnts *, int, int);
+int Vect_sfa_is_line_closed(const struct line_pnts *, int, int);
+int Vect_sfa_get_num_features(const struct Map_info *);
+ * Internal functions, MUST NOT be used in modules
+int Vect_print_header(const struct Map_info *);
+void Vect__init_head(struct Map_info *);
+/* Open/close/rewind map */
+int Vect_coor_info(const struct Map_info *, struct Coor_info *);
+const char *Vect_maptype_info(const struct Map_info *);
+int Vect_maptype(const struct Map_info *);
+int Vect_open_topo(struct Map_info *, int);
+int Vect_open_topo_pg(struct Map_info *, int);
+int Vect_save_topo(struct Map_info *);
+int Vect_open_sidx(struct Map_info *, int);
+int Vect_save_sidx(struct Map_info *);
+int Vect_sidx_dump(const struct Map_info *, FILE *);
+int Vect_build_sidx_from_topo(const struct Map_info *);
+int Vect_build_sidx(struct Map_info *);
+int Vect_open_fidx(struct Map_info *, struct Format_info_offset *);
+int Vect_save_fidx(struct Map_info *, struct Format_info_offset *);
+int Vect_fidx_dump(const struct Map_info *, FILE *);
+int Vect_save_frmt(struct Map_info *);
+int Vect__write_head(const struct Map_info *);
+int Vect__read_head(struct Map_info *);
+int V1_open_old_nat(struct Map_info *, int);
+int V1_open_old_ogr(struct Map_info *, int);
+int V1_open_old_pg(struct Map_info *, int);
+int V2_open_old_ogr(struct Map_info *);
+int V2_open_old_pg(struct Map_info *);
+int V1_open_new_nat(struct Map_info *, const char *, int);
+int V1_open_new_ogr(struct Map_info *, const char *, int);
+int V1_open_new_pg(struct Map_info *, const char *, int);
+int V1_rewind_nat(struct Map_info *);
+int V1_rewind_ogr(struct Map_info *);
+int V1_rewind_pg(struct Map_info *);
+int V2_rewind_nat(struct Map_info *);
+int V2_rewind_ogr(struct Map_info *);
+int V2_rewind_pg(struct Map_info *);
+int V1_close_nat(struct Map_info *);
+int V1_close_ogr(struct Map_info *);
+int V1_close_pg(struct Map_info *);
+int V2_close_ogr(struct Map_info *);
+int V2_close_pg(struct Map_info *);
+/* Read/write lines (internal use only) */
+int V1_read_line_nat(struct Map_info *, struct line_pnts *,
+ struct line_cats *, off_t);
+int V1_read_line_ogr(struct Map_info *, struct line_pnts *,
+int V1_read_line_pg(struct Map_info *, struct line_pnts *,
+int V2_read_line_nat(struct Map_info *, struct line_pnts *,
+ struct line_cats *, int);
+int V2_read_line_sfa(struct Map_info *, struct line_pnts *,
+int V2_read_line_pg(struct Map_info *, struct line_pnts *,
+int V1_read_next_line_nat(struct Map_info *, struct line_pnts *,
+int V1_read_next_line_ogr(struct Map_info *, struct line_pnts *,
+int V1_read_next_line_pg(struct Map_info *, struct line_pnts *,
+int V2_read_next_line_nat(struct Map_info *, struct line_pnts *,
+int V2_read_next_line_ogr(struct Map_info *, struct line_pnts *,
+int V2_read_next_line_pg(struct Map_info *, struct line_pnts *,
+int V1_delete_line_nat(struct Map_info *, off_t);
+int V1_delete_line_ogr(struct Map_info *, off_t);
+int V1_delete_line_pg(struct Map_info *, off_t);
+int V2_delete_line_nat(struct Map_info *, int);
+int V2_delete_line_sfa(struct Map_info *, int);
+int V2_delete_line_pg(struct Map_info *, int);
+int V1_restore_line_nat(struct Map_info *, off_t);
+int V2_restore_line_nat(struct Map_info *, int, off_t);
+off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
+off_t V1_write_line_ogr(struct Map_info *, int, const struct line_pnts *,
+off_t V1_write_line_pg(struct Map_info *, int, const struct line_pnts *,
+off_t V2_write_line_nat(struct Map_info *, int, const struct line_pnts *,
+off_t V2_write_line_sfa(struct Map_info *, int, const struct line_pnts *,
+off_t V2_write_line_pg(struct Map_info *, int, const struct line_pnts *,
+off_t V1_rewrite_line_nat(struct Map_info *, int, int, off_t,
+ const struct line_pnts *, const struct line_cats *);
+off_t V1_rewrite_line_ogr(struct Map_info *, int, int, off_t,
+off_t V1_rewrite_line_pg(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_nat(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_sfa(struct Map_info *, int, int, off_t,
+off_t V2_rewrite_line_pg(struct Map_info *, int, int, off_t,
+ /* Build topology */
+int Vect_build_nat(struct Map_info *, int);
+void Vect__build_downgrade(struct Map_info *, int);
+int Vect__build_sfa(struct Map_info *, int);
+int Vect_build_ogr(struct Map_info *, int);
+int Vect_build_pg(struct Map_info *, int);
+int Vect_build_line_area(struct Map_info *, int, int);
+int Vect_isle_find_area(struct Map_info *, int);
+int Vect_attach_isle(struct Map_info *, int);
+int Vect_attach_isles(struct Map_info *, const struct bound_box *);
+int Vect_attach_centroids(struct Map_info *, const struct bound_box *);
+ /* GEOS support */
+#ifdef HAVE_GEOS
+GEOSGeometry *Vect_read_line_geos(struct Map_info *, int, int*);
+GEOSGeometry *Vect_line_to_geos(struct Map_info *, const struct line_pnts*, int);
+GEOSGeometry *Vect_read_area_geos(struct Map_info *, int);
+GEOSCoordSequence *Vect_get_area_points_geos(struct Map_info *, int);
+GEOSCoordSequence *Vect_get_isle_points_geos(struct Map_info *, int);
+#endif
+ /* Raster color tables */
+int Vect_read_colors(const char *, const char *, struct Colors *);
+int Vect_remove_colors(const char *, const char *);
+void Vect_write_colors(const char *, const char *, struct Colors *);
+/* Simplified RTree search using an ilist to store rectangle ids */
+int RTreeSearch2(struct RTree *, struct RTree_Rect *, struct ilist *);
+#endif /* GRASS_VECTORDEFS_H */
Added: sandbox/turek/turntable/lib/vector/Vlib/net.c
--- sandbox/turek/turntable/lib/vector/Vlib/net.c (rev 0)
+++ sandbox/turek/turntable/lib/vector/Vlib/net.c 2013-07-16 14:45:05 UTC (rev 57179)
@@ -0,0 +1,2152 @@
+ * \file lib/vector/Vlib/net.c
+ * \brief Vector library - net releated fns
+ * Higher level functions for reading/writing/manipulating vectors.
+ * (C) 2001-2009, 2013 by the GRASS Development Team
+ * This program is free software under the GNU General Public License
+ * (>=v2). Read the file COPYING that comes with GRASS for details.
