[GRASS-SVN] r57234 - in grass/trunk/gui/wxpython: . docs gcp
svn_grass at osgeo.org
Sat Jul 20 11:41:49 PDT 2013
Author: wenzeslaus
Date: 2013-07-20 11:41:49 -0700 (Sat, 20 Jul 2013)
New Revision: 57234
Added:
grass/trunk/gui/wxpython/gcp/Makefile
grass/trunk/gui/wxpython/gcp/g.gui.gcp.html
grass/trunk/gui/wxpython/gcp/g.gui.gcp.py
grass/trunk/gui/wxpython/gcp/wxGUI_gcp_frame.jpg
Removed:
grass/trunk/gui/wxpython/docs/wxGUI.gcp.html
grass/trunk/gui/wxpython/docs/wxGUI_gcp_frame.jpg
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/gcp/manager.py
wxGUI/gcp: enabling GCP manager (with wizard) as g.gui.gcp module
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2013-07-20 17:32:39 UTC (rev 57233)
+++ grass/trunk/gui/wxpython/Makefile 2013-07-20 18:41:49 UTC (rev 57234)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap dbmgr vdigit iclass
+SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap dbmgr vdigit iclass gcp
EXTRA_CLEAN_FILES = menustrings.py build_ext.pyc xml/menudata.xml xml/module_tree_menudata.xml
include $(MODULE_TOPDIR)/include/Make/Dir.make
Deleted: grass/trunk/gui/wxpython/docs/wxGUI.gcp.html
--- grass/trunk/gui/wxpython/docs/wxGUI.gcp.html 2013-07-20 17:32:39 UTC (rev 57233)
+++ grass/trunk/gui/wxpython/docs/wxGUI.gcp.html 2013-07-20 18:41:49 UTC (rev 57234)
@@ -1,317 +0,0 @@
-<!-- meta page description: wxGUI GCP Manager -->
-<!-- meta page index: wxGUI -->
-<h2>DESCRIPTION</h2>
-The <b>GCP Manager</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
-extension which allows the user to create, edit, and manage
-Ground Control Points. It is available from the menu
-"File | Manage Ground Control Points".
-<p>
-The <b>GCP Manager</b> provides an interactive graphical interface to
-manage and analyze Ground Control Points. A backup copy of the initial
-POINTS file is always maintained and updated only on request (Save GCPs
-to POINTS file). This guarantees that accidential changes are not
-permanent and can be undone by reloading the Ground Control Points.
-<p>
-The GCP Manager must be started in the target location, not in the
-source location.
-<p>
-The GCP Manager is structured into three panels:
-<ul>
- <li>The topmost panel shows a list of Ground Control Points. Tools to
- manipulate and analyze GCPs are provided in the toolbar. This panel can
- be moved out of the GCP manager window by either dragging with the
- caption or by clicking on the pin button on the right in the caption.
- This panel can also be placed below the map displays by dragging.
- <li>The two panels in the lower part are used for map and GCP display,
- the left pane showing a map from the source location and the right
- pane showing a reference map from the target location. Numbered Ground
- Control Points are shown on both map displays.
-</ul>
-<h3>Components of the GCP Manager</h3>
-<center>
- <br><img src="wxGUI_gcp_frame.jpg" border="0" alt="GCP Manager"><br><br>
-</center>
-<p>
-<em>Toolbars</em>
-<p>
-Two toolbars are provided with the GCP Manager, one for managing the map
-displays and one for managing the GCP list.
-<p>
-<em>List of ground control points</em>
-<p>
-The list of Ground Control Points can be sorted by clicking on a column
-header. Clicking on a cloumn header will sort the GCPs ascending, a
-second click on the same column will sort the GCPs descending. Overall
-RMS error and individual RMS errors of all points are often improved if
-the GCP with the highest RMS error is adjusted. Individual coordinates
-can be edited by double-clicking on a row.
