[GRASS-SVN] r57222 - grass/branches/releasebranch_6_4
svn_grass at osgeo.org
Thu Jul 18 10:41:16 PDT 2013
Author: neteler
Date: 2013-07-18 10:41:15 -0700 (Thu, 18 Jul 2013)
New Revision: 57222
grass/branches/releasebranch_6_4/SUBMITTING_DOCS
SUBMITTING_DOCS: updated for PNG compression and svn propset script; cosmetics
Modified: grass/branches/releasebranch_6_4/SUBMITTING_DOCS
--- grass/branches/releasebranch_6_4/SUBMITTING_DOCS 2013-07-18 17:22:56 UTC (rev 57221)
+++ grass/branches/releasebranch_6_4/SUBMITTING_DOCS 2013-07-18 17:41:15 UTC (rev 57222)
@@ -2,7 +2,7 @@
NOTE: Please improve this list!
-Dear (new) GRASS Developer,
+Dear (new) GRASS GIS Developer,
When submitting documentation to GRASS SVN repository, please take
care of following rules:
@@ -82,11 +82,15 @@
3. Usage of limited HTML tags
Since the MAN conversion of g.html2man is limited, please use
no other HTML tags than:
- <A> <B> <BLINK> <BODY> <BR> <CODE> <DD> <DL> <DT> <EM>
- <H2> <H3> <H4> <HEAD> <HEADER> <HR> <I> <IMG> <LI> <OL> <P>
- <PRE> <SUP> <TABLE> <TD> <TH> <TITLE> <TR> <UL>
+ <a> <b> <blink> <body> <br> <code> <dd> <dl> <dt> <em>
+ <h2> <h3> <h4> <head> <header> <hr> <i> <img> <li> <ol> <p>
+ <pre> <sup> <table> <td> <th> <title> <tr> <ul>
+ Note that all tags has a closing tag except for <hr/>, <br/> and <p>.
+ Use lower case forms.
+ (The MAN converter is here: tools/g.html2man/)
4. Suggested HTML markup protocol:
Module names (i.e., v.category) should be emphsized with <em>,
and boldface <b> for flags and parameter names. Shell commands,
@@ -96,7 +100,7 @@
5. When submitting new files to the repository set SVN properties,
- e.g. for HTML file:
+ e.g. for HTML file
svn:mime-type : text/html
svn:keywords : Author Date Id
@@ -105,9 +109,16 @@
See
http://svnbook.red-bean.com/en/1.4/svn.advanced.props.html
+ You can also simply use this script:
+ http://svn.osgeo.org/grass/grass-addons/tools/module_svn_propset.sh
-6. See also
+6. Compress PNG images with
+7. See also
http://grass.osgeo.org/wiki/Updating_GRASS_Documentation
[please add further hints if required]
+"Your attention to detail is appreciated."
