[GRASS-SVN] r57187 - in grass/trunk/gui/wxpython: . core lmgr xml
svn_grass at osgeo.org
Wed Jul 17 04:17:55 PDT 2013
Author: wenzeslaus
Date: 2013-07-17 04:17:54 -0700 (Wed, 17 Jul 2013)
New Revision: 57187
Added:
grass/trunk/gui/wxpython/xml/module_tree.xml
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/core/menutree.py
grass/trunk/gui/wxpython/core/toolboxes.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/menudata.py
grass/trunk/gui/wxpython/xml/main_menu.xml
wxGUI/toolboxes: different tree for menu and for search module (missing some formal things)
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2013-07-17 10:08:51 UTC (rev 57186)
+++ grass/trunk/gui/wxpython/Makefile 2013-07-17 11:17:54 UTC (rev 57187)
@@ -1,7 +1,7 @@
MODULE_TOPDIR = ../..
SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap dbmgr vdigit iclass
-EXTRA_CLEAN_FILES = menustrings.py build_ext.pyc xml/menudata.xml
+EXTRA_CLEAN_FILES = menustrings.py build_ext.pyc xml/menudata.xml xml/module_tree_menudata.xml
include $(MODULE_TOPDIR)/include/Make/Dir.make
include $(MODULE_TOPDIR)/include/Make/Doxygen.make
@@ -28,6 +28,7 @@
default: $(DSTFILES)
-$(MAKE) $(ETCDIR)/xml/module_items.xml
-$(MAKE) xml/menudata.xml
+ -$(MAKE) xml/module_tree_menudata.xml
-$(MAKE) menustrings.py
$(MAKE) parsubdirs
@@ -38,6 +39,9 @@
xml/menudata.xml: core/toolboxes.py
$(call run_grass,$(PYTHON) $< > $@)
+xml/module_tree_menudata.xml: core/toolboxes.py
+ $(call run_grass,$(PYTHON) $< dummy_parameter > $@)
menustrings.py: core/menutree.py $(ETCDIR)/xml/menudata.xml $(ETCDIR)/xml/menudata_modeler.xml $(ETCDIR)/xml/menudata_psmap.xml
@echo "# This is a generated file.\n" > $@
$(call run_grass,$(PYTHON) $< >> $@)
Modified: grass/trunk/gui/wxpython/core/menutree.py
--- grass/trunk/gui/wxpython/core/menutree.py 2013-07-17 10:08:51 UTC (rev 57186)
+++ grass/trunk/gui/wxpython/core/menutree.py 2013-07-17 11:17:54 UTC (rev 57187)
@@ -49,10 +49,13 @@
from core.treemodel import TreeModel, ModuleNode
from core.settings import UserSettings
+from core.toolboxes import expandAddons
if not os.getenv("GISBASE"):
sys.exit("GRASS is not running. Exiting...")
+# TODO: change the system to remove strange derived classes
class MenuTreeModelBuilder:
"""!Abstract menu data class"""
def __init__(self, filename):
@@ -62,6 +65,7 @@
subkey = 'selection')
xmlTree = etree.parse(filename)
+ expandAddons(xmlTree)
self.model = TreeModel(ModuleNode)
self._createModel(xmlTree)
Modified: grass/trunk/gui/wxpython/core/toolboxes.py
--- grass/trunk/gui/wxpython/core/toolboxes.py 2013-07-17 10:08:51 UTC (rev 57186)
+++ grass/trunk/gui/wxpython/core/toolboxes.py 2013-07-17 11:17:54 UTC (rev 57187)
@@ -43,6 +43,7 @@
import grass.script.task as gtask
import grass.script.core as gcore
from grass.script.core import ScriptError
+from core.debug import Debug
# this could be placed to functions
@@ -67,6 +68,89 @@
gcore.try_remove(path)
+# TODO: merge the function with getMenuFile
+def getMenudataFile(userRootFile, newFile, fallback):
+ """!Returns path to XML file for building menu.
+ Creates toolbox directory where user defined toolboxes should be located.
+ Checks whether it is needed to create new XML file (user changed toolboxes)
+ or the already generated file could be used.
+ If something goes wrong during building or user doesn't modify menu,
+ default file (from distribution) is returned.