-<p>
-The first column holds a checkbox and displays the point number. A GCP
-is only used for RMS error calculation and georectification if its
-checkbox on the left is checked. Uncheck to deactivate a GCP (mark as
-unused GCP).
-<p>
-<em>Two panels for map display</em>
-<p>
-The left panel is used to display a map from the source location, the
-right panel to display a map from the target loaction. Zooming in and
-out is always possible with the mouse wheel and done for each map canvas
-separately.
-<p>
-GCPs are displayed in different colors, depending on whether a GCP has
-a high RMS error, is currently unused or is currently selected. Optionally,
-currently unused GCPs are not shown on the map display.
-<p>
-<em>Statusbar</em>
-<p>
-At the bottom of the GCP Manager is a statusbar providing several
-functions. The default is set to <em>Go to GCP No.</em> (see also below).
-Typing a number or using the up/down arrows will center the maps on the
-given GCP, useful with a high zoom.
-<h4>GCP Map Display Toolbar</h4>
-<dl>
-<dt><img src="icons/show.png" alt="icon">
- <em>Display map</em></dt>
-<dd>Displays maps for source and target canvas and re-renders any layers
-that have changed since the last time the display was updated.</dd>
-<dt><img src="icons/layer-redraw.png" alt="icon">
- <em>Re-render map</em></dt>
-<dd>Re-renders both source and target canvas regardless of whether they
-have changed or not.</dd>
-<dt><img src="icons/erase.png" alt="icon">
- <em>Erase display</em></dt>
-<dd>Erases both source and target canvas to a white background.</dd>
-<dt><img src="icons/gcp-create.png" alt="icon">
- <em>Define GCP (Ground Control Points)</em></dt>
-<dd>On left mouse click, coordinates are defined for the currently
-selected GCP.</dd>
-<dt><img src="icons/pan.png" alt="icon">
- <em>Pan</em></dt>
-<dd>Interactive selection of a new center of view in the active
-display monitor. Drag the pan cursor while pressing the left mouse
-button to pan. Alternatively left-click on the new center. Panning
-changes the location of the region displayed but not the size of the
-area displayed or the resolution.</dd>
-<dt><img src="icons/zoom-in.png" alt="icon">
- <em>Zoom in</em></dt>
-<dd>Interactive zooming with the mouse in the active map canvas (source
-or target). Drawing a box or just a left click with the mouse and zoom-in
-cursor causes the display to zoom in so that the area defined by the box
-fills the display. The map resolution is not changed. Clicking with the
-zoom-in cursor causes the display to zoom in by 30%, centered on the
-point where the mouse is clicked. Zooming changes the display region
-extents (both size and location of area displayed).</dd>
-<dt><img src="icons/zoom-out.png" alt="icon">
- <em>Zoom out</em></dt>
-or target). Drawing a box or just a left click with the mouse and zoom-out
-cursor causes the display to zoom out so that the area displayed
-shrinks to fill the area defined by the box. The map resolution is not
-changed. Clicking with the zoom-out cursor causes the display to zoom
-out by 30%, centered on the point where the mouse is clicked. Zooming
-changes the display region extents (both size and location of area
-displayed).</dd>
-<dt><img src="icons/zoom-more.png" alt="icon">
- <em>Adjust display zoom</em></dt>
-<dd>Source and target display are adjusted by using the current GCPs for
-coordinate transformation:
-<br><br>
- <dl>
- <dt><em>Adjust source display to target display</em>
- <dd>The extents of the source display are adjusted to the current
- extents of the target display.