+ * \author Radim Blazek
+ * \author Štěpán Turek steapn.turek seznam.cz (turns costs support)
+#include <stdlib.h>
+#include <string.h>
+#include <fcntl.h>
+#include <grass/dbmi.h>
+#include <grass/vector.h>
+#include <grass/glocale.h>
+static int From_node; /* from node set in SP and used by clipper for first arc */
+static int clipper(dglGraph_s * pgraph,
+ dglSPClipInput_s * pargIn,
+ dglSPClipOutput_s * pargOut, void *pvarg)
+{ /* caller's pointer */
+ dglInt32_t cost;
+ dglInt32_t from;
+ G_debug(3, "Net: clipper()");
+ from = dglNodeGet_Id(pgraph, pargIn->pnNodeFrom);
+ G_debug(3, " Edge = %d NodeFrom = %d NodeTo = %d edge cost = %d",
+ (int)dglEdgeGet_Id(pgraph, pargIn->pnEdge),
+ (int)from, (int)dglNodeGet_Id(pgraph, pargIn->pnNodeTo),
+ (int)pargOut->nEdgeCost);
+ if (from != From_node) { /* do not clip first */
+ if (dglGet_NodeAttrSize(pgraph) > 0) {
+ memcpy(&cost, dglNodeGet_Attr(pgraph, pargIn->pnNodeFrom),
+ sizeof(cost));
+ if (cost == -1) { /* closed, cannot go from this node except it is 'from' node */
+ G_debug(3, " closed node");
+ return 1;
+ else {
+ G_debug(3, " EdgeCost += %d (node)", (int)cost);
+ pargOut->nEdgeCost += cost;
+ else {
+ G_debug(3, " don't clip first node");
+ return 0;
+ \brief Build network graph extended with turntable.
+ Internal format for edge costs is integer, costs are multiplied
+ before conversion to int by 1000 and for lenghts LL without geo flag by 1000000.
+ The same multiplication factor is used for nodes.
+ Costs in database column may be 'integer' or 'double precision' number >= 0
+ or -1 for infinity i.e. arc or node is closed and cannot be traversed
+ If record in table is not found for arcs, costs for arc are set to 0.
+ If record in table is not found for node, costs for node are set to 0.
+ \param Map vector map
+ \param ltype line type for arcs
+ \param afield arc costs field (if 0, use length)
+ \param nfield node costs field (if 0, do not use node costs)
+ \param tfield number of field where turntable is attached
+ \param tucfield number of field with unique categories used in the turntable
+ \param afcol column with forward costs for arc
+ \param abcol column with backward costs for arc (if NULL, back costs = forward costs),
+ \param ncol column with costs for nodes (if NULL, do not use node costs),
+ \param geo use geodesic calculation for length (LL),
+ \param algorithm not used (in future code for algorithm)
+ \return 0 on success, 1 on error
+int
+Vect_net_ttb_build_graph(struct Map_info *Map,
+ int ltype,
+ int afield,
+ int nfield,
+ int tfield,
+ int tucfield,
+ const char *afcol,
+ const char *abcol,
+ const char *ncol, int geo, int algorithm)
+ int i, j, from, to, line, nlines, nnodes, ret, type, cat, skipped, cfound;
+ int dofw, dobw;
+ struct line_pnts *Points;
+ struct line_cats *Cats;
+ double dcost, bdcost, ll;
+ int cost, bcost;
+ dglGraph_s *gr;
+ dglInt32_t opaqueset[16] =
+ { 360000, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
+ struct field_info *Fi;
+ dbDriver *driver = NULL;
+ dbDriver *ttbdriver = NULL;
+ dbHandle handle;
+ dbString stmt;
+ dbColumn *Column;
+ dbCatValArray fvarr, bvarr;
+ int fctype = 0, bctype = 0, nrec, nturns;
+ int ln_cat, nnode_lns, i_line, line_id, i_virt_edge;
+ struct line_cats *ln_Cats;
+ double x, y, z;
+ struct bound_box box;
+ struct boxlist *List;
+ dglInt32_t dgl_cost = cost;
+ /*TODO attributes of turntable shoud be in stored one place */
+ const char *tcols[] =
+ { "cat", "ln_from", "ln_to", "cost", "isec", NULL
+ dbCatValArray tvarrs[5] = { };
+ int tctype[5] = { 0 };
+ int tucfield_idx;
+ int t, f;
+ int node_pt_id, turn_cat, tucfound;
+ int isec;
+ /* TODO int costs -> double (waiting for dglib) */
+ G_debug(1, "Vect_build_graph(): ltype = %d, afield = %d, nfield = %d",
+ ltype, afield, nfield);
+ G_debug(1, " afcol = %s, abcol = %s, ncol = %s", afcol, abcol, ncol);
+ G_message(_("Building graph..."));
+ Map->dgraph.line_type = ltype;
+ Points = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ ll = 0;
+ if (G_projection() == 3)
+ ll = 1; /* LL */
+ if (afcol == NULL && ll && !geo)
+ Map->dgraph.cost_multip = 1000000;
+ else
+ Map->dgraph.cost_multip = 1000;
+ nlines = Vect_get_num_lines(Map);
+ nnodes = Vect_get_num_nodes(Map);
+ gr = &(Map->dgraph.graph_s);
+ /* Allocate space for costs, later replace by functions reading costs from graph */
+ Map->dgraph.edge_fcosts =
+ (double *)G_malloc((nlines + 1) * sizeof(double));
+ Map->dgraph.edge_bcosts =
+ Map->dgraph.node_costs =
+ (double *)G_malloc((nnodes + 1) * sizeof(double));
+ /* Set to -1 initially */
+ for (i = 1; i <= nlines; i++) {
+ Map->dgraph.edge_fcosts[i] = -1; /* forward */
+ Map->dgraph.edge_bcosts[i] = -1; /* backward */
+ for (i = 1; i <= nnodes; i++) {
+ Map->dgraph.node_costs[i] = 0;
+ dglInitialize(gr, (dglByte_t) 1, sizeof(dglInt32_t), (dglInt32_t) 0,
+ opaqueset);
+ if (gr == NULL)
+ G_fatal_error(_("Unable to build network graph"));
+ db_init_handle(&handle);
+ db_init_string(&stmt);
+ if (abcol != NULL && afcol == NULL)
+ G_fatal_error(_("Forward costs column not specified"));
+ /* --- Add arcs --- */
+ /* Open db connection */
+ /* Get field info */
+ if (tfield < 1)
+ G_fatal_error(_("Turntable field < 1"));
+ Fi = Vect_get_field(Map, tfield);
+ if (Fi == NULL)
+ G_fatal_error(_("Database connection not defined for layer %d"),
+ tfield);
+ /* Open database */