+ Debug.msg(1, "toolboxes.getMenudataFile: {userRootFile}, {newFile}, {fallback}".format(**locals()))
+ distributionRootFile = os.path.join(ETCWXDIR, 'xml', userRootFile)
+ userRootFile = os.path.join(GetSettingsPath(), 'toolboxes', userRootFile)
+ if not os.path.exists(userRootFile):
+ userRootFile = None
+ ##fallback = os.path.join(ETCWXDIR, 'xml', 'menudata.xml')
+ # always create toolboxes directory if does not exist yet
+ tbDir = _setupToolboxes()
+ if tbDir:
+ menudataFile = os.path.join(tbDir, newFile)
+ generateNew = False
+ # when any of main_menu.xml or toolboxes.xml are changed,
+ # generate new menudata.xml
+ if os.path.exists(menudataFile):
+ # remove menu file when there is no main_menu and toolboxes
+ if not userToolboxesFile and not userRootFile:
+ os.remove(menudataFile)
+ Debug.msg(2, "toolboxes.getMenudataFile: no user defined files, menudata deleted")
+ return fallback
+ if bool(userToolboxesFile) != bool(userRootFile):
+ # always generate new because we don't know if there has been any change
+ generateNew = True
+ Debug.msg(2, "toolboxes.getMenudataFile: only one of the user defined files")
+ else:
+ # if newer files -> generate new
+ menudataTime = os.path.getmtime(menudataFile)
+ if userToolboxesFile:
+ if os.path.getmtime(userToolboxesFile) > menudataTime:
+ Debug.msg(2, "toolboxes.getMenudataFile: user toolboxes is newer than menudata")
+ if userRootFile:
+ if os.path.getmtime(userRootFile) > menudataTime:
+ Debug.msg(2, "toolboxes.getMenudataFile: user root file is newer than menudata")
+ elif userToolboxesFile or userRootFile:
+ Debug.msg(2, "toolboxes.getMenudataFile: no menudata")
+ else:
+ Debug.msg(2, "toolboxes.getMenudataFile: no user defined files")
+ return fallback
+ if generateNew:
+ try:
+ # The case when user does not have custom root
+ # file but has toolboxes requieres regeneration.
+ # Unfortunately, this is the case can be often: defined
+ # toolboxes but undefined module tree file.
+ Debug.msg(2, "toolboxes.getMenudataFile: creating a tree")
+ tree = createTree(distributionRootFile=distributionRootFile, userRootFile=userRootFile)
+ except ETREE_EXCEPTIONS:
+ GError(_("Unable to parse user toolboxes XML files. "
+ "Default toolboxes will be loaded."))
+ return fallback
+ try:
+ xml = _getXMLString(tree.getroot())
+ fh = open(menudataFile, 'w')
+ fh.write(xml)
+ fh.close()
+ return menudataFile
+ except:
+ return fallback
+ else:
+ else:
+ return fallback
def getMenuFile():
@@ -76,6 +160,7 @@
+ Debug.msg(1, "toolboxes.getMenuFile")
@@ -156,7 +241,40 @@
return False
return True
+# TODO: merge with toolboxes2menudata
+def createTree(distributionRootFile, userRootFile, userDefined=True):
+ """!Creates XML file with data for menu.
+ Parses toolboxes files from distribution and from users,
+ puts them together, adds metadata to modules and convert
+ tree to previous format used for loading menu.
+ @param userDefined use toolboxes defined by user or not (during compilation)
+ @return ElementTree instance
+ if userDefined and userRootFile:
+ mainMenu = etree.parse(userRootFile)
+ else:
+ mainMenu = etree.parse(distributionRootFile)
+ toolboxes = etree.parse(toolboxesFile)
+ if userDefined and userToolboxesFile:
+ userToolboxes = etree.parse(userToolboxesFile)
+ else:
+ userToolboxes = None
+ wxguiItems = etree.parse(wxguiItemsFile)
+ moduleItems = etree.parse(moduleItemsFile)
+ return toolboxes2menudataInternal(mainMenu=mainMenu,
+ toolboxes=toolboxes,
+ userToolboxes=userToolboxes,
+ wxguiItems=wxguiItems,
+ moduleItems=moduleItems)
def toolboxes2menudata(userDefined=True):
@@ -190,6 +308,7 @@
+# TODO: rename
def toolboxes2menudataInternal(mainMenu, toolboxes, userToolboxes,
wxguiItems, moduleItems):
@@ -215,10 +334,10 @@
if not userHasToolboxes:
_removeUserToolboxesItem(root)
- _expandAddonsItem(root)
_expandToolboxes(root, toolboxes)
+ # we do not expand addons here since they need to be expanded in runtime
_expandItems(root, moduleItems, 'module-item')
_expandItems(root, wxguiItems, 'wxgui-item')
@@ -250,6 +369,17 @@
elem.tail = i
+def expandAddons(tree):
+ """!Expands addons element.
+ root = tree.getroot()
+ _expandAddonsItem(root)
+ # expanding and converting is done twice, so there is some overhead
+ _expandRuntimeModules(root)
+ _addHandlers(root)
+ _convertTree(root)
def _expandToolboxes(node, toolboxes):
"""!Expands tree with toolboxes.