- <dt><em>Adjust target display to source display</em>
- </dl>
-<dt><em>Set active map canvas</em></dt>
-<dd>Sets the currently active map canvas (source or target). Click
-to set active map canvas for <em>Return to previous zoom</em> or
-<em>Zoom to extent of currently displayed map</em>. Alternatively, move
-the mouse over the map canvas to be used as active canvas.</dd>
-<dt><img src="icons/zoom-last.png" alt="icon">
- <em>Return to previous zoom</em></dt>
-<dd>Returns to the previous zoom extent. Up to 10 levels of zoom back are
-maintained.</dd>
-<dt><img src="icons/zoom-extent.png" alt="icon">
-<em>Zoom to extent of currently displayed map</em></dt>
-<dd>Zoom to the extent of the currently displayed map in the active map
-canvas (source or target).</dd>
-<dt><img src="icons/settings.png" alt="icon">
-<em>Settings</em></dt>
-<dd>Shows a settings dialog for GCP management and display:<br><br>
- <dl>
- <dt><em>Symbology</em></dt>
- <dd>Settings for map and GCP display:<br><br>
- <dl>
- <dt><em>Highlight highest RMS error only</em></dt>
- <dd>Only the GCP with the highest RMS error will be displayed in
- a different colour, both in the list of GCPs and the GCP Map Display.
- <dt><em>Factor for RMS error threshold = M + SD * factor:</em></dt>
- <dd>All GCPs with an RMS error larger than mean RMS + RMS standard
- deviation * this factor will be displayed in a different colour,
- both in the list of GCPs and the GCP Map Display. As a rule of
- thumb, GCPs with an RMS error larger than <em>M + SD * 2</em> are
- most probably wrong. GCPs with an RMS error larger than
- <em>M + SD * 1</em> are worth closer inspection. This option is
- only available if <em>Highlight highest RMS error only</em> is
- unchecked.</dd>
- <dt><em>Color</em></dt>
- <dd>Set the color for GCPs on the GCP Map Display.</dd>
- <dt><em>Color for high RMS error</em></dt>
- <dd>Set the color for GCPs with a high RMS error on the GCP Map
- Display.</dd>
- <dt><em>Color for selected GCP</em></dt>
- <dd>Set the color for the currently selected GCP on the GCP Map
- Display.</dd>
- <dt><em>Show unused GCPs</em></dt>
- <dd>If unchecked, unused GCPs will not be shown on the GCP Map
- Display.</dd>
- <dt><em>Color for unused GCPs</em></dt>
- <dd>Set the color for unused GCPs on the GCP Map Display.</dd>
- <dt><em>Symbol size</em></dt>
- <dd>Set the symbol size for GCPs on the GCP Map Display.</dd>
- <dt><em>Line width</em></dt>
- <dd>Set the line width for GCPs on the GCP Map Display.</dd>
- <dt><em>Select source map to display</em></dt>
- <dd>Select a source map for the left pane of the GCP Map Display.</dd>
- <dt><em>Select target map to display</em></dt>
- <dd>Select a target map for the right pane of the GCP Map Display.</dd>
- </dl>
- </dd>
- <dt><br><em>Rectification</em></dt>
- <dd>Settings for georectification:<br><br>
- <dl>
- <dt><em>Select rectification method</em></dt>
- <dd>Set the polynomial order for georectification. This order will
- also be used for RMS error calculation.</dd>
- <dt><em>Clip to computational region in target location</em></dt>
- <dd>Clip raster maps to the current computational region in the
- target location when georectifying.</dd>
- <dt><em>Extension for output maps</em></dt>
- <dd>Change the extension for output map names when doing the actual
- georectification.</dd>
- </dl>
- </dd>
- </dl><br>
-</dd>
-<dt><img src="icons/help.png" alt="icon">
-<em>Show Help</em></dt>
-<dd>Show help page for the GCP Manager.
-<dt><img src="icons/quit.png" alt="icon">
-<em>Quit</em></dt>
-<dd>Quit the GCP Manager.