+ ttbdriver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (ttbdriver == NULL)
+ G_fatal_error(_("Unable to open database <%s> by driver <%s>"),
+ Fi->database, Fi->driver);
+ i = 0;
+ while (tcols[i]) {
+ /* Load costs to array */
+ if (db_get_column(ttbdriver, Fi->table, tcols[i], &Column) != DB_OK)
+ G_fatal_error(_("Turntable column <%s> not found in table <%s>"),
+ tcols[i], Fi->table);
+ tctype[i] = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
+ if ((tctype[i] == DB_C_TYPE_INT || tctype[i] == DB_C_TYPE_DOUBLE) &&
+ tcols[i] == "cost") ;
+ else if (tctype[i] == DB_C_TYPE_INT) ;
+ else
+ G_fatal_error(_
+ ("Data type of column <%s> not supported (must be numeric)"),
+ tcols[i]);
+ db_CatValArray_init(&tvarrs[i]);
+ nturns =
+ db_select_CatValArray(ttbdriver, Fi->table, Fi->key, tcols[i],
+ NULL, &tvarrs[i]);
+ ++i;
+ G_debug(1, "forward costs: nrec = %d", nrec);
+ /* Set node attributes */
+ G_message("Register nodes");
+ if (ncol != NULL) {
+ G_debug(2, "Set nodes' costs");
+ if (nfield < 1)
+ G_fatal_error("Node field < 1");
+ G_message(_("Setting node costs..."));
+ Fi = Vect_get_field(Map, nfield);
+ if (Fi == NULL)
+ nfield);
+ driver = db_start_driver_open_database(Fi->driver, Fi->database);
+ if (driver == NULL)
+ if (db_get_column(driver, Fi->table, ncol, &Column) != DB_OK)
+ G_fatal_error(_("Column <%s> not found in table <%s>"),
+ ncol, Fi->table);
+ fctype = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
+ if (fctype != DB_C_TYPE_INT && fctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_
+ ncol);
+ db_CatValArray_init(&fvarr);
+ nrec =
+ db_select_CatValArray(driver, Fi->table, Fi->key, ncol, NULL,
+ &fvarr);
+ G_debug(1, "node costs: nrec = %d", nrec);
+ tucfield_idx = Vect_cidx_get_field_index(Map, tucfield);
+ List = Vect_new_boxlist(0);
+ ln_Cats = Vect_new_cats_struct();
+ G_message("Building turns graph...");
+ i_virt_edge = 1;
+ /* TODO: what happens if we set attributes of not existing node (skipped lines,
+ * nodes without lines) */
+ /* select points at node */
+ Vect_get_node_coor(Map, i, &x, &y, &z);
+ box.E = box.W = x;
+ box.N = box.S = y;
+ box.T = box.B = z;
+ Vect_select_lines_by_box(Map, &box, GV_POINT, List);
+ G_debug(2, " node = %d nlines = %d", i, List->n_values);
+ cfound = 0;
+ dcost = 0;
+ tucfound = 0;
+ for (j = 0; j < List->n_values; j++) {
+ line = List->id[j];
+ G_debug(2, " line (%d) = %d", j, line);
+ type = Vect_read_line(Map, NULL, Cats, line);
+ if (!(type & GV_POINT))
+ continue;
+ /* get node column costs */
+ if (ncol != NULL && !cfound && Vect_cat_get(Cats, nfield, &cat)) { /* point with category of field found */
+ /* Set costs */
+ if (fctype == DB_C_TYPE_INT) {
+ ret =
+ db_CatValArray_get_value_int(&fvarr, cat, &cost);
+ dcost = cost;
+ else { /* DB_C_TYPE_DOUBLE */
+ ret =
+ db_CatValArray_get_value_double(&fvarr, cat,
+ &dcost);
+ if (ret != DB_OK) {
+ G_warning(_
+ ("Database record for node %d (cat = %d) not found "
+ "(cost set to 0)"), i, cat);
+ cfound = 1;
+ Map->dgraph.node_costs[i] = dcost;
+ /* add virtual nodes and lines, which represents the intersections
+ there are added two nodes for every intersection, which are linked
+ with the nodes (edges in primal graph).
+ the positive node - when we are going from the intersection
+ the negative node - when we are going to the intersection
+ TODO There are more possible approaches in virtual nodes management.
+ We can also add and remove them dynamically as they are needed
+ for analysis when Vect_net_ttb_shortest_path is called
+ (problem of flattening graph).
+ Currently this static solution was chosen, because it cost
+ time only when graph is build. However it costs more memory space.
+ For Dijkstra algorithm this expansion should not be problem
+ because we can only get into positive node or go from the negative
+ node.
+ ret = Vect_cat_get(Cats, tucfield, &cat);
+ if (!tucfound && ret) { /* point with category of field found */
+ /* find lines which belongs to the intersection */
+ nnode_lns = Vect_get_node_n_lines(Map, i);
+ /* connect every line with virtual nodes*/
+ for(i_line = 0; i_line < nnode_lns; i_line++) {
+ line_id = Vect_get_node_line(Map, i, i_line);
+ Vect_read_line(Map, NULL, ln_Cats, abs(line_id));
+ Vect_cat_get(ln_Cats, tucfield, &ln_cat);
+ if(line_id < 0) ln_cat *= -1;
+ f = cat * 2;
+ if (ln_cat < 0) t = ln_cat * -2 + 1;
+ else t = ln_cat * 2;
+ G_debug(5, "Add arc %d for virtual node from %d to %d cost = %d", i_virt_edge, f, t, 0);
+ /* positive, start virtual node */
+ ret = dglAddEdge(gr, (dglInt32_t) f, (dglInt32_t) t,
+ (dglInt32_t) 0,
+ (dglInt32_t) (-i_virt_edge));
+ if (ret < 0)
+ G_fatal_error(_("Cannot add network arc for virtual node connection."));
+ t = cat * 2 + 1;
+ i_virt_edge++;
+ if (-ln_cat < 0) f = ln_cat * 2 + 1;
+ else f = ln_cat * -2;
+ /* negative, destination virtual node */
+ (dglInt32_t) 0,
+ if (ret < 0)
+ i_virt_edge++;
+ ++tucfound;
+ else if (ret)
+ ++tucfound;
+ if (tucfound > 1)
+ G_warning(_("There exists more than one point of node <%d> in unique category field <%d>.\n"
+ "The unique categories layer is not valid therefore you will probably get incorrect results."), tucfield, i);
+ if (ncol != NULL && !cfound)
+ G_debug(2,
+ "Category of field %d not attached to any points in node %d"
+ "(costs set to 0)", nfield, i);
+ Vect_destroy_cats_struct(ln_Cats);
+ for (i = 1; i <= nturns; i++) {
