[GRASS-SVN] r57229 - grass/branches/develbranch_6/raster/r.watershed/front
svn_grass at osgeo.org
Thu Jul 18 16:51:40 PDT 2013
Author: hamish
Date: 2013-07-18 16:51:40 -0700 (Thu, 18 Jul 2013)
New Revision: 57229
grass/branches/develbranch_6/raster/r.watershed/front/main.c
drop underscore and semi-redundant 'options' from tab name (merge from trunk)
Modified: grass/branches/develbranch_6/raster/r.watershed/front/main.c
--- grass/branches/develbranch_6/raster/r.watershed/front/main.c 2013-07-18 18:25:00 UTC (rev 57228)
+++ grass/branches/develbranch_6/raster/r.watershed/front/main.c 2013-07-18 23:51:40 UTC (rev 57229)
@@ -57,20 +57,20 @@
module->description = _("Watershed basin analysis program");
opt1 = G_define_standard_option(G_OPT_R_ELEV);
- opt1->guisection = _("Input_options");
+ opt1->guisection = _("Inputs");
opt2 = G_define_standard_option(G_OPT_R_INPUT);
opt2->key = "depression";
opt2->label = _("Name of input raster map with real depressions");
opt2->description = _("All non-NULL and non-zero cells are considered as real depressions");
opt2->required = NO;
- opt2->guisection = _("Input_options");
+ opt2->guisection = _("Inputs");
opt3 = G_define_standard_option(G_OPT_R_INPUT);
opt3->key = "flow";
opt3->description = _("Name of input raster representing amount of overland flow per cell");
opt3->required = NO;
- opt3->guisection = _("Input_options");
+ opt3->guisection = _("Inputs");
opt4 = G_define_standard_option(G_OPT_R_INPUT);
opt4->key = "disturbed.land";
@@ -78,7 +78,7 @@
_("Name of input raster map percent of disturbed land");
opt4->description = _("For USLE");
opt4->required = NO;
- opt4->guisection = _("Input_options");
+ opt4->guisection = _("Inputs");
opt5 = G_define_standard_option(G_OPT_R_INPUT);
opt5->key = "blocking";
@@ -87,33 +87,33 @@
opt5->description =
_("For USLE. All non-NULL and non-zero cells are considered as blocking terrain.");
opt5->required = NO;
- opt5->guisection = _("Input_options");
+ opt5->guisection = _("Inputs");
opt8 = G_define_standard_option(G_OPT_R_OUTPUT);
opt8->key = "accumulation";
opt8->label = _("Name for output accumulation raster map");
opt8->description = _("Number of cells that drain through each cell");
opt8->required = NO;
- opt8->guisection = _("Output_options");
+ opt8->guisection = _("Outputs");
opt9 = G_define_standard_option(G_OPT_R_OUTPUT);
opt9->key = "drainage";
opt9->description = _("Name for output drainage direction raster map");
opt9->required = NO;
- opt9->guisection = _("Output_options");
+ opt9->guisection = _("Outputs");
opt10 = G_define_standard_option(G_OPT_R_OUTPUT);
opt10->key = "basin";
opt10->label = _("Name for basins raster map");
opt10->description = _("Unique label for each watershed basin");
opt10->required = NO;
- opt10->guisection = _("Output_options");
+ opt10->guisection = _("Outputs");
opt11 = G_define_standard_option(G_OPT_R_OUTPUT);
opt11->key = "stream";
opt11->description = _("Name for output stream segments raster map");
opt11->required = NO;
- opt11->guisection = _("Output_options");
+ opt11->guisection = _("Outputs");
opt12 = G_define_standard_option(G_OPT_R_OUTPUT);
opt12->key = "half.basin";
@@ -121,14 +121,14 @@
opt12->description =
_("Each half-basin is given a unique value");
opt12->required = NO;
- opt12->guisection = _("Output_options");
+ opt12->guisection = _("Outputs");
opt13 = G_define_standard_option(G_OPT_R_OUTPUT);
opt13->key = "visual";
opt13->description =
_("Name for output raster map useful for visual display of results (DEPRECATED)");
opt13->required = NO;
- opt13->guisection = _("Output_options");
+ opt13->guisection = _("Outputs");
opt14 = G_define_standard_option(G_OPT_R_OUTPUT);
opt14->key = "length.slope";
@@ -136,14 +136,14 @@
opt14->description =
_("Slope length and steepness (LS) factor for USLE");
opt14->required = NO;
- opt14->guisection = _("Output_options");
+ opt14->guisection = _("Outputs");
opt15 = G_define_standard_option(G_OPT_R_OUTPUT);
opt15->key = "slope.steepness";
opt15->label = _("Name for output slope steepness raster map");
opt15->description = _("Slope steepness (S) factor for USLE");
opt15->required = NO;
- opt15->guisection = _("Output_options");
+ opt15->guisection = _("Outputs");
opt6 = G_define_option();
opt6->key = "threshold";
@@ -151,7 +151,7 @@
_("Minimum size of exterior watershed basin");
opt6->required = NO;
opt6->type = TYPE_INTEGER;
- opt6->guisection = _("Input_options");
+ opt6->guisection = _("Inputs");
opt7 = G_define_option();
opt7->key = "max.slope.length";
@@ -160,7 +160,7 @@
opt7->description = _("For USLE");
opt7->required = NO;
opt7->type = TYPE_DOUBLE;
- opt7->guisection = _("Input_options");
+ opt7->guisection = _("Inputs");
opt16 = G_define_option();
opt16->key = "convergence";