@@ -344,7 +474,7 @@
>>> toolboxes = etree.fromstring('<toolboxes><toolbox name="UserToolbox"><items><module-item name="g.region"/></items></toolbox></toolboxes>')
>>> _expandUserToolboxesItem(tree, toolboxes)
>>> etree.tostring(tree)
- '<toolbox><items><toolbox name="GeneratedUserToolboxesList"><label>Toolboxes</label><items><toolbox name="UserToolbox"><items><module-item name="g.region" /></items></toolbox></items></toolbox></items></toolbox>'
+ '<toolbox><items><toolbox name="GeneratedUserToolboxesList"><label>Custom toolboxes</label><items><toolbox name="UserToolbox"><items><module-item name="g.region" /></items></toolbox></items></toolbox></items></toolbox>'
tboxes = toolboxes.findall('.//toolbox')
@@ -354,7 +484,7 @@
el = etree.Element('toolbox', attrib={'name': 'GeneratedUserToolboxesList'})
items.insert(idx, el)
label = etree.SubElement(el, tag='label')
- label.text = _("Toolboxes")
+ label.text = _("Custom toolboxes")
it = etree.SubElement(el, tag='items')
for toolbox in tboxes:
it.append(copy.deepcopy(toolbox))
@@ -374,34 +504,50 @@
items.remove(n)
+def _getAddons():
+ return sorted(RunCommand('g.extension', quiet=True, read=True,
+ flags='a').splitlines())
+def _removeAddonsItem(node, addonsNodes):
+ # TODO: change impl to be similar with the remove toolboxes
+ for n in addonsNodes:
+ items = node.find('./items')
+ if items is not None:
+ items.remove(n)
+ # because of inconsistent menudata file
+ items = node.find('./menubar')
+ items.remove(n)
def _expandAddonsItem(node):
- """!Expands tag addons (in main_menu.xml) with currently installed addons.append
+ """!Expands addons element with currently installed addons.
Note: there is no mechanism yet to tell the gui to rebuild the menudata.xml
file when new addons are added/removed.
# no addonsTag -> do nothing
- addonsTags = node.findall('./items/addons')
+ addonsTags = node.findall('.//addons')
if not addonsTags:
return
# fetch addons
- addons = sorted(RunCommand('g.extension', quiet=True, read=True,
- flags = 'a').splitlines())
+ addons = _getAddons()
# no addons -> remove addons tag
if not addons:
- for n in addonsTags:
- items = node.find('./items')
- idx = items.getchildren().index(n)
- items.remove(n)
+ _removeAddonsItem(node, addonsTags)
return
# create addons toolbox
# keywords and desc are handled later automatically
+ for n in addonsTags:
+ # find parent is not possible with implementation of etree (in 2.7)
- el = etree.Element('toolbox', attrib={'name': 'AddonsToolboxesList'})
+ # do not set name since it is already in menudata file
+ # attib={'name': 'AddonsList'}
+ el = etree.Element('menu')
label.text = _("Addons")
@@ -548,7 +694,9 @@
root.attrib = {}
label = root.find('label')
- root.remove(label)
+ # must check because of inconsistent XML menudata file
+ if label is not None:
+ root.remove(label)
_convertTag(root, 'description', 'help')
_convertTag(root, 'wx-id', 'id')
_convertTag(root, 'module', 'command')
@@ -558,7 +706,9 @@
root.tag = 'menudata'
i1 = root.find('./items')
- i1.tag = 'menubar'
+ if i1 is not None:
+ i1.tag = 'menubar'
_convertTagAndRemoveAttrib(root, 'toolbox', 'menu')
@@ -669,14 +819,22 @@
File is written to the standard output.