+ /* TODO use cursors */
+ db_CatValArray_get_value_int(&tvarrs[0], i, &turn_cat);
+ db_CatValArray_get_value_int(&tvarrs[1], i, &from);
+ db_CatValArray_get_value_int(&tvarrs[2], i, &to);
+ db_CatValArray_get_value_int(&tvarrs[4], i, &isec);
+ dcost = 0.0;
+ /* TODO optization do not do it for every turn in intersection again */
+ if (Vect_cidx_find_next
+ (Map, tucfield_idx, isec, GV_POINT, 0, &type,
+ &node_pt_id) == -1) {
+ G_warning(_
+ ("Unable to find point representing intersection <%d> in unique categories field <%d>.\n"
+ "Cost for the intersection was set to 0.\n"
+ isec, tucfield);
+ else {
+ Vect_read_line(Map, Points, Cats, node_pt_id);
+ node_pt_id =
+ Vect_find_node(Map, *Points->x, *Points->y, *Points->z,
+ 0.0, WITHOUT_Z);
+ if (node_pt_id == 0) {
+ G_warning(_
+ ("Unable to find node for point representing intersection <%d> in unique categories field <%d>.\n"
+ isec, tucfield);
+ else{
+ G_debug(2, " node = %d", node_pt_id);
+ dcost = Map->dgraph.node_costs[node_pt_id];
+ G_debug(2, "Set node's cost to %f", dcost);
+ if (dcost >= 0) {
+ /* Set costs from turntable */
+ if (tctype[3] == DB_C_TYPE_INT) {
+ ret =
+ db_CatValArray_get_value_int(&tvarrs[3], i,
+ &cost);
+ dcost = cost;
+ else /* DB_C_TYPE_DOUBLE */
+ ret =
+ db_CatValArray_get_value_double(&tvarrs[3], i,
+ &dcost);
+ G_warning(_("Database record for turn with cat = %d in not found. "
+ "(The turn was skipped."), i);
+ continue;
+ if (dcost >= 0) {
+ if (ncol != NULL)
+ cost =
+ (Map->dgraph.node_costs[node_pt_id] +
+ dcost) * (dglInt32_t) Map->dgraph.cost_multip;
+ else
+ cost = dcost * (dglInt32_t) Map->dgraph.cost_multip;
+ /* dglib does not like negative id's of nodes */
+ if (from < 0) f = from * -2 + 1;
+ else f = from * 2;
+ if (to < 0) t = to * -2 + 1;
+ else t = to * 2;
+ G_debug(5, "Add arc/turn %d for turn from %d to %d cost = %d", turn_cat, f, t, cost);
+ (dglInt32_t) cost,
+ (dglInt32_t) (turn_cat));
+ if (ret < 0)
+ G_fatal_error(_("Cannot add network arc representing turn."));
+ Vect_destroy_boxlist(List);
+ i = 0;
+ db_CatValArray_free(&tvarrs[i]);
+ ++i;
+ db_close_database_shutdown_driver(driver);
+ db_CatValArray_free(&fvarr);
+ if (afcol != NULL) {
+ if (afield < 1)
+ G_fatal_error(_("Arc field < 1"));
+ Fi = Vect_get_field(Map, afield);
+ if (Fi == NULL)
+ afield);
+ if (db_get_column(driver, Fi->table, afcol, &Column) != DB_OK)
+ afcol, Fi->table);
+ G_fatal_error(_
+ afcol);
+ nrec =
+ db_select_CatValArray(driver, Fi->table, Fi->key, afcol, NULL,
+ &fvarr);
+ if (abcol != NULL) {
+ if (db_get_column(driver, Fi->table, abcol, &Column) != DB_OK)
+ abcol, Fi->table);
+ bctype = db_sqltype_to_Ctype(db_get_column_sqltype(Column));
+ if (bctype != DB_C_TYPE_INT && bctype != DB_C_TYPE_DOUBLE)
+ G_fatal_error(_
+ abcol);
+ db_CatValArray_init(&bvarr);
+ nrec =
+ db_select_CatValArray(driver, Fi->table, Fi->key, abcol, NULL,
+ &bvarr);
+ G_debug(1, "backward costs: nrec = %d", nrec);
+ skipped = 0;
+ G_message(_("Registering arcs..."));
+ G_percent(i, nlines, 1); /* must be before any continue */
+ type = Vect_read_line(Map, Points, Cats, i);
+ if (!(type & ltype & (GV_LINE | GV_BOUNDARY)))
+ continue;
+ Vect_get_line_nodes(Map, i, &from, &to);
+ dcost = bdcost = 0;
+ cfound = Vect_cat_get(Cats, tucfield, &cat);
+ if (!cfound)
+ continue;
+ if (cfound > 1)
+ G_warning(_("Line with id <%d> has more unique categories defined in field <%d>.\n"
+ "The unique categories layer is not valid therefore you will probably get incorrect results."), i, tucfield);
+ if (!(Vect_cat_get(Cats, afield, &cat))) {
+ G_debug(2,
+ "Category of field %d not attached to the line %d -> cost was set to 0",
+ afield, i);
+ skipped += 2; /* Both directions */
+ else {
+ ret = db_CatValArray_get_value_int(&fvarr, cat, &cost);
+ dcost = cost;
+ ret =
+ db_CatValArray_get_value_double(&fvarr, cat, &dcost);
+ G_warning(_("Database record for line %d (cat = %d, "
+ "forward/both direction(s)) not found "
+ "(cost was set to 0)"), i, cat);
+ if (bctype == DB_C_TYPE_INT) {
+ ret =
+ db_CatValArray_get_value_int(&bvarr, cat, &bcost);
+ bdcost = bcost;
+ ret =
+ db_CatValArray_get_value_double(&bvarr, cat,
+ &bdcost);
+ "backword direction) not found"
+ else
+ bdcost = dcost;
+ else {
+ if (ll) {
+ if (geo)
+ dcost = Vect_line_geodesic_length(Points);
+ else
+ dcost = Vect_line_length(Points);
+ else
+ bdcost = dcost;
+ cost = (dglInt32_t) Map->dgraph.cost_multip * dcost;
+ dgl_cost = cost;
+ cat = cat * 2;
+ G_debug(5, "Setinng node %d cost: %d", cat, cost);
+ dglNodeSet_Attr(gr, dglGetNode(gr, (dglInt32_t) cat),
+ & dgl_cost);
+ Map->dgraph.edge_fcosts[i] = dcost;
+ cost = (dglInt32_t) Map->dgraph.cost_multip * bdcost;
+ dgl_cost = cost;
+ ++cat;
+ & dgl_cost);
+ Map->dgraph.edge_bcosts[i] = bdcost;
+ if (afcol != NULL && skipped > 0)
+ G_debug(2, "%d lines missing category of field %d skipped", skipped,
+ afield);
+ db_CatValArray_free(&bvarr);
+ db_close_database_shutdown_driver(ttbdriver);
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_cats_struct(Cats);
+ G_message(_("Flattening the graph..."));
+ ret = dglFlatten(gr);
+ if (ret < 0)
+ G_fatal_error(_("GngFlatten error"));
+ /* init SP cache */
+ /* disable to debug dglib cache */
+ dglInitializeSPCache(gr, &(Map->dgraph.spCache));
+ G_message(_("Graph was built"));
+ return 0;
+ \brief Build network graph.
+ If record in table is not found for arcs, arc is skip.