-</dl>
-<h4>Toolbar for the GCP list</h4>
-<dl>
-<dt><img src="icons/gcp-save.png" alt="icon">
-<em>Save GCPs to POINTS file</em></dt>
-<dd>The current list of GCPs is saved to the imagery group's POINTS file
-and to a backup copy.</dd>
-<dt><img src="icons/gcp-add.png" alt="icon">
-<em>Add new GCP</em></dt>
-<dd>Adds a new Ground Control Point to the list and selects it for editing.</dd>
-<dt><img src="icons/gcp-delete.png" alt="icon">
-<em>Delete selected GCP</em></dt>
-<dd>Deletes the currently selected GCP from the list.</dd>
-<dt><img src="icons/gcp-remove.png" alt="icon">
-<em>Clear selected GCP</em></dt>
-<dd>Resets all coordinates of the currently selected GCP to 0 (zero).</dd>
-<dt><img src="icons/reload.png" alt="icon">
-<em>Reload GCPs from POINTS file</em></dt>
-<dd>Reloads GCPs from the imagery group's POINTS file.</dd>
-<dt><img src="icons/gcp-rms.png" alt="icon">
-<em>Recalculate RMS error</em></dt>
-<dd>Recalculates forward and backward RMS error for all GCP marked for
-use (activated checkbox in first row).
-</dd>
-<dt><img src="icons/georectify.png" alt="icon">
-<em>Georectify</em></dt>
-<dd>Uses <em><a href="i.rectify.html">i.rectify</a></em> to georectify
-all images in the source imagery group.
-</dd>
-</dl>
-<h4>GCP Map Display Statusbar</h4>
-The GCP map display statusbar is similar to the statusbar in the regular
-GRASS GIS map display with two differences, <em>Go to</em> has been
-replaced with <em>Go to GCP No.</em> and <em>Projection</em> has been
-replaced with <em>RMS error</em>.
-<p>
-If <em>Go to GCP No.</em> is selected, a GCP number can be given in the
-left side of the statusbar and the source and target map canvas will be
-centered on the given GCP. Clicking on the map canvas will update
-coordinates for this GCP.
-<p>
-If <em>RMS error</em> is selected, the overall forward and backward RMS
-error is displayed.
-<h2>SEE ALSO</h2>
-<em>
- <a href="wxGUI.html">wxGUI</a><br>
- <a href="wxGUI.components.html">wxGUI components</a>
-</em>
-<p>
-<em>
- <a href="i.rectify.html">i.rectify</a>,
- <a href="m.transform.html">m.transform</a>
-</em>
-<p>
-See also <a href="http://grasswiki.osgeo.org/wiki/WxGUI/Video_tutorials#Georectifier">video
-tutorials</a> on GRASS Wiki.
-<h2>AUTHORS</h2>
-Markus Metz<br><br>
-<em>Based on the Georectifier (GRASS 6.4.0)</em> by Michael Barton<br>
-Martin Landa, Czech Technical University in Prague, Czech Republic
-<p>
-<i>$Date$</i>
Deleted: grass/trunk/gui/wxpython/docs/wxGUI_gcp_frame.jpg
(Binary files differ)
Added: grass/trunk/gui/wxpython/gcp/Makefile
--- grass/trunk/gui/wxpython/gcp/Makefile (rev 0)
+++ grass/trunk/gui/wxpython/gcp/Makefile 2013-07-20 18:41:49 UTC (rev 57234)
@@ -0,0 +1,5 @@
+MODULE_TOPDIR = ../../..
+include $(MODULE_TOPDIR)/include/Make/GuiScript.make
+default: guiscript
Copied: grass/trunk/gui/wxpython/gcp/g.gui.gcp.html (from rev 57232, grass/trunk/gui/wxpython/docs/wxGUI.gcp.html)
--- grass/trunk/gui/wxpython/gcp/g.gui.gcp.html (rev 0)
+++ grass/trunk/gui/wxpython/gcp/g.gui.gcp.html 2013-07-20 18:41:49 UTC (rev 57234)
@@ -0,0 +1,317 @@
+<!-- meta page description: wxGUI GCP Manager -->
+<!-- meta page index: wxGUI -->
+<h2>DESCRIPTION</h2>
+The <b>GCP Manager</b> is a <em><a href="wxGUI.html">wxGUI</a></em>
+extension which allows the user to create, edit, and manage
+Ground Control Points. It is available from the menu
+"File | Manage Ground Control Points".
