[GRASS-SVN] r57240 - in grass/trunk/gui/wxpython: core iclass lmgr mapdisp
Sun Jul 21 12:01:24 PDT 2013
Author: wenzeslaus
Date: 2013-07-21 12:01:24 -0700 (Sun, 21 Jul 2013)
New Revision: 57240
   grass/trunk/gui/wxpython/core/render.py
   grass/trunk/gui/wxpython/iclass/frame.py
   grass/trunk/gui/wxpython/lmgr/layertree.py
   grass/trunk/gui/wxpython/mapdisp/main.py
   grass/trunk/gui/wxpython/mapdisp/mapwindow.py
wxGUI/mapwindow: removing call to layer tree by direct calls from tree to map object
Modified: grass/trunk/gui/wxpython/core/render.py
--- grass/trunk/gui/wxpython/core/render.py	2013-07-21 16:03:20 UTC (rev 57239)
+++ grass/trunk/gui/wxpython/core/render.py	2013-07-21 19:01:24 UTC (rev 57240)
@@ -1098,20 +1098,17 @@
         return None
-    def ReorderLayers(self, layerList):
-        """!Reorder list to match layer tree
-        @param layerList list of layers
-        self.layers = layerList
+    def SetLayers(self, layers):
+        self.layers = layers
+        # only for debug
+        # might be removed including message, it seems more than clear
         layerNameList = ""
         for layer in self.layers:
             if layer.GetName():
                 layerNameList += layer.GetName() + ','
-        Debug.msg (4, "Map.ReoderLayers(): layers=%s" % \
-                   (layerNameList))
+        Debug.msg(5, "Map.SetLayers(): layers=%s" % (layerNameList))
     def ChangeLayer(self, layer, render = False, **kargs):
         """!Change map layer properties
Modified: grass/trunk/gui/wxpython/iclass/frame.py
--- grass/trunk/gui/wxpython/iclass/frame.py	2013-07-21 16:03:20 UTC (rev 57239)
+++ grass/trunk/gui/wxpython/iclass/frame.py	2013-07-21 19:01:24 UTC (rev 57240)
@@ -1252,7 +1252,7 @@
             choice.SetSelection(0)
             #layers.reverse()
-            self.map.ReorderLayers(layers)
+            self.map.SetLayers(layers)
             self.frame.Render(self.mapWindow)
     def SetOpacity(self, name):
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py	2013-07-21 16:03:20 UTC (rev 57239)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py	2013-07-21 19:01:24 UTC (rev 57240)
@@ -1131,7 +1131,7 @@
         # redraw map if auto-rendering is enabled
         self.rerender = True
-        self.reorder = True
+        self.Map.SetLayers(self.GetVisibleLayers())
         if self.mapdisplay.GetToolbar('vdigit'):
             self.mapdisplay.toolbars['vdigit'].UpdateListOfLayers (updateTool = True)
@@ -1215,7 +1215,7 @@
     def OnCmdChanged(self, event):
         """!Change command string"""
@@ -1356,7 +1356,7 @@
         # select new item
         self.SelectItem(newItem)
@@ -1525,40 +1525,33 @@
                                                          active = True))
                 if nlayers < 2:
                     mapWin.ResetView()
-    def ReorderLayers(self):
-        """!Add commands from data associated with any valid layers
-        (checked or not) to layer list in order to match layers in
-        layer tree."""
+    def GetVisibleLayers(self):
         # make a list of visible layers
-        treelayers = []
+        layers = []
         vislayer = self.GetFirstVisibleItem()
         if not vislayer or self.GetPyData(vislayer) is None:
-            return
+            return layers
         itemList = ""
         for item in range(self.GetCount()):
             itemList += self.GetItemText(vislayer) + ','
-            if self.GetLayerInfo(vislayer, key = 'type') != 'group':
-                treelayers.append(self.GetLayerInfo(vislayer, key = 'maplayer'))
+            if self.GetLayerInfo(vislayer, key='type') != 'group':
+                layers.append(self.GetLayerInfo(vislayer, key='maplayer'))
             if not self.GetNextVisible(vislayer):
                 break
             else:
                 vislayer = self.GetNextVisible(vislayer)
-        Debug.msg (4, "LayerTree.ReorderLayers(): items=%s" % \
-                   (itemList))
-        # reorder map layers
-        treelayers.reverse()
-        self.Map.ReorderLayers(treelayers)
-        self.reorder = False
+        Debug.msg(5, "LayerTree.GetVisibleLayers(): items=%s" %
+                  (reversed(itemList)))
+        layers.reverse()
+        return layers
     def ChangeLayer(self, item):
         """!Change layer"""
         type = self.GetLayerInfo(item, key = 'type')
@@ -1594,10 +1587,11 @@
         # if digitization tool enabled -> update list of available vector map layers
             self.mapdisplay.GetToolbar('vdigit').UpdateListOfLayers(updateTool = True)
-        self.rerender = self.reorder = True
+        self.rerender = True
     def OnCloseWindow(self, event):
         pass
         # self.Map.Clean()
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py	2013-07-21 16:03:20 UTC (rev 57239)
+++ grass/trunk/gui/wxpython/mapdisp/main.py	2013-07-21 19:01:24 UTC (rev 57240)
@@ -170,7 +170,7 @@
                 else:
                     reorderedLayers[layersOrder[i]] = layer
-            self.ReorderLayers(reorderedLayers)
+            self.SetLayers(reorderedLayers)
         except IOError, e:
             grass.warning(_("Unable to read cmdfile '%(cmd)s'. Details: %(det)s") % \
Modified: grass/trunk/gui/wxpython/mapdisp/mapwindow.py
--- grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2013-07-21 16:03:20 UTC (rev 57239)
+++ grass/trunk/gui/wxpython/mapdisp/mapwindow.py	2013-07-21 19:01:24 UTC (rev 57240)
@@ -628,10 +628,7 @@
         # render background image if needed
-        # update layer dictionary if there has been a change in layers
-        if self.tree and self.tree.reorder:
-            self.tree.ReorderLayers()
         # reset flag for auto-rendering
         if self.tree:
             self.tree.rerender = False
@@ -1577,8 +1574,8 @@
         @param render True to re-render display
         if not layers:
-            layers = self.tree.GetSelectedLayer(multi = True, checkedOnly = False)
-            layers = [self.tree.GetLayerInfo(layer, key = 'maplayer') for layer in layers]
+            layers = self._giface.GetLayerList().GetSelectedLayers(checkedOnly=False)
+            layers = [layer.maplayer for layer in layers]
         if not layers:
             return
