[GRASS-SVN] r57236 - grass/trunk/lib/vector
svn_grass at osgeo.org
Sun Jul 21 01:38:51 PDT 2013
Author: martinl
Date: 2013-07-21 01:38:51 -0700 (Sun, 21 Jul 2013)
New Revision: 57236
grass/trunk/lib/vector/vectorlib_pg.dox
vlib(pg): doxygen cosmetics
Modified: grass/trunk/lib/vector/vectorlib_pg.dox
--- grass/trunk/lib/vector/vectorlib_pg.dox 2013-07-20 19:29:57 UTC (rev 57235)
+++ grass/trunk/lib/vector/vectorlib_pg.dox 2013-07-21 08:38:51 UTC (rev 57236)
@@ -23,9 +23,10 @@
\section vlibFn List of functions
Note that the functions listed bellow are lower level subroutines, in
-other word these functions are not consider for usage. They are
-internally used by the vector library when accessing PostGIS data. The
-programmer should use higher level functions instead.
+other word these functions are not considered to be part of public
+API. They are internally used by the vector library when accessing
+PostGIS data. The programmer should use higher level functions
+instead.
- Vect_open_old() to open exising vector map (ie. PostGIS table when using GRASS-PostGIS data provider)
- Vect_open_new() to create new vector map
@@ -51,12 +52,11 @@
- V2_open_old_pg()
- V1_open_new_pg()
-- V2_open_new_pg()
- V1_close_pg()
- V2_close_pg()
-\par Read feature from PostGIS table
+\par Read access
- V1_rewind_pg()
- V2_rewind_pg()
@@ -68,21 +68,23 @@
- V2_read_line_sfa()
- V2_read_line_pg()
-\par Write new feature to PostGIS table
+\par Write new feature or topological element
- V1_write_line_pg()
-- V2_write_line_sfa()
-- V2_write_line_pg()
+- V2_write_line_sfa() - write new simple feature
+- V2_write_line_pg() - write new topological element in PostGIS Topology schema
-\par Delete exising feature from PostGIS table
+\par Delete exising feature or topological element
- V1_delete_line_pg()
-- V2_delete_line_sfa()
+- V2_delete_line_sfa() - delete simple feature
+- V2_delete_line_pg() - delete topological element from PostGIS Topology schema
-\par Modify existing feature from PostGIS table
+\par Modify existing feature or topological element
- V1_rewrite_line_pg()
-- V2_rewrite_line_sfa()
+- V2_rewrite_line_sfa() - modify simple feature
+- V2_rewrite_line_pg() - modify topological element from PostGIS Topology schema
\par Build topology