+<p>
+The <b>GCP Manager</b> provides an interactive graphical interface to
+manage and analyze Ground Control Points. A backup copy of the initial
+POINTS file is always maintained and updated only on request (Save GCPs
+to POINTS file). This guarantees that accidential changes are not
+permanent and can be undone by reloading the Ground Control Points.
+<p>
+The GCP Manager must be started in the target location, not in the
+source location.
+<p>
+The GCP Manager is structured into three panels:
+<ul>
+ <li>The topmost panel shows a list of Ground Control Points. Tools to
+ manipulate and analyze GCPs are provided in the toolbar. This panel can
+ be moved out of the GCP manager window by either dragging with the
+ caption or by clicking on the pin button on the right in the caption.
+ This panel can also be placed below the map displays by dragging.
+ <li>The two panels in the lower part are used for map and GCP display,
+ the left pane showing a map from the source location and the right
+ pane showing a reference map from the target location. Numbered Ground
+ Control Points are shown on both map displays.
+</ul>
+<h3>Components of the GCP Manager</h3>
+<center>
+ <br><img src="wxGUI_gcp_frame.jpg" border="0" alt="GCP Manager"><br><br>
+</center>
+<p>
+<em>Toolbars</em>
+<p>
+Two toolbars are provided with the GCP Manager, one for managing the map
+displays and one for managing the GCP list.
+<p>
+<em>List of ground control points</em>
+<p>
+The list of Ground Control Points can be sorted by clicking on a column
+header. Clicking on a cloumn header will sort the GCPs ascending, a
+second click on the same column will sort the GCPs descending. Overall
+RMS error and individual RMS errors of all points are often improved if
+the GCP with the highest RMS error is adjusted. Individual coordinates
+can be edited by double-clicking on a row.
+<p>
+The first column holds a checkbox and displays the point number. A GCP
+is only used for RMS error calculation and georectification if its
+checkbox on the left is checked. Uncheck to deactivate a GCP (mark as
+unused GCP).
+<p>
+<em>Two panels for map display</em>
+<p>
+The left panel is used to display a map from the source location, the
+right panel to display a map from the target loaction. Zooming in and
+out is always possible with the mouse wheel and done for each map canvas
+separately.
+<p>
+GCPs are displayed in different colors, depending on whether a GCP has
+a high RMS error, is currently unused or is currently selected. Optionally,
+currently unused GCPs are not shown on the map display.
+<p>
+<em>Statusbar</em>
+<p>
+At the bottom of the GCP Manager is a statusbar providing several
+functions. The default is set to <em>Go to GCP No.</em> (see also below).
+Typing a number or using the up/down arrows will center the maps on the
+given GCP, useful with a high zoom.