+int
+Vect_net_build_graph(struct Map_info *Map,
+ int ltype,
+ int afield,
+ int nfield,
+ int dofw, dobw;
+ int cost, bcost;
+ dglGraph_s *gr;
+ dglInt32_t dgl_cost;
+ dbHandle handle;
+ dbString stmt;
+ dbColumn *Column;
+ int fctype = 0, bctype = 0, nrec;
+ ll = 0;
+ ll = 1; /* LL */
+ else
+ if (ncol != NULL)
+ opaqueset);
+ else
+ dglInitialize(gr, (dglByte_t) 1, (dglInt32_t) 0, (dglInt32_t) 0,
+ opaqueset);
+ if (gr == NULL)
+ if (afield < 1)
+ if (Fi == NULL)
+ afield);
+ G_fatal_error(_
+ afcol);
+ nrec =
+ &fvarr);
+ G_fatal_error(_
+ abcol);
+ nrec =
+ &bvarr);
+ skipped = 0;
+ dofw = dobw = 1;
+ continue;
+ G_debug(2,
+ "Category of field %d not attached to the line %d -> line skipped",
+ afield, i);
+ continue;
+ else {
+ dcost = cost;
+ ret =
+ "(forward/both direction(s) of line skipped)"),
+ i, cat);
+ dofw = 0;
+ ret =
+ bdcost = bcost;
+ ret =
+ &bdcost);
+ "(direction of line skipped)"), i, cat);
+ dobw = 0;
+ else {
+ if (dofw)
+ bdcost = dcost;
+ else
+ dobw = 0;
+ else {
+ if (ll) {
+ if (geo)
+ else
+ else
+ bdcost = dcost;
+ if (dofw && dcost != -1) {
+ G_debug(5, "Add arc %d from %d to %d cost = %d", i, from, to,
+ cost);
+ ret =
+ dglAddEdge(gr, (dglInt32_t) from, (dglInt32_t) to,
+ (dglInt32_t) cost, (dglInt32_t) i);
+ if (ret < 0)
+ G_fatal_error("Cannot add network arc");
+ G_debug(5, "bdcost = %f edge_bcosts = %f", bdcost,
+ Map->dgraph.edge_bcosts[i]);
+ if (dobw && bdcost != -1) {
+ bcost = (dglInt32_t) Map->dgraph.cost_multip * bdcost;
+ G_debug(5, "Add arc %d from %d to %d bcost = %d", -i, to, from,
+ bcost);
+ ret =
+ dglAddEdge(gr, (dglInt32_t) to, (dglInt32_t) from,
+ (dglInt32_t) bcost, (dglInt32_t) - i);
+ if (ret < 0)
+ G_fatal_error(_("Cannot add network arc"));
+ afield);
+ G_debug(2, "Register nodes");
+ double x, y, z;
+ if (nfield < 1)
+ if (Fi == NULL)
+ nfield);
+ ncol, Fi->table);
+ G_fatal_error(_
+ ncol);
+ nrec =
+ &fvarr);
+ cfound = 0;
+ dcost = 0;
+ continue;
+ if (Vect_cat_get(Cats, nfield, &cat)) { /* point with category of field found */
+ /* Set costs */
+ ret =
+ dcost = cost;
+ ret =
+ &dcost);
+ G_warning(_
+ cfound = 1;
+ break;
+ if (!cfound) {
+ G_debug(2,
+ if (dcost == -1) { /* closed */
+ cost = -1;
+ else {
+ dgl_cost = cost;
+ G_debug(3, "Set node's cost to %d", cost);
+ dglNodeSet_Attr(gr, dglGetNode(gr, (dglInt32_t) i), &dgl_cost);
+ if (ret < 0)
+ return 0;
+ \brief Converts result path of DGLib into output format.
+static int convert_dgl_shortest_path_result(struct Map_info *Map,
+ dglSPReport_s * pSPReport,
+ struct ilist *List)
+ int i, line;
+ Vect_reset_list(List);
+ for (i = 0; i < pSPReport->cArc; i++) {
+ line =
+ dglEdgeGet_Id(&(Map->dgraph.graph_s),
+ pSPReport->pArc[i].pnEdge);
+ G_debug(2, "From %ld to %ld - cost %ld user %d distance %ld", pSPReport->pArc[i].nFrom, pSPReport->pArc[i].nTo, dglEdgeGet_Cost(&(Map->dgraph.graph_s), pSPReport->pArc[i].pnEdge) / Map->dgraph.cost_multip, /* this is the cost from clip() */
+ line, pSPReport->pArc[i].nDistance);
+ Vect_list_append(List, line);
+ return 0;
+ \brief Converts DGLib result path into output format on data using turntable.
+static int ttb_convert_dgl_shortest_path_result(struct Map_info *Map,
+ int tucfield,
+ int i, dgl_edge, line_id, type, tucfield_idx;
+ int line_ucat;
+ dgl_edge =
+ line_ucat =
+ dglNodeGet_Id(&(Map->dgraph.graph_s),
+ dglEdgeGet_Head(&(Map->dgraph.graph_s),
+ pSPReport->pArc[i].pnEdge));
+ /* get standard ucat numbers (DGLib does not like negative node numbers) */
+ if (line_ucat % 2 == 1)
+ line_ucat = ((line_ucat - 1) / -2);
+ else
+ line_ucat = (line_ucat) / 2;
+ /* skip virtual nodes */
+ (Map, tucfield_idx, abs(line_ucat), GV_LINE, 0, &type,
+ &line_id) == -1)
+ continue;
+ if(line_ucat < 0)
+ line_id *= -1;
+ line_ucat, pSPReport->pArc[i].nDistance);
+ Vect_list_append(List, line_id);
+ return 0;
+static int find_shortest_path(struct Map_info *Map, int from, int to,
+ struct ilist *List, double *cost, int tucfield)
+ int *pclip, cArc, nRet;
+ dglSPReport_s *pSPReport;
+ dglInt32_t nDistance;
+ int use_cache = 1; /* set to 0 to disable dglib cache */
+ G_debug(3, "Vect_net_shortest_path(): from = %d, to = %d", from, to);
+ /* Note : if from == to dgl goes to nearest node and returns back (dgl feature) =>
+ * check here for from == to */
+ /* Check if from and to are identical, otherwise dglib returns path to neares node and back! */
+ if (from == to) {
+ if (cost != NULL)
+ *cost = 0;
+ return 0;
+ From_node = from;
+ pclip = NULL;
+ if (List != NULL) {
+ if (use_cache) {
+ nRet =
+ dglShortestPath(&(Map->dgraph.graph_s), &pSPReport,
+ (dglInt32_t) from, (dglInt32_t) to, clipper,
+ pclip, &(Map->dgraph.spCache));
+ else {
+ nRet =
+ pclip, NULL);
+ else {
+ if (use_cache) {
+ nRet =
+ dglShortestDistance(&(Map->dgraph.graph_s), &nDistance,
+ clipper, pclip, &(Map->dgraph.spCache));
+ else {
+ nRet =
+ clipper, pclip, NULL);
+ if (nRet == 0) {
+ /* G_warning("Destination node %d is unreachable from node %d\n" , to , from); */
+ if (cost != NULL)
+ *cost = PORT_DOUBLE_MAX;
+ return -1;
+ else if (nRet < 0) {
+ G_warning(_("dglShortestPath error: %s"),
+ dglStrerror(&(Map->dgraph.graph_s)));
+ return -1;
+ if (tucfield <= 0)
+ convert_dgl_shortest_path_result(Map, pSPReport, List);
+ else
+ ttb_convert_dgl_shortest_path_result(Map, pSPReport, tucfield,
+ List);
+ if (cost != NULL) {
+ if (List != NULL)
+ *cost = (double)pSPReport->nDistance / Map->dgraph.cost_multip;
+ else
+ *cost = (double)nDistance / Map->dgraph.cost_multip;
+ cArc = pSPReport->cArc;
+ dglFreeSPReport(&(Map->dgraph.graph_s), pSPReport);
+ else
+ cArc = 0;
+ return cArc;
+ \brief Find shortest path on network.
+ Costs for 'from' and 'to' nodes are not considered (SP found even if
+ 'from' or 'to' are 'closed' (costs = -1) and costs of these
+ nodes are not added to SP costs result.