- tree = toolboxes2menudata(userDefined=False)
- root = tree.getroot()
- sys.stdout.write(_getXMLString(root))
+ # TODO: fix parameter handling
+ if len(sys.argv) > 1:
+ mainFile = os.path.join(ETCWXDIR, 'xml', 'module_tree.xml')
+ tree = createTree(distributionRootFile=mainFile, userRootFile=None, userDefined=False)
+ sys.stdout.write(_getXMLString(root))
+ else:
+ tree = toolboxes2menudata(userDefined=False)
return 0
if __name__ == '__main__':
if sys.argv[1] == 'doctest':
sys.exit(doc_test())
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2013-07-17 10:08:51 UTC (rev 57186)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2013-07-17 11:17:54 UTC (rev 57187)
@@ -47,7 +47,7 @@
from core.utils import SetAddOnPath, GetLayerNameFromCmd, command2ltype
from gui_core.preferences import MapsetAccess, PreferencesDialog
from lmgr.layertree import LayerTree, LMIcons
-from lmgr.menudata import LayerManagerMenuData
+from lmgr.menudata import LayerManagerMenuData, LayerManagerModuleTree
from gui_core.widgets import GNotebook
from modules.mcalc_builder import MapCalcFrame
from dbmgr.manager import AttributeManager
@@ -105,7 +105,10 @@
self._giface = LayerManagerGrassInterface(self)
+ # the main menu bar
self._menuTreeBuilder = LayerManagerMenuData()
+ # the search tree and command console
+ self._moduleTreeBuilder = LayerManagerModuleTree()
self._auimgr = wx.aui.AuiManager(self)
@@ -279,7 +282,7 @@
self._gconsole = GConsole(guiparent = self, giface = self._giface,
ignoredCmdPattern = '^d\..*|^r[3]?\.mapcalc$|^i.group')
self.goutput = GConsoleWindow(parent = self, gconsole = self._gconsole,
- menuModel=self._menuTreeBuilder.GetModel(),
+ menuModel=self._moduleTreeBuilder.GetModel(),
gcstyle = GC_SEARCH | GC_PROMPT)
self.notebook.AddPage(page = self.goutput, text = _("Command console"), name = 'output')
@@ -317,7 +320,7 @@
# create 'search module' notebook page
if not UserSettings.Get(group = 'manager', key = 'hideTabs', subkey = 'search'):
- self.search = SearchModuleWindow(parent = self, model=self._menuTreeBuilder.GetModel())
+ self.search = SearchModuleWindow(parent = self, model=self._moduleTreeBuilder.GetModel())
self.search.showNotification.connect(lambda message: self.SetStatusText(message))
self.notebook.AddPage(page = self.search, text = _("Search modules"), name = 'search')
else:
Modified: grass/trunk/gui/wxpython/lmgr/menudata.py
--- grass/trunk/gui/wxpython/lmgr/menudata.py 2013-07-17 10:08:51 UTC (rev 57186)
+++ grass/trunk/gui/wxpython/lmgr/menudata.py 2013-07-17 11:17:54 UTC (rev 57187)
@@ -18,7 +18,7 @@
import os
from core.menutree import MenuTreeModelBuilder
-from core.toolboxes import getMenuFile
+from core.toolboxes import getMenuFile, getMenudataFile
from core.globalvar import ETCWXDIR
from core.gcmd import GError
@@ -34,3 +34,19 @@
MenuTreeModelBuilder.__init__(self, fallback)
+class LayerManagerModuleTree(MenuTreeModelBuilder):
+ def __init__(self, filename=None):
+ fallback = os.path.join(ETCWXDIR, 'xml', 'module_tree_menudata.xml')
+ if not filename:
+ filename = getMenudataFile(userRootFile='module_tree.xml',
+ newFile='module_tree_menudata.xml',
+ fallback=fallback)
+ # TODO: try-except useless?
+ try:
+ MenuTreeModelBuilder.__init__(self, filename)
+ except (ValueError, AttributeError, TypeError):
+ MenuTreeModelBuilder.__init__(self, fallback)
Modified: grass/trunk/gui/wxpython/xml/main_menu.xml
--- grass/trunk/gui/wxpython/xml/main_menu.xml 2013-07-17 10:08:51 UTC (rev 57186)
+++ grass/trunk/gui/wxpython/xml/main_menu.xml 2013-07-17 11:17:54 UTC (rev 57187)
@@ -10,7 +10,6 @@
<subtoolbox name="Imagery"/>
<subtoolbox name="Volumes"/>
<subtoolbox name="Database"/>
- <user-toolboxes-list />
<subtoolbox name="Help"/>
</items>
</toolbox>
Added: grass/trunk/gui/wxpython/xml/module_tree.xml
--- grass/trunk/gui/wxpython/xml/module_tree.xml (rev 0)
+++ grass/trunk/gui/wxpython/xml/module_tree.xml 2013-07-17 11:17:54 UTC (rev 57187)
@@ -0,0 +1,16 @@
+<?xml version="1.0" encoding="UTF-8"?>
+<!DOCTYPE toolbox SYSTEM "main_menu.dtd">
+<toolbox name="DefaultModuleTree">
+ <label>Default GRASS GIS module tree</label>
+ <items>
+ <subtoolbox name="Raster"/>
+ <subtoolbox name="Vector"/>
+ <subtoolbox name="Imagery"/>
+ <subtoolbox name="Volumes"/>
+ <subtoolbox name="Database"/>
+ <subtoolbox name="Temporal"/>
+ <user-toolboxes-list/>
+ <addons/>
+ </items>
+</toolbox>
Property changes on: grass/trunk/gui/wxpython/xml/module_tree.xml
___________________________________________________________________
Added: svn:mime-type
+ text/xml
Added: svn:eol-style
+ native