+<h4>GCP Map Display Toolbar</h4>
+<dl>
+<dt><img src="icons/show.png" alt="icon">
+ <em>Display map</em></dt>
+<dd>Displays maps for source and target canvas and re-renders any layers
+that have changed since the last time the display was updated.</dd>
+<dt><img src="icons/layer-redraw.png" alt="icon">
+ <em>Re-render map</em></dt>
+<dd>Re-renders both source and target canvas regardless of whether they
+have changed or not.</dd>
+<dt><img src="icons/erase.png" alt="icon">
+ <em>Erase display</em></dt>
+<dd>Erases both source and target canvas to a white background.</dd>
+<dt><img src="icons/gcp-create.png" alt="icon">
+ <em>Define GCP (Ground Control Points)</em></dt>
+<dd>On left mouse click, coordinates are defined for the currently
+selected GCP.</dd>
+<dt><img src="icons/pan.png" alt="icon">
+ <em>Pan</em></dt>
+<dd>Interactive selection of a new center of view in the active
+display monitor. Drag the pan cursor while pressing the left mouse
+button to pan. Alternatively left-click on the new center. Panning
+changes the location of the region displayed but not the size of the
+area displayed or the resolution.</dd>
+<dt><img src="icons/zoom-in.png" alt="icon">
+ <em>Zoom in</em></dt>
+<dd>Interactive zooming with the mouse in the active map canvas (source
+or target). Drawing a box or just a left click with the mouse and zoom-in
+cursor causes the display to zoom in so that the area defined by the box
+fills the display. The map resolution is not changed. Clicking with the
+zoom-in cursor causes the display to zoom in by 30%, centered on the
+point where the mouse is clicked. Zooming changes the display region
+extents (both size and location of area displayed).</dd>
+<dt><img src="icons/zoom-out.png" alt="icon">
+ <em>Zoom out</em></dt>
+or target). Drawing a box or just a left click with the mouse and zoom-out
+cursor causes the display to zoom out so that the area displayed
+shrinks to fill the area defined by the box. The map resolution is not
+changed. Clicking with the zoom-out cursor causes the display to zoom
+out by 30%, centered on the point where the mouse is clicked. Zooming
+changes the display region extents (both size and location of area
+displayed).</dd>
+<dt><img src="icons/zoom-more.png" alt="icon">
+ <em>Adjust display zoom</em></dt>
+<dd>Source and target display are adjusted by using the current GCPs for
+coordinate transformation:
+<br><br>
+ <dl>
+ <dt><em>Adjust source display to target display</em>
+ <dd>The extents of the source display are adjusted to the current
+ extents of the target display.
+ <dt><em>Adjust target display to source display</em>
+ </dl>
+<dt><em>Set active map canvas</em></dt>
+<dd>Sets the currently active map canvas (source or target). Click
+to set active map canvas for <em>Return to previous zoom</em> or
+<em>Zoom to extent of currently displayed map</em>. Alternatively, move
+the mouse over the map canvas to be used as active canvas.</dd>
+<dt><img src="icons/zoom-last.png" alt="icon">
+ <em>Return to previous zoom</em></dt>
+<dd>Returns to the previous zoom extent. Up to 10 levels of zoom back are
+maintained.</dd>
+<dt><img src="icons/zoom-extent.png" alt="icon">
+<em>Zoom to extent of currently displayed map</em></dt>
+<dd>Zoom to the extent of the currently displayed map in the active map
+canvas (source or target).</dd>
+<dt><img src="icons/settings.png" alt="icon">
+<em>Settings</em></dt>
+<dd>Shows a settings dialog for GCP management and display:<br><br>
+ <dl>
+ <dt><em>Symbology</em></dt>
+ <dd>Settings for map and GCP display:<br><br>
+ <dl>
+ <dt><em>Highlight highest RMS error only</em></dt>
+ <dd>Only the GCP with the highest RMS error will be displayed in
+ a different colour, both in the list of GCPs and the GCP Map Display.