+ \param from from node
+ \param from type if 0 - point, if 1 edge
+ \param to to node
+ \param to type if 0 - point, if 1 edge
+ \param layer with turntable
+ \param layer with unique cats for turntable
+ \param[out] List list of line ids (path)
+ \param[out] cost costs value
+ \return number of segments
+ \return 0 is correct for from = to, or List == NULL ? sum of costs is better return value,
+ \return -1 : destination unreachable
+int
+Vect_net_ttb_shortest_path(struct Map_info *Map, int from, int from_type, int to, int to_type, int tfield,
+ int tucfield, struct ilist *List, double *cost)
+ double x,y,z;
+ struct boxlist *box_List;
+ int f, t;
+ int i_line, line, type, cfound;
+ box_List = Vect_new_boxlist(0);
+ if(from_type == 0) {
+ Vect_get_node_coor(Map, from, &x, &y, &z);
+ Vect_select_lines_by_box(Map, &box, GV_POINT, box_List);
+ cfound = 0;
+ for (i_line = 0; i_line < box_List->n_values; i_line++) {
+ line = box_List->id[i_line];
+ continue;
+ if (Vect_cat_get(Cats, tucfield, &f)) {
+ ++cfound;
+ break;
+ if(!cfound)
+ G_fatal_error(_("Unable to find for node <%d> point with unique category defined."), from);
+ else if (cfound > 1)
+ G_warning(_("There exists more than one point on node <%d> with unique category in field <%d>.\nThe unique category layer may not be valid."), tucfield, from);
+ G_debug(1, "from node = %d, unique cat = %d ", from, f);
+ f = f * 2;
+ else {
+ if (from < 0)
+ f = from * -2 + 1;
+ else
+ f = from * 2;
+ G_debug(2, "from edge unique cat = %d", from);
+ if(to_type == 0) {
+ Vect_get_node_coor(Map, to, &x, &y, &z);
+ cfound = 0;
+ continue;
+ if (Vect_cat_get(Cats, tucfield, &t)){
+ cfound = 1;
+ break;
+ if(!cfound)
+ G_fatal_error(_("Unable to find for node <%d> point with unique category defined."), to);
+ G_warning(_("There exists more than one point on node <%d> with unique category in field <%d>.\nThe unique category layer may not be valid."), tucfield, to);
+ G_debug(0, "to node = %d, unique cat = %d ", to, t);
+ t = t * 2 + 1;
+ else {
+ if (to < 0)
+ t = to * -2 + 1;
+ else
+ t = to * 2;
+ G_debug(2, "to edge unique cat = %d", to);
+ Vect_destroy_boxlist(box_List);
+ return find_shortest_path(Map, f, t, List,
+ cost, tucfield);
+ \brief Find shortest path.
+ \param to to node
+int
+Vect_net_shortest_path(struct Map_info *Map, int from, int to,
+ struct ilist *List, double *cost)
+ return find_shortest_path(Map, from, to, List, cost, -1);
+ \brief Get graph structure
+ Graph is built by Vect_net_build_graph().
+ Returns NULL when graph is not built.
+ \param Map pointer to Map_info struct
+ \return pointer to dglGraph_s struct or NULL
+dglGraph_s *Vect_net_get_graph(struct Map_info * Map)
+ return &(Map->dgraph.graph_s);
+ \brief Returns in cost for given direction in *cost.
+ cost is set to -1 if closed.
+ \param line line id
+ \param direction direction (GV_FORWARD, GV_BACKWARD)
+ \param[out] cost
+ \return 1 OK
+ \return 0 does not exist (was not inserted)
+int
+Vect_net_get_line_cost(const struct Map_info *Map, int line, int direction,
+ double *cost)
+ /* dglInt32_t *pEdge; */
+ G_debug(5, "Vect_net_get_line_cost(): line = %d, dir = %d", line,
+ direction);
+ if (direction == GV_FORWARD) {
+ /* V1 has no index by line-id -> array used */
+ pEdge = dglGetEdge(&(Map->dgraph.graph_s), line);
+ if (pEdge == NULL)
+ return 0;
+ *cost = (double) dglEdgeGet_Cost(&(Map->dgraph.graph_s), pEdge);
+ if (Map->dgraph.edge_fcosts[line] == -1) {
+ *cost = -1;
+ return 0;
+ else
+ *cost = Map->dgraph.edge_fcosts[line];
+ else if (direction == GV_BACKWARD) {
+ pEdge = dglGetEdge(&(Map->dgraph.graph_s), -line);
+ return 0;
+ if (Map->dgraph.edge_bcosts[line] == -1) {
+ *cost = -1;
+ return 0;
+ else
+ *cost = Map->dgraph.edge_bcosts[line];
+ G_debug(5, "Vect_net_get_line_cost(): edge_bcosts = %f",
+ Map->dgraph.edge_bcosts[line]);
+ else {
+ G_fatal_error(_("Wrong line direction in Vect_net_get_line_cost()"));
+ return 1;
+ \brief Get cost of node
+ \param node node id
+ \return 1
+int Vect_net_get_node_cost(const struct Map_info *Map, int node, double *cost)
+ G_debug(3, "Vect_net_get_node_cost(): node = %d", node);
+ *cost = Map->dgraph.node_costs[node];
+ G_debug(3, " -> cost = %f", *cost);
+ return 1;
+ \brief Find nearest node(s) on network.
+ \param Map vetor map
+ \param x,y,z point coordinates (z coordinate NOT USED !)
+ \param direction (GV_FORWARD - from point to net, GV_BACKWARD - from net to point)
+ \param maxdist maximum distance to the network
+ \param[out] node1 pointer where to store the node number (or NULL)
+ \param[out] node2 pointer where to store the node number (or NULL)
+ \param[out] ln pointer where to store the nearest line number (or NULL)
+ \param[out] costs1 pointer where to store costs on nearest line to node1 (not costs from x,y,z to the line) (or NULL)
+ \param[out] costs2 pointer where to store costs on nearest line to node2 (not costs from x,y,z to the line) (or NULL)
+ \param[out] Points1 pointer to structure where to store vertices on nearest line to node1 (or NULL)
+ \param[out] Points2 pointer to structure where to store vertices on nearest line to node2 (or NULL)
+ \param[out] pointer where to distance to the line (or NULL)
+ \param[out] distance
+ \return number of nodes found (0,1,2)
+int Vect_net_nearest_nodes(struct Map_info *Map,
+ double x, double y, double z,
+ int direction, double maxdist,
+ int *node1, int *node2, int *ln, double *costs1,
+ double *costs2, struct line_pnts *Points1,
+ struct line_pnts *Points2, double *distance)
+ int line, n1, n2, nnodes;
+ int npoints;
+ int segment; /* nearest line segment (first is 1) */
+ static struct line_pnts *Points = NULL;
+ double cx, cy, cz, c1, c2;
+ double along; /* distance along the line to nearest point */
+ double length;
+ G_debug(3, "Vect_net_nearest_nodes() x = %f y = %f", x, y);
+ /* Reset */
+ if (node1)
+ *node1 = 0;
+ if (node2)
+ *node2 = 0;
+ if (ln)
+ *ln = 0;
+ if (costs1)
+ *costs1 = PORT_DOUBLE_MAX;
+ if (costs2)
+ *costs2 = PORT_DOUBLE_MAX;
+ if (Points1)
+ Vect_reset_line(Points1);
+ if (Points2)
+ Vect_reset_line(Points2);
+ if (distance)
+ *distance = PORT_DOUBLE_MAX;
+ if (!Points)
+ /* Find nearest line */
+ line = Vect_find_line(Map, x, y, z, Map->dgraph.line_type, maxdist, 0, 0);
+ if (line < 1)
+ return 0;
+ Vect_read_line(Map, Points, NULL, line);
+ npoints = Points->n_points;
+ Vect_get_line_nodes(Map, line, &n1, &n2);
+ segment =
+ Vect_line_distance(Points, x, y, z, 0, &cx, &cy, &cz, distance, NULL,
+ &along);
+ G_debug(4, "line = %d n1 = %d n2 = %d segment = %d", line, n1, n2,
+ segment);
+ /* Check first or last point and return one node in that case */
+ G_debug(4, "cx = %f cy = %f first = %f %f last = %f %f", cx, cy,
+ Points->x[0], Points->y[0], Points->x[npoints - 1],
+ Points->y[npoints - 1]);
+ if (Points->x[0] == cx && Points->y[0] == cy) {
+ if (node1)
+ *node1 = n1;
+ if (ln)
+ *ln = line;
+ if (costs1)
+ *costs1 = 0;
+ if (Points1) {
+ Vect_append_point(Points1, x, y, z);
+ Vect_append_point(Points1, cx, cy, cz);
+ G_debug(3, "first node nearest");
+ return 1;
+ if (Points->x[npoints - 1] == cx && Points->y[npoints - 1] == cy) {
+ if (node1)
+ *node1 = n2;
+ if (ln)
+ *ln = line;
+ if (costs1)
+ *costs1 = 0;
+ if (Points1) {
+ G_debug(3, "last node nearest");
+ return 1;
+ nnodes = 2;
+ /* c1 - costs to get from/to the first vertex */
+ /* c2 - costs to get from/to the last vertex */
+ if (direction == GV_FORWARD) { /* from point to net */
+ Vect_net_get_line_cost(Map, line, GV_BACKWARD, &c1);
+ Vect_net_get_line_cost(Map, line, GV_FORWARD, &c2);
+ else {
+ Vect_net_get_line_cost(Map, line, GV_FORWARD, &c1);
+ Vect_net_get_line_cost(Map, line, GV_BACKWARD, &c2);
+ if (c1 < 0)
+ nnodes--;
+ if (c2 < 0)
+ nnodes--;
+ if (nnodes == 0)
+ return 0; /* both directions closed */
+ length = Vect_line_length(Points);
+ if (ln)
+ *ln = line;
+ if (nnodes == 1 && c1 < 0) { /* first direction is closed, return node2 as node1 */
+ if (node1)
+ *node1 = n2;
+ if (costs1) { /* to node 2, i.e. forward */
+ *costs1 = c2 * (length - along) / length;
+ if (Points1) { /* to node 2, i.e. forward */
+ int i;
+ for (i = segment; i < npoints; i++)
+ Vect_append_point(Points1, Points->x[i], Points->y[i],
+ Points->z[i]);
+ else {
+ for (i = npoints - 1; i >= segment; i--)
+ Points->z[i]);
+ else {
+ if (node1)
+ *node1 = n1;
+ if (node2)
+ *node2 = n2;
+ if (costs1) { /* to node 1, i.e. backward */
+ *costs1 = c1 * along / length;
+ if (costs2) { /* to node 2, i.e. forward */
+ *costs2 = c2 * (length - along) / length;
+ if (Points1) { /* to node 1, i.e. backward */
+ int i;
+ for (i = segment - 1; i >= 0; i--)
+ Points->z[i]);
+ else {
+ for (i = 0; i < segment; i++)
+ Points->z[i]);
+ if (Points2) { /* to node 2, i.e. forward */
+ int i;
+ Vect_append_point(Points2, x, y, z);
+ Vect_append_point(Points2, cx, cy, cz);
+ Vect_append_point(Points2, Points->x[i], Points->y[i],
+ Points->z[i]);
+ else {
+ Points->z[i]);
+ return nnodes;
+ \brief Find shortest path on network between 2 points given by coordinates.
+ \param fx,fy,fz from point x coordinate (z ignored)
+ \param tx,ty,tz to point x coordinate (z ignored)
+ \param fmax maximum distance to the network from 'from'
+ \param tmax maximum distance to the network from 'to'
+ \param tfield number of layer where turntable is attached
+ (if it has 0 value - network is without turntable)
+ \param tucfield number of layer with unique categories used in turntable
+ \param costs pointer where to store costs on the network (or NULL)
+ \param Points pointer to the structure where to store vertices of shortest path (or NULL)
+ \param List pointer to the structure where list of lines on the network is stored (or NULL)
+ \param NodesList pointer to the structure where list of nodes on the network is stored (or NULL)
+ \param FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
+ \param TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
+ \param fdist distance from 'from' to the net (or NULL)
+ \param tdist distance from 'to' to the net (or NULL)
+ \return 1 OK, 0 not reachable
+static int
+find_shortest_path_coor(struct Map_info *Map,
+ double fx, double fy, double fz, double tx,
+ double ty, double tz, double fmax, double tmax,
+ int tfield, int tucfield,
+ double *costs, struct line_pnts *Points,
+ struct ilist *List, struct ilist *NodesList,
+ struct line_pnts *FPoints,
+ struct line_pnts *TPoints, double *fdist,
+ double *tdist)
+ int fnode[2], tnode[2]; /* nearest nodes, *node[1] is 0 if only one was found */
+ double fcosts[2], tcosts[2], cur_cst; /* costs to nearest nodes on the network */
+ int nfnodes, ntnodes, fline, tline;
+ static struct line_pnts *APoints, *SPoints, *fPoints[2], *tPoints[2];
+ static struct ilist *LList;
+ static int first = 1;
+ int reachable, shortcut;
+ int i, j, fn = 0, tn = 0;
+ /* from/to_point_node is set if from/to point projected to line
+ *falls exactly on node (shortcut -> fline == tline) */
+ int from_point_node = 0;
+ int to_point_node = 0;
+ G_debug(3, "Vect_net_shortest_path_coor()");
+ if (first) {
+ APoints = Vect_new_line_struct();
+ SPoints = Vect_new_line_struct();
+ fPoints[0] = Vect_new_line_struct();
+ fPoints[1] = Vect_new_line_struct();
+ tPoints[0] = Vect_new_line_struct();
+ tPoints[1] = Vect_new_line_struct();
+ LList = Vect_new_list();
+ first = 0;
+ /* Reset */
+ if (costs)
+ *costs = PORT_DOUBLE_MAX;
+ if (Points)
+ Vect_reset_line(Points);
+ if (fdist)
+ *fdist = 0;
+ if (tdist)
+ *tdist = 0;
+ if (List)
+ List->n_values = 0;
+ if (FPoints)
+ Vect_reset_line(FPoints);
+ if (TPoints)
+ Vect_reset_line(TPoints);
+ if (NodesList != NULL)
+ Vect_reset_list(NodesList);
+ /* Find nearest nodes */
+ fnode[0] = fnode[1] = tnode[0] = tnode[1] = 0;
+ nfnodes =
+ Vect_net_nearest_nodes(Map, fx, fy, fz, GV_FORWARD, fmax, &(fnode[0]),
+ &(fnode[1]), &fline, &(fcosts[0]),
+ &(fcosts[1]), fPoints[0], fPoints[1], fdist);
+ if (nfnodes == 0)
+ return 0;