+ <dt><em>Factor for RMS error threshold = M + SD * factor:</em></dt>
+ <dd>All GCPs with an RMS error larger than mean RMS + RMS standard
+ deviation * this factor will be displayed in a different colour,
+ both in the list of GCPs and the GCP Map Display. As a rule of
+ thumb, GCPs with an RMS error larger than <em>M + SD * 2</em> are
+ most probably wrong. GCPs with an RMS error larger than
+ <em>M + SD * 1</em> are worth closer inspection. This option is
+ only available if <em>Highlight highest RMS error only</em> is
+ unchecked.</dd>
+ <dt><em>Color</em></dt>
+ <dd>Set the color for GCPs on the GCP Map Display.</dd>
+ <dt><em>Color for high RMS error</em></dt>
+ <dd>Set the color for GCPs with a high RMS error on the GCP Map
+ Display.</dd>
+ <dt><em>Color for selected GCP</em></dt>
+ <dd>Set the color for the currently selected GCP on the GCP Map
+ Display.</dd>
+ <dt><em>Show unused GCPs</em></dt>
+ <dd>If unchecked, unused GCPs will not be shown on the GCP Map
+ Display.</dd>
+ <dt><em>Color for unused GCPs</em></dt>
+ <dd>Set the color for unused GCPs on the GCP Map Display.</dd>
+ <dt><em>Symbol size</em></dt>
+ <dd>Set the symbol size for GCPs on the GCP Map Display.</dd>
+ <dt><em>Line width</em></dt>
+ <dd>Set the line width for GCPs on the GCP Map Display.</dd>
+ <dt><em>Select source map to display</em></dt>
+ <dd>Select a source map for the left pane of the GCP Map Display.</dd>
+ <dt><em>Select target map to display</em></dt>
+ <dd>Select a target map for the right pane of the GCP Map Display.</dd>
+ </dl>
+ </dd>
+ <dt><br><em>Rectification</em></dt>
+ <dd>Settings for georectification:<br><br>
+ <dl>
+ <dt><em>Select rectification method</em></dt>
+ <dd>Set the polynomial order for georectification. This order will
+ also be used for RMS error calculation.</dd>
+ <dt><em>Clip to computational region in target location</em></dt>
+ <dd>Clip raster maps to the current computational region in the
+ target location when georectifying.</dd>
+ <dt><em>Extension for output maps</em></dt>
+ <dd>Change the extension for output map names when doing the actual
+ georectification.</dd>
+ </dl>
+ </dd>
+ </dl><br>
+</dd>
+<dt><img src="icons/help.png" alt="icon">
+<em>Show Help</em></dt>
+<dd>Show help page for the GCP Manager.
+<dt><img src="icons/quit.png" alt="icon">
+<em>Quit</em></dt>
+<dd>Quit the GCP Manager.
+</dl>
+<h4>Toolbar for the GCP list</h4>
+<dl>
+<dt><img src="icons/gcp-save.png" alt="icon">
+<em>Save GCPs to POINTS file</em></dt>
+<dd>The current list of GCPs is saved to the imagery group's POINTS file
+and to a backup copy.</dd>
+<dt><img src="icons/gcp-add.png" alt="icon">
+<em>Add new GCP</em></dt>
+<dd>Adds a new Ground Control Point to the list and selects it for editing.</dd>
+<dt><img src="icons/gcp-delete.png" alt="icon">
+<em>Delete selected GCP</em></dt>
+<dd>Deletes the currently selected GCP from the list.</dd>
+<dt><img src="icons/gcp-remove.png" alt="icon">
+<em>Clear selected GCP</em></dt>
+<dd>Resets all coordinates of the currently selected GCP to 0 (zero).</dd>
+<dt><img src="icons/reload.png" alt="icon">
+<em>Reload GCPs from POINTS file</em></dt>
+<dd>Reloads GCPs from the imagery group's POINTS file.</dd>
+<dt><img src="icons/gcp-rms.png" alt="icon">
+<em>Recalculate RMS error</em></dt>
+<dd>Recalculates forward and backward RMS error for all GCP marked for
+use (activated checkbox in first row).
+</dd>
+<dt><img src="icons/georectify.png" alt="icon">
+<em>Georectify</em></dt>
+<dd>Uses <em><a href="i.rectify.html">i.rectify</a></em> to georectify
+all images in the source imagery group.
+</dd>
+</dl>
+<h4>GCP Map Display Statusbar</h4>
+The GCP map display statusbar is similar to the statusbar in the regular
+GRASS GIS map display with two differences, <em>Go to</em> has been
+replaced with <em>Go to GCP No.</em> and <em>Projection</em> has been
+replaced with <em>RMS error</em>.
+<p>
+If <em>Go to GCP No.</em> is selected, a GCP number can be given in the
+left side of the statusbar and the source and target map canvas will be
+centered on the given GCP. Clicking on the map canvas will update
+coordinates for this GCP.