+ if (nfnodes == 1 && fPoints[0]->n_points < 3) {
+ from_point_node = fnode[0];
+ ntnodes =
+ Vect_net_nearest_nodes(Map, tx, ty, tz, GV_BACKWARD, tmax,
+ &(tnode[0]), &(tnode[1]), &tline, &(tcosts[0]),
+ &(tcosts[1]), tPoints[0], tPoints[1], tdist);
+ if (ntnodes == 0)
+ return 0;
+ if (ntnodes == 1 && tPoints[0]->n_points < 3) {
+ to_point_node = tnode[0];
+ G_debug(3, "fline = %d tline = %d", fline, tline);
+ reachable = shortcut = 0;
+ cur_cst = PORT_DOUBLE_MAX;
+ /* It may happen, that 2 points are at the same line. */
+ /* TODO?: it could also happen that fline != tline but both points are on the same
+ * line if they fall on node but a different line was found. This case is correctly
+ * handled as normal non shortcut, but it could be added here. In that case
+ * NodesList collection must be changed */
+ if (fline == tline && (nfnodes > 1 || ntnodes > 1)) {
+ double len, flen, tlen, c, fseg, tseg;
+ double fcx, fcy, fcz, tcx, tcy, tcz;
+ Vect_read_line(Map, APoints, NULL, fline);
+ len = Vect_line_length(APoints);
+ /* distance along the line */
+ fseg =
+ Vect_line_distance(APoints, fx, fy, fz, 0, &fcx, &fcy, &fcz, NULL,
+ NULL, &flen);
+ tseg =
+ Vect_line_distance(APoints, tx, ty, tz, 0, &tcx, &tcy, &tcz, NULL,
+ NULL, &tlen);
+ Vect_reset_line(SPoints);
+ if (flen == tlen) {
+ cur_cst = 0;
+ reachable = shortcut = 1;
+ else if (flen < tlen) {
+ Vect_net_get_line_cost(Map, fline, GV_FORWARD, &c);
+ if (c >= 0) {
+ cur_cst = c * (tlen - flen) / len;
+ Vect_append_point(SPoints, fx, fy, fz);
+ Vect_append_point(SPoints, fcx, fcy, fcz);
+ for (i = fseg; i < tseg; i++)
+ Vect_append_point(SPoints, APoints->x[i], APoints->y[i],
+ APoints->z[i]);
+ Vect_append_point(SPoints, tcx, tcy, tcz);
+ Vect_append_point(SPoints, tx, ty, tz);
+ else { /* flen > tlen */
+ Vect_net_get_line_cost(Map, fline, GV_BACKWARD, &c);
+ if (c >= 0) {
+ cur_cst = c * (flen - tlen) / len;
+ for (i = fseg - 1; i >= tseg; i--)
+ APoints->z[i]);
+ /* Find the shortest variant from maximum 4 */
+ for (i = 0; i < nfnodes; i++) {
+ for (j = 0; j < ntnodes; j++) {
+ double ncst, cst;
+ int ret;
+ G_debug(3, "i = %d fnode = %d j = %d tnode = %d", i, fnode[i], j,
+ tnode[j]);
+ if (tfield && tucfield)
+ ret = Vect_net_ttb_shortest_path(Map, fnode[i], 0, tnode[j], 0, tfield,
+ tucfield, NULL, &ncst);
+ else
+ ret =
+ Vect_net_shortest_path(Map, fnode[i], tnode[j], NULL, &ncst);
+ if (ret == -1)
+ continue; /* not reachable */
+ cst = fcosts[i] + ncst + tcosts[j];
+ if (reachable == 0 || cst < cur_cst) {
+ cur_cst = cst;
+ fn = i;
+ tn = j;
+ shortcut = 0;
+ reachable = 1;
+ G_debug(3, "reachable = %d shortcut = %d cur_cst = %f", reachable,
+ shortcut, cur_cst);
+ if (reachable) {
+ if (shortcut) {
+ if (Points)
+ Vect_append_points(Points, SPoints, GV_FORWARD);
+ if (NodesList) {
+ /* Check if from/to point projected to line falls on node and
+ *add it to the list */
+ if (from_point_node > 0)
+ Vect_list_append(NodesList, from_point_node);
+ if (to_point_node > 0)
+ Vect_list_append(NodesList, to_point_node);
+ else {
+ if (NodesList) {
+ /* it can happen that starting point falls on node but SP starts
+ * form the other node, add it in that case,
+ * similarly for to point below */
+ if (from_point_node > 0 && from_point_node != fnode[fn]) {
+ /* add starting net SP search node */
+ Vect_list_append(NodesList, fnode[fn]);
+ Vect_net_ttb_shortest_path(Map, fnode[fn], 0, tnode[tn], 0, tfield,
+ tucfield, LList, NULL);
+ else
+ Vect_net_shortest_path(Map, fnode[fn], tnode[tn], LList,
+ NULL);
+ G_debug(3, "Number of lines %d", LList->n_values);
+ if (Points)
+ Vect_append_points(Points, fPoints[fn], GV_FORWARD);
+ if (FPoints)
+ Vect_append_points(FPoints, fPoints[fn], GV_FORWARD);
+ for (i = 0; i < LList->n_values; i++) {
+ int line;
+ line = LList->value[i];
+ G_debug(3, "i = %d line = %d", i, line);
+ if (Points) {
+ Vect_read_line(Map, APoints, NULL, abs(line));
+ if (line > 0)
+ Vect_append_points(Points, APoints, GV_FORWARD);
+ else
+ Vect_append_points(Points, APoints, GV_BACKWARD);
+ if (NodesList) {
+ int node, node1, node2;
+ Vect_get_line_nodes(Map, abs(line), &node1, &node2);
+ /* add the second node, the first of first segmet was alread added */
+ if (line > 0)
+ node = node2;
+ else
+ node = node1;
+ Vect_list_append(NodesList, node);
+ if (List)
+ if (Points)
+ Vect_append_points(Points, tPoints[tn], GV_FORWARD);
+ if (TPoints)
+ Vect_append_points(TPoints, tPoints[tn], GV_FORWARD);
+ if (NodesList) {
+ if (to_point_node > 0 && to_point_node != tnode[tn]) {
+ if (costs)
+ *costs = cur_cst;
+ return reachable;
+ \param[out] costs pointer where to store costs on the network (or NULL)
+ \param[out] Points pointer to the structure where to store vertices of shortest path (or NULL)
+ \param[out] List pointer to the structure where list of lines on the network is stored (or NULL)
+ \param[out] FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
+ \param[out] TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
+ \param[out] fdist distance from 'from' to the net (or NULL)
+ \param[out] tdist distance from 'to' to the net (or NULL)
+ \return 1 OK
+ \return 0 not reachable
+int
+Vect_net_shortest_path_coor(struct Map_info *Map,
+ struct ilist *List, struct line_pnts *FPoints,
+ double *tdist)
+ return find_shortest_path_coor(Map, fx, fy, fz, tx, ty, tz, fmax, tmax, 0,
+ 0, costs, Points, List, NULL, FPoints,
+ TPoints, fdist, tdist);
+ \brief Find shortest path on network with turntable between 2 points given by coordinates.
+ \return 1 OK
+int
+Vect_net_ttb_shortest_path_coor(struct Map_info *Map,
+ double tmax, int tfield, int tucfield,
+ double *tdist)
+ tfield, tucfield, costs, Points, List,
+ NULL, FPoints, TPoints, fdist, tdist);
+int
+Vect_net_shortest_path_coor2(struct Map_info *Map,
+ double *tdist)
+ 0, costs, Points, List, NodesList, FPoints,
+int
+Vect_net_ttb_shortest_path_coor2(struct Map_info *Map,
+ double *tdist)
+ NodesList, FPoints, TPoints, fdist, tdist);