+<p>
+If <em>RMS error</em> is selected, the overall forward and backward RMS
+error is displayed.
+<h2>SEE ALSO</h2>
+<em>
+ <a href="wxGUI.html">wxGUI</a><br>
+ <a href="wxGUI.components.html">wxGUI components</a>
+</em>
+<p>
+<em>
+ <a href="i.rectify.html">i.rectify</a>,
+ <a href="m.transform.html">m.transform</a>
+</em>
+<p>
+See also <a href="http://grasswiki.osgeo.org/wiki/WxGUI/Video_tutorials#Georectifier">video
+tutorials</a> on GRASS Wiki.
+<h2>AUTHORS</h2>
+Markus Metz<br><br>
+<em>Based on the Georectifier (GRASS 6.4.0)</em> by Michael Barton<br>
+Martin Landa, Czech Technical University in Prague, Czech Republic
+<p>
+<i>$Date$</i>
Added: grass/trunk/gui/wxpython/gcp/g.gui.gcp.py
--- grass/trunk/gui/wxpython/gcp/g.gui.gcp.py (rev 0)
+++ grass/trunk/gui/wxpython/gcp/g.gui.gcp.py 2013-07-20 18:41:49 UTC (rev 57234)
@@ -0,0 +1,76 @@
+#!/usr/bin/env python
+# MODULE: GCP Manager
+# AUTHOR(S): Markus Metz
+# PURPOSE: Georectification and Ground Control Points management.
+# COPYRIGHT: (C) 2012 by Markus Metz, and the GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%module
+#% description: Georectifies a map and allows to manage Ground Control Points.
+#% keywords: general
+#% keywords: GUI
+#% keywords: georectification
+#%end
+Module to run GCP management tool as stadalone application.
+ at author Vaclav Petras <wenzeslaus gmail.com> (standalone module)
+import os
+import sys
+import wx
+import grass.script as grass
+# adding a path to wxGUI modules
+if __name__ == '__main__':
+ WXGUIBASE = os.path.join(os.getenv('GISBASE'), 'etc', 'gui', 'wxpython')
+ if WXGUIBASE not in sys.path:
+ sys.path.append(WXGUIBASE)
+from core.settings import UserSettings
+from core.globalvar import CheckWxVersion
+from core.giface import StandaloneGrassInterface
+from gcp.manager import GCPWizard
+def main():
+ """!Sets the GRASS display driver
+ @todo use command line options as an alternative to wizard
+ driver = UserSettings.Get(group='display', key='driver', subkey='type')
+ if driver == 'png':
+ os.environ['GRASS_RENDER_IMMEDIATE'] = 'png'
+ else:
+ os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+ options, flags = grass.parser()
+ app = wx.PySimpleApp()
+ if not CheckWxVersion([2, 9]):
+ wx.InitAllImageHandlers()
+ wizard = GCPWizard(parent=None, giface=StandaloneGrassInterface())
+ app.MainLoop()
+ main()
Property changes on: grass/trunk/gui/wxpython/gcp/g.gui.gcp.py
___________________________________________________________________
Added: svn:executable
Modified: grass/trunk/gui/wxpython/gcp/manager.py
--- grass/trunk/gui/wxpython/gcp/manager.py 2013-07-20 17:32:39 UTC (rev 57233)
+++ grass/trunk/gui/wxpython/gcp/manager.py 2013-07-20 18:41:49 UTC (rev 57234)
@@ -1769,7 +1769,7 @@
def OnHelp(self, event):
"""!Show GCP Manager manual page"""
- self._giface.Help(entry = 'wxGUI.GCP_Manager')
+ self._giface.Help(entry='wxGUI.gcp')
def OnUpdateActive(self, event):
Copied: grass/trunk/gui/wxpython/gcp/wxGUI_gcp_frame.jpg (from rev 57232, grass/trunk/gui/wxpython/docs/wxGUI_gcp_frame.jpg)
